09-03-2012 10:26 AM - edited 03-10-2019 07:29 PM
Hello folks,
I wonder what I have to do in ISE to enable it sending SMS when activating a new guest account. I believe there must be a corresponding setting somewhere under Web Portal Management to configure SMS gateway neither under Global system settings.
Solved! Go to Solution.
09-24-2013 07:32 AM
This issue has not been resolved ( %mobilenumber% variable is not inserted into address %mobilenumber%@domain.net).
We opened case on this issue, but it is not yet resolved .
But support working in this direction - is already fixed problems with subdomains (@sms.domain.net) and restrictions on the number of characters after symbol @.
This issue we have resolved as follows: all notifications are sent to corporate e-mail Microsoft Exchange Server, where rule is configured to process messages sent over e-mail/SMS gateway (based on field *Destination in template "Configure SMS Text Notification"). According to this rule, Microsoft Exchange sends these messages to another server that is running a regular "Microsoft SMTP Service" ( for receiving and storing messages in a local folder). The same connector is configured to send messages for @sms.domain.net back to the mail server Microsoft Exchange. In the scheduler is configured launch PowerShell script that "cuts" from the body of the message variable %mobilenumber% (which was previously defined in template "Configure SMS Text Notification") and inserts it into address %mobilenumber%@sms.domain.net.mobilenumber%@sms.domain.net.
When the problem is resolved, this server will not be used/needed, and SMS message will be forwarded directly to the gateway e-mail/SMS or in SMSC.
Sincerely,
Andrey
01-02-2019 08:12 AM
09-04-2012 02:35 PM
This is configured under the web page templates for the Sponsor portal. http://www.cisco.com/en/US/docs/security/ise/1.1.1/user_guide/ise_guest_pol.html#wp1068521
It uses the configure SMTP server to send an e-mail message to the SMS gateway.
09-05-2012 10:30 AM
What you referred me to is configuring the way it the SMS or email message will look like, i.e.template.
My problem is with connection settings. I can't even send the email from ISE not even sending SMS
09-05-2012 10:33 AM
I tried to look into this and it seems as if the smtp gateway is also the sms gateway also. I am thinking that somehow the exchange server will have to have an sms gateway configured to it, but I agree with you it isnt very clear as to how you an send the message with just the phone number, I would think you would need the domain also.
For better results you may want to open a TAC case to see if someone could shed more light on this for you.
Tarik Admani
*Please rate helpful posts*
01-23-2013 01:50 PM
Have you fixed the problem to send email to guest users? ... I receive an "Internal Error" message when I try to send email to a guest ... How can I troubleshoot and verify at least the ISE is trying to reach the SMTP server?
09-05-2012 10:42 AM
On the page where you customize the SMS message there is a field for the Destination. This is where you specify the SMS gateway e-mail address. My ISE has this set to sms@example.com by default. You would change this to whatever the e-mail address of your SMS gateway is.
09-05-2012 12:41 PM
I'm wondering what kind of logic did ISE developers pursue to hide SMS gateway portal connection setting in the Language template. I'm still not able to send email to the user who is setup as a guest. ISE gives me an internal error even though I have configured the right SMTP server under ISE Administration->System->SMTP Server. ISE and SMTP server are in the same network and there are no relay restrictions on the mail server.
12-14-2012 01:40 AM
Faced with a similar problem (in Cisco ISE 1.1.2.142).
When editing a template (Administration->Web Portal Management->Settings->Sponsor->Language Template->English) "Configure SMS Text Message Notification", if the field "* Destination" set to "%mobilenumber%@sms.domainname.net", then there will be no change of the variable "%mobilenumber%" to the phone number entered in the "Guest Account->Phone Number:".
Whether it is possible to use variables "%mobilenumber%" in the "* Destination"?
01-23-2013 02:19 PM
It looks there's a big gap between what's in Cisco documentation and in the real state of things. Anyone from Cisco support please disprove it. I would appreciate if there's a detailed guide covering just this portion. Why on earth mentioning this feature in the first place if it doesn't work.
07-17-2013 06:38 AM
Kindly review the below link:
http://www.cisco.com/en/US/docs/security/ise/1.0/user_guide/ise10_guest_pol.html#wp1068521
08-05-2013 08:05 PM
n Cisco ISE, Release 1.1 internalization (UTF-8) and localization support is focused on the text and information that is presented to end user (connecting to Cisco ISE) through the Sponsor, Guest, and Client Provisioning portals. This support includes internationalizing all text in the end user interfaces, such as labels, messages, and input configured by the end user or Cisco ISE administrator and displayed in the Sponsor, Guest, and Client Provisioning portals. Guest account information that is notified through email and SMS is also localized.
To confgiure ISE SMS notification for guest account please see the attached PDF file.
09-24-2013 03:13 AM
Has ANYONE succeed in getting ISE to sent SMS to a varialbe guest Mobilenumber ?
I need the ISE to sent SMS (Via email2SMSgateway service - i know) via the sponsor webpage to that number the sponsor types in. I:E. a variable mobile number
I can only get this work with FIXED mobile-numbers - not variable ones.
Any ideas ?
I use ISE1.2
I have read and tested the link and PDF in this thread. Did you manage to get your to work and how ?
Kind regards'
Martin
09-24-2013 07:32 AM
Sincerely,
Andrey
01-02-2019 02:42 AM
How to receive incoming SMS? Setup for receiving incoming SMS messages is a two step process, assuming you have already purchased a phone number.
01-02-2019 08:12 AM
