Warning message
886VAW not syncing @ ADSL
Aug 30th, 2012
Dear all,
my newly purchased 886VAW won't sync.
The link ( ISDN ) I'm running it off from runs nicely on my crusty-trusty 803. I linked the box
with the cables supplied against the splitter as usual but can't seem to get a stable CD light ( constantly flashing ).
The box is intended to run against ADSL (with VDSL to come in a few days ).
Can someone shed some light on what I am doing wrong ?
Controller VDSL 0 is DOWN
Daemon Status:           Establishing Link
                        XTU-R (DS)              XTU-C (US)
Chip Vendor ID:         'BDCM'                   'IFTN'
Chip Vendor Specific:   0x0000                   0x71B8
Chip Vendor Country:    0xB500                   0xB500
Modem Vendor ID:        'CSCO'                   '    '
Modem Vendor Specific:  0x4602                   0x0000
Modem Vendor Country:   0xB500                   0x0000
Serial Number Near:                C886VA-W 15.1(4)M
Serial Number Far:
Modem Version Near:    15.1(4)M
Modem Version Far:     0x71b8
Modem Status:            Idle
DSL Config Mode:         AUTO
Trained Mode:
TC Mode:                 UNKNOWN
Selftest Result:         0x00
DELT configuration:      disabled
DELT state:              not running
Trellis:                 OFF                      OFF
Full inits:             0
Failed full inits:      11
Short inits:            4
Failed short inits:     6
Firmware        Source          File Name (version)
VDSL            embedded        VDSL_LINUX_DEV_01212008 (1)
Modem FW  Version:      110506_1916-4.02L.03.B2pvC032b.d23i
Modem PHY Version:      B2pvC032b.d23i
Training Log :  Stopped
Training Log Filename : flash:vdsllog.bin
sho run int ATM0:
interface ATM0
no ip address
atm vc-per-vp 64
no atm ilmi-keepalive
end
interface ATM0.1 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
pvc 1/32
  pppoe-client dial-pool-number 2
end
paolo bevilacqua Fri, 08/31/2012 - 01:12
  • Hall of Fame,
    Founding Member
Update VDSL firmware. Also can try configuring DSL manually.
Dan Jay Fri, 08/31/2012 - 01:31
All fixed - pin in Splitter torn off........
Related Content
