Integration ACS 5.2 with other device (sandvine)
armando.barrera
Hi the following is to apply his usual help, I have a ACS version 5.2 (TACACS) where I require equipment integrated with Sandvine, I currently looking information and very little to manage the integration of ACS with these teams Sandvine.
I have an information on the provider Sandvine with a guide to the case where only states:
TACACS + server
On a TACACS + server, each user entry must allow the service "Sandvine". Within this
service, the attribute-value pairs Following can exist:
• An attribute named "Sandvine-Group" of type string.
Refer to the section "Radius Server" on page 17 for an explanation of each of the
Sandvine-specific attributes. A typical user would look as follows entry:
{user = userA
default service = permit
Sandvine service = {
Sandvine-Group = "sv_operator, sv_admin"
login = cleartext "Passa"
Greetings and thanks for your help
nkarthikeyan
Level 7
Level 7
Hi Armando,
In order to add this type of profile through the AddProfile command, the customer can use the AddProfile -s option [-s [Filename]]. The attributes can be put in a file and they can add the user as seen here.
*$BASEDIR/CLI* ./AddProfile -p 9900 -u userA -s script
These attributes are put in the script file.
*$BASEDIR/CL>* *vi script*
password = clear "userA"
default service=permit
service=Sandvine {
set Sandvine-HomeDir = "/tmp"
set Sandvine-Group = "sv_operator,sv_admin"
set Sandvine-Shell = "/bin/sh"
$BASEDIR is the directory where Cisco Secure is installed.
is this the one you are asking?????
Please do rate if the given information helps.
By
Karthik
Karthik,
Will this work for ACS 5.2?
thanks,
Tarik Admani
*Please rate helpful posts*
before reaching the ACS 5.2 I had implemented an ACS 4.0 on windows and had configured the same Sandvine equipment and working properly. Now migrated to ACS 2.5 appliance not connected with Sandvine equipment yaque not know the ay to configure. Configuration parameters in the ACS 4.0 is very different from the ACS 5.2.
I want to know how to perform the integration between teams Sandvine and ACS 5.2, what are you sending me this steps for integration, only s is set indicating those commands? ACS application level that other things are configured?
