VPN-3DES-AES: Disabled feature
Answered Question
Sep 7th, 2012
Hello all,
I have an ASA that I will like to enable the VPN-3DES-AES license. Unfortunately, we have been using this device for the past few years and the supplier did not supply us with the SKU PAK (white sheet that comes with the box). Is there a way that I can enable this feature?
Thanks alot.
Licensed features for this platform:
Maximum Physical Interfaces  : Unlimited
Maximum VLANs                : 100
Inside Hosts                 : Unlimited
Failover                     : Active/Active
VPN-DES                      : Enabled
VPN-3DES-AES                 : Disabled
Correct Answer by Karsten Iwen about 4 years 9 months ago
You get the license free of charge on www.cisco.com/go/license.
Under "Get new" you choose ASA, provide your serial# and contact, and some minutes later you have the license in your inbox.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Overall Rating: 5 (1 ratings)
Correct Answer
Karsten Iwen Fri, 09/07/2012 - 04:31
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
