block specific incoming call number FXO
Sep 12th, 2012
I try to block incoming calls from specific number on fxo
here's what I did :
voice translation-rule 11000
rule 1 reject /**********/    (I enter my phone number)
voice translation-profile CALL_BLOCK
translate calling 11000
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
call-block translation-profile incoming CALL_BLOCK
call-block disconnect-cause incoming invalid-number
port 0/1/1
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
I tried 2 methods, one on my fxo port 0 and one of my fxo port 1,
when i call port 0 everything's normal but when I call port 1, it takes like 5 rings to get to the phone and it shows anonymous as the caller Id instead of my phone number
why it's not working ?
paolo bevilacqua Wed, 09/12/2012 - 09:02
  • Hall of Fame,
    Founding Member
Apply the translation-profile under voice-port, not dial-peer.
datak2011 Wed, 09/12/2012 - 11:11
in this ???
when i try to, i can't enter the cmd line
voice-port 0/1/0
trunk-group ALL_FXO 64
cptone CA
connection plar opx 296
description Configured by CCA 4 FXO-0/1/0-Custom-OP
caller-id enable
voice-port 0/1/1
cptone CA
description Configured by CCA 4 FXO-0/1/1-Custom-OP
caller-id enable
voice-port 0/1/2
cptone CA
description Configured by CCA 4 FXO-0/1/2-Custom-OP
caller-id enable
voice-port 0/1/3
cptone CA
description Configured by CCA 4 FXO-0/1/3-Custom-OP
caller-id enable
paolo bevilacqua Fri, 09/14/2012 - 23:49
  • Hall of Fame,
    Founding Member
I can tell you what works, then it's up to you  to try it or not.
datak2011 Mon, 09/17/2012 - 06:00
like I told you when I try to enter the command line under Voice-port cisco ios won't let me enter the command..
paolo bevilacqua Mon, 09/17/2012 - 10:53
  • Hall of Fame,
    Founding Member
That is what command?
Anyway that method of blocking call might not work with FXO at all.
