ACE30 & CSM in same chassis
Aug 31st, 2012
We currently have a 6500 chassis with CSM, I need to start migrating services on this over to an ACE30. Both modules are currently in the chassis, has any one ever had any issues running both modules at the same time ?
The ACE will be using completely new IP details, so won't overlap with the CSM and the CSM is very lightly used, less than a dozen servers in total.
Fnu Kanwaljeet Singh Fri, 08/31/2012 - 08:36
  • Cisco Employee,
Hi Richard,
There should be no problems. I have CSM and ACE 20 in same chassis and should not be a problem with ACE 30. Removed serial purposely.
CORE-6500-A#sh module
Mod Ports Card Type                              Model              Serial No.
1    4  SLB Application Processor Complex      WS-X6066-SLB-APC
  3   48  48 port 10/100/1000mb EtherModule      WS-X6148-GE-TX
  4    4  CSM with SSL                                     WS-X6066-SLB-S-K9
  5    2  Supervisor Engine 720 (Active)               WS-SUP720-BASE
  6    1  Application Control Engine Module          ACE20-MOD-K9
Let me know if you have any questions.
Kanwa
