Virtual WLC - Certificate errors
Endorsed Question
Sep 14th, 2012
Hello
I have just setup a vWLC for lab purposes and it´s up and running. I have a few used 1131 LAP:s that tries to join the AP but I just get DTLS certificate errors like these:
*Sep 14 13:25:27.229: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Sep 14 13:25:27.258: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Sep 14 13:25:36.198: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Sep 14 13:26:41.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.105 peer_port: 5246
*Sep 14 13:26:41.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Sep 14 13:26:41.019: %LWAPP-3-CLIENTERRORLOG: Peer certificate verification failed
*Sep 14 13:26:41.020: %CAPWAP-3-ERRORLOG: Certificate verification failed!
*Sep 14 13:26:41.020: DTLS_CLIENT_ERROR: ../capwap/capwap_wtp_dtls.c:333 Certificate verified failed!
*Sep 14 13:26:41.020: %DTLS-4-BAD_CERT: Certificate verification failed. Peer IP: 192.168.1.105
*Sep 14 13:26:41.020: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 192.168.1.105:5246
*Sep 14 13:26:41.021: %DTLS-3-BAD_RECORD: Erroneous record received from 192.168.1.105: Malformed Certificate
*Sep 14 13:26:41.021: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.1.105:5246
*Sep 14 13:27:46.000: %CAPWAP-3-ERRORLOG: Go join a capwap controller
The WLC saids in the log:
*spamApTask7: Sep 14 13:18:34.485: #DTLS-3-HANDSHAKE_FAILURE: openssl_dtls.c:681 Failed to complete DTLS handshake with peer 192.168.1.207
*spamApTask7: Sep 14 13:17:29.502: #DTLS-3-HANDSHAKE_FAILURE: openssl_dtls.c:681 Failed to complete DTLS handshake with peer 192.168.1.207
These AP:s (I have tried 2 so far) have earlier been in use connected to a cluster of 5508:s.
Any idea how I should troubleshoot or solve this? Thanks in advance!
Best regards
Jimmy
VIP Endorsed by Scott Fella
Jwaas9876 about 1 year 4 months ago
Hi All,
I encountered the same issue recently while setting up a lab using a vWLC with 8.1.131.0 code and some 3502i AP's.  The info in this article was a great help and pointed me in the right direction.  The code on my 3502i's was 7.0.116.0 and obviously had issues with the certs connecting to the vWLC.
I downloaded the latest recovery image for the 3502i - ap3g1-rcvk9w8-tar.153-3.JBB6.tar and used the following procedure below to TFTP the file to the AP:
Unplugged the power to the AP, held down the reset button while plugging in the power to the AP, kept holding in the reset button until the AP LED went solid Red color, then let go.
Then setup my laptop for a static IP of 10.0.0.2, SN of 255.0.0.0 and no GW.
Launched Tftpd32 and selected the folder that contained the recovery image file.
Used PuTTY to console into the AP via serial cable, entered the following commands on the AP:
set IP_ADDR 10.0.0.9
set NETMASK 255.0.0.0
set DEFAULT_ROUTER 10.0.0.15
tftp_init
tar -xtract tftp://10.0.0.2/ap3g1-rcvk9w8-tar.153-3.JBB6.tar flash:
set BOOT flash:/ap3g1-rcvk9w8-mx/ap3g1-rcvk9w8-mx
set
boot
Once the AP downloaded the new recovery file and booted, it joined my vWLC and downloaded the 8.1.131.0 code, registered and was ready to go.
The other issue that I encountered pertained to the Eval AP Base License.  I had forgot to accept the EULA for the eval license, so no AP's were able to join until I did that step too.
Hope this helps someone.
Here are the links to the Cisco articles for the aforementioned procedures:
http://www.cisco.com/public/technotes/smbsa/en/us/wireless/Rec_Acc_Pt_fr...
https://supportforums.cisco.com/discussion/11713161/too-many-concurrent-...
Special thanks to Peter Nugent and Scott Fella for the great support they offer on the Cisco Support Forums.  Much appreciated guys!
John Waas
Peter Nugent about 4 years 7 months ago
The latest recovery code will code your ap as 7.3, I setup my vWLC running 3500s. Cant check availability for 1131 as site maintenance going on. The code was dated 30th Aug.
Overall Rating: 5 (7 ratings)
Scott Fella Fri, 09/14/2012 - 07:20
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Well the requirement as of right now is the ap needs to have 7.3 code in order for them to join the vWLC. So you would need the APs to join a WLC running 7.3 in order for it to join the vWLC. The vWLC will not push out the ap code like a 2504, 5508, 7500, 8500, or WiSM2.
jilahbg Fri, 09/14/2012 - 07:45
Oh, I see. Is there a way that I can put a 7.3-code into my AP:s without having a physical WLC?
/Jimmy
Scott Fella Fri, 09/14/2012 - 08:27
  • Hall of Fame,
    2017 Wireless
There is no download available for access points. The only available downloads are for the recovery image, but that's not a 7.3 replacement.
jilahbg Fri, 09/14/2012 - 11:11
So the vWLC is useless unless you have access to a "ordinary" controller also?
Best regards
Jimmy
Scott Fella Fri, 09/14/2012 - 11:18
  • Hall of Fame,
    2017 Wireless
The vWLC doesn't replace the appliance and it doesn't support features that the appliance supports.  So it depends if your looking for certain features or not.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
Peter Nugent Fri, 09/14/2012 - 18:55
  • Cisco Employee,
Scott Fella Fri, 09/14/2012 - 18:58
  • Hall of Fame,
    2017 Wireless
Peter,
That is good to know... do you know if this is going to be documented as I don't think it was in the vWLC guide.
Scott
Peter Nugent Fri, 09/14/2012 - 19:01
  • Cisco Employee,
Not sure Scott
I spoke to a few people as I saw this as a major headache.
UNcertain when all aps will ship with this code but oviously there are people out there wanting to test. I use it as it sits on my VM server. There was talk of a utility etc but thats the only way I have discovered so far.
Scott Fella Fri, 09/14/2012 - 19:04
  • Hall of Fame,
    2017 Wireless
Well its still good news... I had to put a WLC out in the dmz for my peers to have their aps join in order to test out the vWLC.... that was my easy fix:)
Scott
Peter Nugent Fri, 09/14/2012 - 19:09
  • Cisco Employee,
Yeah they did talk about a WLC with 7.3 on specifically for partners aswell as this was seen as a real shortcoming but they got the code out in time.
I struggled as I dont have anything physical in my own lab that will run 7.3, just 4400s and 2100. Need to invest in a 2500 soon I think.
vWLC lets me test some of the newer features of ISE now such as COA etc. STill not perfect but whos lab is!!
jilahbg Sat, 09/15/2012 - 13:50
As far as I can see there is no code for 1131 newer than 2008. Looks like I am stuck...
/Jimmy
daviwatk Tue, 10/02/2012 - 22:58
  • Bronze, 100 points or more
Have you tried loading the Sept. 4 release LWAPP recovery image? c1130-rcvk9w8-tar.124-25e.JAL.tar
You may also need to disable ssc hash validation via the vWLC CLI for the 1130 APs.
>config certificate ssc hash validation disable
I now have an LAP1131AG (eBay for £60) working on my vWLC without the use of first assigning it to a physical WLC running 7.3 code as everyone keeps mentioning.
My vWLC is running 7.3.101.0
Now the most important bit: the Cisco website mentions under its Latest Releases for my 1130 series AP “12.4.10b-JDA(ED)” (03-Nov-08) THIS IS NOT CORRECT! There is a later version than this named “12.4.25e-JAL(ED)” (04-Sept-12) << this is the one you need!
Download “c1130-rcvk9w8-tar.124-25e.JAL.tar” and upgrade; I didn’t use the Upgrade Tool, admittedly the AP did come preconfigured with an LWAPP image (quite old). I just used the general method of renaming the file to .default, changing your IP address to 10.0.0.2/8 etc and using the MODE button.
Changed the mode to Flexconnect, which I believe is the new H-REAP and were off! Serving SSIDs and working without faults •J (I believe I may have played with Certificates also)
I hope this helps everyone and saves them the few hours this cost me •J
P.S. I have some 1200 series, AKA 1200, 1231, 1232, these do not work! However 1240’s do •J
Cheers! Dan.
nkleven Fri, 07/24/2015 - 12:37
I realize this is a longshot...  But do you still have the 7.3.101.0 software?  It's deferred and can't be downloaded anymore.
Scott Fella Fri, 09/14/2012 - 19:12
  • Hall of Fame,
    2017 Wireless
True.... but what is IES... is that replacing ISE:)  just kidding!
Scott
Peter Nugent Fri, 09/14/2012 - 19:17
  • Cisco Employee,
LOL its 0315 here! Didn't realise.
I need to spend more time back in these forums CLN is pretty quiet on the wireless front.
And thanks for endorsing my answer Scott.
Scott Fella Fri, 09/14/2012 - 19:19
  • Hall of Fame,
    2017 Wireless
No problem... Well hopefully we see you more on the forums!
Mikael Gustafsson Sun, 10/07/2012 - 01:53
Could anyone point me in the right direction on how to do a recovery on a 3500i?
Im not been working that much with wireless, but do alot of work with ISE and need some WLC labbing done
Scott Fella Sun, 10/07/2012 - 05:49
  • Hall of Fame,
    2017 Wireless
First you need to download the rcv image for the AP. Here is a link to how to upload the file.
https://supportforums.cisco.com/docs/DOC-14960
Jwaas9876 Sat, 11/28/2015 - 20:50
Hi All,
tftp_init
set
boot
John Waas
Scott Fella Sat, 11/28/2015 - 21:05
  • Hall of Fame,
    2017 Wireless
John,
+5 and thank you for following up with a detailed process. It's things like this that make the forum valuable!
-Scoot
prisecaru_paul Thu, 09/01/2016 - 14:58
Excellent post!!!!
Even though there are many posts on this topic this explains why the cert error. Having a lower version of software on the AP and higher on the controller results in cert error.
One thing I need to add from my experience is that I had to disable my firewall (ZoneAlarm) as the 10.0.0.2 is not a trusted subnet. Something weird was happening as it would allow the AP to begin the TFTP transfer but it would timeout after 10-15 seconds. So to avoid similar issues disable your firewall.
Easy way to check what software you need for the AP:
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compa...
