LACP fast updates on Cisco 3750s
I've got LACP-enabled port-channels between a Cisco 3750 stack and a few different switches (some Cisco 3750s and some Juniper EX2200s).  The Ciscos are all sending slow LACP updates, the Junipers are sending fast LACP updates (but the Cisco they connect with is responding with slow LACP updates).
I have a couple of questions:
1) what are the pros and cons of slow vs fast updates?  my research has led me to the conclusion that fast updates are better for network resiliency as long as you have plenty of bandwidth overhead (which I do at the moment).  is there anything to add to this conclusion?
2) is there any way to configure the Cisco 3750s for fast updates?
Thanks in advance for any advice!
svibeesh85 Tue, 12/11/2012 - 13:16
Hi Mate,
AFAIK cisco does support fast LACP packets. you might want issue show lacp internal.
Also if its feasible a debug.
vibs
ccie-dash.blogspot.com
Here's all the relevant configuration information.  Notice how the 'show lacp internal' shows the switch requesting slow LACP updates and the 'show lacp neighbor' shows the neighbor switch requesting fast updates.  I haven't been able to find any way to set the Cisco switch to request fast LACP updates.
switch#show run int gi1/0/9
Building configuration...
Current configuration : 184 bytes
interface GigabitEthernet1/0/9
switchport mode trunk
channel-group 10 mode active
end
switch#show run int po10
Current configuration : 166 bytes
interface Port-channel10
end
switch#show lacp 10 int
switch#show lacp 10 internal
Flags:  S - Device is requesting Slow LACPDUs
        F - Device is requesting Fast LACPDUs
        A - Device is in Active mode       P - Device is in Passive mode
Channel group 10
                            LACP port     Admin     Oper    Port        Port
Port      Flags   State     Priority      Key       Key     Number      State
Gi1/0/9   SA      bndl      32768         0xA       0xA     0x10A       0x3D
Gi2/0/9   SA      bndl      32768         0xA       0xA     0x20A       0x3D
switch#show lacp 10 nei
switch#show lacp 10 neighbor
Channel group 10 neighbors
Partner's information:
Port      Flags   Priority  Dev ID          Age    key    Key    Number  State
Gi1/0/9   FA      127       a8d0.e5bc.d780   7s    0x0    0x1    0x1     0x3F
Gi2/0/9   FA      127       a8d0.e5bc.d780   7s    0x0    0x1    0x2     0x3F
svibeesh85 Tue, 12/11/2012 - 22:12
Cool
please use the following
conf t
lacp rate fast
end
Hope this helps
Jeff M Sun, 04/03/2016 - 16:25
I realize this thread is 4 years old, however I had this same issue, and hope this information will help somebody else.
The 3750 only supports slow LACP. The rate for this is every 30 seconds.
The 6500 series will support a "Fast" or 1 second LACP rate.
