Vcs cluster state ?
Answered Question
Aug 28th, 2012
someone can explain the vcs status on a cluster configuration?
my question is if the active state must be crossed between peers?, or there must be only one active vcs on the cluster?
please your help
ps: vcs version 7.1
peer 1 master:
peer 2
Thank you very much
Correct Answer by Alok Jaiswal about 4 years 11 months ago
Hi Cristian,
This looks ok. On the master it will show peer as active whice means the peer is reachable..and same way on peer it shows master as active which again same indication that its available.
if you reboot any server and then refresh the page..then it will show uknown or unreachanble or failed.
imprtant part is on the clustering status when you scroll down..it should show succeed and will show you next resync time as well.
Alok
Overall Rating: 5 (2 ratings)
gubadman Wed, 08/29/2012 - 00:05
  • Cisco Employee,
What you have is correct - green is good, and any red is bad.
one peer will always say "This VCS" - that's the box you are logged in on, and all the others in the list should show active - the active means that this peer can communicate with the one(s) showing up as active.
Correct Answer
Alok Jaiswal Wed, 08/29/2012 - 00:07
  • Silver, 250 points or more
Hi Cristian,
Alok
Related Content
