Slow response while typing on the CLI
Mohit Chauhan
Hi friends,
I have a client for whom i set up a new network infrastructure. Everything is working but i have realised that when remote login to devices, I see slow response on the cli when i am typing.
it doesnt matter if i am remote logging in from outside or inside, but its the same result.
What could be the reason for that?
I did few checks to see there wasnt much load on the device, which included the following:
ROUTER-A#sh processes cpu extended
Global Statistics
5 sec CPU util 2%/1% Timestamp 2w1d
Queue Statistics
          Exec Count  Total CPU    Response Time           Queue Length
                                    (avg/max)                (avg/max)
Critical           1          0          0/0                   1/1
High             653          0          0/0                   1/2
Normal           631         12          0/0                   1/7
Low               10         32          0/0                   1/2
Common Process Information
PID Name            Prio Style
CPU Intensive processes
PID Total       Exec    Quant         Burst  Burst size  Schedcall  Schedcall
     CPUms      Count   avg/max        Count avg/max(ms)      Count Per avg/max
Priority Suspends
PID Exec Count Prio-Susps
Latencies
PID Exec Count   Latency
                  avg/max
ROUTER-A#sh int g0/1
GigabitEthernet0/1 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is 30f7.0d95.8521 (bia 30f7.0d95.8521)
  Description: Internet
  Internet address is X.X.X.X/30
  MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
     reliability 255/255, txload 3/255, rxload 36/255
  Keepalive set (10 sec)
  Full Duplex, 10Mbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1815
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1413000 bits/sec, 147 packets/sec
  5 minute output rate 128000 bits/sec, 90 packets/sec
     25525566 packets input, 618421246 bytes, 1812 no buffer
     Received 85815 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     20940307 packets output, 2234891539 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     85814 unknown protocol drops
     6 lost carrier, 0 no carrier, 0 pause output
Any suggestions?
Cheers,
Mo
8 Replies 8
Lee Smitherman
A couple of questions Im sure everyone will ask...
1) is it slow via the console connection?
2) are you using telnet or ssh?
3) Its it slow to connect and when entering the login credentials
4) If you ping from the device your using to connect(use a good packet size such as 1400),  good response times with no drops?
Lee.
Hi Lee
To answer to your questions:
1. its not slow on console
2. i am only using ssh, telnet is disabled
3. Connecting is not slow whne you see  the login banner, however when i start typing in it takes some time to show me the characters (not always but quite often) as if it is a slow connection, which is not the case.
4. i'll have to double check this response time but for sure dont see any single drop out. i am glad even the users are not complaining. but it is just out of concern that i wanted to make sure everything is OK.
I'll ley you how the response time is..
Hi Lee
I did some continuous ping with the load of 1500 and it was constantly at 1ms without a single drop out.
Just to see there wasnt any cpu related error when i did "sho log"
i saw the following setting and info regardng the logging
Console logging: level debugging, 392438 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 726 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level informational, 418837 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 418207 message lines logged
I have a feeling if this is causing this grief??
Cheers,
Mo
good spot!!! Worth switching off the logging to see if it helps,  quite a few entries there!!!  When was the log last cleared?(wondering how long a period these stats are for).
Lee.
Lee.
Not long, this router is being up for 2 -3 weeks now. which logging you want to try disabling? i was thinking of turning off console logging as i still want to see the buffered logs....
I would switch it all of just for a minute or two to test,  then if it proves to be that,  refine what you need logged.
To be honest since your connectivity to the router seems fine, Im not sure what the issue is, but looks a good place to start.
Lee.
singhaam007
Level 3
Level 3
Hello Mohit,
may be u alredy resolve this issue. but if not it may be a memeory issue, i think the new IOS requered more memory, kindly use
Router#show mem sum
and check ur used and free memory.
please rate if this helpful
thanks
Inderjeet Singh
Hi Mohit,
Did you find any fix to this issue ?
