Configuring cisco PIX
anujseth1.con
I am trying to configure cisco Pix firewall but not sure if the firewall is faulty or I am missing something I started with interface configs and i am not able to give IP to the interface
pixfirewall(config)# int ethernet 1
pixfirewall(config-if)# int ethernet 1.100
pixfirewall(config-subif)# ip add
pixfirewall(config-subif)# ip address 193.168.1.1 255.255.255.252
pixfirewall(config-subif)# no shut
pixfirewall#sh int ip brief
Interface                  IP-Address      OK? Method Status                Protocol
Ethernet0                  unassigned      YES unset  administratively down down
Ethernet1                  unassigned      YES unset  up                    up
Ethernet1.100              unassigned      YES manual up                    up
Ethernet2                  unassigned      YES unset  up                    up
Ethernet3                  unassigned      YES unset  administratively down down
Ethernet4                  unassigned      YES unset  administratively down down
Ethernet5                  unassigned      YES unset  administratively down down
pixfirewall# ping 193.168.1.1
Sending 5, 100-byte ICMP Echos to 193.168.1.1, timeout is 2 seconds:
No route to host 193.168.1.1
Success rate is 0 percent (0/1)
pixfirewall#
pixfirewall# sh version
Cisco PIX Security Appliance Software Version 8.0(3)
Device Manager Version 6.0(3)
Compiled on Tue 06-Nov-07 19:50 by builders
System image file is "flash:/pix803.bin"
Config file at boot was "startup-config"
pixfirewall up 4 mins 55 secs
Hardware:   PIX-515E, 128 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0xfff00000, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Encryption hardware device : VAC+ (Crypto5823 revision 0x1)
0: Ext: Ethernet0           : address is 000f.908f.270d, irq 10
1: Ext: Ethernet1           : address is 000f.908f.270e, irq 11
2: Ext: Ethernet2           : address is 000d.88ee.29e0, irq 11
3: Ext: Ethernet3           : address is 000d.88ee.29e1, irq 10
4: Ext: Ethernet4           : address is 000d.88ee.29e2, irq 9
5: Ext: Ethernet5           : address is 000d.88ee.29e3, irq 5
Licensed features for this platform:
Maximum Physical Interfaces  : 6
Maximum VLANs                : 25
Inside Hosts                 : Unlimited
Failover                     : Active/Standby
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
Cut-through Proxy            : Enabled
Guards                       : Enabled
URL Filtering                : Enabled
Security Contexts            : 2
GTP/GPRS                     : Disabled
VPN Peers                    : Unlimited
This platform has a Failover Only-Active/Standby (FO) license.
Serial Number: 808142152
Running Activation Key: 0x931f63f8 0x72785e79 0xe49e5936 0x976cda7c
Configuration last modified by enable_15 at 16:25:54.924 UTC Fri Sep 14
5 Replies 5
varrao
Level 10
Level 10
Hi Anuj,
You would need to assign the nameif to the interface as well:
pixfirewall(config)# no shut
pixfirewall(config-subif)#nameif inside (just an example for name)
Hope that helps,
Varun Rao
Security Team,
Cisco TAC
Varun Rao
I just want to assign the IP addresses to the interfaces. Pref. without sub interfaces
tried giving the names as well but still not showing the ip address
pixfirewall(config-if)# int Ethernet1.100
pixfirewall(config-subif)# name
pixfirewall(config-subif)# nameif inside
ERROR: VLAN must be configured for interface Ethernet1.100
pixfirewall(config-subif)# vl
pixfirewall(config-subif)# vlan 100
pixfirewall(config-subif)# ip add 193.168.1.1 255.255.255.252
Ethernet2                  unassigned      YES manual up                    up
pixfirewall# cond t
ERROR: % Invalid input detected at '^' marker.
pixfirewall# conf t
pixfirewall(config)# int Ethernet2
pixfirewall(config-if)# nameif
pixfirewall(config-if)# nameif outside
INFO: Security level for "outside" set to 0 by default.
pixfirewall(config-if)# ip add
pixfirewall(config-if)# ip address 193.168.1.6 255.255.255.252
pixfirewall(config-if)# no shut
pixfirewall#
Hi Anuj,
Try changing the firewall mode to routed mode so that you can assign ip address to the interfaces directly. I hope that is in transparent mode so it asks for the vlans to be configured for the IP assignments.
Pls check and revert back.
Please do rate if the given information helps.
By
Karthik
To avoid the message ERROR: VLAN must be configured for interface Ethernet1.100, try to configure the vlan before:
It works on GNS3, so it's easy to solve.
Jennifer Halim
Hi Anuj,
The reason why you can't configure anything on the PIX is because that particular PIX has "
Failover Only-Active/Standby (FO) license", meaning you can't configure it as a standalone PIX.
This PIX needs to be part of an Active/Standby failover PIX pair, and the configuration needs to be synchronised from the Active Primary PIX to this PIX.
Hope that answers your question why it's not configurable.
