Install ACS 5.3 on VMware Player?
Answered Question
Aug 29th, 2012
I get an error when installing ACS on VMware Player (not VMware Workstation).  The error is "specified disk sda in partition command which does not exist."  I found this: https://supportforums.cisco.com/thread/201443 which explains to use the LSI Adapter instead of BusLogic.  The problem is, I don't have this option when creating a new HDD or when I go into the advanced settings after creating the new HDD.
Is it possible to install ACS 5.3 in the free version, VMware Player?  Maybe there's some .vmx magic someone has figured out...
Thanks!
Correct Answer by Amjad Abdullah about 4 years 11 months ago
sorry for the wrong link. Updated it above and here it is again:
https://supportforums.cisco.com/thread/2166663
Amjad
You want to say "Thank you"?
Don't. Just rate the useful answers,
that is more useful than "Thank you".
Overall Rating: 5 (1 ratings)
snickered Wed, 08/29/2012 - 12:00
That is what I chose.  Then I mounted the CD, removed the SCSI HDD and added an IDE HDD.  Like I said before, the installation fails with, "specified disk sda in partition command which does not exist."
The link you posted goes to the index of these forums.
snickered Wed, 08/29/2012 - 16:06
Thanks partner.  I was entering 60 for HDD size.  Wow... can't believe that was all.
Related Content
