Warning message
TMS - Endpoint SNMP Traphost Address
Answered Question
Aug 29th, 2012
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 TelePresence
Should I see the SNTP traphost address field under the "Settings" view for a C-Series, EX, E20 endpoints that are managed by TMS?  Is it okay to leave this field blank or should it contain the IP or DNS address of TMS, in conjunction with the SNTP settings on the endpoint itself?
Thanks, Patrick
Correct Answer by Kjetil Ree about 4 years 11 months ago
Hi Patrick,
All SNMP traps from TC and TE software systems are ignored by TMS, so you can safely leave these fields blank.
-Kjetil
Correct Answer by mahkrish about 4 years 11 months ago
Hi Patrick, For Endpoints that Cisco TMS uses SNMP to communicate with, the Traphost IP Address is also set. This is done automatically on all systems if the Enforce Management Settings on Systems is enabled in Network Settings > Cisco TMS Service pane.
Overall Rating: 5 (2 ratings)
Correct Answer
mahkrish Wed, 08/29/2012 - 20:43
  • Bronze, 100 points or more
Patrick Sparkman Thu, 08/30/2012 - 17:27
    2017 TelePresence
I take it the C-Series, EX, and E20 doesn't use SNMP, since they communicate over HTTP/HTTPS?
Correct Answer
Kjetil Ree Fri, 08/31/2012 - 02:39
  • Cisco Employee,
Hi Patrick,
-Kjetil
Related Content
