Switch WS-C4510R+E rebooting issue
Answered Question
Sep 10th, 2012
We have faced the issue with one Access Switch WS-C4510R+E having SUP# WS-X45-SUP7-E and showing the last rebooting reason as below,
CSS45B4W1.trv uptime is 56 minutes
We have checked the current IOS of this Switch and found deferred from Cisco.
Also attaching the crashinfo files, show tech-support an dshare us if have some more finding other than IOS part.
Ashutosh
Uptime for this control processor is 58 minutes
System returned to ROM by reload
System restarted at 15:05:59 IST Mon Sep 10 2012
Running default software
Last reload reason: Critical software exception
Correct Answer by Arumugam Muthaiah about 4 years 11 months ago
I have gone throug the capture shared by you decoded both crashinfo and found below detail
HW: WS-C4510R+E
SW: cat4500e-universalk9.SPA.03.02.00.SG.150-2.SG.bin
------------------ dir crashinfo: ------------------
Directory of crashinfo:/
9922  -rw-           0  Jan 13 2012 15:52:25 +05:30  koops.dat
9923  -rwx      783094  Sep 10 2012 11:54:53 +06:30  crashinfo_iosd_20120910-112352-UTC
9924  -rw-          44  Sep 10 2012 14:54:32 +06:30  last_crashinfo
9925  -rwx      547415  Sep 10 2012 14:54:32 +06:30  crashinfo_iosd_20120910-142331-UTC
9926  -rwx      806623  Sep 10 2012 07:01:46 +06:30  crashinfo_iosd_20120910-063045-UTC
141433856 bytes total (137157632 bytes free)
Log:
*Sep 10 00:31:39.290: %SYS-2-CHUNKBADMAGIC: Bad magic number in chunk header, chunk 89699058  data 896A7790  chunkmagic 15A3C78B  chunk_freemagic EF4321D5 -Process= "Check heaps", ipl= 0, pid= 7
-Traceback= 1#d1c16a2e6f8ceec1892aa2e47e2a2618  :10000000+FCC0E4 :10000000+1BEE56C :10000000+1BEE794 :10000000+1C168F0
  • Decoded the both crashinfo and found that both gave the same reason
  • This issue is matching with known Bug CSCtr35883, please see the detail below,
    • The switch crashes with a bad magic number in chunk header.
    • A switch running 15.0(2)SG/3.2.0SG through 15.0(2)SG1/3.2.1S will experience this issue
Suggestion:
  • This bug is fixed in 03.02.02.SG.150-2.SG2 or later
  • To view more information about this bug please visit the Bug Toolkit located on Cisco's Website at:
http://www.cisco.com/cgi-bin/Support/Bugtool/home.pl
Aru
*** please rate if this post is useful ****
Overall Rating: 5 (1 ratings)
Correct Answer
Arumugam Muthaiah Thu, 09/13/2012 - 08:35
  • Cisco Employee,
HW: WS-C4510R+E
Log:
Suggestion:
Aru
