Warning message
No Name Appears When Callings from LYNC 2010 to Cisco or vice versa
Aug 28th, 2012
I have a problem when a call is made between Cisco Call Manager 5 and Lync 2010 does not display the name, and check all the fields are complete no restriction nor between endpoints and ports you maintain a configuration mgcp E1. This topology would expllico you what is in the CallManager 5.1 has two E1 configured MGCP gateway is configured to back to back against the Dialogic media gateway that leads to a LAN to AudioCodes and other fiber connection to the PBX provider.
Before topology was connection between Microsoft OCS and the calls worked but after making the change from OCS to Lync 2010 are no longer calls and Call Manager settings remains only made ​​the change of server ip there problems compatibility between the Cisco Call Manager 5 and Lync 2010 someone can guide me what else I can check.
Tommer Catlin Wed, 08/29/2012 - 15:40
  • Green, 3000 points or more
SIP is really not great from CUCM 5. direct to OCS or Lync.    If you can send the SIP call from CUCM to a Cisco SIP ISR gateway, then down to the diaglic or Lync Pool, it might work.   The ISR gateway has better SIP negociations than the CUCM 5.x server.  Otherwise, why are you on CUCM 5.x anyways?  Is a dead product.  Each version of CUCM has increase the functionailty of SIP.  8.x is really where you want to be for this.
Related Content
