Warning message
7945 POE Issue
Sep 4th, 2012
         We are runing several different types of C-6500's, all recently upgraded to s72033-ipservicesk9-mz.122-33.SXI9, the 7945 phones are running  SCCP45.9-2-1S.
     Randomly phones accross several switches, no common switch, port or card, will lose power, but the port for that switch still shows up/up.  This is resolved by reseting the card and turning off port security or just resetting the card.  Power allocation is not the issue, there is more than required.  Below is what we see when one of the phones is off.  This does not appear to happen to a phone twice, once this is done it seams to stay up, but it will then happen to another phone or group of phones.
Gi1/0/4   auto   on         15.4   Ieee PD             3     30.0
     The only change made has been the IOS update, everything else is as it has been prior to the upgrade.
     Thanks ahead of time for any assistance.
Leo Laohoo Tue, 09/04/2012 - 16:54
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hmmmm ... Looks like a cable issue.
On the switch, please run the following commands:
1.  Command:  test cable tdr interface Gi1/0/4;
2.  Wait for approximately 62 seconds (yes, that's how long it'll take for this test to complete on a 6500 chassis);
3.  Command:  sh cable tdr interface Gi1/0/4; and
4.  Post the output.
geprosser Wed, 09/05/2012 - 09:03
Thanks for the replay, I will run that when I get a chance, but do you have any other possible causes.  These where all working correctly before the IOS was upgraded to s72033-ipservicesk9-mz.122-33.SXI9.  Also the problem has not resurfaced once everything was reset.
Leo Laohoo Wed, 09/05/2012 - 15:26
  • Hall of Fame,
    2017 LAN, Wireless
For the last two years, I've been deploying WAPs all over my network (90+ sites) and I've seen my fair share of WAPs booting up+NOT joining the controllers+and getting the dreaded "IEEE" output.
11 out of 10 times, it's cabling fault.
IOS upgrade have nothing to do with it.
geprosser Thu, 09/06/2012 - 05:34
Here is the output
TDR test last run on: September 05 14:45:07
Interface Speed Pair Cable length       Distance to fault   Channel Pair
status
Gi4/21   1000 1-2 36   +/- 20 m       N/A                 Pair A
Terminated
              3-6 44   +/- 20 m       N/A                 Pair B
Terminated
               4-5 44   +/- 20 m       N/A                 Pair C
Terminated
               7-8 46   +/- 20 m       N/A                 Pair D
Terminated
Leo Laohoo Thu, 09/06/2012 - 16:04
  • Hall of Fame,
    2017 LAN, Wireless
The output looks OK.
The phones that constantly go down/up, are these THE SAME ONES?  All the time?
If the answer is yes, can you run the same commands on a few of the phone ports?
geprosser Thu, 09/06/2012 - 16:16
It has only happend to each phone effected once, after that phone was restored it has not happend again to one of those phones.  Here is a rundown of how the issues were resolved.
Switch # 1   First occurrence
Sunday morning we upgraded the switch to a new IOS version (from:
s72033-ipservicesk9-mz.122-18.SXF17b TO: s72033-ipservicesk9-mz.
122-33.SXI9)
Monday morning, soon after duty hours started we had several cards drop
connections. Upon review of incident we noticed that the Cisco phones were
down and that the network connection was disabled. Attempts were made to
re-enable the ports without success. Fix action for this Switch was to
revert back to the last IOS version.
Switch # 2 failure
Tuesday -located in another building. This was switch # 3 located in
that building, with the same failure as experienced on the first switch.
There were only two cards in the switch that failed. We were successful at
re-enabling the ports and also had to remove port security to keep the ports
from failing. Since this fix action we have experienced no more issues with
this switch.
Switch # 3
Wednesday - Another switch slot 1 and slot 2 failed with
the same symptoms. NO network connectivity and all Cisco phones down. After
re-enabling the ports and removal of port security the ports showed to be
connected, however the phones continued to seek IP addresses and there was
still no network connection. We performed a HW-module 1 reset and HW-Module
2 reset and after cards reset, the connections were restored. Since then we
have not experienced any further issues. Port security remains off until
further troubleshooting and isolation of problem.
I hope this is better clarification as to issues/events since new IOS was
loaded.
geprosser Fri, 09/21/2012 - 07:16
Here is a new update
We had another power outage in the same building where we lost the card a week ago. Again we had power issues with phones. Not just individual, sporadic ports, but a logical group of ports. I cleared the problem by doing a shut/no shut range command on the ports affected. It spanned two different cards. So it wasn't just one card.
The real issue is any time we have an outage we will have check to make sure all of the ports have come up correctly. In this case we were at work and all was fixed quickly. Certainly this IOS does not like something.
