SDM: Failure to launch (1841 router)
Sep 3rd, 2012
I have a Cisco 1841 router and am using it at home to study for my CCENT/CCNA exam next week.  I need to practice using the SDM to configure NAT/PAT and DHCP as I hear this could be a possible exam topic.  Here's the problem:
I believe that I already have the SDM on my router (I see an SDM.TAR file listed when I Show Flash).  Unfortunately, I have been unable to launch it even once, though I configured the router to support SDM with the appropriate privilege level password (15), http and secure server settings, username, domain-name, crypto key, authentication, transport input, etc.).
Please; can anyone answer the following for me:
  1. Does the SDM.TAR file that I see in my flash represent the complete SDM or should I see more files in flash with SDM in the name to use this GUI?
  2. How, exactly, can I get my router to launch a webpage and access the SDM from my flash without having to download an SDM to my pc and run it from there (if, in fact, I have the right SDM file in flash to begin with)?
  3. If all else fails; where do I go to download the SDM (it's a little confusing when I put in "SDM" in the Cisco site search).
Any help will be GREATLY appreciated.
Thanks.
Jamal Hyman
Overall Rating: 5 (2 ratings)
ossalman Mon, 09/03/2012 - 06:59
  • Cisco Employee,
hello Jamal,
could you please share the output of show version and show flash... i will review it and get back to you...
thanks,
/Osama
Jamalhyman Mon, 09/03/2012 - 10:39
Hello Ossalman,
Below is the output for both Show Version and Show Flash.  Line 74 in Show Flash references the SDM.TAR.
Thanks alot for taking some time to look into this.
Jamal
Show Version
JamalRouter#show version
Cisco IOS Software, 1841 Software (C1841-ADVSECURITYK9-M),
Version 12.4(3h), REL
EASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 25-Jul-07 13:43 by stshen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE
(fc1)
JamalRouter uptime is 1 minute
System image file is "flash:c1841-advsecurityk9-mz.124-3h.bin"
This product contains cryptographic features and is subject to
United
States and local country laws governing import, export,
transfer and
third-party authority to import, export, distribute or use
encryption.
Importers, exporters, distributors and users are responsible
for
compliance with U.S. and local country laws. By using this
product you
agree to comply with applicable laws and regulations. If you
are unable
to comply with U.S. and local laws, return this product
immediately.
A summary of U.S. laws governing Cisco cryptographic products
may be found at:
may be found at:
If you require further assistance please contact us by sending
email to
[email protected].
Cisco 1841 (revision 7.0) with 234496K/27648K bytes of memory.
Processor board ID FTX1143Y0SN
2 FastEthernet interfaces
2 Serial interfaces
1 Virtual Private Network (VPN) Module
WIC T1-DSU
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
125184K bytes of ATA CompactFlash (Read/Write)
Show Flash
JamalRouter#show flash
-#- --length-- -----date/time------ path
1         5304 Nov 18 2010 20:19:16 +00:00 backup123
2         4096 Sep 01 2012 00:11:50 +00:00 ._.Trashes
3      1164288 Oct 25 2007 19:37:08 +00:00 COMMON.TAR
4            0 Sep 01 2012 00:11:50 +00:00 .Trashes
5            0 Sep 01 2012 13:05:58 +00:00 .Spotlight-V100
6            0 Sep 01 2012 13:05:58 +00:00
.Spotlight-V100/Store-V2
7            0 Sep 01 2012 13:05:58 +00:00
.Spotlight-V100/Store-V2/7FAFF9C8-FEA
E-4DD4-8CDB-AB6E6D095DF0
8            0 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/journals.repair
9         8192 Sep 01 2012 13:06:46 +00:00
E-4DD4-8CDB-AB6E6D095DF0/PSID.DB
10           0 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/tmp.SnowLeopard
11           0 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/tmp.Lion
12           0 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/Lion.created
13          28 Sep 01 2012 13:06:00 +00:00
E-4DD4-8CDB-AB6E6D095DF0/indexState
14        4096 Sep 01 2012 13:06:46 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.indexHead
15       32768 Sep 01 2012 13:06:46 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.indexIds
16        3277 Sep 01 2012 13:06:46 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.indexGroups
17        4096 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.indexPostings
18        8192 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.indexTermIds
19        4096 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.indexPositions
20        8192 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.indexPositionTable
21        8224 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.indexDirectory
22        1024 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.indexCompactDirectory
23       65536 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.indexArrays
24         480 Sep 01 2012 13:06:46 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.indexUpdates
25       65536 Sep 01 2012 13:06:46 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.directoryStoreFile
26        4096 Sep 01 2012 13:06:46 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.indexHead
27       32768 Sep 01 2012 13:06:46 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.indexIds
28        3277 Sep 01 2012 13:06:46 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.indexGroups
29        4096 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.indexPostings
30        8192 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.indexTermIds
31        4096 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.indexPositions
32        8192 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.indexPositionTable
33        8224 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.indexDirectory
34        1024 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.indexCompactDirectory
35       65536 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.indexArrays
36       10445 Sep 01 2012 13:06:46 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.indexUpdates
37       65536 Sep 01 2012 13:06:46 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.directoryStoreFile
38      118784 Sep 01 2012 13:06:00 +00:00
E-4DD4-8CDB-AB6E6D095DF0/STORE.DB
39      118784 Sep 01 2012 13:06:46 +00:00
E-4DD4-8CDB-AB6E6D095DF0/.store.db
40       65536 Sep 01 2012 13:06:30 +00:00
E-4DD4-8CDB-AB6E6D095DF0/reverseDirectoryStore
41           4 Sep 01 2012 13:06:46 +00:00
E-4DD4-8CDB-AB6E6D095DF0/shutdown_time
42           0 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/journals.live
43          75 Sep 01 2012 13:06:46 +00:00
E-4DD4-8CDB-AB6E6D095DF0/journals.live/JOURNAL.1
44           0 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/journalExclusion
45           0 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/journals.scan
46          53 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/journals.scan/JOURNAL.1
47        3136 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/reverseDirectoryStore.shadow
48        4096 Sep 01 2012 13:06:00 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.shadowIndexHead
49           0 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.shadowIndexTermIds
50           0 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.shadowIndexPositionTable
51       65536 Sep 01 2012 13:05:58 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.shadowIndexArrays
52           8 Sep 01 2012 13:06:00 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.shadowIndexCompactDire
53        2056 Sep 01 2012 13:06:00 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.shadowIndexDirectory
54        1088 Sep 01 2012 13:06:00 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.directoryStoreFile.shadow
55           1 Sep 01 2012 13:06:00 +00:00
E-4DD4-8CDB-AB6E6D095DF0/0.shadowIndexGroups
56        4096 Sep 01 2012 13:06:00 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.shadowIndexHea
57           0 Sep 01 2012 13:06:00 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.shadowIndexTermIds
58           0 Sep 01 2012 13:06:00 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.shadowIndexPositionTable
59       65536 Sep 01 2012 13:06:00 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.shadowIndexArrays
60           8 Sep 01 2012 13:06:00 +00:00
61        2056 Sep 01 2012 13:06:00 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.shadowIndexDirectory
62        1088 Sep 01 2012 13:06:00 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.directoryStoreFile.shadow
63           1 Sep 01 2012 13:06:00 +00:00
E-4DD4-8CDB-AB6E6D095DF0/live.0.shadowIndexGroups
64          12 Sep 01 2012 13:06:46 +00:00
E-4DD4-8CDB-AB6E6D095DF0/store.updates
65           2 Sep 01 2012 13:06:46 +00:00
E-4DD4-8CDB-AB6E6D095DF0/reverseStore.updates
66          17 Sep 01 2012 13:06:46 +00:00
E-4DD4-8CDB-AB6E6D095DF0/permStore
67           0 Sep 01 2012 13:05:58 +00:00
.Spotlight-V100/Store-V1
68         348 Sep 01 2012 13:05:58 +00:00
.Spotlight-V100/Store-V1/VolumeConfig
.plist
69        3184 Sep 01 2012 13:05:58 +00:00
.Spotlight-V100/VolumeConfiguration.p
list
70    18716536 Oct 25 2007 19:15:08 +00:00
71      861696 Oct 25 2007 19:36:48 +00:00 ES.TAR
72        1038 Oct 25 2007 19:37:30 +00:00 home.shtml
73      113152 Oct 25 2007 19:37:48 +00:00 HOME.TAR
74     6036480 Oct 25 2007 19:36:24 +00:00 SDM.TAR
75        1821 Oct 25 2007 19:35:42 +00:00 sdmconfig-18xx.cfg
76     1697952 Oct 25 2007 19:38:42 +00:00
securedesktop-ios-3.1.1.45-k9.pkg
77      416354 Oct 25 2007 19:39:10 +00:00
sslclient-win-1.1.3.173.pkg
97796096 bytes available (29976576 bytes used)
ossalman Mon, 09/03/2012 - 23:21
  • Cisco Employee,
hello Jamal,
from what i saw, it seems that there is no problem with the files and the IOS image, i would suggest you to follow the steps mentioned by Alain, if this doesn't help then i would sugest  you to remove the SDM files and download another fresh SDM files,,,, this should solve the problem...
http://www.cisco.com/en/US/products/sw/secursw/ps5318/prod_installation_guide09186a00803e4727.html#wp88569
thanks,
/Osama
Jamalhyman Tue, 09/04/2012 - 01:22
Thanks also,
I will work on this over the next few days and tell you guys if I was successful or not.
Jamal
Related Content
