ā09-19-2012 02:55 AM - edited ā03-10-2019 07:33 PM
Hi everyone,
trying to make sense of ISE licensing. I'll able to use Identity store with static MAC address (manualy added) in authorization policy.
My question is that able to be accomplished via base licensing or is that considered posturing/profiling?
Thanks all!
Iarno Pagliani
ā09-19-2012 04:17 AM
Iarno,
Your understanding is correct. Once a device is granted access using dynamic profiling then that is considered amd advanced feature.
Thanks.
Tarik
ā04-08-2013 05:47 PM
hello,
posturing/profiling are covered under Advance license only, Base license doesnāt have this functionality.
ā09-06-2013 07:41 AM
You can manually add MAC addresses to an identity group, and then reference that group in the authorization policy. This is a static entry and should NOT use an advanced license.
If you have a mass of mac addresses to add, you can load them in to a template excel spreadsheet and import them in one go.
ā09-06-2013 05:41 PM
Profiling is the feature of advance licensing
ā09-06-2013 09:53 PM
ā09-08-2013 07:19 AM
The Base License is consumed whenever an authentication notification is received by Cisco ISE. A single Advanced License is consumed when any one or more of the following services or conditions are applied to the endpoint session:
ā¢Posture
ā¢Security Group Tag assignment
ā¢Authorization using profile information
ā¢Endpoint is registered in the MyDevices Portal
