ASA 5505 - dual wan: wan1 for vpn l2l-wan2 for everything else
Sep 3rd, 2012
Hi to all.
My goal is to use dual wan (with 2 different ISP):
I would use:
wan1 for all: web, mail, ecc
wan2 only for a vpn l2l connection with HQ (voip, intranet).
Obviously the wans have to work at the same time.
It's possible with asa 5505? (without a router).
Do yuo know some tutorial for that?
Thank you.
Julio Carvajal Mon, 09/03/2012 - 09:51
  • Purple, 4500 points or more
Hello Paolo,
It will work as you will specify 2 different destinations on the routing table of the ASA.
It's going to be as simple as that,
Set the 2 interface, configured the proper NAT for those 2 interfaces, set the routes and finally the crypto map on the Wan2.
Julio
Remember to rate all the helpful posts, that is as important as a thanks.
