R3925 can't Run
Sep 24th, 2012
My R3925 Router is running well, but now It cannot reload; It's always in Rommon. This is the Log:
LOG
System Bootstrap, Version 15.0(1r)M8, RELEASE SOFTWARE (fc1)
Copyright (c) 2010 by cisco Systems, Inc.
Total memory size = 1024 MB - DIMM0 = 512 MB, DIMM1 = 512 MB
CISCO3925-CHASSIS with C3900-SPE100/K9 with 1048576 Kbytes of main memory
Main memory is configured to 72/72(dimm 0/1) bit mode with ECC enabled
Readonly ROMMON initialized
Compact Flash1: Not present
program load complete, entry point: 0x4000000, size: 0x18fa0
IOS Image Load Test
___________________
*** Machine Check Exception ***
CPU context of the most recent exception:
R0    = 0x000000be R1    = 0x0041356c R2     = 0xfece5adc R3     = 0x3cb5fbdc
R4    = 0x00413658 R5    = 0x00000080 R6     = 0x0942a35b R7     = 0x89819f0f
R8    = 0x27210ed6 R9    = 0x0041369c R10    = 0x004132dc R11    = 0x3cb5fc20
R12   = 0x69e8f3e9 R13   = 0xef3143d9 R14    = 0x27f2a3c7 R15    = 0x69ffcb5e
R16   = 0xfb207c3f R17   = 0x449f5726 R18    = 0x9b5c677e R19    = 0xdb9e754a
R20   = 0xfd659be7 R21   = 0xbbdc3b73 R22    = 0x6df65e95 R23    = 0xbc73dec2
R24   = 0x4dbf2e5a R25   = 0xd2dc7bc5 R26    = 0xcadc2af8 R27    = 0x95c1775a
R28   = 0xff8e6b80 R29   = 0x00000000 R30    = 0x1dcc1e77 R31    = 0x0041356c
CR    = 0x88000082 LR    = 0xff84b750 CTR    = 0xff84b5dc XER    = 0x20000000
TBU   = 0x00000000 TBL   = 0xbdace30e DEAR   = 0x00000000 IVPR   = 0x00000000
PVR   = 0x00000000 DBCR0 = 0x00000000 DBCR1  = 0x00000000 DBCR2  = 0x00000000
IAC1  = 0x00000000 IAC2  = 0x00000000 DAC1   = 0x00000000 DAC2   = 0x00000000
CSRR0 = 0x00000000 CSRR1 = 0x00000000 MCSRR0 = 0xff84b634 MCSRR1 = 0x02029200
PC    = 0xff84b634 MSR   = 0x02029200
CPU SPR Registers:
CSRR0 = 0x00000000
CSRR1 = 0x00000000
CTR = 0xff84b5dc
DAC1 = 0x00000000
DAC2 = 0x00000000
DBCR0 = 0x00000000
DBCR1 = 0x00000000
DBCR2 = 0x00000000
DBSR = 0x20000000
DEAR = 0x00000000
DEC = 0x000112ce
ESR = 0x00000000
IAC1 = 0x00000000
IAC2 = 0x00000000
IVOR0 = 0x00000100
IVOR1 = 0x00000200
IVOR2 = 0x00000300
IVOR3 = 0x00000400
IVOR4 = 0x00000500
IVOR5 = 0x00000600
IVOR6 = 0x00000700
IVOR8 = 0x00000c00
IVOR10 = 0x00000900
IVOR11 = 0x00000b00
IVOR12 = 0x00000d00
IVOR13 = 0x00001400
IVOR14 = 0x00001300
IVOR15 = 0x00001500
IVPR = 0xff800000
LR = 0xff83f1d8
PIR = 0x00000000
PVR = 0x80210030
SPRG0 = 0x3dd93adb
SPRG1 = 0x3dd93adb
SPRG2 = 0x00413658
SPRG3 = 0x00000000
SPRG4 = 0xff84b750
SPRG5 = 0x00000000
SPRG6 = 0x00000000
SPRG7 = 0x00000000
SRRO = 0xff873eb0
SRR1 = 0x02029200
TBL = 0xc6bf77d9
TBU = 0x00000000
TCR = 0x04400000
TSR = 0x08000000
USPRG0 = 0x00000000
XER = 0x20000000
BBEAR = 0x00000000
BBTAR = 0x00000000
BUCSR = 0x00000001
HID0 = 0x00004080
HID1 = 0xc4021000
IVOR32 = 0x00000f00
IVOR33 = 0x00001000
IVOR34 = 0x00001100
IVOR35 = 0x00001200
L1CFG0 = 0x00383820
L1CFG1 = 0x00383820
L1CSR0 = 0x00010001
L1CSR1 = 0x00000001
MAS0 = 0x10000000
MAS1 = 0xc0000700
MAS2 = 0xff000002
MAS3 = 0xff000033
MAS4 = 0x00000000
MAS6 = 0x00000000
MCAR = 0x3cb5fc20
MCSR = 0x00000008
MCSRR0 = 0xff84b634
MCSRR1 = 0x02029200
MMUCFG = 0x000019c4
MMUCSR0 = 0x00000000
PID0 = 0x00000000
PID1 = 0x00000000
PID2 = 0x00000000
SPEFSCR = 0x00000000
SVR = 0x80e80021
TLB0CFG = 0x04110200
TLB1CFG = 0x101bc010
System Return Info:
count: 19,  reason: reset
pc:0x0,  error address: 0x0
Stack Trace:
FP: 0x00000000, PC: 0x00000000
rommon 1 > context
No context available
rommon 2 > meminfo
Current Memory configuration is:
DIMM0: Size =  512 MB : Start Phy Addr = 0x0_00000000 (interleaved)
DIMM1: Size =  512 MB : Start Phy Addr = 0x0_00000000 (interleaved)
Main memory size: 1024 MB in 72/72(DIMM0/DIMM1) bit mode.
Available main memory starts at 0x1008000, size 1032160KB
Smart Init is enabled.
NVRAM size: 256 KB
Manufacturer's JEDEC ID code:
DIMM0: 7f94000000000000 (p/n SG572648FG8P0ILMF2)
DIMM1: 7f94000000000000 (p/n SG572648FG8P0ILMF2)
rommon 5 > dir flash:
Directory of flash:
2      55378212  -rw-     c3900-universalk9-mz.SPA.150-1.M2.bin
rommon 6 > dev
Devices in device table:
        id  name
   flash0:  compact flash 0
    flash:  compact flash 0
   flash1:  compact flash 1
bootflash:  boot flash
usbflash0:  usbflash0
usbflash1:  usbflash1
I try to change other Flash Card but I don't work. What's the Problem?
Harish Balakrishnan Wed, 09/26/2012 - 07:06
  • Silver, 250 points or more
did you try to do
boot flash:c3900-universalk9-mz.SPA.150-1.M2.bin ?
Harish.
