ASA Clientless SSL VPN with Smart-Tunnel: Problem with Java content display
Sep 13th, 2012
Hi there,
I have implemented a Clientless SSL VPN solution with Smart-Tunnel feature on Cisco ASA 5520, software 8.4(4)1.
I have been successful in making Bookmarks which employ Smart-Tunnel feature to avoid content rewritting (if any). And in reality it works fine with some links. However there are some links to an Oracle portal, it doesn't work.
I was able to log into the Oracle portal with its username/password. However when i click into a button of the drop-down menu, nothing happens while normally there should be a box appearing. The Oracle portal runs with some Java stuffs which i don't really know as i am not a programming engineer anyway.
I don't know whether there is someone else can help me because it goes quite in-depth into the Application level
Tuan, CCIE #26930 (RS,Sec)
ntawork68 Thu, 09/13/2012 - 20:33
The Oracle box is running with the following parameters:
java.runtime.name Java(TM) SE Runtime Environment
java.runtime.version 1.6.0_10-b33
java.security.policy /u01/oracle/apps/tech_st/10.1.3/j2ee/oacore/config/java2.policy
java.specification.name Java Platform API Specification
java.specification.vendor Sun Microsystems Inc.
java.specification.version 1.6
java.util.logging.manager oracle.classloader.util.ApplicationLogManager
java.vendor Sun Microsystems Inc.
java.vendor.url http://java.sun.com/
java.vendor.url.bug http://java.sun.com/cgi-bin/bugreport.cgi
java.version 1.6.0_10
java.vm.info mixed mode
java.vm.name Java HotSpot(TM) Server VM
java.vm.specification.name Java Virtual Machine Specification
java.vm.specification.vendor Sun Microsystems Inc.
java.vm.specification.version 1.0
java.vm.vendor Sun Microsystems Inc.
java.vm.version 11.0-b15
javax.management.builder.initial oracle.oc4j.admin.jmx.server.Oc4jMBeanServerBuilder
jbo.323.compatible true
OA Framework 12.1.3
Oracle OA Extension 10.1.3 - build 1313
Business Components 10.1.3.3
UIX (Cabo) 2_3_6_9
BiBeans Runtime 3.1.1.10 nondebug BI Beans 3.1.1.x
MDS 9.0.6.0.0_45
XML Oracle XML Developers Kit 10.1.3.130 - Production
AOL/J Applications Object Library, Core Java Roll Up Patch J
Servlet 2.4
Java 1.6.0_10
JDBC Driver 11.2.0.1.0
Database Oracle Database 11g Enterprise Edition Release 11.1.0.7.0 - 64bit Production
Operating System Linux 2.6.18-128.el5
Browser Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; WOW64; Trident/5.0)
Related Content
