Warning message
IPS question for ASA 5525-X's
Aug 29th, 2012
I am used to dealing with the separate SSM-10,20 or 40 modules that go in the non-X version of the ASA's.  In those, even in an active standby configuration, you had to individual configure each IPS sensor (even on the standby unit) since the IPS configuration wasnt synchronized between ASA's like the ASA configuration is.
Is the IPS configuration now a part of the 5525-X config or will I still be looking at configuring the IPS separately like I am used to doing ?
Ron
Julio Carvajal Wed, 08/29/2012 - 13:09
  • Purple, 4500 points or more
Hello Ronald,
It needs to be done on the same way, no replication between IPS modules,
Remember to rate all the helpful posts
Julio
Related Content
