09-23-2012 01:15 PM
I'm am trying to get my ASA to authenticate Anyconnect users with Phonefactor authentication. Has anyone successfully done this before?
Solved! Go to Solution.
09-25-2012 02:40 PM
Hi Jason,
For this to work you need to configure the ASA to send a RADIUS request to PhoneFactor, you have to set the RADIUS timeout there as well so that the ASA doesn't time out waiting for a response from PhoneFactor. So, both the ASA and the AnyConnect client need to have a enough time out for the call to take place and get a response.
By default, AnyConnect waits up to 12 seconds for an authentication from the ASA before terminating the connection attempt. You can modify this value in the XML profile as following:
To set the authentication timeout to 90 seconds:
You can see the release notes describing the "Authentication Timeout Control" at:
The rest of the configuration is a pretty common AnyConnect client authenticating against a Radius server.
Let me know if you have any questions.
Portu.
Please rate any helpful posts
10-01-2012 05:40 AM
Hi Jason,
Sorry for any delay.
Guidelines:
Blue: Current user and privilege level.
Black: Steps to open and create a new XML profile.
Green: Complete configuration path.
* If you have previously defined the group-policy then you could define it during the creation of the XML profile.
Once you have the profile, you must make this change:
* You could also include / edit other features to this XML profile, I only edited the authentication timeout value.
On the other hand, according to your License, there is a limit of 250 AnyConnect + WebVPN sessions:
SSL VPN : 250
Let me know if you have any further questions.
Portu.
Message was edited by: Javier Portuguez
10-01-2012 01:05 PM
Jason,
My friend, please upgrade update your ASDM to the latest version available:
http://tools.cisco.com/squish/D1aba
Let me know.
Thanks.
Portu.
10-02-2012 06:16 AM
Jason,
An ASDM upgrade is not a big deal, you will not need to rollback the process.
Just upload the ASDM image and enable it as: "asdm image disk0://your_asdm_image".
Keep me posted.
Thanks.
10-02-2012 10:52 AM
Jason,
Follow these steps:
1- Go to file management:
2- Select "Between local PC and Flash.
3- Select the image from your local folder and move it to "disk:0":
4- Finally, define the ASDM image:
5- Quit the active ASDM instance and connect again.
Let me know if you still have any questions about this procedure.
Thanks.
Portu.
09-25-2012 02:40 PM
Hi Jason,
Portu.
09-28-2012 10:56 AM
Thank you Javier for your assistance.
Few additional problems/questions.
It appears that I am only licensed for Anyconnect Mobile not Anyconnect Essentials
Does this mean that I cannot adjust the timeout? In addition on my ASDM under Tools my File Management option is greyed out. Do I need to upgrade my license to Anyconnect Essentials to adjust the timeout?
Thank you
09-28-2012 11:07 AM
Jason,
To add / modify / delete an XML profile, you only need a valid AnyConnect package on your ASA.
That option should not be grayed out, unless, your does not have the correct privelege level (15 for an admin).
On the other hand, I think you have a premium license, since I see:
SSL VPN peer : 250
You do not Essentials for this to work, the Premium is more than enough.
Please share : "show vpn-sessiondb summary"
Thanks.
Portu.
Please rate any helpful posts.
09-28-2012 11:26 AM
Javier,
Active Session Summary
Sessions:
Active : Cumulative : Peak Concurrent : Inactive
SSL VPN : 1 : 237 : 5
Clientless only : 0 : 73 : 4
With client : 1 : 164 : 3 : 0
IPsec Remote Access : 1 : 631 : 13
Totals : 2 : 868
License Information:
IPsec : 250 Configured : 250 Active : 1 Load : 0%
SSL VPN : 250 Configured : 250 Active : 1 Load : 0%
IPsec : 1 : 820 : 13
Totals : 2 : 1057
Active NAC Sessions:
No NAC sessions to display
Active VLAN Mapping Sessions:
No VLAN Mapping sessions to display
I should definitely have the correct priv level...how can I veryify this?
So accessing and editing the XML file will have to be done via cli?
10-01-2012 05:27 AM
Javier,
I've verified my privilege level...
So I'm at a loss as to why my Tools>File Management is greyed out?? How do I go about editing the XML file to increase the Timeout?
10-01-2012 05:40 AM
Hi Jason,
Guidelines:
SSL VPN : 250
Portu.
10-01-2012 11:00 AM
Javier,
I have no access to the information you provided! I definitely have level 15 privilege access. Any ideas?
10-01-2012 01:05 PM
Jason,
Let me know.
Thanks.
Portu.
10-02-2012 05:13 AM
Javier,
Do I need to upgrade my ASA version in order to upgrade my ASDM version? What impact is there on the ASA when I upgrade ASDM versions? Does the machine need to reboot? What will it impact on the ASA?
Thank you for your assistance, it's been extremely helpful!
10-02-2012 05:50 AM
Good Morning Jason,
A/ No
A/ No impact at all.
A/ You do not need to reboot the machine. No impact on the ASA.
10-02-2012 06:04 AM
Javier,
I will have to incrementally upgrade to the current version...correct? What are my rollback options along this upgrade path?
Many thanks.
10-02-2012 06:16 AM
Jason,
Keep me posted.
Thanks.
10-02-2012 06:55 AM
Since I don't have access ( they are greyed out ) to Tools > Software Updates > Upgrade Software from local computer or Upgrade Software from Cisco.com in the ASDM I will have to perform this upgrade via the CLI?
Would you happen to have a link for this process?
Thank you.
10-02-2012 10:52 AM
Jason,
Follow these steps:
Thanks.
Portu.
