IOS SSL VPN Configuration - AnyConnect
Aug 26th, 2012
Hi Guys,
I have finally been able to configure the Cisco IOS SSL VPN client after days of trial and error with random bits of information I can find... most of it seems to relate to ASA devices!
Anyway I have a few questions;
  • How do I deploy the profile through the router? I want to enable the connect before login option
  • My context doesnt appear to apply as a default context even though I have 1 context? So I have to add /gatekeeper to the end of the address
  • Is there a good chart showing whats available in the ASA vs IOS versions? Disappointed that items like Remote Desktop are removed in IOS
Andrew
jose.vieira525 Mon, 08/27/2012 - 12:19
Hi Matthew
Have you managed to get this fixed?
jose.vieira525 Tue, 08/28/2012 - 10:06
Hi Matthew
You have this document for configuring IOS SSL VPN using SDM
http://www.cisco.com/en/US/products/ps6496/products_configuration_example09186a008071c58b.shtml
Also this document provides more information but it's all CLI based
http://www.cisco.com/en/US/docs/ios-xml/ios/sec_conn_sslvpn/configuration/15-2mt/sec-conn-sslvpn-smart-tunnels-support.html
But for your above questions:
1- Download the XML Anyconnect Profile from any client C:\Users\Default\AppData\Local\........
2- Change the XML File
true
Then follow the steps in the above document to upload this to IOS and enable the profile to be pushed to the clients
When you confiure the context does it allow you to configure with only the IP address and no name?
e.g. https://xx.xx.xx.xx  and not https://xx.xx.xx.xx/admin
Not that i'm aware but if you Google you mind be able to find something but in the end of the day you should be using an ASA to provide Remote Access
thesupporthouse... Tue, 08/28/2012 - 20:02
Thanks for the reply, I didnt notice the domain was causing the issue so I changed
gateway gateway_1 domain gatekeeper
to
gateway gateway_1
and it fixed that issue, however I couldnt find in the documentation on how to upload a AnyConnect profile?
I am also now having a issue when I type in the address direct into AnyConnect it wont connect, but if i connect through the website it connects
Andrew
