Warning message
Mobile Voice Access VXML Gateway
Answered Question
Aug 29th, 2012
Hi Everyone
I'm trying to configure MVA and I'm going to through the steps and it's telling me to configure the VXML GW (inboud dial peer to play the IVR and outbound dial peer to CM.) What I wanted to know is are they talking about a standard H323 gateway and enable something on it and if so where do I get the IVR from. I even open up a case with TAC and the engineer on the phone didn't know how to configure this. He told me that it's kinda difficult and that I would need to get the GW piece done first before I can do the rest.Also if anyone has any documentation on how to configure this from start to finish I would greatly appreicate it.Thanks in advance for the help and have a great day.
Correct Answer by Chris Deren about 4 years 11 months ago
This is well documented in the CUCM Features and service guide, you do this on ingress H323 or SIP GW with the following:
http://:8080/ccmivr/pages/IVRMainpage.vxml
and then add dial peers that invoke it, i.e.
dial-peer voice 58888 pots
service CCM (Mobile Connect VXML application)
incoming called-number 58888
dial-peer voice 101 voip
preference 1
destination-pattern
session target ipv4:10.1.30.3
codec g711ulaw
dtmf-relay h245-alphanumeric
no vad
HTH,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Wed, 08/29/2012 - 15:46
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
preference 1
destination-pattern
codec g711ulaw
no vad
HTH,
Chris
scooter817 Wed, 08/29/2012 - 15:57
Thanks Chris
When I get into the office tommorrow I'm going to try this out
scooter817 Thu, 08/30/2012 - 12:19
I applied the configurations and it worked like a charm, thanks Chris I really appreicate the help.
roboliveira Mon, 07/08/2013 - 21:00
I'm not understanding this. Is the Mobile Voice Access DN in dial peer 101 supposed to be the same as the destination pattern in the pots dial peer?
Sent from Cisco Technical Support Android App
