Warning message
Configuring Call Pickup and Busy Lamp Field - SIMPLE QUESTION UNANSWERED
Aug 30th, 2012
In configuring BLF do I need to declare a station name ? The name should be only one at the entire network or could double if the ext/ usr is different ?
c. Enter the following string in the Extended Function field:
fnc=blf+cp;sub=Stephanie@$PROXY;ext=300@$PROXY
Using the following syntax:
fnc=type;sub=stationname@$PROXY;ext=extension#@$PROXY
where:
- fnc: function
- blf: busy lamp field
- cp: call pickup
- sub: station name
- ext or usr: extension or user (the usr and ext keywords are
interchangeable)
Thanks in advance !
Related Content
