MPLS Ipv6 Not working for some reason.
Answered Question
Sep 7th, 2012
Hi Guys,
I have v4 mpls working fine but v6 refuses to work correctly.
Looking at the ipv6 routing table for the VRF we can see prefix's coming from the remote PE's
BGP is up in vpnv6 and ipv6 unicast.
Everything seems fine but I just cant seem to ping between the sites.
as mentioned, ipv4 works fine for the same vrf.
Any ideas on where I can start troubleshooting.
G
Correct Answer by Peter Paluch about 4 years 6 months ago
Hi Graham,
One thing that immediately caught my attention is the fact that the next hops towards the IPv6 routes are IPv6 addresses themselves. For example:
   Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 6656:113 (default for vrf TEST)
*>i2A00:ED0:2000:8000::/64
                    2A00:ED0::3C             0    100      0 ?
Note the next hop - it is 2A00:ED0::3C. In common 6VPE scenarios, this should be an IPv6-mapped IPv4 address, i.e. ::FFFF:X.X.X.X. This IPv4 address is then used to look up the upper label from the LFIB (the IPv4 routing in these networks is supposed to be already working and LDP should take care of disseminating label-to-prefix mappings).
However, to my best knowledge, Cisco does not yet support LDP for IPv6 (anyone feel free to correct me if I am wrong!). This means that while you are capable of looking up the bottom label (visible in the show ip bgp vpnv6 unicast ... labels), you are unable to look up the topmost label that's supposed to carry this packet via an appropriate LSP to the remote PE.
So in order for the 6VPE to actually work, you should configure your BGP neighbors using IPv4 addresses and use those IPv4 addresses in the address-family vpnv6 stanza as neighbor X.X.X.X activate. This will cause BGP to use IPv6-mapped IPv4 addresses as the next hops towards the IPv6 routes in the appropriate VRFs, and enabling the lookup of the topmost label in the IPv4 LFIB.
Does this make any sense? It's a convoluted concept.
Best regards,
Peter
Overall Rating: 5 (6 ratings)
Peter Paluch Fri, 09/07/2012 - 04:45
  • Cisco Employee,
Hi Graham,
Please be so kind as to post the following information:
  • configuration of the BGP process
  • show ip bgp vpnv6 vrf VRFNAME
  • show ip bgp vpnv6 vrf VRFNAME labels
  • show ipv6 route
Thank you!
Best regards,
Peter
graham smart Fri, 09/07/2012 - 05:01
Hey man,
Here you go, Thanks for the quick reply.
Ive omitted the sh ipv6 route ( as it holds the entire internet routing table )
PE1
vrf definition TEST
rd XXXX:113
route-target export XXXX:113
route-target import XXXX:113
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
interface FastEthernet0/1
vrf forwarding TEST
ip address 192.168.123.123 255.255.255.0
duplex auto
speed auto
ipv6 address 2A00:XXXX:2000:C000::1/64
ipv6 enable
router bgp XXXX
address-family ipv4 vrf TEST
  redistribute connected
  redistribute static
  default-information originate
  no synchronization
exit-address-family
address-family ipv6 vrf TEST
  redistribute static
  no synchronization
exit-address-family
end
sh ip bgp vpnv6 unicast ?
  all  Display information about all VPN NLRIs
  rd   Display information for a route distinguisher
  vrf  Display information for a VPN Routing/Forwarding instance
sh ip bgp vpnv6 unicast vrf TEST
BGP table version is 20, local router ID is 212.125.95.222
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Route Distinguisher: XXXX:113 (default for vrf TEST)
*> 2A00:ED0:2000:C000::/64
                    ::                       0         32768 ?
sh ip bgp vpnv6 unicast vrf EST lab
bar023#sh ip bgp vpnv6 unicast vrf TEST labels
   Network          Next Hop      In label/Out label
Route Distinguisher: XXXX:113 (TEST)
                    2A00:ED0::3C    nolabel/17
                    ::              1798/nolabel(TEST)
PE2
vrf definition TEST
rd XXXX:113
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
vrf forwarding TEST
duplex auto
speed auto
ipv6 enable
router bgp XXXX
  redistribute static
  no synchronization
exit-address-family
  redistribute static
  no synchronization
exit-address-family
end
BGP table version is 20, local router ID is 212.125.95.225
*> 2A00:ED0:2000:8000::/64
                    ::                       0         32768 ?
*>i2A00:ED0:2000:C000::/64
                    2A00:ED0::15             0    100      0 ?
                    ::                       0         32768 ?
                    ::              IPv6 VRF Aggr:17/nolabel(TEST)
                    2A00:ED0::15    nolabel/1798
Correct Answer
Peter Paluch Fri, 09/07/2012 - 05:27
  • Cisco Employee,
Hi Graham,
Best regards,
Peter
graham smart Fri, 09/07/2012 - 05:34
Hmm doesnt make much sense..
I have IPv6 neighbors ( as my core is 100% dual stacked )
So i wouldnt want to remove any IPv6 neighbors.
What would I do to get it to fallback to this v4 mapped addresses?
This i smy BGP setup:
sh ip bgp all sum
For address family: IPv6 Unicast
BGP router identifier 212.125.95.222, local AS number 6656
BGP table version is 61635, main routing table version 61635
10325 network entries using 1610700 bytes of memory
10325 path entries using 784700 bytes of memory
6854/6829 BGP path/bestpath attribute entries using 1151472 bytes of memory
25 BGP rrinfo entries using 600 bytes of memory
6588 BGP AS-PATH entries using 190104 bytes of memory
4 BGP extended community entries using 96 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
Bitfield cache entries: current 1 (at peak 2) using 32 bytes of memory
BGP using 3737704 total bytes of memory
BGP activity 71935/61598 prefixes, 93448/83102 paths, scan interval 60 secs
Neighbor        V          AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
2A00:ED0::5     4       6656   37560     157    61635    0    0 01:46:39    10325
For address family: VPNv4 Unicast
BGP router identifier 212.125.95.222, local AS number xxxx
BGP table version is 36, main routing table version 36
10 network entries using 1560 bytes of memory
19 path entries using 1292 bytes of memory
6854/2 BGP path/bestpath attribute entries using 1151472 bytes of memory
BGP using 1345156 total bytes of memory
BGP activity 71935/61598 prefixes, 93448/83102 paths, scan interval 15 secs
212.125.95.21   4       xxxx   13083     199       36    0    0 03:17:28        9
212.125.95.52   4       xxxx   13088     199       36    0    0 03:17:30        9
For address family: VPNv6 Unicast
BGP table version is 20, main routing table version 20
2 network entries using 360 bytes of memory
2 path entries using 192 bytes of memory
BGP using 1342856 total bytes of memory
2A00:ED0::A     4       xxxx     150     151       20    0    0 02:15:15        1
bar023#
Mohamed Sobair Fri, 09/07/2012 - 05:54
  • Gold, 750 points or more
Peter ,, You Rock!!!  Absolutely correct statements.
graham,
IPv6 doesnt support LDP natively yet, So even if you are having dual stacked core, the Current implementation doesnt support having IGP Lookup on IPv6 yet, its therfore , a manadatory performs IGP lookup for the 6VPE in the IPv4 next hop.
So, Your neighbor under the VPNv6 address Family should be an IPv4 address of your remote PE or your Route Reflector.
if you look at your previous verfication, you will find that an VPNv6 Label is visible and Carried over BGP, However, the IGP Label to reach the next Hop wasnt not able to be determined and looked up, and the reason is because You should should map IPv4 - To - IPv6 for the 6VPE implementation, Keep in mind that Of Course, the Egress PE performs lookup at the VPNv6 Label and Performs a nother Lookup (IPv6 CEF) to forward a native IPv6 Packet to the Customer Edge (CE Router).
The TOP Label in the mpls core (IGP Label Lookup) is always going to be for an IPv4 Mapped Address.
Let us know if this answers your question,
Mohame
graham smart Fri, 09/07/2012 - 06:06
Hey Guys,
AWESOME STUFF!
IT works!
Fully makes sense now.
I have my vpnv6 address-family configured with v4 addresses and now it works
At first it didnt make sense having vpnv6 carrying v6 prefixes over a v4 peer. Seemed odd.
Anyway, I no activated the V6 neighbors ( so they are ready oneday ) and now just use v4 neighbors in my vpnv6.
Phew.
Awesome stuff!
I thought something was terribly amiss on the core or something. Couldnt for my life figure it out.
Wonderful work Peter! and thanks for clarifying Mohame
Great stuff Very pleased.
Have a great weekend guys
Peter Paluch Fri, 09/07/2012 - 05:56
  • Cisco Employee,
Hello Graham,
You would not necessarily need to remove all IPv6 neighbors - for the global routing table (non-VRF), you may retain your IPv6 neighbors as you like in the address-family ipv6 stanza. However, in the address-family vpnv6, you need to refer to your BGP neighbors by their IPv4 loopback address.
I am also thinking about using route-maps to modify the next hop attribute of a VPNv6 route advertised to a peer to ::FFFF:X.X.X.X where X.X.X.X is your own loopback IPv4 address but I doubt that it would work, as I have a feeling that the next hop as advertised in BGP VPNv6 updates is not a plain IPv6 address.
To put it simply, a VPNv6 peering using IPv6 addresses would, to my best knowledge, work only on a direct connection between two routers (back-to-back PEs or ASBRs). If there is a routed infrastructure between two PEs, you need to peer them using IPv4 even if you need to carry VPNv6 routes - because LDP for IPv6 is not implemented yet.
Best regards,
Peter
graham smart Fri, 09/07/2012 - 06:08
yeha thanks.. I think you helped clear it up in my head what to change
AWESOME STUFF!
IT works!
Phew.
Awesome stuff!
Mohamed Sobair Fri, 09/07/2012 - 06:11
Peter,
Even in a Back to Back PEs or ASBRs, the VPNv6 peering will not work for an IPv6 neighbor under the BGP address Family.
Its still wont be able to Looked up the TOP Label using an IPv6, it has to be an IPv4, and I am Sure about it. You Can try it on a Lab.
Mohamed
Peter Paluch Fri, 09/07/2012 - 06:22
  • Cisco Employee,
Hi Mohamed,
I'll probably try it and I am not going to doubt what you say, but my logic tells me that for back-to-back PEs, it should work at least in theory because of Penultimate Hop Popping - the labeled packets would so or so have only the bottom label attached, so they don't need the upper label. It seems that this is also what the Configuration Guide suggests here:
http://www.cisco.com/en/US/docs/ios-xml/ios/ipv6/configuration/15-0m/ip6-ov-mpls-6vpe.html#GUID-B060A9BB-30D3-4AAA-8196-739D37546DDB
Best regards,
Peter
Peter Paluch Fri, 09/07/2012 - 08:19
  • Cisco Employee,
Hello Mohamed,
I have actually made quite an interesting discovery.
I have two routers connected back to back, both having a VRF with a directly connected IPv6 network on a loopback, and a straightforward BGP configuration that peers these neighbors using their IPv6 addresses on the common link.
R2:
hostname R2
vrf definition V1
rd 1:1
route-target export 1:1
route-target import 1:1
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
ip cef
ipv6 unicast-routing
ipv6 cef
interface Loopback0
vrf forwarding V1
no ip address
ipv6 address 2000::2/128
interface Serial0/0/1
ip address 10.0.23.2 255.255.255.0
ipv6 address 2000:0:0:23::2/64
mpls bgp forwarding
clock rate 2000000
router bgp 1
bgp router-id 2.2.2.2
bgp log-neighbor-changes
neighbor 2000:0:0:23::3 remote-as 1
no neighbor 2000:0:0:23::3 activate
  neighbor 2000:0:0:23::3 send-community extended
exit-address-family
address-family ipv6 vrf V1
exit-address-family
R3:
hostname R3
vrf definition V1
rd 1:1
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
ip cef
ipv6 cef
interface Loopback0
vrf forwarding V1
no ip address
ipv6 address 2000::3/128
ip address 10.0.23.3 255.255.255.0
ipv6 address 2000:0:0:23::3/64
ipv6 ospf 1 area 0
mpls bgp forwarding
router bgp 1
no synchronization
bgp router-id 3.3.3.3
neighbor 2000:0:0:23::2 remote-as 1
no auto-summary
  neighbor 2000:0:0:23::2 activate
  neighbor 2000:0:0:23::2 send-community extended
exit-address-family
  no synchronization
exit-address-family
The IPv6 routes in the VRFs are exchanged nicely but the pings don't work even though I've enabled mpls bgp forwarding on the interfaces. This confirms what you have originally indicated.
R2#show ipv6 route
IPv6 Routing Table - default - 3 entries
Codes: C - Connected, L - Local, S - Static, U - Per-user Static route
       B - BGP, HA - Home Agent, MR - Mobile Router, R - RIP
       I1 - ISIS L1, I2 - ISIS L2, IA - ISIS interarea, IS - ISIS summary
       D - EIGRP, EX - EIGRP external, ND - Neighbor Discovery, l - LISP
       O - OSPF Intra, OI - OSPF Inter, OE1 - OSPF ext 1, OE2 - OSPF ext 2
       ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2
C   2000:0:0:23::/64 [0/0]
     via Serial0/0/1, directly connected
L   2000:0:0:23::2/128 [0/0]
     via Serial0/0/1, receive
L   FF00::/8 [0/0]
     via Null0, receive
R2#show ipv6 route vrf V1
IPv6 Routing Table - V1 - 3 entries
LC  2000::2/128 [0/0]
     via Loopback0, receive
B   2000::3/128 [200/0]
     via 2000:0:0:23::3%default, indirectly connected
L   FF00::/8 [0/0]
     via Null0, receive
R2#ping vrf V1 2000::3
Sending 5, 100-byte ICMP Echos to 2000::3, timeout is 2 seconds:
Success rate is 0 percent (0/5)
R2#show mpls interface
Interface              IP            Tunnel   BGP Static Operational
Serial0/0/1            No            No       Yes No     Yes
After having a close look at the CEF contents on one of these routers, this caught my eye:
R2#show ipv6 cef vrf V1 2000::3/128 internal
2000::3/128, epoch 0, flags rib defined all labels, RIB[B], refcount 4, per-destination sharing
  sources: RIB
  feature space:
   IPRM: 0x00018000
   LFD: 2000::3/128 0 local labels
        contains path extension list
  ifnums: (none)
  path 68172C78, path list 68174118, share 1/1, type attached nexthop, for IPv6, flags must-be-labelled
    MPLS short path extensions: MOI flags = 0x0 label 17
  nexthop 2000:0:0:23::3 Null0 label 17, adjacency Null0
  output chain: label 17 Lookup in input interface's mpls table
Note that the adjacency is pointing towards Null0 although the next hop is known in the global routing table and for a directly connected neighbor like this one, no MPLS label is required.
You could say that this Null0 adjacency has been installed because there is no MPLS label known towards the next hop 2000:0:0:23::3. However, this is not the case. Let me add the following configuration to R2 and R3:
R2:
route-map Test
  set ipv6 next-hop ::FFFF:10.0.23.2
router bgp 1
  neighbor 2000:0:0:23::3 route-map Test out
R3:
route-map Test
  set ipv6 next-hop ::FFFF:10.0.23.3
router bgp 1
  neighbor 2000:0:0:23::2 route-map Test out
I am basically manipulating the next hop attributes manually here and I am setting them to the IPv4 addresses of R2 and R3, respectively - something that would be done automatically if we used IPv4 addresses in the BGP peering configuration from the beginning.
Now, on R2:
     via 10.0.23.3%default, indirectly connected
L   FF00::/8 [0/0]
     via Null0, receive
  sources: RIB
  feature space:
   IPRM: 0x00018000
  ifnums: (none)
  path 68172968, path list 68173EE8, share 1/1, type recursive, for IPv6, flags must-be-labelled
  recursive via 10.0.23.3[IPv4:Default] label 17, fib 66D3174C, 1 terminal fib, v4:Default:10.0.23.3/32
    path 681729D8, path list 68173F38, share 1/1, type recursive, for IPv4, flags doesnt-source-via, cef-internal
    recursive via 10.0.23.0/24[IPv4:Default], fib 66D316C8, 1 terminal fib, v4:Default:10.0.23.0/24
      path 68172B28, path list 68174028, share 1/1, type connected prefix, for IPv4
        MPLS short path extensions: MOI flags = 0x1 label implicit-null
      connected to Serial0/0/1, adjacency IP adj out of Serial0/0/1 67A2E220
  output chain: label 17 label implicit-null TAG adj out of Serial0/0/1 66E7A6C0
Success rate is 100 percent (5/5), round-trip min/avg/max = 0/2/4 ms
R2#show mpls forwarding-table
Local      Outgoing   Prefix           Bytes Label   Outgoing   Next Hop
Label      Label      or Tunnel Id     Switched      interface
16         Pop Label  2000::2/128[V]   1000          aggregate/V1
R2#show mpls ip binding all
R2#show ip cef 10.0.23.3 detail
10.0.23.3/32, epoch 0, flags attached
  1 RR source [active source]
   Dependent covered prefix type rr cover 10.0.23.0/24
    attached to Serial0/0/1
R2#show ip cef 10.0.23.3 internal
10.0.23.3/32, epoch 0, flags attached, refcount 6, per-destination sharing
  sources: RR
  feature space:
   LFD: 10.0.23.3/32 0 local labels
        label switch chain 0x68288650
  subblocks:
    non-eos chain implicit-null
  ifnums:
   Serial0/0/1(5)
  output chain: IP adj out of Serial0/0/1 67A2E220
R2#
Note that in this case, the next hop was an IPv6-mapped IPv4 address for which there is no label known, either (I did not configure any LDP). Yet, the IPv6 CEF was now willing to create a correct adjacency and the ping actually worked - even though the IPv4 next hop address does not have any valid MPLS label mapping.
From this, it follow that the direct PE-PE connection with BGP peering using IPv6 addresses will not work to provide a working connectivity between IPv6 VRFs. Yet, it is not because there is no MPLS label mapping towards the IPv6 next hop address but merely because the IPv6 CEF is not willing to create an adjacency towards a VPNv6 route if the next hop is an IPv6 address. The only difference here is indeed the IP address in the next hop attribute: for IPv6 address, Null0 adjacency is inserted into IPv6 CEF. For IPv6-mapped IPv4 address, the adjacency is created correctly.
It seems that the IPv6 CEF is simply not going to create non-Null0 adjacencies towards IPv6 next hops. Probably this limitation will be lifted after true LDP for IPv6 is implemented.
Any thoughts are highly welcome!
Best regards,
Peter
graham smart Fri, 09/07/2012 - 08:34
I fear I have poked a hornets nest here
Very interesting read Peter!
I find it strange that LDP v6 isnt available after all this time.
If I were to create a 100% IPv6 network I assume this means that MPLS is a no-no until LDP v6 is available.
Im not saying I will make 100% only v6 network but I feel dirty using V4 to transfer V6 routes ( even if its the best / correct way ) to do it.
Will be interesting to see what others think here.
-Graham
Peter Paluch Fri, 09/07/2012 - 14:19
  • Cisco Employee,
Hello Graham,
Thank you! It has been an interesting experiment for me, too.
Yes, in a way, I find it strange as well. However, pure IPv6 networks are very rare today, especially in service provider world where MPLS is usually run. In these networks, IPv4 is practically omnipresent. Therefore, there is no real pressure for IPv6 LDP. The 6PE and 6VPE technologies (you're running 6VPE here) have been specifically designed to overcome the lack of IPv6 LDP by referring to IPv4 next hops and associated MPLS labels.
What's even more important, although the RFC 5036 (LDP, published in October 2007) does discuss the ability of LDP to carry IPv6 label bindings, it is quite terse on the details. There is a draft updating the details (http://tools.ietf.org/html/draft-ietf-mpls-ldp-ipv6-07) but it was first published in November 2010 and it still did not make it to a RFC.
I admit that running IPv4 to have MPLS-supported IPv6 is a quirk. Sadly, there's nothing better available for the moment. Hopefully that changes soon.
Best regards,
Peter
Mohamed Sobair Thu, 09/13/2012 - 01:57
Hello Peter,
You have made an excellent experiment, and I  have tested this behaviour in a LAB before. You mentioned in the main thread , a  label is not needed for a directly IPv6 neighbor, I am not entirely  agree. a Label would always be needed, but the point is that the PHP  router performs POP operation and forward the Packets to the egress PE. The TOP Label in the Case of IPv4 is created by the Egress PE and POPed by the PHP router.
From my opinion as I illustarted earlier, the reason of this behaviour even for an IPv6 CEF not creating the right adjacency, is because there is NO Valid Label Binding in the LFIB table.  The IPv6 directly connected neighbor has no Local LDP binding and the LSR doesnt perofrm what a called unsolicited upstream label distribution for an IPv6 packet. Meaning, R3 doesnt have a Valid Label for the 2000:0:0:23::3, and hence R2 doesnt perform correct POP for this host
In an IPv4, this is different. If you examine the Local Label bindings (LIB Table) for router 3 and router 2, you should find valid Label bindings for each directly connected Prefix, but this is not the case with IPv6. This can also be confirmed with (show mple forwarding table) to validate the correct PoP operation from Router(2), but its not visible as shown in your previous verification.  This is my opinion and thought about it.
Mohamed
Peter Paluch Sat, 09/15/2012 - 07:40
  • Cisco Employee,
Hello Mohamed,
Thank you for your response!
I believe this is where we diverge in our understanding. I do not believe that the label would always be needed. It is true that a directly connected neighbor would probably advertise an implicit-null label for a directly connected network, resulting in a POP operation. However, that only means that on the wire, the packet will have no topmost MPLS label. For the data plane, it is irrelevant whether the topmost label was not pushed onto the packet at all or whether the previous topmost label was POPped. In the end, the packet will simply not be equipped with the topmost label.
[ ... cut ... ]
This does not appear to be the case, Mohamed - I have recreated the exact setup as described before. Have a look:
LIB not enabled
16         Pop Label  2000::2/128[V]   500           aggregate/V1
R2#show mpls forwarding-table detail
        MAC/Encaps=0/0, MRU=0, Label Stack{}
        VPN route: V1
        No output feature configured
L   FF00::/8 [0/0]
     via Null0, receive
R2#show ipv6 cef vrf V1 2000::3 detail
  recursive via 10.0.23.3 label 16
R2#show ip bgp vpnv6 unicast vrf V1 label
Route Distinguisher: 1:1 (V1)
   2000::2/128      ::              16/nolabel(V1)
   2000::3/128      ::FFFF:10.0.23.3
                                    nolabel/16
You may see here that because I am not running LDP between my R2 and R3 (no mpls ip is configured between these two routers and I am not exchanging any IPv4 routes via BGP), there is no LIB present and no label mappings are created for any IPv4 prefixes, including the IPv4 prefixes I am using as next hop towards the 6VPE networks. In the IPv6 CEF, the 2000::3/128 prefix clearly has only a single label 16 (learned via BGP) associated, and there is no transport label identified - because it does not exist at all. Yet, the pings are successful - despite the obvious fact that there are no label mappings for IPv4 prefixes. If I use your own words, "there is NO Valid Label Binding in the LFIB table" - and yet the connectivity is established!
This seems to confirm my original opinion - that the IPv6 CEF is currently intentionally implemented to create adjacencies to Null0 if the next hop towards a 6VPE prefix in a VRF is an IPv6 address itself - knowing that IPv6 LDP is not implemented yet so using a single label (the VRF label) would not work in general (having two PEs in a back-to-back configuration like this is rare).
Looking forward to reading your thoughts on this.
Best regards,
Peter
Mohamed Sobair Sun, 09/16/2012 - 03:58
Peter,
I agree I was mistaken in my previous statement. In the Last post , I combined between the requirement of the TOP Label between directly connected and in-directly connected PEs for this type of scenario. Apologize , it was misleading. You are correct.
In the Data Plane, the TOP-Label would be needed if its not directly connected PEs or ASBRs (ie: peering with Loopbacks), However, your example mostly used when connecting two different ASBRs, where the command (mpls bgp forwarding) is required to reveal the VPNv6 Label and no requirement for TOP Label.  Just to add, this type of test is normally not used between PEs within the Same AS for the sake of the original poster query , and with most type of SP implementations, there is no directly connected PEs with such (6VPE) implementation.
Mohamed
Yasir nawaz Fri, 04/04/2014 - 23:46
Hi Peter,
Hope you are well. I have same problem. I' m unable to ping VPVN6 neighbors. I have set 9.9.0.2 as RR for VPNv6 for two routers R 3( 9.9.0.3) and R6 ( 9.9.0.6) but unfortunately I'm unable to ping them though I'm getting the routes, Please have a look at below output.
R3#sh bgp vpnv6 uni all
BGP table version is 15, local router ID is 9.9.0.3
Route Distinguisher: 9:9 (default for vrf ABC)
*>i2002:172:9::2/128
                    ::FFFF:9.9.0.2           0    100      0 i
*> 2002:172:9::3/128
                    ::                       0         32768 i
*>i2002:172:9::6/128
                    ::FFFF:9.9.0.6           0    100      0 i
*>i2002:172:9::13/128
                    ::FFFF:9.9.0.6           1    100      0 109 ?
*>i2002:172:9::14/128
                    ::FFFF:9.9.0.6           0    100      0 109 i
*>i2002:172:9:134::/64
                    ::FFFF:9.9.0.6           0    100      0 109 ?
*>i2002:172:9:146::/64
                    ::FFFF:9.9.0.6           0    100      0 ?
amadulin2013 Wed, 03/26/2014 - 01:54
Hi Peter,
Hope you're doung well!
Just a quick question, is Cisco still does not support LDP for IPV6 setup?
Related Content
