09-05-2012 05:40 PM - edited 03-04-2019 05:29 PM
Hi Team,
I can't understand this situation. my understanding BGP ASN should be within 5 digit. but, APNIC assigned us 6 digit for ASN.
surly, that configuration was rejectted from cisco router configuration.
R1(config)#router bgp ?
<1-65535> Autonomous system number
R1(config)#router bgp xxxxxx
% Invalid input detected at '^' marker.
in this case, how can I do? ask it to APNIC to correct ASN? otherwise. let me know my understanding is wrong.
Solved! Go to Solution.
09-05-2012 05:50 PM
It sounds like you have a 4-byte ASN which will require an IOS that supports 32-bit AS numbers:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6554/ps6599/data_sheet_C78-521821.html
HTH,
John
09-05-2012 05:50 PM
HTH,
John
