Warning message
Enterprise Data Fields
Answered Question
Aug 30th, 2012
Hi there !
I'm in the path below: CCX8.x > Menu > Cisco Desktop Administrator > Enterprise Data > Fields
Then I created a few variables (for exemple: 1234.NAME) to be used in the Script Set Enterprise Call Info Step > Extended Call Variables...
The thing is, I try to Add a ECC Variable but the name fileds are not there ! .. some are, but not the new ones...
I was hoping to see a name field ( --1234.NAME --) that was created in the Desktop Admin...
I'm I doing something wrong ?
Thanks.
Andrei.
Correct Answer by anchoudh about 4 years 11 months ago
Hi Andrei,
Please refer the section "Set Enterprise Call Info Step"
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_8_5/programming/guide/uccx851_step_ref.pdf
In the Cisco Unified CCX workflow, in the Expanded Call Variables tab of the Set Enterprise
Call Info step, create an ECC variable called "user.layout" and set its value to the name of the
custom layout.
And section "Expanded Call Variables Tab (Set Enterprise Call Info Step)" from page 67 onwards in the above link for the detailed explanation of this step.
Hope it helps.
Anand
Pls rate all helpful posts !!
Overall Rating: 5 (1 ratings)
anchoudh Thu, 08/30/2012 - 08:00
  • Red, 2250 points or more
Hi Andrei,
Did you move the newly created enterprise Data fields from Available pane to the left pane ( where order is mentioned ) in CDA ?
Hope it helps.
Anand
Pls rate helpful posts !!
andrei.goncalves Thu, 08/30/2012 - 08:06
the new variables does not appear in this screen... I only can see the same fields that is in screen you posted..
Andrei.
andrei.goncalves Thu, 08/30/2012 - 10:54
That is a good document,
with it, I found some of my custom fields in the Desktop Workflow Admi (Voice Contact Workflow) ...
I tried something.. but.. anyway, back to the Script, in Set Enterprise Call Info Step, they are not there...
Andrei.
Correct Answer
anchoudh Thu, 08/30/2012 - 11:07
Hi Andrei,
custom layout.
Hope it helps.
Anand
Related Content
