Multiple Console Connections
Sep 11th, 2012
I just ordered used switches and routers from eBay and I was wondering was thier a way to have each device with a console cable somehow connected to my computer? I heard having a console to serial then serial to usb on a hub would work, any feed back on this method?
paolo bevilacqua Tue, 09/11/2012 - 01:10
  • Hall of Fame,
    Founding Member
You could have easily found the answer with a search.
Most people use old 2511 for that.
Karsten Iwen Tue, 09/11/2012 - 01:20
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
Multiple USB-to-serial connections can work. But that really doesn't look good ... ;-)
In addition to Paolos suggested 2511, you could use a very cheap 3620 or 2600 router with an NM-16A. With this module you also need an octal-cable to connect the console-ports.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Tannersummers Tue, 09/11/2012 - 01:35
So from what I googled, the expansion slot can connect to the octal-cable in which all the console connections connect to using said router as a server? if that is true it seems like the NM-16A seems pretty expensive, is their another alternative?
paolo bevilacqua Tue, 09/11/2012 - 20:52
  • Hall of Fame,
    Founding Member
Answered above.
Tannersummers Tue, 09/11/2012 - 22:24
I can't seem to find anything. Not sure if it what I am typing in the search bar or what.
Related Content
