Warning message
help static nat on ASA5510
Aug 26th, 2012
Dear Cisco!
We have network topology                         Inside Netwrok (172.168.1.0/27) --- ASA5510----- Outside network (192.168.10.0/24)
ASA5510 have: Inside interface: 172.168.1.30/27; outside interface: 192.168.10.254
And we config:
# object network obj_inside
# subnet 172.168.1.0 255.255.255.224
# nat (inside,outside) dynamic interface
# object network obj_srv
# host 172.168.1.1
# nat (inside,outside) static 192.168.10.10 service tcp www www
# access-list outside_in extended permit tcp any host 172.168.1.1 eq 80
# access-group outside_in in interface outside
So, we í in from outside, we can't access web at 192.168.10.10?
Could you please help us config this situation?
Thanks!
Julio Carvajal Sun, 08/26/2012 - 21:48
  • Purple, 4500 points or more
Hello Tran,
Do the following:
object network 192.168.10.10
host 192.168.10.10
object service HTTP
service tcp source eq 80
nat (inside,outside) 1 source static obj_srv  192.168.10.10 service HTTP HTTP
Rate all the helpful posts
Julio
tran trong nghia Mon, 08/27/2012 - 01:24
Dear Jcarvaja!
We try config same you said.
: Saved
: Written by cisco at 23:51:41.749 UTC Sun Aug 26 2012
ASA Version 8.4(2)
hostname ASA84
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
nameif inside
security-level 100
ip address 172.168.1.30 255.255.255.224
interface Ethernet0/1
nameif outside
security-level 0
ip address 192.168.10.254 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
object network obj_websrv
host 172.168.1.1
object network obj_websrv_map
host 192.168.10.10
object service HTTP
service tcp source eq www
object service TELNET
service tcp source eq telnet
access-list outside_access_in remark web
access-list outside_access_in extended permit object HTTP any object obj_websrv
access-list outside_access_in remark telnet
access-list outside_access_in extended permit object TELNET any object obj_websrv
access-list outside_in extended permit object TELNET any object obj_websrv_map
pager lines 24
logging asdm informational
mtu management 1500
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source static obj_websrv obj_websrv_map service HTTP HTTP
nat (inside,outside) source static obj_websrv obj_websrv_map service TELNET TELNET
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username cisco password 3USUcOPFUiMCO4Jk encrypted
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:95c89977b58cece71e602943c945c150
and from Pc with address 192.168.10.20, in outside zone we can't access webserver with ip map: 192.168.10.10?
Could you help us check this problem?
Thanks!
Julio Carvajal Mon, 08/27/2012 - 12:57
Hello Tran,
The ACL is wrong
Changed to this:
access-list  outside_access_in line 1 permit tcp any host  172.168.1.1 eq 80
Julio
Remember to rate all the helpful posts
