09-06-2012 05:27 AM
I have a site to site VPN between ASA - inside 192.168.1.x and Cisco router 192.168.3.x.
I was asked to add access for additional hosts from subnet 1.x to 3.x (there were some already working).
I added them configuration is identical to the ones configured previously.
Now if i try ping from 1.x to 3.x it doesn't work but from 3.x to 1.x works (obviously after that ping from 1.x to 3.x works too).
I can't seem to find where the problem might be.
Thank you
09-09-2012 06:04 AM
Hi Tomasz ,
can you please post the config here , as i understand is after pinging from the router side you can ping in the other direction , so lets check the ASA .
also one thing you can do is to get :
packet-tracer input inside icmp host1 8 8 host2 det
before initiating the tunnel , host1 is an ip at the ASA side host2 is an ip on the router side.
HTH .
Mohammad.
09-11-2012 04:54 AM
Hello Mohammad,
First of all thank you for your response. I managed to solve this problem - in site to site configuration i didn't change the local network to match newly added addresses - silly .
sideline: the packet tracer was showing that everything is ok.
