Configuring IPSec VPN tunnel Cisco ISR 2921 router with watchguard firebox
Aug 29th, 2012
I am configuring a vpn ipsec tunnel with cisco isr 2921 router and Watchguard edge 1250e. I have the watchguard configured so I just need to make sure I have everything setup on the cisco side. At this point, there is no communication as I am not sure if I configured it correctly. I will appreciate any input or advise at this point. Should I do the crypto map on g 0/0 or dialer 1?
aaa new-model
aaa session-id common
no ipv6 cef
ip source-route
ip cef
no ip mfib
ip dhcp excluded-address 192.168.9.10
ip dhcp pool net-pool
network 192.168.9.0 255.255.255.0
default-router 192.168.9.1
dns-server 205.171.3.65 205.171.2.65 4.2.2.2 8.8.8.8
ip domain name yourdomain.com
ip name-server 205.171.3.65
ip name-server 205.171.2.65
vpdn enable
vpdn-group 1
crypto pki trustpoint TP-self-signed-2237670851
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2237670851
revocation-check none
rsakeypair TP-self-signed-2237670851
crypto pki certificate chain TP-self-signed-2237670851
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32323337 36373038 3531301E 170D3132 30353134 31373438
  33375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 32333736
  37303835 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100E320 1DC4AC90 080058C1 08DA93E6 09A7B0FF D8D706F4 68C54F01 B030077A
  97896835 6CCA359A D1DB90A4 176F5D97 31129690 947751AE 8FA1BDC1 D2AC683B
  F6FA54D4 13B4DDC4 286BFD6C ABF5F147 4646A9A5 8F75D03B 46E92925 BB943EF3
  CBB3FDC5 38BE1517 07851CCE C9AE596D A58EA082 33EC0FCD A2EB253A 9312A7D6
  CABF0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1454702D 174F7FBB E501B514 C48A500C ECCF0160 F0301D06
  03551D0E 04160414 54702D17 4F7FBBE5 01B514C4 8A500CEC CF0160F0 300D0609
  2A864886 F70D0101 05050003 81810060 1D2DFD78 41F1C3FF BFD5B193 4B9CCA3F
  014DC751 36763A64 6C4A8C77 FB08E80A AAEB8984 8E117B2D D606F0DA 67D668E6
  D16A1436 92B2B4DE 7869E391 6C126E38 A272E1E2 28433220 54473A6A 1B2B38D6
  7E615EFF 0BC8CF41 74F35DFD 272DAC25 A3321B18 CC7ACD18 72D87F07 230E5FC8
  E42D5282 4D600A6B CE68F610 C24197
        quit
license udi pid CISCO2921/K9 sn FGL1620105M
username cts privilege 15 secret 4 FSdPUzdNhPsmsoWy1av0ajAiJ9HFqwVJ5JqhnviI97w
redundancy
crypto isakmp policy 1
authentication pre-share
crypto isakmp policy 9
hash md5
crypto isakmp key XXXXXXXX address 206.169.224.30
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set Jobcloud esp-aes esp-sha-hmac
crypto ipsec transform-set jobcloud esp-aes esp-sha-hmac
crypto map jobcloud 1 ipsec-isakmp
set peer 206.169.224.30
set transform-set jobcloud
match address 100
bba-group pppoe global
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description ADSL WAN Interface
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface GigabitEthernet0/1
ip address 192.168.9.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1436
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
interface Virtual-Template1
ip address negotiated
ppp ipcp route default
interface Virtual-Template2
interface Dialer1
description ADSL WAN Dialer
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1460
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname ctstechnicalserv
ppp chap password 0 GK8g9Da3
ppp pap sent-username ctstechnicalserv password 0 GK8g9Da3
ppp ipcp address accept
no cdp enable
crypto map jobcloud
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list NAT interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended NAT
permit ip 192.168.9.0 0.0.0.255 any
access-list 50 permit 192.168.9.0 0.0.0.255
access-list 50 permit 63.0.0.0 0.0.0.255
access-list 50 permit any
access-list 100 permit ip 192.168.9.0 0.0.0.255 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
Below is the output for show crypto map and show crypto ipsec sa
Jobcloud#show crypto map
Crypto Map IPv4 "jobcloud" 1 ipsec-isakmp
        Peer = 206.169.224.30
        Extended IP access list 100
        Current peer: 206.169.224.30
        Security association lifetime: 4608000 kilobytes/86400 seconds
        Responder-Only (Y/N): N
        PFS (Y/N): N
        Transform sets={
                jobcloud:  { esp-aes esp-sha-hmac  } ,
        Interfaces using crypto map jobcloud:
                Dialer1
                Virtual-Access3
Jobcloud#show crypto ipsec sa
interface: Dialer1
    Crypto map tag: jobcloud, local addr 63.224.36.214
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (192.168.9.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (192.168.1.0/255.255.255.0/0/0)
   current_peer 206.169.224.30 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
aaa new-model
Karsten Iwen Wed, 08/29/2012 - 15:09
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
On the interface that has IP enabled. That is the Dialer in your case.
There are a couple of problems with your config:
1) isakmp-policies:
MD5 shouldn't be used any more for new deployments.
Both policies use DES and DH-Group1, Both are not considered secure.
2) ipsec-transforms:
You have two transforms, but you use only one of them. Delete the other.
3) IPSec-SA-Lifetime
Is the long lifetime of one day really wanted/needed? The default of one hour is more secure.
4) NAT
Your outgoing VPN-traffic is NATed to your public IP and then will not match the crypto-ACL any more. You have to deny that traffic in the ACL "NAT"
5) There is no incoming ACL on the Dialer. Your router and network is opened up for attacks from the internet.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
johnlloyd_13 Wed, 08/29/2012 - 19:24
  • Blue, 1500 points or more
hi joseph,
in addition to what karsten posted, kindly provide the watchguard's IPsecVPN setup.
the crypto map on the 2921 is correctly applied under the dialer interface.
jlabitag0510 Thu, 08/30/2012 - 09:46
Thanks for the reply Karten and John. This is a brand new router and will be securing it soon.
The cisco router doesnt have a static IP it is getting it via century link. I have PPPOE enabled. I dont think this is the issue as I saw a few people setup vpn via dynamic IP from the provider.
Here is the Tunnel and gateway image from the watchguard. There is also a BOVPN in/out policy that allows the gateway and tunnel access with port any opened.
johnlloyd_13 Thu, 08/30/2012 - 19:33
hi joseph,
thanks for the screenshots! kindly amend these on your cisco 2921 and do a ping from a host on the 192.168.9.0/24 subnet.
post your show crypto isakmp sa and show crypto ipsec sa afterwards.
encryption 3des
hash sha
group 1
no crypto ipsec transform-set jobcloud esp-aes esp-sha-hmac
crypto ipsec transform-set jobcloud esp-3des esp-sha-hmac
deny ip 192.168.9.0 0.0.0.255 192.168.1.0 0.0.0.255
Related Content
