Warning message
route-map for static PAT entries
Aug 27th, 2012
  • Gold, 750 points or more
Just discovered that CCA doesn't add route-map to static PAT entries into CLI, like it does on dynamic nat entry. Route-map bypasses NAT for remote VPN site-to-site networks. Without route-map on static-nats, remote users can't access the PATted server IP and port through the site-to-site VPN. If I manually add route-map to the static PAT entry, it starts to work. I just opened a case with SBCS team and asked them file the bug. Has anyone seen this before?
mcasimirc63 Mon, 08/27/2012 - 08:30
  • Silver, 250 points or more
Have you tried setting up EZ-VPN server and Client Mode using NEM?  Using NEM will allow the VPN'ed users to access the server without using NAT.
Roman Rodichev Mon, 08/27/2012 - 09:05
Right, but I want to stay with CCA's Multi-site manager configuration.
