High CPU Utilization on 7606
Answered Question
Sep 29th, 2012
Dear concern,
Our Router  7606 is in a problem with high CPU Utilization. We are using one EBGP  and one IBGP session. We are also running OSPF with area 0 between two  IBGP router to exchange few local networks. When bandwidth cross 100 MB  than only CPU use become 100%. when bandwidth consumption is 80MB CPU  use become 80% end so on.
Pls find the bellow out put and assist us.
Out put is when bandwidth consumption is 34MB
CPU utilization for five seconds: 44%/43%; one minute: 42%; five minutes: 30%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
  78          44        9625          4  0.39%  0.03%  0.00%   2 Virtual Exec
  13          40         375        106  0.07%  0.00%  0.00%   0 ARP Input
  30         116        1098        105  0.07%  0.01%  0.00%   0 IPC Seat Manager
164         524       42660         12  0.07%  0.04%  0.05%   1 Virtual Exec
186           0       22945          0  0.07%  0.03%  0.02%   0 ACE Tunnel Task
259          12       89401          0  0.07%  0.10%  0.08%   0 Ethernet Msec Ti
   1           0           8          0  0.00%  0.00%  0.00%   0 Chunk Manager
   2           4         156         25  0.00%  0.01%  0.00%   0 Load Meter
   4           0          47          0  0.00%  0.00%  0.00%   0 SCP async: Draco
   5           0         173          0  0.00%  0.00%  0.00%   0 Retransmission o
   6           0           3          0  0.00%  0.00%  0.00%   0 IPC ISSU Dispatc
   7           0           1          0  0.00%  0.00%  0.00%   0 PF Redun ICC Req
   8        8684         466      18635  0.00%  0.86%  0.81%   0 Check heaps
   9           0           1          0  0.00%  0.00%  0.00%   0 Pool Manager
  10           0           1          0  0.00%  0.00%  0.00%   0 DiscardQ Backgro
  11           0           2          0  0.00%  0.00%  0.00%   0 Timers
  12           4         226         17  0.00%  0.00%  0.00%   0 WATCH_AFS
  14           8         853          9  0.00%  0.00%  0.00%   0 ARP Background
  15           0           2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  16           0           1          0  0.00%  0.00%  0.00%   0 ATM ASYNC PROC
  End = e   Freeze = f
Enter Command:
RTLSGR1#sh memory statistics
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   1322CA94   1692218732   522133152   1170085580   1168835904   1169364236
      I/O   78000000   134217728    50319772    83897956    83897956    83896252
RTLSGR1#sh cef drop
% Command accepted but obsolete, see 'show (ip|ipv6) cef switching statistics [feature]'
IPv4 CEF Drop Statistics
Slot  Encap_fail  Unresolved Unsupported    No_route      No_adj  ChkSum_Err
RP             0           0         422          10           4           0
5/0            0           0           0           0           0           0
3/0            0           0           0           0           0           0
RTLSGR1#
SUP
RSP720-3C-GE
IOS
c7600rsp72043_rp-ADVENTERPRISEK9-M
Correct Answer by Pulikkal Sekhar... about 4 years 9 months ago
Please don't forget to mark the query as answered if you are satisfied with the answer
Overall Rating: 5 (1 ratings)
Pulikkal Sekhar... Sat, 09/29/2012 - 23:33
  • Cisco Employee,
The reason for high cpu is interrupts here (44%/43%)
When did you start seeing this issue? Did you make any change prior to this issue
Can you upload the following output
1. Show tech
2. Show interfaces | inc up|rate|drop
sabuz_banik Sun, 09/30/2012 - 00:37
The router was configured one month back and was running well.One week back customer complain with dropping the packet through ICMP/Ping. After issuing sh proc cpu moni we found CPU uses increase parallal to bandwidth consumption.
RTLSGR1#
RTLSGR1#Show interfaces | inc up|rate|drop
GigabitEthernet5/1 is up, line protocol is up (connected)
  Full-duplex, 1000Mb/s, media type is LH
  Input queue: 0/75/4426/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  5 minute input rate 117567000 bits/sec, 151845 packets/sec
  5 minute output rate 113281000 bits/sec, 144974 packets/sec
     0 unknown protocol drops
GigabitEthernet5/2 is up, line protocol is up (connected)
  5 minute input rate 43863000 bits/sec, 68152 packets/sec
  5 minute output rate 48144000 bits/sec, 75019 packets/sec
Loopback0 is up, line protocol is up
  Keepalive not supported
RTLSGR1#sh tech-support
------------------ show clock ------------------
*07:10:26.950 UTC Sun Sep 30 2012
------------------ show version ------------------
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRE6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 15-Mar-12 05:31 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRE6, RELEASE SOFTWARE (fc1)
RTLSGR1 uptime is 21 hours, 10 minutes
Uptime for this control processor is 21 hours, 10 minutes
System returned to ROM by reload (SP by reload)
System image file is "bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRE6.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco CISCO7606-S (M8500) processor (revision 1.0) with 1900544K/131072K bytes of memory.
Processor board ID FOX1249G0P1
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.0, (0x80390020)
CORE: E500, Version: 2.0, (0x80210020)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
Last reset from power-on
1 Virtual Ethernet interface
2 Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
507024K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
------------------ show running-config ------------------
Building configuration...
Current configuration : 3282 bytes
! Last configuration change at 20:13:17 UTC Sat Sep 29 2012 by rtl
version 12.2
service password-encryption
service counters max age 10
hostname RTLSGR1
boot-start-marker
boot system flash sup-bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRE6.bin
boot-end-marker
enable secret 5
enable password 7
no aaa new-model
no ip source-route
no ip domain lookup
vtp mode transparent
mls rp ip
no mls flow ip
no mls flow ipv6
no mls rate-limit multicast ipv4 fib-miss
no mls rate-limit multicast ipv4 partial
no mls rate-limit unicast acl vacl-log
no mls rate-limit unicast ip rpf-failure
no mls rate-limit unicast ip icmp unreachable no-route
no mls rate-limit unicast ip icmp unreachable acl-drop
no mls rate-limit unicast ip errors
no mls rate-limit all ttl-failure
no mls rate-limit all mtu-failure
mls cef error action reset
spanning-tree mode pvst
diagnostic cns publish cisco.cns.device.diag_results
diagnostic cns subscribe cisco.cns.device.diag_commands
username das privilege 15 secret 5
username rtl privilege 15 secret 5
redundancy
main-cpu
  auto-sync running-config
mode sso
vlan internal allocation policy ascending
ip ssh version 2
class-map match-all icmp
  match protocol icmp
policy-map icmp-policy
  class icmp
    priority 100
  class class-default
    fair-queue
interface Loopback0
ip address 192.168.18.3 255.255.255.240
interface GigabitEthernet5/1
description Internet With NetroNext
ip address 103.14.80.19 255.255.255.240
speed nonegotiate
interface GigabitEthernet5/2
ip address 103.12.212.130 255.255.255.252
speed nonegotiate
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
redistribute static subnets route-map rtl
network 103.14.80.16 0.0.0.15 area 0
network 192.168.18.0 0.0.0.15 area 0
router bgp 58636
no synchronization
bgp router-id 103.12.212.130
bgp log-neighbor-changes
network 103.12.212.128 mask 255.255.255.252
network 103.14.80.0 mask 255.255.252.0
network 103.14.80.16 mask 255.255.255.240
neighbor 103.12.212.129 remote-as 132337
neighbor 192.168.18.1 remote-as 58636
neighbor 192.168.18.1 update-source Loopback0
neighbor 192.168.18.1 soft-reconfiguration inbound
no auto-summary
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip http server
no ip http secure-server
ip route 103.14.80.0 255.255.252.0 Null0
ip route 103.14.80.48 255.255.255.240 103.14.80.20
ip route 192.168.100.0 255.255.255.0 103.14.80.49
ip route 192.168.101.0 255.255.255.0 103.14.80.49
ip route 192.168.102.0 255.255.255.0 103.14.80.49
ip prefix-list netronext-out seq 5 permit 103.14.80.0/24
ip prefix-list netronext-out seq 10 deny 0.0.0.0/0 le 32
access-list 10 permit 192.168.100.0
access-list 10 permit 192.168.101.0
access-list 10 permit 192.168.102.0
no cdp run
route-map rtl permit 10
match ip address 10
snmp-server community RO
control-plane
line con 0
line vty 0 4
login local
length 0
international
transport input telnet
exception crashinfo buffersize 80
end
------------------ show stacks ------------------
Minimum process stacks:
Free/Size   Name
5548/6000   OIR IOS Process
5532/6000   ISSU Infra API Delayed Registration Process
4488/6000   IPC ISSU Versioning Process
3508/6000   IPC ISSU Receive Process
5444/6000   IPC Zone Manager
5544/6000   ICC Retry Q
3236/6000   IPC Split Init
4284/6000   RTTY Client Registration
3856/6000   PF ISSU PRST media read proc
5552/6000   CDP BLOB
5508/6000   FM HA Sync
5508/6000   L3 Manager HA
2144/6000   c6k ivrfs
11068/12000  MRIB IPv4 Init Process
11480/12000  MRIB IPv6 Init Process
11076/12000  MFIB RP IPC
5116/6000   ICC Slave Comp. Up
3396/6000   eobc_init_process
4912/6000   DRMI Master Reg. Slave Process
5552/6000   PM MP Process
4940/6000   EARL INFO CAPABILITY process
5552/6000   Low Batt Process
5492/6000   C6K ENV RP init
5000/6000   SPAN Subsystem
5364/6000   PostOfficeNet
5548/6000   SASL MAIN
11052/12000  Router Init
10892/12000  CDP Protocol
53996/60000  EEM TCL Proc
53796/60000  EEM Auto Registration Proc
11536/12000  cdp init process
6320/12000  Init
5032/6000   Draco DFS Port Registation Proc
4840/6000   IPC LC Port Opener
5548/6000   MPLS ACL RP CFG Background
5340/6000   RADIUS INITCONFIG
4780/6000   LCC Configure
9504/12000  draco-oir:slot 5
4028/6000   BGP Open
4832/6000   SLB RF Active Proc
10512/12000  draco-oir:slot 3
5496/6000   URPF stats
2552/3000   Rom Random Update Process
33720/36000  TCP Command
10816/12000  Exec
5516/6000   Link Status process
5940/12000  Virtual Exec
5528/6000   FCP Router
5536/6000   moduleTrap Generation Process
19912/24000  show techsupport huge_stack
Interrupt level stacks:
Level    Called Unused/Size  Name
  1   253516503   6364/9000  dma Intr handler
  2     1192726   6476/9000  eobc etsec1 tx interrupt
  3           0   9000/9000  Low Battery Interrupt
  4       18402   8916/9000  16550 Con/Aux Interrupt
  5           0   9000/9000  SP to RP Interrupt
  6     3538172   8924/9000  Timebase Reference Interrupt
  7    19127678   8812/9000  M8500_TIMER_INTERRUPT
******* Information of Last System Crash **********
Using bootdisk:crashinfo.
%Error opening bootdisk:crashinfo (File not found)
****** Information of Last System Crash - SP ******
The last crashinfo failed to be written.
Please verify the exception crashinfo configuration
the filesytem devices, and the free space on the
filesystem devices.
Using crashinfo_FAILED.
%Error opening disk0:crashinfo_FAILED (File not found)
------------------ show interfaces ------------------
  Hardware is C7600 1Gb 802.3, address is 0021.a00b.1f80 (bia 0021.a00b.1f80)
  Description: Internet With NetroNext
  Internet address is 103.14.80.19/28
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 35/255, rxload 36/255
  Keepalive set (10 sec)
  input flow-control is off, output flow-control is on
  Clock mode is auto
  Last input 00:00:00, output 00:00:00, output hang never
  Output queue: 0/40 (size/max)
  5 minute input rate 145078000 bits/sec, 187358 packets/sec
  5 minute output rate 140346000 bits/sec, 179956 packets/sec
  L2 Switched: ucast: 21922 pkt, 1587633 bytes - mcast: 28897 pkt, 3332971 bytes
  L3 in Switched: ucast: 1945640473 pkt, 284679948179 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 7186984243 pkt, 630745022136 bytes mcast: 0 pkt, 0 bytes
     5385099034 packets input, 561321660323 bytes, 0 no buffer
     Received 62921 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 3 throttles
     0 watchdog, 0 multicast, 0 pause input
     7186568266 packets output, 630714825156 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 lost carrier, 0 no carrier, 0 pause output
  Internet address is 103.12.212.130/30
     reliability 255/255, txload 15/255, rxload 13/255
  Media-type configured as SFP connector
  Clock mode is auto
  5 minute input rate 54458000 bits/sec, 85172 packets/sec
  5 minute output rate 59194000 bits/sec, 92575 packets/sec
  L2 Switched: ucast: 798508 pkt, 74558632 bytes - mcast: 1 pkt, 64 bytes
  L3 in Switched: ucast: 4478303555 pkt, 361957334907 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 473908163 pkt, 38519838944 bytes mcast: 0 pkt, 0 bytes
     4479526586 packets input, 362293052779 bytes, 0 no buffer
     Received 3 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 126 overrun, 0 ignored
     4938216931 packets output, 398118007574 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 4 pause output
  Hardware is Loopback
  Internet address is 192.168.18.3/28
  MTU 1514 bytes, BW 8000000 Kbit/sec, DLY 5000 usec,
  Encapsulation LOOPBACK, loopback not set
  Last input 11:13:25, output never, output hang never
  Output queue: 0/0 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     473 packets output, 89549 bytes, 0 underruns
Vlan1 is administratively down, line protocol is down
  Hardware is EtherSVI, address is 0021.a00b.1f80 (bia 0021.a00b.1f80)
  Last input never, output never, output hang never
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 1 interface resets
------------------ show interfaces history ------------------
------------------ show controllers ------------------
        Hardware is RSP720 EOBC
Interface information:
        Interface EOBC0/0(idb 0x17CCC6D0)
        108696 packets input, 27128580 bytes
        4 broadcasts received
        126939 packets output, 45936031 bytes
        4300 broadcasts sent
Dev_Instance=0x183C6B98 406612888
Receive/Transmit Buffer Descriptors
        RingSz  Shadow   StartBD  LastBD   Head  Tail Pend
  Rx0    512   183C7534  79C43CC0 79C44CB8   152   0    0
  Tx0    512   0         79C44D00 79C45CF8   475   475  0
  Rx Drop On Busy Disabled
Hash match table for multicast (in use 1, maximum 64 entries):
    Entry 0 MAC Addr = 0100.8300.0000
ETSEC counters in Hardware
64b         = 685        64b-127b    = 227        128b-255b   = 51
256b-511b   = 609        512b-1023b  = 565        1024b-1518b = 937
1519b-1522b = 0          RxBytes     = 0          RxPkt       = 49
RxFCSErr    = 0          RxMCast     = 27         RxBCast     = 4
RxCntrlFr   = 0          RxPauseFR   = 0          RxUnkop     = 0
RxAlignErr  = 0          RxLenErr    = 0          RxCodeErr   = 0
RxSenseErr  = 0          RxUnder     = 0          RxOver      = 0
RxFrag      = 10         RxJab       = 0          RxDrop      = 0
RxFilerRej  = 0          Txbytes     = 0          TxPkt       = 987
TxMCast     = 202        TxBCast     = 0          TxPause     = 0
TxDef       = 205        TxCol       = 29         TxMCol      = 3
TxLateCol   = 0          TxExCol     = 0          TxTotCol    = 38
TxDrop      = 0          TxJab       = 0          TxFCS       = 0
TxOver      = 0          TxUnder     = 0          TxFrg       = 0
------------------ show user ------------------
    Line       User       Host(s)              Idle       Location
   1 vty 0     rtl        idle                 00:03:48 203.76.109.154
*  2 vty 1     rtl        idle                 00:00:01 203.76.109.154
  Interface    User               Mode         Idle     Peer Address
------------------ show data-corruption ------------------
No data inconsistency errors have been recorded.
------------------ show memory statistics ------------------
Processor   1322CA94   1692218732   522457996   1169760736   1167289628   1168873196
      I/O   78000000   134217728    50320188    83897540    83838016    83831612
------------------ show process memory ------------------
Processor Pool Total: 1692218732 Used:  522444180 Free: 1169774552
      I/O Pool Total:  134217728 Used:   50320144 Free:   83897584
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0  263483816   13296604  238688968       7490  171325823 *Init*
   0   0      14068    4875544      14068         11         11 *Sched*
   0   0  159652980  162595780    1497596        193        155 *Dead*
   0   0          0          0     677692          0          0 *MallocLite*
   1   0     517920          0     525148          0          0 Chunk Manager
   2   0        236        236       4228          0          0 Load Meter
   3   0          0          0       7092          0          0 FCP Router
   4   0     293812     293812       7092       3617       4797 SCP async: Draco
   5   0          0          0       7228          0          0 Retransmission o
   6   0      15056          0       7228          0          0 IPC ISSU Dispatc
   7   0          0          0       7228          0          0 PF Redun ICC Req
   8   0       3360        236      10352          0          0 Check heaps
   9   0      82936     212216      90164       5560          0 Pool Manager
  10   0          0      16160       7228          0          0 DiscardQ Backgro
  11   0        236        236       7228          0          0 Timers
  12   0          0          0       4228          0          0 WATCH_AFS
  13   0      66120      35624      37724      15618      15618 ARP Input
  14   0     987328     962224      32332         21         21 ARP Background
  15   0        236        236       7228          0          0 ATM Idle Timer
  16   0          0          0       7228          0          0 ATM ASYNC PROC
  17   0          0          0       7228          0          0 AAA_SERVER_DEADT
  18   0          0          0      13228          0          0 Policy Manager
  19   0      35392      10336      33488        124        124 Entity MIB API
  20   0     598996          0     609224        176        144 EEM ED Syslog
  21   0          0          0       7228          0          0 IFS Agent Manage
  22   0         80       1604       7228          0          0 IPC Event Notifi
  23   0          0          0       7228          0          0 IPC Mcast Pendin
  24   0          0          0       7228          0          0 IPC Dynamic Cach
  25   0          0          0       7228          0          0 IPC Service NonC
  26   0     122128     115760      13516        104        104 PF_Split Sync Pr
  27   0          0          0       7228     138630     138630 IPC Periodic Tim
  28   0      24460          0       8572          0          0 IPC Deferred Por
  29   0          0          0       7228          0          0 IPC Process leve
  30   0     350760     213028     167956     113119     113119 IPC Seat Manager
  31   0          0          0       7228          0          0 IPC Check Queue
  32   0     216344          0      19248        566        552 IPC Seat RX Cont
  33   0      12516       5384      18372          0          0 IPC Seat TX Cont
  34   0      19184        496      16536      11275      11275 IPC Keep Alive M
  35   0          0          0       7228          0          0 IPC Loadometer
  36   0          0          0       7228          0          0 Compute SRP rate
  37   0          0          0       7228          0          0 RO Notify Timers
  38   0          0          0       4228          0          0 RMI RM Notify Wa
  39   0          0          0       7228          0          0 CEF MIB API
  40   0        236        236       7228          0          0 DDR Timers
  41   0          0          0       7228          0          0 ifIndex Receive
  42   0          0          0       7228          0          0 SENSOR-MGR event
  43   0        236        236       7228          0          0 Serial Backgroun
  44   0          0          0      25228          0          0 Crash writer
  45   0        304          0       7532          0          0 Exception contro
  46   0       3416       2984       7228         22         22 RPC pf-split-rp
  47   0    4882872    4882872       7228      39746      39746 EnvMon
  48   0        236        236       7228          0          0 GraphIt
  49   0     310092     132988     160812       1091       1091 rf proxy rp agen
  50   0        236        236       7228          0          0 rf proxy message
  51   0      15760       2276      20200        187        187 Entity MIB C6k P
  52   0       5484        236       7228          2          2 client_entity_se
  53   0          0          0       7228          0          0 SERIAL A'detect
  54   0          0          0       7228          0          0 Snmp ICC Process
  55   0     134844       6636       8228         44         44 Cat6k SNMP
  56   0        236       1032       7228          0          0 Cat6k SNMP Trap
  57   0       8820       2892      12704          6          6 RPC idprom-MP
  58   0          0          0       7228          0          0 Dynamic ARP Insp
  59   0          0          0       7228          0          0 Critical Bkgnd
  60   0      34916        708      15524          2          2 Net Background
  61   0       2472       2156      13544          0          0 IDB Work
  62   0        236        236      13228        320        320 Logger
  63   0      13664       3196       7228          0          0 TTY Background
  64   0       2268       1720       7776         10         10 IF-MGR control p
  65   0          0          0       7228          0          0 IF-MGR event pro
  66   0        472        604       7228          0          0 RPC rf_rfmib_not
  67   0      80432      61164      26496        352        352 Env action
  68   0          0          0       7228          0          0 EOBC ETSEC FREEZ
  69   0        236        236       7228          0          0 Flash ICC Server
  70   0          0          0       7228          0          0 ICC Nego
  71   0        224          0       7452          0          0 itasca
  72   0          0          0       7228       7060       7060 Net Input
  73   0      46548     130276      15188          0          0 draco-oir-proces
  75   0        696        700       7452          4          4 svclc
  76   0          0          0       7228          0          0 IPC ISSU Version
  77   0          0          0       7228          0          0 IPC ISSU Version
  78   1    2606832    2579140      14712      13299      13303 Virtual Exec
  79   0          0          0       7228          0          0 IPC ISSU Version
  80   0          0          0       7228          0          0 IPC ISSU Version
  81   0          0          0       7228          0          0 IPC ISSU Version
  82   0          0          0       7228          0          0 IPC ISSU Version
  83   0          0          0       7228          0          0 IPC ISSU Version
  84   0          0          0       7228          0          0 IPC ISSU Version
  85   0          0          0       7228          0          0 IPC ISSU Version
  86   0          0          0       7228          0          0 IPC ISSU Version
  87   0          0          0       7228          0          0 IPC ISSU Version
  88   0          0          0       7228          0          0 IPC ISSU Version
  89   0          0          0       7228          0          0 IPC ISSU Version
  90   0       4728          0      11956          0          0 IPC ISSU Version
  91   0          0          0       7228          0          0 IPC ISSU Version
  92   0          0          0       7228          0          0 IPC ISSU Version
  93   0          0          0       7228          0          0 IPC ISSU Version
  94   0          0          0       7228          0          0 IPC ISSU Version
  95   0          0          0       7228          0          0 IPC ISSU Version
  96   0          0          0       7228          0          0 IPC ISSU Version
  97   0          0          0       7228          0          0 IPC ISSU Version
  98   0          0          0       7228          0          0 IPC ISSU Version
  99   0          0          0       7228          0          0 IPC ISSU Version
100   0          0          0       7228          0          0 IPC ISSU Version
101   0          0          0       7228          0          0 IPC ISSU Version
102   0          0          0       7228          0          0 IPC ISSU Version
103   0          0          0       7228          0          0 IPC ISSU Version
104   0          0          0       7228          0          0 IPC ISSU Version
105   0          0          0       7228          0          0 IPC ISSU Version
106   0          0          0       7228          0          0 IPC ISSU Version
107   0          0          0       7228          0          0 IPC ISSU Version
108   0          0          0       7228          0          0 IPC ISSU Version
109   0          0          0       7228          0          0 IPC ISSU Version
110   0          0          0       7228          0          0 IPC ISSU Version
111   0          0          0       7228          0          0 IPC ISSU Version
112   0          0          0       7228          0          0 IPC ISSU Version
113   0          0          0       7228          0          0 IPC ISSU Version
114   0        944        944       7228         39         39 RPC Sync
115   0        472        604       7228          0          0 RPC rpc-slave-15
116   0          0        148       7228          0          0 SCP Multicast
117   0        224          0       7452          0          0 simba
118   0          0          0       7228          0          0 MWAM CONFIG ON S
119   0          0          0       7228          0          0 SAMI CONFIG ON S
120   0          0          0       7228          0          0 cpf_msg_holdq_pr
121   0          0          0       7228          0          0 cpf_msg_rcvq_pro
122   0          0          0       7228          0          0 CHKPT Test clien
123   0          0          0       7228          0          0 DHCPC HA
124   0          0          0       7228          0          0 DHCPD HA
125   0          0          0       7228          0          0 DHCPv6 Relay HA
126   0          0          0       7228          0          0 Network-rf Notif
127   0          0          0       7228          0          0 ARP HA
128   0          0          0       7228          0          0 MDR SM Proxy Sla
129   0          0          0       7228          0          0 RF CWAN HA Proce
130   0          0          0       7228          0          0 CWAN HA VLAN SYN
131   0          0          0       7228          0          0 CWAN IF EVENT HA
132   0          0          0       7228          0          0 CWAN APS HA Proc
133   0          0          0       7228          0          0 CWAN SRP HA Proc
134   0          0          0       4228          0          0 Inode Table Dest
135   0        800        208       7228      76018      76018 Heartbeat Proces
136   0         76          0       7228          0          0 Const ICC reques
137   0          0          0       7228          0          0 Const ICC event
138   0          0          0       7228          0          0 Const ICC except
139   0          0          0       7228          0          0 ICC Local Reques
140   0          0       1168       7228          0          0 ICC Async mcast
141   0          0    1710624       7228          0          0 ICC Async true m
142   0       1064        864       7428          1          1 ICC Mcast IPC Ev
143   0          0          0       7228          0          0 ICC_REQ Debug Pr
144   0          0          0       7228          0          0 ICC FC Process
145   0          0          0       7228          0          0 ICC FC Test Send
146   0          0          0       7228          0          0 ICC FC Test Low
147   0          0          0       7228          0          0 PF Sync process
148   0          0          0       7228          0          0 QoS HA CHKPT
149   0          0          0       7228          0          0 CWRP SPA TSM HA
150   0        236        236      10228          0          0 Switch IP Host T
151   0          0          0       7156          0          0 EM Action CNS
152   0       4728          0      11956          0          0 IKE HA Mgr
153   0          0          0       7228          0          0 IPSEC HA Mgr
154   0     154076       9256      94388         20         20 PF_Init Process
155   0          0          0       7228          0          0 Transport Port A
156   0       3052       2648       7380        605        605 RTTYS Process
157   0          0          0      13228          0          0 RFS server proce
158   0          0          0       7228          0          0 BACK CHECK
159   0        236        236       7228          0          0 Compute load avg
160   0       4968       1196      12196          0          0 Per-minute Jobs
161   0       6396       5972      10652         16         16 Per-Second Jobs
162   0          0          0       7228          0          0 cpf_process_tpQ
163   0          0          0       7228          0          0 IPC Apps Task
164   2    1628868    1627492      14508        438        429 Virtual Exec
165   0          0          0       7228          0          0 AggMgr Process
166   0        236        236       7228          0          0 CWAN ICC
167   0          0          0       7228          0          0 SFF8472
168   0        236        236       7228          0          0 Service Group PC
169   0          0          0       7228          0          0 LSM Vlan alloc p
170   0     145440          0       7228      21154      21154 Remote Console P
171   0          0          0       7228          0          0 CCB SEND RETRY A
172   0          0          0       7228          0          0 POS APS Event Pr
173   0      88384      31164      59528       1036       1036 CWAN OIR Handler
174   0        236        236       7228          0          0 CWAN Egress SACL
175   0          0          0       7228          0          0 DSX3MIB ll handl
176   0          0          0       7228          0          0 EI RP
177   0       3592       3592       7228          8          8 FPD Management P
178   0          0          0       7228          0          0 FPD Action Proce
179   0        236        236       7228          0          0 const FPD ICC pr
180   0          0          0       7228          0          0 dwdm RPC RP proc
181   0        236        236       7228          0          0 netclk_process
182   0          0          0       7228          0          0 netclk_ha_proces
183   0        472        472       7228          7          8 SCP async: LCP#5
184   0        236        236       7228          0          0 CWAN ACD tasks
185   0       1884        472       8640          1          1 ACE_REQUESTS han
186   0      16668          0      41896          0          0 ACE Tunnel Task
187   0          0          0      25228          0          0 ACE VRF Task
188   0        472        472       7228          2          2 CMFI RP process
189   0          0          0       7228          0          0 CWAN CHOCX PROCE
190   0          0          0       7228          0          0 HAL Mailbox
191   0          0          0       7228          0          0 CWAN CHDSX PROCE
192   0          0          0       7228          0          0 CT3 Mailbox
193   0          0          0       7228          0          0 CE3 Mailbox
194   0        236        236       7228          0          0 MIP Mailbox
195   0          0          0       7228          0          0 Earl NDE Task
196   0    1873932    1873932       7228      15216      15216 esw_vlan_stat_pr
197   0        388        236       7380          0          0 Gemini L3 forwar
198   0          0          0       7228          0          0 CWRP SPA ATM OIR
199   0          0          0       7228          0          0 ACE event
200   0          0          0       7228          0          0 ACE HAPI
201   0          0          0       7228          0          0 ACE policy loade
202   0        236          0       4464          0          0 Async write proc
203   0        236          0       4464          0          0 Async write proc
204   0        236          0       4464          0          0 Async write proc
205   0        236          0       4464          0          0 Async write proc
206   0          0          0       4228          0          0 DFS flush period
207   0        236        236       7228          0          0 AAA Server
208   0          0          0       7228          0          0 AAA ACCT Proc
209   0      49384          0      56612          0          0 ACCT Periodic Pr
210   0          0          0       7228          0          0 AAA System Acct
211   0          0          0       7228          0          0 Auth-proxy AAA B
212   0          0          0       7228          0          0 IP Admin SM Proc
213   0       6576      13112      13452          0          0 Collection proce
214   0        224          0      13452          0          0 CEF switching ba
215   0        224          0       4452          0          0 ADJ NSF process
216   0     940704     940476      13456       8546       8546 ADJ resolve proc
217   0          0          0       7228          0          0 PPCP RP Stats Ba
218   0        236        236       7228          0          0 AAA Dictionary R
219   0          0          0       7228          0          0 DHCP Snooping cl
220   0          0          0       7228          0          0 DHCP Snooping
221   0      18372       1424      21124          1          6 IP ARP Adjacency
222   0      49384          0      56612          0          0 IP ARP Retry Age
223   0    1997100    1934388      36440     759858     759857 IP Input
224   0          0          0       7228          0          0 ICMP event handl
225   0        236        236       7228          0          0 PIM register asy
226   0          0          0       7228          0          0 IPv6 ping proces
227   0        236        236       7228        360        360 MOP Protocols
228   0        236        236       7228          0          0 PPP SIP
229   0        236        236       7228          0          0 PPP Bind
230   0        236        236      13228          0          0 PPP IP Route
231   0        584        584       7740        229        229 IFCOM Msg Hdlr
232   0          0          0       7228          0          0 HDLC HA
233   0      68868        236      81860          0          0 SSM connection m
234   0        472        236       7464      54699      54699 Spanning Tree
235   0      68100       2512      10228          6          6 EAPoUDP Process
236   0          0          0      13228          0          0 SSS Manager
237   0          0          0      13228          0          0 SSS Policy Manag
238   0          0          0       7228          0          0 SSS Feature Mana
239   0          0          0       7228          0          0 SSS Feature Time
240   0          0          0       7228          0          0 SG DPM
241   0          0          0       7228          0          0 Timer handler fo
242   0          0          0       7228          0          0 Prepaid response
243   0          0          0       7228          0          0 Timed Policy act
244   0          0          0       7228          0          0 AAA response han
245   0          0          0       7228          0          0 AAA EPD HANDLER
246   0          0          0       7228          0          0 PM EPD API
247   0        236        236      13228          0          0 KRB5 AAA
248   0        236        236       7228          0          0 cv6 per prefix a
249   0        236        236       7228          0          0 Const MGRE Proce
250   0          0          0       7228          0          0 CCM
251   0          0          0       7228          0          0 CCM IPC flow con
252   0          0          0      13228          0          0 DMLP Counter
253   0        236        236      10228          0          0 802.1x Accountin
254   0        236        236       7228          0          0 Dot1x Mgr Proces
255   0          0          0       7228          0          0 EAP Framework
256   0          0          0       7228          0          0 EAP Test
257   0        236        236      13228          0          0 Ethernet CFM
258   0        236        236      13228          0          0 Ethernet Timer C
259   0        236        236      13228          0          0 Ethernet Msec Ti
260   0        236        236      13228          0          0 Ethernet LMI
261   0       3052          0      16280          0          0 IMA PROC
262   0        236        236       7228          0          0 IPAM/ODAP Events
263   0      49384          0      62612          0          0 IPAM Manager
264   0        236        236      13228          0          0 IPAM Events
265   0     307568      44204     270592          0          0 EEM Server
266   0       8060       6848       8968         52         52 SW VLAN RP
267   0       1820          0       9048          0          0 const ipfib per-
268   0        472        236       7464          0          0 CFMPAL-RP Proces
269   0        472        236       7464          0          0 ECFMPAL RPC Proc
270   0        236        236       7228          0          0 ACR platform pro
271   0       9780        472       7136          2          2 OBFL Cfg Dispatc
272   0        236        236      10228          0          0 Ethernet OAM Pro
273   0      10224          0      11428          0          0 CEF RP IPC Backg
274   0      26656      13524      75076        106        106 HWIF QoS Process
275   0      33644      33996       9228          0          0 crypto sw pk pro
276   0       2624          0       9852          0          0 MLS FIB RP
277   0          0          0       7228          0          0 mcast_rp_icc Pro
278   0      86112        236      93104          0          0 MIRP-RP Process
279   0       1580        236       8572          0          0 const-mfib-rp Pr
280   0        236        236       7228          0          0 QOS Stats Export
281   0        236        236       7228          0          0 QOS Stats Gather
282   0          0          0       7228          0          0 Switch IP Admiss
283   0        236        236      10228          0          0 Switch IP Host T
284   0          0          0       7228          0          0 TCAM API Process
285   0        236        236       7228          0          0 REP Topology cha
286   0          0          0      13228          0          0 TC SIP
287   0        236        236       7228          0          0 IP PORTBUNDLE
288   0          0          0       7228          0          0 SG CMD HANDLER
289   0        236        236      13228          0          0 IP Static Sessio
290   0          0          0       7228          0          0 RADIUS Proxy
291   0          0          0       7228          0          0 vaccess_lock_pro
292   0          0          0       7228          0          0 va_lock_ha_proce
293   0       4728          0      11956          0          0 AC Switch
294   0        236        236       7228          0          0 OCE punted Pkts
295   0          0          0       7228          0          0 LSP Tunnel FRR
296   0          0          0      10228          0          0 MPLS Auto-Tunnel
297   0          0          0       7228          0          0 O-UNI Client Msg
298   0          0          0       7228          0          0 IP Traceroute
299   0          0          0       7228          0          0 FRR Background P
300   0      22608       6604      34940          0          0 CEF background p
301   0        224          0      13452          0          0 fib_fib_bfd_sb e
302   0          0          0      10228          0          0 IP IRDP
303   0        224        688       7452          0          0 XDR background p
304   0    8627048    8019932     725092      81393      81391 XDR mcast
305   0       6448          0      13676          0          0 LSD HA Proc
306   0      14900          0       7228          0          0 IPC LC Message H
307   0          0          0       7228          0          0 XDR RP Ping Back
308   0     134268     166340       7228       1879       1879 XDR RP backgroun
309   0          0          0       7228          0          0 XDR RP Test Back
310   0       7736       7680      11004          0          0 IP Background
311   0       8564       3192      16680          5          5 IP Connected Rou
312   0   72679268      49024   72432552          0          0 IP RIB Update
313   0          0          0       7228          0          0 ACR HA
314   0          0          0       7228          0          0 ACR HA IPC flow
315   0      32820          0      46048          0          0 ATM HA
316   0          0          0       7228          0          0 ATM HA IPC flow
317   0          0          0       7228          0          0 ATM HA ACR
318   0          0          0       7244          0          0 SNMP Timers
319   0       3052          0      10280          0          0 CEM PROC
320   0          0          0       7228          0          0 CEM HA
321   0          0          0       7228          0          0 BFD HA
322   0          0     655880      10092         12         12 BGP Scheduler
323   0          0          0       7100          0          0 IPC ISSU Version
324   0      43688       2584      32964          0          0 CEF: IPv4 proces
325   0        516          0       7452          0          0 ADJ background
326   0          0          0       7228          0          0 RETRY_REPOPULATE
327   0          0          0       7228          0          0 Socket Timers
328   0          0          0       7228          0          0 FR HA
329   0          0      37920      13228       8578       8578 TCP Timer
330   0    2170956          0      13228          0          0 TCP Protocols
331   0        940          0      11168          0          0 HTTP CORE
332   0          0          0       7228          0          0 HSRP HA
333   0          0          0       7228          0          0 IDS Timer
334   0          0          0       7228          0          0 Inspect Timer
335   0      11264       1740      16752          0          0 EEM Policy Direc
336   0        224          0      13452          0          0 MFIB Master back
337   0       3700          0      13928          0          0 EEM ED CLI
338   0        472        236      10464          0          0 Multicast Offloa
339   0      95132        236      36536          0          0 SCTP Main Proces
340   0          0          0       7228          0          0 IPv6 ACL RP Proc
341   0     751484     751484       7228          0          0 QoS stats proces
342   0          0          0       7228          0          0 SLB CF process
343   0          0          0       7228          0          0 SLB Replicate IP
344   0          0          0       7228          0          0 VRRP HA
345   0          0          0       7228          0          0 MFI Comm RP Proc
346   0          0          0      13228          0          0 Path set broker
347   0          0          0       7228          0          0 LDP HA
348   0        236        236       7228          0          0 MPLS VPN HA Clie
349   0          0          0       7228          0          0 RSVP HA Services
350   0        236        236       7228          0          0 TSPTUN HA
351   0          0          0       7228          0          0 ac_atm_state_eve
352   0          0          0       7228          0          0 ATM HA AC
353   0        236        236       7228          0          0 BD MACSEC HA
354   0        236        236       7228          0          0 BD MACSEC HA
355   0          0          0       7228          0          0 CEM HA AC
356   0          0          0       7228          0          0 VTEMPLATE IPC fl
357   0          0          0       7228          0          0 XC RIB MGR
358   0          0          0       7228          0          0 CMFI VPN HA Proc
359   0        236        236       4228          0          0 L2X Switching Ev
360   0          0          0       7228          0          0 AAA HA
361   0        236        236       7228          0          0 ATIP_UDP_TSK
362   0        236        236       7228          0          0 PPP NBF
363   0          0          0       7228          0          0 Cv6 RP Process
364   0        224          0       7452          0          0 XDR FOF process
365   0          0          0       7228          0          0 HQF MSFC Event P
366   0        236        236       7228          0          0 PPP Compress Inp
367   0        236        236       7228          0          0 PPP Compress Res
368   0          0          0      25228          0          0 COPS
369   0          0          0       7228          0          0 802.1x Critical
370   0          0          0       7228          0          0 MAB Framework
371   0          0          0       7228          0          0 ECFM HA IPC flow
372   0        236        236       7228          0          0 EFP Errd
373   0    1758368    8255248      19528       8441       8441 L3 Manager
374   0          0          0       7228          0          0 L3 Manager Commo
375   0     825592      64140     874052        112        163 FM core
376   0          0          0       7228          0          0 GLBP HA
377   0          0          0       7228          0          0 Probe Input
378   0          0          0       7228          0          0 IMA HA
379   0        224          0      13452          0          0 MRIB RP Proxy
380   0          0          0       7228          0          0 RARP Input
381   0        236        236      10228          0          0 static
382   0        472        236       4464          0          0 PfR BR Learn
383   0          0          0       7228          0          0 PAD InCall
384   0        236        236      13228          0          0 X.25 Background
385   0          0          0       7228          0          0 X.25 Encaps Mana
386   0          0          0       7228          0          0 CFIB RP process
387   0      10264       3600      13588         24         24 Const Rate Limit
388   0       6576       1484      13360         40         40 HIDDEN VLAN Proc
389   0          0          0       7228          0          0 FR XDR manager
390   0          0          0       7228          0          0 CWAN LTL manager
391   0          0          0       7228       1216       1216 CWAN-RP SCP Proc
392   0      88512       1748      72048         15         17 CWAN-RP SCP Inpu
393   0          0          0       7228          0          0 DHCP Snooping HA
394   0       3700          0      13964          0          0 EEM ED Counter
395   0        340        236       7332          0          0 IPHC RP Process
396   0       1824        236      11816          0          0 L2TRACE SERVER
397   0        236        236       7228          0          0 CWPA QoS
398   0        312        236       7304          0          0 Const TCAM Mgr R
399   0        236        236       7228          0          0 MWAM_CONSOLE Tim
400   0          0          0       7228          0          0 Container Proces
401   0        236        236      13228          0          0 IP SIP Process
402   0        236        236      13228          0          0 IP Inband Sessio
403   0          0          0       7228          0          0 Crypto PAS Proc
404   0          0          0       7228          0          0 Crypto HW Proc
405   0        236        336       7228          0          0 Inter Chassis Pr
406   0     188328          0     173872          0          0 LSD Main Proc
407   0       1728        236       8720          0          0 LFDp Input Proc
408   0        236        236       7228          0          0 AAA Cached Serve
409   0       4728          0      11956          0          0 EM Background Pr
410   0        236        236       7228          0          0 LOCAL AAA
411   0        236        236       7228          0          0 ENABLE AAA
412   0        236        236       7228          0          0 LINE AAA
413   0   13183188   12088236      10092      37225      37225 BGP I/O
414   0       1012        236       8004          0          0 TPLUS
415   0          0          0       7228          0          0 IDMGR CORE
416   0          0          0       7228          0          0 MPLS Auto Mesh P
417   0        236        236       7228          0          0 Crypto Support
418   0      12096       1836       7908          0          0 crypto engine pr
419   0          0          0       7228          0          0 encrypt proc
420   0       2312       1512      10028          4          4 Crypto CA
421   0          0          0       9228          0          0 Crypto PKI-CRL
422   0          0          0       9228          0          0 Crypto SSL
423   0          0          0      10228          0          0 QOS PERUSER
424   0        472        236       7464          0          0 PIM HA
425   0          0          0       7228          0          0  Laminar Icc Eve
426   0        236        236      13228          0          0 SLB Main CPU pro
427   0        236        236       7228          0          0 CRYPTO MAP FREE
428   0      45488       3336      67380          0          0 Crypto ACL
429   0          0          0       7228          0          0 Crypto INT
430   0       5404        236      18396          1          1 Crypto IKMP
431   0     104832       4372      48100         10         10 IPSEC key engine
432   0          0          0       7228          0          0 IPSEC manual key
433   0          0          0       9228          0          0 Key Proc
434   0        460        236       7452          0          0 Lawful Intercept
435   0        484        236       7476          0          0 LI messaging
436   0          0          0       7228          0          0 LI C6K
437   0          0          0       7228          0          0 LI C6K PROV
438   0        224          0       7452          0          0 DATA Transfer Pr
439   0        224          0       7452          0          0 DATA Collector
440   0        236      22992       7228          0          0 AAA SEND STOP EV
441   0       3700          0      13928          0          0 EEM ED Routing
442   0       3700          0      13928          0          0 EEM ED Track
443   0       3956          0      14184          0          0 EEM ED Resource
444   0          0          0       7228          0          0 L3MM Process
445   0          0          0       7228          0          0 Syslog Traps
446   0        236        368       7228          0          0 RPC aapi_rp
447   0       2660       2792       7228         22         22 RPC capi_rp
448   0        236        368       7228          0          0 RPC chapi_rp
449   0        236        368       7228          0          0 RPC dot1x_aaa_rp
450   0        236        368       7228          0          0 RPC ether_oam_sp
451   0        236        368       7276          0          0 RPC epld_sp2rp
452   0        236        368       7228          0          0 RPC gvrp_sp2rp
453   0        236        368       7228          0          0 RPC idbman_sp2mp
454   0        224          0       7452          0          0 LC Registry Expo
455   0    1159560    1158732       8188       9406       9406 RPC online_diag_
456   0        520        652       7228          2          2 RPC online_wan_d
457   0        236        368       7228          0          0 RPC pagp_switch_
458   0        236        368       7228          0          0 RPC pm_switch_sp
459   0        236        368       7228          0          0 RPC psecure_rp
460   0        236        368       7228          0          0 RPC pt_switch_sp
461   0        236        368       7228          0          0 RPC qnq_switch_s
462   0        236        368       7228          0          0 RPC rf_cli_sp2rp
463   0          0          0       7228          0          0 SONET Traps
465   0        236        236       7228          0          0 VTPMIB EDIT BUFF
466   0        236        368       7228          0          0 RPC snmp_notify
467   0        236        368       7228          0          0 RPC snmp_stackli
468   0        236        368       7228          0          0 RPC span_switch_
469   0        236        368       7228          0          0 RPC stp_sp2mp_ap
470   0      23508       5036      17592        418        418 OSPF-1 Router
471   0        236        236       7228          0          0 Module enable-di
472   0       3784       3916       7228         36         36 RPC c6k_power_rp
473   0       4488       4620       7228         36         36 RPC c6k_rp_envir
474   0        236        368       7228          0          0 RPC ecfmpal_rpc_
475   0          0          0       7248          0          0 CONST AFL
476   0        236        368       7228          0          0 RPC cwan_ltl_sp2
477   0        236        236       7228          0          0 RP Error Detecti
478   0        236        368       7228          0          0 RPC error_detect
479   0          0          0       7256          0          0 HW Capacity ICC
480   0        236        368       7228          0          0 RPC itasca_rp
481   0        224          0       7452          0          0 RP L2 Applicatio
482   0          0          0       7228          0          0 LACP-MP Process
483   0      93728      93504       7452         15         15 Online Diag EEM
484   0          0          0       7228          0          0 PAgP-MP Process
485   0        236        368       7228          0          0 RPC pclc_g2_agsm
486   0        236        368       7228          0          0 RPC pclc_g2_fw_r
487   0        236        236       7228         64         64 Logger ICC Proce
488   0        236        368       7228          0          0 RPC pf_issu_sp2r
489   0        236        368       7228          0          0 RPC pikachu_rp
491   0       2124       2256       7228         16         16 RPC pm-mp
492   0          0          0       7228          0          0 PM Callback
493   0   17273652   17270048      10832     208900     278016 Port manager per
494   0          0          0       7228          0          0 Max CPU utilizat
495   0      15496        840       7228          4          4 RPC lcc_sp
496   0       2656       2788       7228          6          6 RPC fabman_sp
497   0        236        236       7228         21         21 rp to lc clock u
498   0     716220     716220       7228       3037       3037 SPA ENTITY Proce
499   0  261911580   16746680  249624548         29         29 BGP Router
500   0        236        236       7228          0          0 SPAN Capture
501   0          0          0       7228          0          0 EC-Card-Cfg
502   0        236        368       7228          0          0 RPC sw_backup_in
503   0       3124       2728       7228         20         20 RPC sw_vlan_rp
504   0        472        604       7228          2          2 RPC udld_rp
505   0       2448       1784       7228         12         12 RPC vtp_const_ap
506   0        236        368       7228          0          0 RPC rep_sp2rp_ap
507   0        236        368       7228          0          0 RPC dot1ad_sp2mp
508   0        236        236       7228          0          0 Rommon upgrade p
509   0        236        368       7228          0          0 RPC mlacp_sp2mp
510   0        236        236       7228          0          0 ICRM
511   0        236        368       7228          0          0 RPC icrm_sp2rp
512   0       4728          0      11956          0          0 ACR RP PROC
513   0       3700          0      13928          0          0 EEM ED Interface
514   0     120312        236     133304          0          0 MRIB Process
515   0          0         88       7228          0          0 CWAN OIR IPC Rea
516   0          0          0       7228          0          0 MFI LFD Stats Pr
517   0          0          0      13228          0          0 MFI LFD Timer Pr
518   0       4952          0      12180          0          0 MFI LFD Main Pro
519   0          0          0       7228          0          0 PF Clock Process
520   0       3700          0      13928          0          0 EEM ED IOSWD
521   0       3700          0      13964          0          0 EEM ED None
522   0       3700          0      13928          0          0 EEM ED OIR
523   0       3804        320      14032          0          0 EEM ED RF
524   0       3700          0      13928          0          0 EEM ED SNMP
525   0       3700          0      13928          0          0 EEM ED SNMP Noti
526   0       3700          0      13928          0          0 EEM ED Timer
527   0       3700          0      13928          0          0 EEM ED Ipsla
528   0      96588      42512      92252          0          0 Call Home proces
529   0          0          0       7228          0          0 IP SLAs Ethernet
530   0          0          0       7228          0          0 IP SLA AutoEther
531   0       3700          0      13956          0          0 EEM ED RPC
532   0          0          0       7228          0          0 DRMI Config Disp
533   0      40956      40956      13228        170        170 Syslog
534   0        236        236       7228          0          0 CWAN Bridge task
535   0        236        236      13228          0          0 QM MRM Process o
536   0        472        472      61228         19         19 QM Process on RP
537   0        236        236      61228          0          0 QM Reply Process
538   0        236        236      61228          0          0 QM Timer ACL Pro
539   0        236        236       7228          0          0 DHCP Snooping Sw
540   0          0          0       7280          0          0 Call Home Timer
541   0        236        236       7228          0          0 CONST PC POLICYM
542   0        228          0       7456          0          0 Online Diag CNS
543   0        224          0       7452          1          1 Online Diag CNS
544   0       3700          0      13928          0          0 EM ED GOLD
545   0       3700          0      13928          0          0 EEM ED Test
546   0       3700          0      13928          0          0 EEM ED Config
547   0       3700          0      13928          0          0 EEM ED Env
548   0          0          0       7228          0          0 VACL Logger
549   0        472        472       7228          2          2 REP RP Proc
550   0        236        236      61228          0          0 SIP10G QM Proces
551   0          0          0       7228          0          0 IP SLA MPLSLM Pr
552   0          0          0      10120          0          0 BGP Scanner
553   0   12940880     131176       7296          0          0 BGP Task
554   0          0          0       7232          0          0 TCP Listener
555   0   29160932   29156288      14176     269296     269296 IP SNMP
556   0    2114456          0      13228          0          0 PDU DISPATCHER
557   0 1712745824 1714860372      16832      66357      66362 SNMP ENGINE
558   0       1184        236      14176          0          0 IP SNMPV6
559   0          0          0      13228          0          0 SNMP ConfCopyPro
560   0        236        236      13228          0          0 SNMP Traps
561   0          0          0       7092          0          0 BGP Event
562   0       9852       7692      11172       8150       8150 OSPF-1 Hello
                                572598004 Total
------------------ show process cpu ------------------
CPU utilization for five seconds: 51%/48%; one minute: 51%; five minutes: 54%
   1           0           9          0  0.00%  0.00%  0.00%   0 Chunk Manager
   2        4088       15239        268  0.00%  0.01%  0.00%   0 Load Meter
   3           0           1          0  0.00%  0.00%  0.00%   0 FCP Router
   4          20        2433          8  0.00%  0.00%  0.00%   0 SCP async: Draco
   8     1345764       70348      19130  0.00%  1.17%  0.95%   0 Check heaps
   9           4          16        250  0.00%  0.00%  0.00%   0 Pool Manager
  10           0           2          0  0.00%  0.00%  0.00%   0 DiscardQ Backgro
  12         156        5708         27  0.07%  0.00%  0.00%   0 WATCH_AFS
  13        1380       14314         96  0.00%  0.00%  0.00%   0 ARP Input
  14         124       79056          1  0.00%  0.00%  0.00%   0 ARP Background
  17           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  18           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  19           0          24          0  0.00%  0.00%  0.00%   0 Entity MIB API
  20           8         156         51  0.00%  0.00%  0.00%   0 EEM ED Syslog
  21           0           1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  22           8       15228          0  0.00%  0.00%  0.00%   0 IPC Event Notifi
  23          44       73996          0  0.00%  0.00%  0.00%   0 IPC Mcast Pendin
  24           0        1271          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  25           8       15222          0  0.00%  0.00%  0.00%   0 IPC Service NonC
  26           0         107          0  0.00%  0.00%  0.00%   0 PF_Split Sync Pr
  27         268       73995          3  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  28          76       74001          1  0.00%  0.00%  0.00%   0 IPC Deferred Por
  29           0           1          0  0.00%  0.00%  0.00%   0 IPC Process leve
  30       13464       68870        195  0.00%  0.00%  0.00%   0 IPC Seat Manager
  31           0        1386          0  0.00%  0.00%  0.00%   0 IPC Check Queue
  32          12         190         63  0.00%  0.00%  0.00%   0 IPC Seat RX Cont
  33           0           9          0  0.00%  0.00%  0.00%   0 IPC Seat TX Cont
  34         104        7628         13  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  35          28       15225          1  0.00%  0.00%  0.00%   0 IPC Loadometer
  36           0        7622          0  0.00%  0.00%  0.00%   0 Compute SRP rate
  37           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  38           0           1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  39           0           1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  40           0           2          0  0.00%  0.00%  0.00%   0 DDR Timers
  41           0           1          0  0.00%  0.00%  0.00%   0 ifIndex Receive
  42           0           1          0  0.00%  0.00%  0.00%   0 SENSOR-MGR event
  43           0           2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  44           0           1          0  0.00%  0.00%  0.00%   0 Crash writer
  45           0           1          0  0.00%  0.00%  0.00%   0 Exception contro
  46           0          22          0  0.00%  0.00%  0.00%   0 RPC pf-split-rp
  47        3104       20479        151  0.00%  0.00%  0.00%   0 EnvMon
  48          36       76172          0  0.00%  0.00%  0.00%   0 GraphIt
  49          60        1088         55  0.00%  0.00%  0.00%   0 rf proxy rp agen
  50           0           3          0  0.00%  0.00%  0.00%   0 rf proxy message
  51           8          16        500  0.00%  0.00%  0.00%   0 Entity MIB C6k P
  52           4           3       1333  0.00%  0.00%  0.00%   0 client_entity_se
  53           0           1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  54           0           1          0  0.00%  0.00%  0.00%   0 Snmp ICC Process
  55           0          39          0  0.00%  0.00%  0.00%   0 Cat6k SNMP
  56           0           8          0  0.00%  0.00%  0.00%   0 Cat6k SNMP Trap
  57           0          17          0  0.00%  0.00%  0.00%   0 RPC idprom-MP
  58          64       75811          0  0.00%  0.00%  0.00%   0 Dynamic ARP Insp
  59           0           1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  60          16        9148          1  0.00%  0.00%  0.00%   0 Net Background
  61           0           3          0  0.00%  0.00%  0.00%   0 IDB Work
  62           0         271          0  0.00%  0.00%  0.00%   0 Logger
  63          32       75789          0  0.00%  0.00%  0.00%   0 TTY Background
  64           0          17          0  0.00%  0.00%  0.00%   0 IF-MGR control p
  65           0          23          0  0.00%  0.00%  0.00%   0 IF-MGR event pro
  66           0           5          0  0.00%  0.00%  0.00%   0 RPC rf_rfmib_not
  67          20         352         56  0.00%  0.00%  0.00%   0 Env action
  68          40       75810          0  0.00%  0.00%  0.00%   0 EOBC ETSEC FREEZ
  69           0           2          0  0.00%  0.00%  0.00%   0 Flash ICC Server
  70           0           1          0  0.00%  0.00%  0.00%   0 ICC Nego
  71           0         130          0  0.00%  0.00%  0.00%   0 itasca
  72         124        6686         18  0.00%  0.00%  0.00%   0 Net Input
  73           4          10        400  0.00%  0.00%  0.00%   0 draco-oir-proces
  75           0          58          0  0.00%  0.00%  0.00%   0 svclc
  76           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  77           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  78       80952    15522694          5  0.00%  0.09%  3.01%   1 Virtual Exec
  79           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  80           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  81           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  82           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  83           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  84           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  85           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  86           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  87           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  88           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  89           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  90           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  91           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  92           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  93           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  94           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  95           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  96           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  97           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  98           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  99           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
100           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
101           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
102           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
103           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
104           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
105           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
106           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
107           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
108           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
109           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
110           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
111           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
112           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
113           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
114           0          11          0  0.00%  0.00%  0.00%   0 RPC Sync
115           0           3          0  0.00%  0.00%  0.00%   0 RPC rpc-slave-15
116           0           3          0  0.00%  0.00%  0.00%   0 SCP Multicast
117           0         128          0  0.00%  0.00%  0.00%   0 simba
118           0           3          0  0.00%  0.00%  0.00%   0 MWAM CONFIG ON S
119           0           1          0  0.00%  0.00%  0.00%   0 SAMI CONFIG ON S
120           0           2          0  0.00%  0.00%  0.00%   0 cpf_msg_holdq_pr
121           0           1          0  0.00%  0.00%  0.00%   0 cpf_msg_rcvq_pro
122           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
123           0           1          0  0.00%  0.00%  0.00%   0 DHCPC HA
124           0           1          0  0.00%  0.00%  0.00%   0 DHCPD HA
125           0           1          0  0.00%  0.00%  0.00%   0 DHCPv6 Relay HA
126           0           1          0  0.00%  0.00%  0.00%   0 Network-rf Notif
127           0           4          0  0.00%  0.00%  0.00%   0 ARP HA
128           0           1          0  0.00%  0.00%  0.00%   0 MDR SM Proxy Sla
129          40        1271         31  0.00%  0.00%  0.00%   0 RF CWAN HA Proce
130           0           1          0  0.00%  0.00%  0.00%   0 CWAN HA VLAN SYN
131           0           1          0  0.00%  0.00%  0.00%   0 CWAN IF EVENT HA
132           0           1          0  0.00%  0.00%  0.00%   0 CWAN APS HA Proc
133           0           1          0  0.00%  0.00%  0.00%   0 CWAN SRP HA Proc
134           0           1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
135         768       75868         10  0.00%  0.00%  0.00%   0 Heartbeat Proces
136           0           2          0  0.00%  0.00%  0.00%   0 Const ICC reques
137           0           1          0  0.00%  0.00%  0.00%   0 Const ICC event
138           0           1          0  0.00%  0.00%  0.00%   0 Const ICC except
139           0           1          0  0.00%  0.00%  0.00%   0 ICC Local Reques
140           0           7          0  0.00%  0.00%  0.00%   0 ICC Async mcast
141         244        4235         57  0.00%  0.00%  0.00%   0 ICC Async true m
142           0           3          0  0.00%  0.00%  0.00%   0 ICC Mcast IPC Ev
143           0           1          0  0.00%  0.00%  0.00%   0 ICC_REQ Debug Pr
144           0           1          0  0.00%  0.00%  0.00%   0 ICC FC Process
145           0           1          0  0.00%  0.00%  0.00%   0 ICC FC Test Send
146           0           1          0  0.00%  0.00%  0.00%   0 ICC FC Test Low
147           0           1          0  0.00%  0.00%  0.00%   0 PF Sync process
148           0           1          0  0.00%  0.00%  0.00%   0 QoS HA CHKPT
149           0           1          0  0.00%  0.00%  0.00%   0 CWRP SPA TSM HA
150           0           2          0  0.00%  0.00%  0.00%   0 Switch IP Host T
151           0           1          0  0.00%  0.00%  0.00%   0 EM Action CNS
152           0           1          0  0.00%  0.00%  0.00%   0 IKE HA Mgr
153           0           1          0  0.00%  0.00%  0.00%   0 IPSEC HA Mgr
154           8          26        307  0.00%  0.00%  0.00%   0 PF_Init Process
155           0        1290          0  0.00%  0.00%  0.00%   0 Transport Port A
156        1896      376787          5  0.00%  0.00%  0.00%   0 RTTYS Process
157           0           1          0  0.00%  0.00%  0.00%   0 RFS server proce
158           0           1          0  0.00%  0.00%  0.00%   0 BACK CHECK
159         120       15241          7  0.00%  0.00%  0.00%   0 Compute load avg
160       30688        1303      23551  0.00%  0.02%  0.00%   0 Per-minute Jobs
161         712       76223          9  0.00%  0.00%  0.00%   0 Per-Second Jobs
162           0           1          0  0.00%  0.00%  0.00%   0 cpf_process_tpQ
163           0           1          0  0.00%  0.00%  0.00%   0 IPC Apps Task
164         636         382       1664  3.83%  0.50%  0.10%   2 Virtual Exec
165           0           2          0  0.00%  0.00%  0.00%   0 AggMgr Process
166           0           2          0  0.00%  0.00%  0.00%   0 CWAN ICC
167           0           1          0  0.00%  0.00%  0.00%   0 SFF8472
168           0           2          0  0.00%  0.00%  0.00%   0 Service Group PC
169           0           1          0  0.00%  0.00%  0.00%   0 LSM Vlan alloc p
170         584       17174         34  0.00%  0.00%  0.00%   0 Remote Console P
171           0           1          0  0.00%  0.00%  0.00%   0 CCB SEND RETRY A
172           0           1          0  0.00%  0.00%  0.00%   0 POS APS Event Pr
173         180        1326        135  0.00%  0.00%  0.00%   0 CWAN OIR Handler
174           0           2          0  0.00%  0.00%  0.00%   0 CWAN Egress SACL
175           0           1          0  0.00%  0.00%  0.00%   0 DSX3MIB ll handl
176           0           1          0  0.00%  0.00%  0.00%   0 EI RP
177           0           7          0  0.00%  0.00%  0.00%   0 FPD Management P
178           0           1          0  0.00%  0.00%  0.00%   0 FPD Action Proce
179           0           2          0  0.00%  0.00%  0.00%   0 const FPD ICC pr
180           0           1          0  0.00%  0.00%  0.00%   0 dwdm RPC RP proc
181           0           2          0  0.00%  0.00%  0.00%   0 netclk_process
182           0           1          0  0.00%  0.00%  0.00%   0 netclk_ha_proces
183           0           7          0  0.00%  0.00%  0.00%   0 SCP async: LCP#5
184           0           2          0  0.00%  0.00%  0.00%   0 CWAN ACD tasks
185           0           3          0  0.00%  0.00%  0.00%   0 ACE_REQUESTS han
186         380     2292756          0  0.00%  0.01%  0.00%   0 ACE Tunnel Task
187           0           1          0  0.00%  0.00%  0.00%   0 ACE VRF Task
188           8          16        500  0.00%  0.00%  0.00%   0 CMFI RP process
189          48       75806          0  0.00%  0.00%  0.00%   0 CWAN CHOCX PROCE
190           0           1          0  0.00%  0.00%  0.00%   0 HAL Mailbox
191          28       75807          0  0.00%  0.00%  0.00%   0 CWAN CHDSX PROCE
192           0           1          0  0.00%  0.00%  0.00%   0 CT3 Mailbox
193           0           1          0  0.00%  0.00%  0.00%   0 CE3 Mailbox
194           0           2          0  0.00%  0.00%  0.00%   0 MIP Mailbox
195           0           1          0  0.00%  0.00%  0.00%   0 Earl NDE Task
196        1440       15032         95  0.00%  0.00%  0.00%   0 esw_vlan_stat_pr
197           0           3          0  0.00%  0.00%  0.00%   0 Gemini L3 forwar
198           0           1          0  0.00%  0.00%  0.00%   0 CWRP SPA ATM OIR
199           0           1          0  0.00%  0.00%  0.00%   0 ACE event
200           0           1          0  0.00%  0.00%  0.00%   0 ACE HAPI
201           0        5078          0  0.00%  0.00%  0.00%   0 ACE policy loade
202           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
203           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
204           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
205           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
206           0        1270          0  0.00%  0.00%  0.00%   0 DFS flush period
207           0           2          0  0.00%  0.00%  0.00%   0 AAA Server
208           0           1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
209           0           1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
210           0           1          0  0.00%  0.00%  0.00%   0 AAA System Acct
211           0           1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
212           0         255          0  0.00%  0.00%  0.00%   0 IP Admin SM Proc
213           0          32          0  0.00%  0.00%  0.00%   0 Collection proce
214           0           2          0  0.00%  0.00%  0.00%   0 CEF switching ba
215           0           1          0  0.00%  0.00%  0.00%   0 ADJ NSF process
216        1400       16528         84  0.00%  0.00%  0.00%   0 ADJ resolve proc
217           0           1          0  0.00%  0.00%  0.00%   0 PPCP RP Stats Ba
218           0           2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
219           0           1          0  0.00%  0.00%  0.00%   0 DHCP Snooping cl
220           0         638          0  0.00%  0.00%  0.00%   0 DHCP Snooping
221           0          16          0  0.00%  0.00%  0.00%   0 IP ARP Adjacency
222         240     2292751          0  0.00%  0.02%  0.00%   0 IP ARP Retry Age
223       70028      632119        110  0.15%  0.08%  0.08%   0 IP Input
224           0           1          0  0.00%  0.00%  0.00%   0 ICMP event handl
225           0           3          0  0.00%  0.00%  0.00%   0 PIM register asy
226           0           1          0  0.00%  0.00%  0.00%   0 IPv6 ping proces
227           0         181          0  0.00%  0.00%  0.00%   0 MOP Protocols
228           0           2          0  0.00%  0.00%  0.00%   0 PPP SIP
229           0           2          0  0.00%  0.00%  0.00%   0 PPP Bind
230           0           2          0  0.00%  0.00%  0.00%   0 PPP IP Route
231         408        7964         51  0.00%  0.00%  0.00%   0 IFCOM Msg Hdlr
232           0           1          0  0.00%  0.00%  0.00%   0 HDLC HA
233           4          26        153  0.00%  0.00%  0.00%   0 SSM connection m
234        1212       54535         22  0.00%  0.00%  0.00%   0 Spanning Tree
235           4           5        800  0.00%  0.00%  0.00%   0 EAPoUDP Process
236           0           1          0  0.00%  0.00%  0.00%   0 SSS Manager
237           0           1          0  0.00%  0.00%  0.00%   0 SSS Policy Manag
238           0           1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
239         112      295201          0  0.00%  0.00%  0.00%   0 SSS Feature Time
240           0           1          0  0.00%  0.00%  0.00%   0 SG DPM
241           0           1          0  0.00%  0.00%  0.00%   0 Timer handler fo
242           0           1          0  0.00%  0.00%  0.00%   0 Prepaid response
243           0           1          0  0.00%  0.00%  0.00%   0 Timed Policy act
244           0           1          0  0.00%  0.00%  0.00%   0 AAA response han
245           0           1          0  0.00%  0.00%  0.00%   0 AAA EPD HANDLER
246           0           1          0  0.00%  0.00%  0.00%   0 PM EPD API
247           0           2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
248           0           3          0  0.00%  0.00%  0.00%   0 cv6 per prefix a
249           0           2          0  0.00%  0.00%  0.00%   0 Const MGRE Proce
250           0           1          0  0.00%  0.00%  0.00%   0 CCM
251           0           2          0  0.00%  0.00%  0.00%   0 CCM IPC flow con
252           0           1          0  0.00%  0.00%  0.00%   0 DMLP Counter
253           0           2          0  0.00%  0.00%  0.00%   0 802.1x Accountin
254           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
255           0           1          0  0.00%  0.00%  0.00%   0 EAP Framework
256           0           1          0  0.00%  0.00%  0.00%   0 EAP Test
257           0           2          0  0.00%  0.00%  0.00%   0 Ethernet CFM
258          68      293550          0  0.00%  0.00%  0.00%   0 Ethernet Timer C
259         860     9142058          0  0.15%  0.10%  0.08%   0 Ethernet Msec Ti
260           0           2          0  0.00%  0.00%  0.00%   0 Ethernet LMI
261           0           1          0  0.00%  0.00%  0.00%   0 IMA PROC
262           0           2          0  0.00%  0.00%  0.00%   0 IPAM/ODAP Events
263         236     2292773          0  0.00%  0.01%  0.00%   0 IPAM Manager
264           0           2          0  0.00%  0.00%  0.00%   0 IPAM Events
265          24         182        131  0.00%  0.00%  0.00%   0 EEM Server
266          12          37        324  0.00%  0.00%  0.00%   0 SW VLAN RP
267           0           2          0  0.00%  0.00%  0.00%   0 const ipfib per-
268           0           2          0  0.00%  0.00%  0.00%   0 CFMPAL-RP Proces
269           0          24          0  0.00%  0.00%  0.00%   0 ECFMPAL RPC Proc
270           0           2          0  0.00%  0.00%  0.00%   0 ACR platform pro
271           0           4          0  0.00%  0.00%  0.00%   0 OBFL Cfg Dispatc
272           0           2          0  0.00%  0.00%  0.00%   0 Ethernet OAM Pro
273           0           5          0  0.00%  0.00%  0.00%   0 CEF RP IPC Backg
274           8          61        131  0.00%  0.00%  0.00%   0 HWIF QoS Process
275          24           5       4800  0.00%  0.00%  0.00%   0 crypto sw pk pro
276           0           1          0  0.00%  0.00%  0.00%   0 MLS FIB RP
277           0           1          0  0.00%  0.00%  0.00%   0 mcast_rp_icc Pro
278           0           2          0  0.00%  0.00%  0.00%   0 MIRP-RP Process
279           0           2          0  0.00%  0.00%  0.00%   0 const-mfib-rp Pr
280           0           2          0  0.00%  0.00%  0.00%   0 QOS Stats Export
281           4        7609          0  0.00%  0.00%  0.00%   0 QOS Stats Gather
282           0           1          0  0.00%  0.00%  0.00%   0 Switch IP Admiss
283           0           2          0  0.00%  0.00%  0.00%   0 Switch IP Host T
284           4          33        121  0.00%  0.00%  0.00%   0 TCAM API Process
285           0           2          0  0.00%  0.00%  0.00%   0 REP Topology cha
286           0           1          0  0.00%  0.00%  0.00%   0 TC SIP
287           0           2          0  0.00%  0.00%  0.00%   0 IP PORTBUNDLE
288           0           1          0  0.00%  0.00%  0.00%   0 SG CMD HANDLER
289           8       18602          0  0.00%  0.00%  0.00%   0 IP Static Sessio
290           0           1          0  0.00%  0.00%  0.00%   0 RADIUS Proxy
291           0           1          0  0.00%  0.00%  0.00%   0 vaccess_lock_pro
292           0           1          0  0.00%  0.00%  0.00%   0 va_lock_ha_proce
293           0           1          0  0.00%  0.00%  0.00%   0 AC Switch
294           0           2          0  0.00%  0.00%  0.00%   0 OCE punted Pkts
295           0           1          0  0.00%  0.00%  0.00%   0 LSP Tunnel FRR
296           0           1          0  0.00%  0.00%  0.00%   0 MPLS Auto-Tunnel
297           4           1       4000  0.00%  0.00%  0.00%   0 O-UNI Client Msg
298           0           1          0  0.00%  0.00%  0.00%   0 IP Traceroute
299           0           1          0  0.00%  0.00%  0.00%   0 FRR Background P
300           0        1531          0  0.00%  0.00%  0.00%   0 CEF background p
301           0           2          0  0.00%  0.00%  0.00%   0 fib_fib_bfd_sb e
302           0           1          0  0.00%  0.00%  0.00%   0 IP IRDP
303           0           3          0  0.00%  0.00%  0.00%   0 XDR background p
304       13180       56877        231  0.00%  0.00%  0.00%   0 XDR mcast
305           0           1          0  0.00%  0.00%  0.00%   0 LSD HA Proc
306         428       13001         32  0.00%  0.00%  0.00%   0 IPC LC Message H
307           0           3          0  0.00%  0.00%  0.00%   0 XDR RP Ping Back
308          16        1274         12  0.00%  0.00%  0.00%   0 XDR RP backgroun
309           0           1          0  0.00%  0.00%  0.00%   0 XDR RP Test Back
310           4        1304          3  0.00%  0.00%  0.00%   0 IP Background
311         980          63      15555  0.00%  0.00%  0.00%   0 IP Connected Rou
312       22200        3683       6027  0.00%  0.00%  0.00%   0 IP RIB Update
313           0           1          0  0.00%  0.00%  0.00%   0 ACR HA
314           0           2          0  0.00%  0.00%  0.00%   0 ACR HA IPC flow
315           0           1          0  0.00%  0.00%  0.00%   0 ATM HA
316           0           2          0  0.00%  0.00%  0.00%   0 ATM HA IPC flow
317           0           1          0  0.00%  0.00%  0.00%   0 ATM HA ACR
318           0           3          0  0.00%  0.00%  0.00%   0 SNMP Timers
319           0           1          0  0.00%  0.00%  0.00%   0 CEM PROC
320           0           1          0  0.00%  0.00%  0.00%   0 CEM HA
321           0           1          0  0.00%  0.00%  0.00%   0 BFD HA
322          44       73980          0  0.00%  0.00%  0.00%   0 BGP Scheduler
323           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
324         156      108367          1  0.00%  0.00%  0.00%   0 CEF: IPv4 proces
325           0           6          0  0.00%  0.00%  0.00%   0 ADJ background
326           0           1          0  0.00%  0.00%  0.00%   0 RETRY_REPOPULATE
327           0           1          0  0.00%  0.00%  0.00%   0 Socket Timers
328           0           1          0  0.00%  0.00%  0.00%   0 FR HA
329         336      295864          1  0.00%  0.00%  0.00%   0 TCP Timer
330          68         117        581  0.00%  0.00%  0.00%   0 TCP Protocols
331           0         255          0  0.00%  0.00%  0.00%   0 HTTP CORE
332           0           2          0  0.00%  0.00%  0.00%   0 HSRP HA
333           0           1          0  0.00%  0.00%  0.00%   0 IDS Timer
334           0           1          0  0.00%  0.00%  0.00%   0 Inspect Timer
335           0           2          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
336           0         253          0  0.00%  0.00%  0.00%   0 MFIB Master back
337           0           2          0  0.00%  0.00%  0.00%   0 EEM ED CLI
338           0           2          0  0.00%  0.00%  0.00%   0 Multicast Offloa
339           0           2          0  0.00%  0.00%  0.00%   0 SCTP Main Proces
340           0           3          0  0.00%  0.00%  0.00%   0 IPv6 ACL RP Proc
341          20        7610          2  0.00%  0.00%  0.00%   0 QoS stats proces
342           0           1          0  0.00%  0.00%  0.00%   0 SLB CF process
343           0           2          0  0.00%  0.00%  0.00%   0 SLB Replicate IP
344           0           2          0  0.00%  0.00%  0.00%   0 VRRP HA
345           0           2          0  0.00%  0.00%  0.00%   0 MFI Comm RP Proc
346           0           1          0  0.00%  0.00%  0.00%   0 Path set broker
347           0           1          0  0.00%  0.00%  0.00%   0 LDP HA
348           0           2          0  0.00%  0.00%  0.00%   0 MPLS VPN HA Clie
349           0           1          0  0.00%  0.00%  0.00%   0 RSVP HA Services
350           0           2          0  0.00%  0.00%  0.00%   0 TSPTUN HA
351           0           1          0  0.00%  0.00%  0.00%   0 ac_atm_state_eve
352           0           1          0  0.00%  0.00%  0.00%   0 ATM HA AC
353           0           2          0  0.00%  0.00%  0.00%   0 BD MACSEC HA
354           0           2          0  0.00%  0.00%  0.00%   0 BD MACSEC HA
355           0           1          0  0.00%  0.00%  0.00%   0 CEM HA AC
356           0           2          0  0.00%  0.00%  0.00%   0 VTEMPLATE IPC fl
357           0           1          0  0.00%  0.00%  0.00%   0 XC RIB MGR
358           0           1          0  0.00%  0.00%  0.00%   0 CMFI VPN HA Proc
359           0           2          0  0.00%  0.00%  0.00%   0 L2X Switching Ev
360           0           1          0  0.00%  0.00%  0.00%   0 AAA HA
361           0           2          0  0.00%  0.00%  0.00%   0 ATIP_UDP_TSK
362           0           2          0  0.00%  0.00%  0.00%   0 PPP NBF
363           0           1          0  0.00%  0.00%  0.00%   0 Cv6 RP Process
364           0           2          0  0.00%  0.00%  0.00%   0 XDR FOF process
365           0           1          0  0.00%  0.00%  0.00%   0 HQF MSFC Event P
366           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Inp
367           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Res
368           0           1          0  0.00%  0.00%  0.00%   0 COPS
369           0           1          0  0.00%  0.00%  0.00%   0 802.1x Critical
370           0           1          0  0.00%  0.00%  0.00%   0 MAB Framework
371           0           2          0  0.00%  0.00%  0.00%   0 ECFM HA IPC flow
372           0           2          0  0.00%  0.00%  0.00%   0 EFP Errd
373         664       80053          8  0.00%  0.00%  0.00%   0 L3 Manager
374           0           4          0  0.00%  0.00%  0.00%   0 L3 Manager Commo
375         180      105941          1  0.00%  0.00%  0.00%   0 FM core
376           0           2          0  0.00%  0.00%  0.00%   0 GLBP HA
377           0           1          0  0.00%  0.00%  0.00%   0 Probe Input
378           0           1          0  0.00%  0.00%  0.00%   0 IMA HA
379           0           1          0  0.00%  0.00%  0.00%   0 MRIB RP Proxy
380           0           1          0  0.00%  0.00%  0.00%   0 RARP Input
381           0          21          0  0.00%  0.00%  0.00%   0 static
382          40       75262          0  0.00%  0.00%  0.00%   0 PfR BR Learn
383           0           1          0  0.00%  0.00%  0.00%   0 PAD InCall
384           0           2          0  0.00%  0.00%  0.00%   0 X.25 Background
385           0           1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
386           0           1          0  0.00%  0.00%  0.00%   0 CFIB RP process
387           0          10          0  0.00%  0.00%  0.00%   0 Const Rate Limit
388       77292       38104       2028  0.00%  0.05%  0.05%   0 HIDDEN VLAN Proc
389           0           1          0  0.00%  0.00%  0.00%   0 FR XDR manager
390           0           1          0  0.00%  0.00%  0.00%   0 CWAN LTL manager
391           4        1219          3  0.00%  0.00%  0.00%   0 CWAN-RP SCP Proc
392           8           9        888  0.00%  0.00%  0.00%   0 CWAN-RP SCP Inpu
393           0           1          0  0.00%  0.00%  0.00%   0 DHCP Snooping HA
394           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Counter
395           0           8          0  0.00%  0.00%  0.00%   0 IPHC RP Process
396           0           2          0  0.00%  0.00%  0.00%   0 L2TRACE SERVER
397           0           2          0  0.00%  0.00%  0.00%   0 CWPA QoS
398           0           2          0  0.00%  0.00%  0.00%   0 Const TCAM Mgr R
399           0           2          0  0.00%  0.00%  0.00%   0 MWAM_CONSOLE Tim
400           0           1          0  0.00%  0.00%  0.00%   0 Container Proces
401         356       18602         19  0.00%  0.00%  0.00%   0 IP SIP Process
402           0           2          0  0.00%  0.00%  0.00%   0 IP Inband Sessio
403           0           1          0  0.00%  0.00%  0.00%   0 Crypto PAS Proc
404           0           1          0  0.00%  0.00%  0.00%   0 Crypto HW Proc
405           0           4          0  0.00%  0.00%  0.00%   0 Inter Chassis Pr
406           8       15224          0  0.00%  0.00%  0.00%   0 LSD Main Proc
407           0           2          0  0.00%  0.00%  0.00%   0 LFDp Input Proc
408           0           2          0  0.00%  0.00%  0.00%   0 AAA Cached Serve
409           0           1          0  0.00%  0.00%  0.00%   0 EM Background Pr
410           0           2          0  0.00%  0.00%  0.00%   0 LOCAL AAA
411           0           2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
412           0           2          0  0.00%  0.00%  0.00%   0 LINE AAA
413        6000       20423        293  0.00%  0.00%  0.00%   0 BGP I/O
414           0           2          0  0.00%  0.00%  0.00%   0 TPLUS
415           0           1          0  0.00%  0.00%  0.00%   0 IDMGR CORE
416           0           4          0  0.00%  0.00%  0.00%   0 MPLS Auto Mesh P
417           4           2       2000  0.00%  0.00%  0.00%   0 Crypto Support
418           0          13          0  0.00%  0.00%  0.00%   0 crypto engine pr
419           0           1          0  0.00%  0.00%  0.00%   0 encrypt proc
420           0           7          0  0.00%  0.00%  0.00%   0 Crypto CA
421           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
422           0           1          0  0.00%  0.00%  0.00%   0 Crypto SSL
423           0           1          0  0.00%  0.00%  0.00%   0 QOS PERUSER
424           0           2          0  0.00%  0.00%  0.00%   0 PIM HA
425           0           1          0  0.00%  0.00%  0.00%   0  Laminar Icc Eve
426           0           2          0  0.00%  0.00%  0.00%   0 SLB Main CPU pro
427           0           2          0  0.00%  0.00%  0.00%   0 CRYPTO MAP FREE
428           4           4       1000  0.00%  0.00%  0.00%   0 Crypto ACL
429           0           1          0  0.00%  0.00%  0.00%   0 Crypto INT
430           0           3          0  0.00%  0.00%  0.00%   0 Crypto IKMP
431          24        3811          6  0.00%  0.00%  0.00%   0 IPSEC key engine
432           0           1          0  0.00%  0.00%  0.00%   0 IPSEC manual key
433           0           1          0  0.00%  0.00%  0.00%   0 Key Proc
434           0           2          0  0.00%  0.00%  0.00%   0 Lawful Intercept
435           0           2          0  0.00%  0.00%  0.00%   0 LI messaging
436           0           1          0  0.00%  0.00%  0.00%   0 LI C6K
437           0           1          0  0.00%  0.00%  0.00%   0 LI C6K PROV
438           0           1          0  0.00%  0.00%  0.00%   0 DATA Transfer Pr
439           0           1          0  0.00%  0.00%  0.00%   0 DATA Collector
440           0          59          0  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
441           0           9          0  0.00%  0.00%  0.00%   0 EEM ED Routing
442           0           9          0  0.00%  0.00%  0.00%   0 EEM ED Track
443           0          17          0  0.00%  0.00%  0.00%   0 EEM ED Resource
444           0           1          0  0.00%  0.00%  0.00%   0 L3MM Process
445           0           1          0  0.00%  0.00%  0.00%   0 Syslog Traps
446           0           6          0  0.00%  0.00%  0.00%   0 RPC aapi_rp
447           0          37          0  0.00%  0.00%  0.00%   0 RPC capi_rp
448           0           2          0  0.00%  0.00%  0.00%   0 RPC chapi_rp
449           0           6          0  0.00%  0.00%  0.00%   0 RPC dot1x_aaa_rp
450           0           2          0  0.00%  0.00%  0.00%   0 RPC ether_oam_sp
451           0           2          0  0.00%  0.00%  0.00%   0 RPC epld_sp2rp
452           0           2          0  0.00%  0.00%  0.00%   0 RPC gvrp_sp2rp
453           0           2          0  0.00%  0.00%  0.00%   0 RPC idbman_sp2mp
454           0           1          0  0.00%  0.00%  0.00%   0 LC Registry Expo
455        1260        9301        135  0.00%  0.00%  0.00%   0 RPC online_diag_
456           0           4          0  0.00%  0.00%  0.00%   0 RPC online_wan_d
457           0           2          0  0.00%  0.00%  0.00%   0 RPC pagp_switch_
458           0           7          0  0.00%  0.00%  0.00%   0 RPC pm_switch_sp
459           0           2          0  0.00%  0.00%  0.00%   0 RPC psecure_rp
460           0           2          0  0.00%  0.00%  0.00%   0 RPC pt_switch_sp
461           0           6          0  0.00%  0.00%  0.00%   0 RPC qnq_switch_s
462           0           2          0  0.00%  0.00%  0.00%   0 RPC rf_cli_sp2rp
463           0           1          0  0.00%  0.00%  0.00%   0 SONET Traps
465           0           2          0  0.00%  0.00%  0.00%   0 VTPMIB EDIT BUFF
466           0           2          0  0.00%  0.00%  0.00%   0 RPC snmp_notify
467           0           2          0  0.00%  0.00%  0.00%   0 RPC snmp_stackli
468           0           2          0  0.00%  0.00%  0.00%   0 RPC span_switch_
469           0           2          0  0.00%  0.00%  0.00%   0 RPC stp_sp2mp_ap
470       64552       75715        852  0.00%  0.00%  0.00%   0 OSPF-1 Router
471           0           2          0  0.00%  0.00%  0.00%   0 Module enable-di
472          16          28        571  0.00%  0.00%  0.00%   0 RPC c6k_power_rp
473           0          37          0  0.00%  0.00%  0.00%   0 RPC c6k_rp_envir
474           0           2          0  0.00%  0.00%  0.00%   0 RPC ecfmpal_rpc_
475           0           1          0  0.00%  0.00%  0.00%   0 CONST AFL
476           0           2          0  0.00%  0.00%  0.00%   0 RPC cwan_ltl_sp2
477           0       12623          0  0.00%  0.00%  0.00%   0 RP Error Detecti
478           0           2          0  0.00%  0.00%  0.00%   0 RPC error_detect
479           0           1          0  0.00%  0.00%  0.00%   0 HW Capacity ICC
480           0           2          0  0.00%  0.00%  0.00%   0 RPC itasca_rp
481           0           1          0  0.00%  0.00%  0.00%   0 RP L2 Applicatio
482           0           3          0  0.00%  0.00%  0.00%   0 LACP-MP Process
483           0          13          0  0.00%  0.00%  0.00%   0 Online Diag EEM
484           0           3          0  0.00%  0.00%  0.00%   0 PAgP-MP Process
485           0           2          0  0.00%  0.00%  0.00%   0 RPC pclc_g2_agsm
486           0           2          0  0.00%  0.00%  0.00%   0 RPC pclc_g2_fw_r
487           0          18          0  0.00%  0.00%  0.00%   0 Logger ICC Proce
488           0           2          0  0.00%  0.00%  0.00%   0 RPC pf_issu_sp2r
489           0           2          0  0.00%  0.00%  0.00%   0 RPC pikachu_rp
491           4          32        125  0.00%  0.00%  0.00%   0 RPC pm-mp
492           4       13898          0  0.00%  0.00%  0.00%   0 PM Callback
493        4320       77550         55  0.00%  0.00%  0.00%   0 Port manager per
494          16       15220          1  0.00%  0.00%  0.00%   0 Max CPU utilizat
495           0           6          0  0.00%  0.00%  0.00%   0 RPC lcc_sp
496           0           8          0  0.00%  0.00%  0.00%   0 RPC fabman_sp
497           0          23          0  0.00%  0.00%  0.00%   0 rp to lc clock u
498         520        4241        122  0.00%  0.00%  0.00%   0 SPA ENTITY Proce
499       42776       86442        494  0.00%  0.00%  0.00%   0 BGP Router
500           0           2          0  0.00%  0.00%  0.00%   0 SPAN Capture
501           0           3          0  0.00%  0.00%  0.00%   0 EC-Card-Cfg
502           0           2          0  0.00%  0.00%  0.00%   0 RPC sw_backup_in
503           0          22          0  0.00%  0.00%  0.00%   0 RPC sw_vlan_rp
504           0           4          0  0.00%  0.00%  0.00%   0 RPC udld_rp
505           0          14          0  0.00%  0.00%  0.00%   0 RPC vtp_const_ap
506           0           2          0  0.00%  0.00%  0.00%   0 RPC rep_sp2rp_ap
507           0           2          0  0.00%  0.00%  0.00%   0 RPC dot1ad_sp2mp
508           0           2          0  0.00%  0.00%  0.00%   0 Rommon upgrade p
509           0           2          0  0.00%  0.00%  0.00%   0 RPC mlacp_sp2mp
510           0           2          0  0.00%  0.00%  0.00%   0 ICRM
511           0           2          0  0.00%  0.00%  0.00%   0 RPC icrm_sp2rp
512           0           1          0  0.00%  0.00%  0.00%   0 ACR RP PROC
513           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Interface
514           0           2          0  0.00%  0.00%  0.00%   0 MRIB Process
515           0           2          0  0.00%  0.00%  0.00%   0 CWAN OIR IPC Rea
516          12        7603          1  0.00%  0.00%  0.00%   0 MFI LFD Stats Pr
517          16       14364          1  0.00%  0.00%  0.00%   0 MFI LFD Timer Pr
518           0           2          0  0.00%  0.00%  0.00%   0 MFI LFD Main Pro
519           4           1       4000  0.00%  0.00%  0.00%   0 PF Clock Process
520           0           3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
521           0           3          0  0.00%  0.00%  0.00%   0 EEM ED None
522           0           3          0  0.00%  0.00%  0.00%   0 EEM ED OIR
523           0           6          0  0.00%  0.00%  0.00%   0 EEM ED RF
524           0           3          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
525           0           2          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Noti
526           0        1923          0  0.00%  0.00%  0.00%   0 EEM ED Timer
527           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Ipsla
528           8           2       4000  0.00%  0.00%  0.00%   0 Call Home proces
529           0           1          0  0.00%  0.00%  0.00%   0 IP SLAs Ethernet
530           0           1          0  0.00%  0.00%  0.00%   0 IP SLA AutoEther
531           0           2          0  0.00%  0.00%  0.00%   0 EEM ED RPC
532           4         488          8  0.00%  0.00%  0.00%   0 DRMI Config Disp
533           4         142         28  0.00%  0.00%  0.00%   0 Syslog
534           0           4          0  0.00%  0.00%  0.00%   0 CWAN Bridge task
535           0           2          0  0.00%  0.00%  0.00%   0 QM MRM Process o
536           0           7          0  0.00%  0.00%  0.00%   0 QM Process on RP
537           0           2          0  0.00%  0.00%  0.00%   0 QM Reply Process
538           0           2          0  0.00%  0.00%  0.00%   0 QM Timer ACL Pro
539           4        6095          0  0.00%  0.00%  0.00%   0 DHCP Snooping Sw
540           0        1270          0  0.00%  0.00%  0.00%   0 Call Home Timer
541           0           2          0  0.00%  0.00%  0.00%   0 CONST PC POLICYM
542           0           1          0  0.00%  0.00%  0.00%   0 Online Diag CNS
543           0           1          0  0.00%  0.00%  0.00%   0 Online Diag CNS
544           0           3          0  0.00%  0.00%  0.00%   0 EM ED GOLD
545           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Test
546           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Config
547           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Env
548           0        1270          0  0.00%  0.00%  0.00%   0 VACL Logger
549           0           6          0  0.00%  0.00%  0.00%   0 REP RP Proc
550           0           2          0  0.00%  0.00%  0.00%   0 SIP10G QM Proces
551           4        3790          1  0.00%  0.00%  0.00%   0 IP SLA MPLSLM Pr
552     1716156        5215     329080  0.00%  1.06%  1.18%   0 BGP Scanner
553       23044       10246       2249  0.00%  0.00%  0.00%   0 BGP Task
554           0           3          0  0.00%  0.00%  0.00%   0 TCP Listener
555       31992      231276        138  0.00%  0.00%  0.00%   0 IP SNMP
556        6744      114886         58  0.00%  0.00%  0.00%   0 PDU DISPATCHER
557       67964      503483        134  0.00%  0.00%  0.00%   0 SNMP ENGINE
558           0           2          0  0.00%  0.00%  0.00%   0 IP SNMPV6
559           0           1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
560           0           2          0  0.00%  0.00%  0.00%   0 SNMP Traps
561       34256          92     372347  0.00%  0.00%  0.00%   0 BGP Event
562         740       25021         29  0.00%  0.00%  0.00%   0 OSPF-1 Hello
------------------ show process cpu history ------------------
      555555554444455555555554444466666444444444444444444444444444
      222111119999977777000008888822222888888888888888888889999988
  100
   90
   80
   70
   60              *****          *****
   50 **********************************************************
   40 **********************************************************
   30 **********************************************************
   20 **********************************************************
   10 **********************************************************
     0....5....1....1....2....2....3....3....4....4....5....5....6
               0    5    0    5    0    5    0    5    0    5    0
               CPU% per second (last 60 seconds)
      666677875666667666666667666766665777655555555445554555555556
      400288088455443867265472589442328254822222121883218244667870
  100
   90
   80     ****                          *
   70     *##*  **  **** ** ******     *##*
   60 ****####********#*****************###                 ****
   50 #####################################*******************##
   40 ##########################################################
   30 ##########################################################
   20 ##########################################################
   10 ##########################################################
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
                     1    1
      765554333399579099880
      569292853299525051200
  100           **  ***   *
   90           **  ****  *
   80 *         **  *#*****
   70 **        ** *####***
   60 *** *     ****####***
   50 #****     ***########
   40 ##******  ***########
   30 #####********########
   20 ######******#########
   10 ###########*#########
     0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
               0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
------------------ show file systems ------------------
File Systems:
       Size(b)       Free(b)      Type  Flags  Prefixes
             -             -    opaque     rw   system:
             -             -    opaque     rw   tmpsys:
             -             -    opaque     ro   flexwan-fpd:
*    978649088     936673280      disk     rw   disk0:
             -             -      disk     rw   disk1:
     518791168     191971328      disk     rw   sup-bootdisk:
     143064752             0    opaque     ro   sup-microcode:
             0     359259484    opaque     wo   sup-image:
        127212        126656     nvram     rw   const_nvram:
             -             -    opaque     rw   null:
             -             -    opaque     ro   tar:
             -             -   network     rw   tftp:
             -             -    opaque     wo   syslog:
       4059328       4052833     nvram     rw   nvram:
     518791168     375496704      disk     rw   bootdisk:#
             -             -   network     rw   rcp:
             -             -   network     rw   ftp:
             -             -   network     rw   http:
             -             -   network     rw   scp:
             -             -   network     rw   https:
             -             -    opaque     ro   cns:
------------------ show file descriptors ------------------
File Descriptors:
  No open file descriptors
------------------ show disk0: all ------------------
-#- --length-- -----date/time------ path
1     33554432 Jul 23 2012 14:18:36 +00:00 tftd
2     33554432 Jul 23 2012 14:21:14 +00:00 sea_log.dat
936673280 bytes available (41975808 bytes used)
******** ATA Flash Card Geometry/Format Info ********
ATA CARD GEOMETRY
   Manufacturer Name      Vendor
   Model Number           CF Card
   Serial Number          7DF707050F0700112420
   Firmware Revision      Ver5.00M
   Number of Heads        16
   Number of Cylinders    1897
   Sectors per Cylinder   63
   Sector Size            512
   Total Sectors          1912176
ATA PARTITION 1 INFO
   Start Sector           63
   Number of Sectors      1912113
   Size in Bytes          979001856
   File System Type       FAT16
   Number of FAT Sectors  234
   Sectors Per Cluster    32
   Number of Clusters     59732
   Number of Data Sectors 1911424
   Base FAT Sector        189
   Base Root Sector       657
   Base Data Sector       689
ATA MONLIB INFO
   Image Monlib size      92420
   Disk Monlib Size       92420
   Disk Space Available   96256
   Name                   rsp720-atafslib-m
   Start sector           2
   End sector             182
   Updated By             c7600rsp72043_sp-IPSERVICESK9-M12.2(33)SRE2
   Version                2
RFS VERSION :
Negotiated Version                  : 0
Highest version supported in Server : 0
Highest version supported in Client : 0
------------------ show sup-bootdisk: all ------------------
1     33554432 Jul 23 2012 16:35:32 +00:00 sea_log.dat
2    143294340 Sep 28 2012 22:07:22 +00:00 c7600rsp72043-ipservicesk9-mz.122-33.SRE2.bin
3    149969316 Jul 23 2012 16:05:36 +00:00 c7600rsp72043-adventerprisek9-mz.122-33.SRE6.bin
191971328 bytes available (326819840 bytes used)
ATA CARD GEOMETRY
   Manufacturer Name      SMART MODULAR TECH
   Model Number           SMART CF
   Serial Number          00001011510101683286
   Firmware Revision      20060811
   Number of Heads        16
   Number of Cylinders    1006
   Sector Size            512
   Total Sectors          1014048
   Start Sector           63
   Number of Sectors      1013985
   Size in Bytes          519160320
   Number of FAT Sectors  248
   Sectors Per Cluster    16
   Number of Clusters     63329
   Number of Data Sectors 1013264
   Base FAT Sector        189
   Base Root Sector       685
   Base Data Sector       717
ATA MONLIB INFO
   Start sector           2
   End sector             182
   Updated By             c7600rsp72043_sp-ADVIPSERVICESK9-M12.2(33)SRE1
   Version                2
RFS VERSION :
------------------ dir const_nvram: ------------------
Directory of const_nvram:/
    1  -rw-         556                      vlan.dat
127212 bytes total (126656 bytes free)
------------------ dir nvram: ------------------
Directory of nvram:/
3965  -rw-        3346                      startup-config
3966  ----          25                      private-config
3967  -rw-        3346                      underlying-config
    1  ----           0                      rf_cold_starts
    2  ----         206                      persistent-data
    3  -rw-           0                      ifIndex-table
4059328 bytes total (4052833 bytes free)
------------------ show bootdisk: all ------------------
1    143294340 Aug 25 2012 04:39:50 +00:00 c7600rsp72043-ipservicesk9-mz.122-33.SRE2.bin
375496704 bytes available (143294464 bytes used)
ATA CARD GEOMETRY
   Serial Number          00001011510101683267
   Number of Heads        16
   Sector Size            512
   Start Sector           63
   Base FAT Sector        189
ATA MONLIB INFO
   Start sector           2
   End sector             182
   Updated By             c7600rsp72043_rp-ADVIPSERVICESK9-M12.2(33)SRE1
   Version                2
------------------ show redundancy ------------------
Redundant System Information :
       Available system uptime = 21 hours, 11 minutes
Switchovers system experienced = 0
              Standby failures = 0
        Last switchover reason = none
                 Hardware Mode = Simplex
    Configured Redundancy Mode = sso
     Operating Redundancy Mode = sso
              Maintenance Mode = Disabled
                Communications = Down      Reason: Simplex mode
Current Processor Information :
               Active Location = slot 5
        Current Software state = ACTIVE
       Uptime in current state = 21 hours, 10 minutes
                 Image Version = Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRE6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 15-Mar-12 05:31 by prod_rel_team
                          BOOT = sup-bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRE6.bin,1;
                   CONFIG_FILE =
                       BOOTLDR =
        Configuration register = 0x2102
Peer (slot: unavailable) information is not available because it is in 'DISABLED' state
------------------ show redundancy history ------------------
00:00:00 client added: RF_INTERNAL_MSG(0) seq=0
00:00:00 client added: RF_LAST_CLIENT(65000) seq=379
00:00:00 RF_STATUS_SEND_RF_STATE(408) RF_LAST_CLIENT(65000) op=1 rc=0
00:00:02 client added: ISSU process(3099) seq=324
00:00:02 RF_STATUS_SEND_RF_STATE(408) ISSU process(3099) op=1 rc=0
00:00:02 client added: Force RPR(3200) seq=64
00:00:02 RF_STATUS_SEND_RF_STATE(408) Force RPR(3200) op=1 rc=0
00:00:02 client added: Cat6k Startup Config Sync(1301) seq=192
00:00:02 RF_STATUS_SEND_RF_STATE(408) Cat6k Startup Config Sync(1301) op=1 rc=0
00:00:02 client added: C6K/7600 penultimate client(1356) seq=349
00:00:02 RF_STATUS_SEND_RF_STATE(408) C6K/7600 penultimate client(1356) op=1 rc=0
00:00:02 client added: REP Protocol(212) seq=287
00:00:02 RF_STATUS_SEND_RF_STATE(408) REP Protocol(212) op=1 rc=0
00:00:02 client added: Persistent Variable(3300) seq=62
00:00:02 RF_STATUS_SEND_RF_STATE(408) Persistent Variable(3300) op=1 rc=0
00:00:02 client added: DATA DESCRIPTOR RF CLIENT(141) seq=341
00:00:02 client added: CHKPT RF(25) seq=68
00:00:02 RF_STATUS_SEND_RF_STATE(408) CHKPT RF(25) op=1 rc=0
00:00:02 client added: Event Manager(77) seq=77
00:00:02 RF_STATUS_SEND_RF_STATE(408) Event Manager(77) op=1 rc=0
00:00:02 client added: Cat6k CAPI(1317) seq=266
00:00:02 RF_STATUS_SEND_RF_STATE(408) Cat6k CAPI(1317) op=1 rc=0
00:00:04 client added: LAN-Switch Private Vlan(511) seq=335
00:00:04 RF_STATUS_SEND_RF_STATE(408) LAN-Switch Private Vlan(511) op=1 rc=0
00:00:04 client added: LAN-Switch Port Manager(502) seq=155
00:00:04 RF_STATUS_SEND_RF_STATE(408) LAN-Switch Port Manager(502) op=1 rc=0
00:00:04 client added: PM SP client(1321) seq=336
00:00:04 RF_STATUS_SEND_RF_STATE(408) PM SP client(1321) op=1 rc=0
00:00:04 client added: TABLEID FOF SP(1511) seq=114
00:00:04 RF_STATUS_SEND_RF_STATE(408) TABLEID FOF SP(1511) op=1 rc=0
00:00:04 client added: Switch SPAN client(504) seq=284
00:00:04 RF_STATUS_SEND_RF_STATE(408) Switch SPAN client(504) op=1 rc=0
00:00:04 client added: Cat6k Power(1318) seq=159
00:00:04 RF_STATUS_SEND_RF_STATE(408) Cat6k Power(1318) op=1 rc=0
00:00:04 client added: Cat6k Fabric Manager(1302) seq=81
00:00:04 RF_STATUS_SEND_RF_STATE(408) Cat6k Fabric Manager(1302) op=1 rc=0
00:00:04 client added: Cat6k Platform First Client(1319) seq=1
00:00:04 RF_STATUS_SEND_RF_STATE(408) Cat6k Platform First Client(1319) op=1 rc=0
00:00:04 client added: Cat6k Platform(1313) seq=158
00:00:04 RF_STATUS_SEND_RF_STATE(408) Cat6k Platform(1313) op=1 rc=0
00:00:04 client added: Cat6k Clear counter(1315) seq=339
00:00:04 RF_STATUS_SEND_RF_STATE(408) Cat6k Clear counter(1315) op=1 rc=0
00:00:04 client added: Cat6k OIR(1303) seq=84
00:00:04 RF_STATUS_SEND_RF_STATE(408) Cat6k OIR(1303) op=1 rc=0
00:00:04 client added: Cat6k IDPROM(1307) seq=194
00:00:04 RF_STATUS_SEND_RF_STATE(408) Cat6k IDPROM(1307) op=1 rc=0
00:00:04 client added: MCM(3100) seq=73
00:00:04 RF_STATUS_SEND_RF_STATE(408) MCM(3100) op=1 rc=0
00:00:04 client added: PF_UCODE(1330) seq=72
00:00:04 RF_STATUS_SEND_RF_STATE(408) PF_UCODE(1330) op=1 rc=0
00:00:04 client added: REP SP client(1355) seq=286
00:00:04 RF_STATUS_SEND_RF_STATE(408) REP SP client(1355) op=1 rc=0
00:00:04 client added: IOS Config ARCHIVE(4020) seq=366
00:00:04 RF_STATUS_SEND_RF_STATE(408) IOS Config ARCHIVE(4020) op=1 rc=0
00:00:04 client added: IOS Config ROLLBACK(4021) seq=367
00:00:04 RF_STATUS_SEND_RF_STATE(408) IOS Config ROLLBACK(4021) op=1 rc=0
00:00:04 client added: LAN-Switch VTP VLAN(501) seq=122
00:00:04 RF_STATUS_SEND_RF_STATE(408) LAN-Switch VTP VLAN(501) op=1 rc=0
00:00:04 client added: LAN-Switch PAgP/LACP(510) seq=334
00:00:04 RF_STATUS_SEND_RF_STATE(408) LAN-Switch PAgP/LACP(510) op=1 rc=0
00:00:04 client added: Cat6k PAgP/LACP(1305) seq=261
00:00:04 RF_STATUS_SEND_RF_STATE(408) Cat6k PAgP/LACP(1305) op=1 rc=0
00:00:04 client added: VLAN Mapping(1322) seq=337
00:00:04 RF_STATUS_SEND_RF_STATE(408) VLAN Mapping(1322) op=1 rc=0
00:00:04 *my state = INITIALIZATION(2) *peer state = DISABLED(1)
00:00:04 RF_PROG_INITIALIZATION(100) RF_INTERNAL_MSG(0) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k Platform First Client(1319) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Persistent Variable(3300) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Force RPR(3200) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) CHKPT RF(25) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) PF_UCODE(1330) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) MCM(3100) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Event Manager(77) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k Fabric Manager(1302) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k OIR(1303) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) TABLEID FOF SP(1511) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) LAN-Switch VTP VLAN(501) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) LAN-Switch Port Manager(502) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k Platform(1313) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k Power(1318) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k Startup Config Sync(1301) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k IDPROM(1307) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k PAgP/LACP(1305) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k CAPI(1317) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Switch SPAN client(504) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) REP SP client(1355) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) REP Protocol(212) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) ISSU process(3099) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) LAN-Switch Private Vlan(511) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) PM SP client(1321) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) VLAN Mapping(1322) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) Cat6k Clear counter(1315) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) C6K/7600 penultimate client(1356) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) IOS Config ARCHIVE(4020) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) IOS Config ROLLBACK(4021) op=0 rc=11
00:00:04 RF_PROG_INITIALIZATION(100) RF_LAST_CLIENT(65000) op=0 rc=11
00:00:04 *my state = NEGOTIATION(3) peer state = DISABLED(1)
00:00:32 client added: Config Sync RF client(5006) seq=146
00:00:32 RF_STATUS_SEND_RF_STATE(408) Config Sync RF client(5006) op=3 rc=0
00:00:32 client added: Network RF Client(5023) seq=101
00:00:32 RF_STATUS_SEND_RF_STATE(408) Network RF Client(5023) op=3 rc=0
00:00:32 client added: CEF RRP RF Client(5025) seq=125
00:00:32 RF_STATUS_SEND_RF_STATE(408) CEF RRP RF Client(5025) op=3 rc=0
00:00:32 client added: CHKPT RF(5026) seq=68
00:00:32 RF_STATUS_SEND_RF_STATE(408) CHKPT RF(5026) op=3 rc=0
00:00:32 client added: Redundancy Mode RF(5030) seq=60
00:00:32 RF_STATUS_SEND_RF_STATE(408) Redundancy Mode RF(5030) op=3 rc=0
00:00:32 client added: SNMP RF Client(5035) seq=200
00:00:32 RF_STATUS_SEND_RF_STATE(408) SNMP RF Client(5035) op=3 rc=0
00:00:32 client added: History RF Client(5036) seq=210
00:00:32 RF_STATUS_SEND_RF_STATE(408) History RF Client(5036) op=3 rc=0
00:00:32 client added: ARP(5058) seq=241
00:00:32 RF_STATUS_SEND_RF_STATE(408) ARP(5058) op=3 rc=0
00:00:32 client added: XDR RRP RF Client(5072) seq=124
00:00:32 RF_STATUS_SEND_RF_STATE(408) XDR RRP RF Client(5072) op=3 rc=0
00:00:32 client added: Event Manager(5078) seq=77
00:00:32 RF_STATUS_SEND_RF_STATE(408) Event Manager(5078) op=3 rc=0
00:00:32 client added: SLB RF Client(5088) seq=281
00:00:32 RF_STATUS_SEND_RF_STATE(408) SLB RF Client(5088) op=3 rc=0
00:00:32 client added: Network RF 2 Client(5094) seq=331
00:00:32 RF_STATUS_SEND_RF_STATE(408) Network RF 2 Client(5094) op=3 rc=0
00:00:32 client added: Config Verify RF client(5095) seq=300
00:00:32 RF_STATUS_SEND_RF_STATE(408) Config Verify RF client(5095) op=3 rc=0
00:00:32 client added: DHCPC(5101) seq=187
00:00:32 RF_STATUS_SEND_RF_STATE(408) DHCPC(5101) op=3 rc=0
00:00:32 client added: DHCPD(5102) seq=188
00:00:32 RF_STATUS_SEND_RF_STATE(408) DHCPD(5102) op=3 rc=0
00:00:32 client added: MQC QoS(5103) seq=292
00:00:32 RF_STATUS_SEND_RF_STATE(408) MQC QoS(5103) op=3 rc=0
00:00:32 client added: MWAM RF Client(5104) seq=290
00:00:32 RF_STATUS_SEND_RF_STATE(408) MWAM RF Client(5104) op=3 rc=0
00:00:32 client added: SAMI RF Client(5105) seq=291
00:00:32 RF_STATUS_SEND_RF_STATE(408) SAMI RF Client(5105) op=3 rc=0
00:00:32 client added: CRYPTO RSA(5131) seq=313
00:00:32 RF_STATUS_SEND_RF_STATE(408) CRYPTO RSA(5131) op=3 rc=0
00:00:32 client added: IKE RF Client(5136) seq=311
00:00:32 RF_STATUS_SEND_RF_STATE(408) IKE RF Client(5136) op=3 rc=0
00:00:32 client added: IPSEC RF Client(5137) seq=312
00:00:32 RF_STATUS_SEND_RF_STATE(408) IPSEC RF Client(5137) op=3 rc=0
00:00:32 client added: IfIndex(5140) seq=61
00:00:32 RF_STATUS_SEND_RF_STATE(408) IfIndex(5140) op=3 rc=0
00:00:32 client added: DATA DESCRIPTOR RF CLIENT(5142) seq=341
00:00:32 RF_STATUS_SEND_RF_STATE(408) DATA DESCRIPTOR RF CLIENT(5142) op=3 rc=0
00:00:32 client added: DHCPv6 Relay(5149) seq=318
00:00:32 RF_STATUS_SEND_RF_STATE(408) DHCPv6 Relay(5149) op=3 rc=0
00:00:32 client added: IP Tunnel RF(5152) seq=299
00:00:32 RF_STATUS_SEND_RF_STATE(408) IP Tunnel RF(5152) op=3 rc=0
00:00:32 client added: MFIB RRP RF Client(5307) seq=133
00:00:32 RF_STATUS_SEND_RF_STATE(408) MFIB RRP RF Client(5307) op=3 rc=0
00:00:32 client added: LAN-Switch IP Host Table(5510) seq=306
00:00:32 RF_STATUS_SEND_RF_STATE(408) LAN-Switch IP Host Table(5510) op=3 rc=0
00:00:32 client added: Cat6k Startup Config Sync(6302) seq=192
00:00:32 RF_STATUS_SEND_RF_STATE(408) Cat6k Startup Config Sync(6302) op=3 rc=0
00:00:32 client added: Cat6k Platform(6314) seq=158
00:00:32 RF_STATUS_SEND_RF_STATE(408) Cat6k Platform(6314) op=3 rc=0
00:00:32 client added: Cat6k Clear counter(6316) seq=339
00:00:32 RF_STATUS_SEND_RF_STATE(408) Cat6k Clear counter(6316) op=3 rc=0
00:00:32 client added: Cat6k PF_ML_RP(6321) seq=332
00:00:32 RF_STATUS_SEND_RF_STATE(408) Cat6k PF_ML_RP(6321) op=3 rc=0
00:00:32 client added: Cat6k CWAN HA(6502) seq=94
00:00:32 RF_STATUS_SEND_RF_STATE(408) Cat6k CWAN HA(6502) op=3 rc=0
00:00:32 client added: CWAN APS HA RF Client(6503) seq=201
00:00:32 RF_STATUS_SEND_RF_STATE(408) CWAN APS HA RF Client(6503) op=3 rc=0
00:00:32 client added: CWAN VLAN RF Client(6504) seq=95
00:00:32 RF_STATUS_SEND_RF_STATE(408) CWAN VLAN RF Client(6504) op=3 rc=0
00:00:32 client added: Cat6k CWAN Interface Events(6505) seq=140
00:00:32 RF_STATUS_SEND_RF_STATE(408) Cat6k CWAN Interface Events(6505) op=3 rc=0
00:00:32 client added: Cat6k SPA TSM(6506) seq=107
00:00:32 RF_STATUS_SEND_RF_STATE(408) Cat6k SPA TSM(6506) op=3 rc=0
00:00:32 client added: CWAN SRP RF Client(6507) seq=267
00:00:32 RF_STATUS_SEND_RF_STATE(408) CWAN SRP RF Client(6507) op=3 rc=0
00:00:32 client added: CWAN LTL Mgr HA RF Client(6508) seq=141
00:00:32 RF_STATUS_SEND_RF_STATE(408) CWAN LTL Mgr HA RF Client(6508) op=3 rc=0
00:00:32 client added: TABLEID FOF RP(6513) seq=115
00:00:32 RF_STATUS_SEND_RF_STATE(408) TABLEID FOF RP(6513) op=3 rc=0
00:00:32 client added: ISSU Test Client(9006) seq=327
00:00:32 RF_STATUS_SEND_RF_STATE(408) ISSU Test Client(9006) op=3 rc=0
00:00:32 client added: IOS Config ARCHIVE(9021) seq=366
00:00:32 RF_STATUS_SEND_RF_STATE(408) IOS Config ARCHIVE(9021) op=3 rc=0
00:00:32 client added: IOS Config ROLLBACK(9022) seq=367
00:00:32 RF_STATUS_SEND_RF_STATE(408) IOS Config ROLLBACK(9022) op=3 rc=0
00:00:33 RF_EVENT_GO_ACTIVE(512) op=0 rc=0
00:00:33 *my state = ACTIVE-FAST(9) peer state = DISABLED(1)
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Platform First Client(1319) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Redundancy Mode RF(5030) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) IfIndex(5140) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Persistent Variable(3300) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Force RPR(3200) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) CHKPT RF(25) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) CHKPT RF(5026) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) PF_UCODE(1330) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) MCM(3100) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Event Manager(77) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Event Manager(5078) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Fabric Manager(1302) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k OIR(1303) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k CWAN HA(6502) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) CWAN VLAN RF Client(6504) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Network RF Client(5023) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k SPA TSM(6506) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) TABLEID FOF SP(1511) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) TABLEID FOF RP(6513) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) LAN-Switch VTP VLAN(501) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) XDR RRP RF Client(5072) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) CEF RRP RF Client(5025) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) MFIB RRP RF Client(5307) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k CWAN Interface Events(6505) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) CWAN LTL Mgr HA RF Client(6508) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Config Sync RF client(5006) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) LAN-Switch Port Manager(502) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Platform(1313) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Platform(6314) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Power(1318) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) DHCPC(5101) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) DHCPD(5102) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Startup Config Sync(1301) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Startup Config Sync(6302) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k IDPROM(1307) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) SNMP RF Client(5035) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) CWAN APS HA RF Client(6503) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) History RF Client(5036) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) ARP(5058) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k PAgP/LACP(1305) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k CAPI(1317) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) CWAN SRP RF Client(6507) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) SLB RF Client(5088) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Switch SPAN client(504) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) REP SP client(1355) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) REP Protocol(212) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) MWAM RF Client(5104) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) SAMI RF Client(5105) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) MQC QoS(5103) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) IP Tunnel RF(5152) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Config Verify RF client(5095) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) LAN-Switch IP Host Table(5510) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) IKE RF Client(5136) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) IPSEC RF Client(5137) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) CRYPTO RSA(5131) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) DHCPv6 Relay(5149) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) ISSU process(3099) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) ISSU Test Client(9006) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Network RF 2 Client(5094) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k PF_ML_RP(6321) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) LAN-Switch PAgP/LACP(510) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) LAN-Switch Private Vlan(511) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) PM SP client(1321) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) VLAN Mapping(1322) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Clear counter(1315) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) Cat6k Clear counter(6316) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) DATA DESCRIPTOR RF CLIENT(5142) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) C6K/7600 penultimate client(1356) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) IOS Config ARCHIVE(4020) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) IOS Config ARCHIVE(9021) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) IOS Config ROLLBACK(4021) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) IOS Config ROLLBACK(9022) op=0 rc=0
00:00:33 RF_STATUS_MAINTENANCE_ENABLE(403) RF_LAST_CLIENT(65000) op=0 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) RF_INTERNAL_MSG(0) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Platform First Client(1319) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Redundancy Mode RF(5030) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Redundancy Mode RF(5030) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) IfIndex(5140) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IfIndex(5140) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Persistent Variable(3300) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Force RPR(3200) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) CHKPT RF(25) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) CHKPT RF(5026) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CHKPT RF(5026) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) PF_UCODE(1330) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) MCM(3100) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Event Manager(77) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Event Manager(5078) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Event Manager(5078) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Fabric Manager(1302) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k OIR(1303) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k CWAN HA(6502) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN HA(6502) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) CWAN VLAN RF Client(6504) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN VLAN RF Client(6504) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Network RF Client(5023) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF Client(5023) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k SPA TSM(6506) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k SPA TSM(6506) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) TABLEID FOF SP(1511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) TABLEID FOF RP(6513) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) TABLEID FOF RP(6513) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) LAN-Switch VTP VLAN(501) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) XDR RRP RF Client(5072) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) XDR RRP RF Client(5072) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) CEF RRP RF Client(5025) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CEF RRP RF Client(5025) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) MFIB RRP RF Client(5307) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MFIB RRP RF Client(5307) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k CWAN Interface Events(6505) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN Interface Events(6505) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) CWAN LTL Mgr HA RF Client(6508) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN LTL Mgr HA RF Client(6508) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Config Sync RF client(5006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Sync RF client(5006) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) LAN-Switch Port Manager(502) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Platform(1313) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Platform(6314) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Platform(6314) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Power(1318) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) DHCPC(5101) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPC(5101) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) DHCPD(5102) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPD(5102) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Startup Config Sync(1301) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Startup Config Sync(6302) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Startup Config Sync(6302) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k IDPROM(1307) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) SNMP RF Client(5035) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SNMP RF Client(5035) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) CWAN APS HA RF Client(6503) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN APS HA RF Client(6503) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) History RF Client(5036) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) History RF Client(5036) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) ARP(5058) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ARP(5058) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k PAgP/LACP(1305) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k CAPI(1317) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) CWAN SRP RF Client(6507) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN SRP RF Client(6507) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) SLB RF Client(5088) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SLB RF Client(5088) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Switch SPAN client(504) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) REP SP client(1355) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) REP Protocol(212) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) MWAM RF Client(5104) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MWAM RF Client(5104) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) SAMI RF Client(5105) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SAMI RF Client(5105) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) MQC QoS(5103) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MQC QoS(5103) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) IP Tunnel RF(5152) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IP Tunnel RF(5152) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Config Verify RF client(5095) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Verify RF client(5095) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) LAN-Switch IP Host Table(5510) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) LAN-Switch IP Host Table(5510) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) IKE RF Client(5136) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IKE RF Client(5136) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) IPSEC RF Client(5137) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IPSEC RF Client(5137) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) CRYPTO RSA(5131) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CRYPTO RSA(5131) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) DHCPv6 Relay(5149) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPv6 Relay(5149) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) ISSU process(3099) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) ISSU Test Client(9006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ISSU Test Client(9006) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Network RF 2 Client(5094) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF 2 Client(5094) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k PF_ML_RP(6321) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k PF_ML_RP(6321) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) LAN-Switch Private Vlan(511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) PM SP client(1321) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) VLAN Mapping(1322) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Clear counter(1315) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) Cat6k Clear counter(6316) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Clear counter(6316) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) DATA DESCRIPTOR RF CLIENT(5142) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DATA DESCRIPTOR RF CLIENT(5142) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) C6K/7600 penultimate client(1356) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) IOS Config ARCHIVE(4020) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) IOS Config ARCHIVE(9021) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ARCHIVE(9021) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) IOS Config ROLLBACK(4021) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_FAST(200) IOS Config ROLLBACK(9022) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ROLLBACK(9022) op=200 rc=0
00:00:33 RF_PROG_ACTIVE_FAST(200) RF_LAST_CLIENT(65000) op=0 rc=11
00:00:33 *my state = ACTIVE-DRAIN(10) peer state = DISABLED(1)
00:00:33 RF_PROG_ACTIVE_DRAIN(201) RF_INTERNAL_MSG(0) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Platform First Client(1319) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Redundancy Mode RF(5030) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Redundancy Mode RF(5030) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) IfIndex(5140) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IfIndex(5140) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Persistent Variable(3300) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Force RPR(3200) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) CHKPT RF(25) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) CHKPT RF(5026) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CHKPT RF(5026) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) PF_UCODE(1330) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) MCM(3100) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Event Manager(77) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Event Manager(5078) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Event Manager(5078) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Fabric Manager(1302) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k OIR(1303) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k CWAN HA(6502) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN HA(6502) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) CWAN VLAN RF Client(6504) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN VLAN RF Client(6504) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Network RF Client(5023) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF Client(5023) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k SPA TSM(6506) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k SPA TSM(6506) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) TABLEID FOF SP(1511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) TABLEID FOF RP(6513) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) TABLEID FOF RP(6513) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) LAN-Switch VTP VLAN(501) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) XDR RRP RF Client(5072) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) XDR RRP RF Client(5072) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) CEF RRP RF Client(5025) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CEF RRP RF Client(5025) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) MFIB RRP RF Client(5307) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MFIB RRP RF Client(5307) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k CWAN Interface Events(6505) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN Interface Events(6505) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) CWAN LTL Mgr HA RF Client(6508) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN LTL Mgr HA RF Client(6508) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Config Sync RF client(5006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Sync RF client(5006) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) LAN-Switch Port Manager(502) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Platform(1313) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Platform(6314) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Platform(6314) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Power(1318) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) DHCPC(5101) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPC(5101) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) DHCPD(5102) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPD(5102) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Startup Config Sync(1301) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Startup Config Sync(6302) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Startup Config Sync(6302) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k IDPROM(1307) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) SNMP RF Client(5035) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SNMP RF Client(5035) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) CWAN APS HA RF Client(6503) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN APS HA RF Client(6503) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) History RF Client(5036) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) History RF Client(5036) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) ARP(5058) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ARP(5058) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k PAgP/LACP(1305) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k CAPI(1317) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) CWAN SRP RF Client(6507) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN SRP RF Client(6507) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) SLB RF Client(5088) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SLB RF Client(5088) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Switch SPAN client(504) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) REP SP client(1355) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) REP Protocol(212) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) MWAM RF Client(5104) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MWAM RF Client(5104) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) SAMI RF Client(5105) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SAMI RF Client(5105) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) MQC QoS(5103) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MQC QoS(5103) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) IP Tunnel RF(5152) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IP Tunnel RF(5152) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Config Verify RF client(5095) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Verify RF client(5095) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) LAN-Switch IP Host Table(5510) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) LAN-Switch IP Host Table(5510) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) IKE RF Client(5136) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IKE RF Client(5136) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) IPSEC RF Client(5137) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IPSEC RF Client(5137) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) CRYPTO RSA(5131) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CRYPTO RSA(5131) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) DHCPv6 Relay(5149) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPv6 Relay(5149) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) ISSU process(3099) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) ISSU Test Client(9006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ISSU Test Client(9006) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Network RF 2 Client(5094) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF 2 Client(5094) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k PF_ML_RP(6321) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k PF_ML_RP(6321) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) LAN-Switch Private Vlan(511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) PM SP client(1321) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) VLAN Mapping(1322) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Clear counter(1315) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) Cat6k Clear counter(6316) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Clear counter(6316) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) DATA DESCRIPTOR RF CLIENT(5142) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DATA DESCRIPTOR RF CLIENT(5142) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) C6K/7600 penultimate client(1356) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) IOS Config ARCHIVE(4020) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) IOS Config ARCHIVE(9021) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ARCHIVE(9021) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) IOS Config ROLLBACK(4021) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_DRAIN(201) IOS Config ROLLBACK(9022) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ROLLBACK(9022) op=201 rc=0
00:00:33 RF_PROG_ACTIVE_DRAIN(201) RF_LAST_CLIENT(65000) op=0 rc=11
00:00:33 *my state = ACTIVE_PRECONFIG(11) peer state = DISABLED(1)
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) RF_INTERNAL_MSG(0) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Platform First Client(1319) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Redundancy Mode RF(5030) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Redundancy Mode RF(5030) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IfIndex(5140) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IfIndex(5140) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Persistent Variable(3300) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Force RPR(3200) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CHKPT RF(25) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CHKPT RF(5026) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CHKPT RF(5026) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) PF_UCODE(1330) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) MCM(3100) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Event Manager(77) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Event Manager(5078) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Event Manager(5078) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Fabric Manager(1302) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k OIR(1303) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k CWAN HA(6502) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN HA(6502) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CWAN VLAN RF Client(6504) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN VLAN RF Client(6504) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Network RF Client(5023) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF Client(5023) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k SPA TSM(6506) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k SPA TSM(6506) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) TABLEID FOF SP(1511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) TABLEID FOF RP(6513) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) TABLEID FOF RP(6513) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) LAN-Switch VTP VLAN(501) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) XDR RRP RF Client(5072) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) XDR RRP RF Client(5072) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CEF RRP RF Client(5025) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CEF RRP RF Client(5025) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) MFIB RRP RF Client(5307) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MFIB RRP RF Client(5307) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k CWAN Interface Events(6505) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN Interface Events(6505) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CWAN LTL Mgr HA RF Client(6508) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN LTL Mgr HA RF Client(6508) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Config Sync RF client(5006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Sync RF client(5006) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) LAN-Switch Port Manager(502) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Platform(1313) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Platform(6314) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Platform(6314) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Power(1318) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) DHCPC(5101) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPC(5101) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) DHCPD(5102) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPD(5102) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Startup Config Sync(1301) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Startup Config Sync(6302) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Startup Config Sync(6302) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k IDPROM(1307) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) SNMP RF Client(5035) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SNMP RF Client(5035) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CWAN APS HA RF Client(6503) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN APS HA RF Client(6503) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) History RF Client(5036) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) History RF Client(5036) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) ARP(5058) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ARP(5058) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k PAgP/LACP(1305) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k CAPI(1317) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CWAN SRP RF Client(6507) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN SRP RF Client(6507) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) SLB RF Client(5088) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SLB RF Client(5088) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Switch SPAN client(504) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) REP SP client(1355) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) REP Protocol(212) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) MWAM RF Client(5104) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MWAM RF Client(5104) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) SAMI RF Client(5105) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SAMI RF Client(5105) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) MQC QoS(5103) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MQC QoS(5103) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IP Tunnel RF(5152) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IP Tunnel RF(5152) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Config Verify RF client(5095) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Verify RF client(5095) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) LAN-Switch IP Host Table(5510) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) LAN-Switch IP Host Table(5510) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IKE RF Client(5136) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IKE RF Client(5136) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IPSEC RF Client(5137) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IPSEC RF Client(5137) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CRYPTO RSA(5131) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CRYPTO RSA(5131) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) DHCPv6 Relay(5149) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPv6 Relay(5149) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) ISSU process(3099) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) ISSU Test Client(9006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ISSU Test Client(9006) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Network RF 2 Client(5094) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF 2 Client(5094) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k PF_ML_RP(6321) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k PF_ML_RP(6321) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) LAN-Switch Private Vlan(511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) PM SP client(1321) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) VLAN Mapping(1322) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Clear counter(1315) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Cat6k Clear counter(6316) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Clear counter(6316) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) DATA DESCRIPTOR RF CLIENT(5142) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DATA DESCRIPTOR RF CLIENT(5142) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) C6K/7600 penultimate client(1356) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IOS Config ARCHIVE(4020) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IOS Config ARCHIVE(9021) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ARCHIVE(9021) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IOS Config ROLLBACK(4021) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IOS Config ROLLBACK(9022) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ROLLBACK(9022) op=202 rc=0
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) RF_LAST_CLIENT(65000) op=0 rc=11
00:00:33 *my state = ACTIVE_POSTCONFIG(12) peer state = DISABLED(1)
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) RF_INTERNAL_MSG(0) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Platform First Client(1319) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Redundancy Mode RF(5030) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Redundancy Mode RF(5030) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IfIndex(5140) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IfIndex(5140) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Persistent Variable(3300) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Force RPR(3200) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CHKPT RF(25) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CHKPT RF(5026) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CHKPT RF(5026) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) PF_UCODE(1330) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) MCM(3100) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Event Manager(77) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Event Manager(5078) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Event Manager(5078) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Fabric Manager(1302) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k OIR(1303) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k CWAN HA(6502) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN HA(6502) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CWAN VLAN RF Client(6504) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN VLAN RF Client(6504) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Network RF Client(5023) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF Client(5023) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k SPA TSM(6506) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k SPA TSM(6506) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) TABLEID FOF SP(1511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) TABLEID FOF RP(6513) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) TABLEID FOF RP(6513) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) LAN-Switch VTP VLAN(501) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) XDR RRP RF Client(5072) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) XDR RRP RF Client(5072) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CEF RRP RF Client(5025) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CEF RRP RF Client(5025) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) MFIB RRP RF Client(5307) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MFIB RRP RF Client(5307) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k CWAN Interface Events(6505) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN Interface Events(6505) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CWAN LTL Mgr HA RF Client(6508) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN LTL Mgr HA RF Client(6508) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Config Sync RF client(5006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Sync RF client(5006) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) LAN-Switch Port Manager(502) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Platform(1313) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Platform(6314) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Platform(6314) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Power(1318) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) DHCPC(5101) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPC(5101) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) DHCPD(5102) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPD(5102) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Startup Config Sync(1301) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Startup Config Sync(6302) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Startup Config Sync(6302) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k IDPROM(1307) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) SNMP RF Client(5035) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SNMP RF Client(5035) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CWAN APS HA RF Client(6503) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN APS HA RF Client(6503) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) History RF Client(5036) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) History RF Client(5036) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) ARP(5058) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ARP(5058) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k PAgP/LACP(1305) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k CAPI(1317) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CWAN SRP RF Client(6507) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN SRP RF Client(6507) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) SLB RF Client(5088) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SLB RF Client(5088) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Switch SPAN client(504) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) REP SP client(1355) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) REP Protocol(212) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) MWAM RF Client(5104) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MWAM RF Client(5104) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) SAMI RF Client(5105) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SAMI RF Client(5105) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) MQC QoS(5103) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MQC QoS(5103) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IP Tunnel RF(5152) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IP Tunnel RF(5152) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Config Verify RF client(5095) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Verify RF client(5095) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) LAN-Switch IP Host Table(5510) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) LAN-Switch IP Host Table(5510) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IKE RF Client(5136) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IKE RF Client(5136) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IPSEC RF Client(5137) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IPSEC RF Client(5137) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CRYPTO RSA(5131) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CRYPTO RSA(5131) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) DHCPv6 Relay(5149) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPv6 Relay(5149) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) ISSU process(3099) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) ISSU Test Client(9006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ISSU Test Client(9006) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Network RF 2 Client(5094) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF 2 Client(5094) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k PF_ML_RP(6321) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k PF_ML_RP(6321) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) LAN-Switch Private Vlan(511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) PM SP client(1321) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) VLAN Mapping(1322) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Clear counter(1315) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Cat6k Clear counter(6316) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Clear counter(6316) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) DATA DESCRIPTOR RF CLIENT(5142) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DATA DESCRIPTOR RF CLIENT(5142) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) C6K/7600 penultimate client(1356) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IOS Config ARCHIVE(4020) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IOS Config ARCHIVE(9021) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ARCHIVE(9021) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IOS Config ROLLBACK(4021) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IOS Config ROLLBACK(9022) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ROLLBACK(9022) op=203 rc=0
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) RF_LAST_CLIENT(65000) op=0 rc=11
00:00:33 *my state = ACTIVE(13) peer state = DISABLED(1)
00:00:33 RF_PROG_ACTIVE(204) RF_INTERNAL_MSG(0) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k Platform First Client(1319) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Redundancy Mode RF(5030) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Redundancy Mode RF(5030) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) IfIndex(5140) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IfIndex(5140) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Persistent Variable(3300) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Force RPR(3200) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) CHKPT RF(25) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) CHKPT RF(5026) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CHKPT RF(5026) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) PF_UCODE(1330) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) MCM(3100) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Event Manager(77) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Event Manager(5078) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Event Manager(5078) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Cat6k Fabric Manager(1302) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k OIR(1303) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k CWAN HA(6502) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN HA(6502) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) CWAN VLAN RF Client(6504) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN VLAN RF Client(6504) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Network RF Client(5023) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF Client(5023) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Cat6k SPA TSM(6506) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k SPA TSM(6506) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) TABLEID FOF SP(1511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) TABLEID FOF RP(6513) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) TABLEID FOF RP(6513) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) LAN-Switch VTP VLAN(501) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) XDR RRP RF Client(5072) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) XDR RRP RF Client(5072) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) CEF RRP RF Client(5025) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CEF RRP RF Client(5025) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) MFIB RRP RF Client(5307) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MFIB RRP RF Client(5307) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Cat6k CWAN Interface Events(6505) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k CWAN Interface Events(6505) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) CWAN LTL Mgr HA RF Client(6508) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN LTL Mgr HA RF Client(6508) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Config Sync RF client(5006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Sync RF client(5006) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) LAN-Switch Port Manager(502) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k Platform(1313) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k Platform(6314) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Platform(6314) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Cat6k Power(1318) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) DHCPC(5101) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPC(5101) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) DHCPD(5102) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPD(5102) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Cat6k Startup Config Sync(1301) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k Startup Config Sync(6302) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Startup Config Sync(6302) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Cat6k IDPROM(1307) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) SNMP RF Client(5035) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SNMP RF Client(5035) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) CWAN APS HA RF Client(6503) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN APS HA RF Client(6503) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) History RF Client(5036) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) History RF Client(5036) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) ARP(5058) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ARP(5058) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Cat6k PAgP/LACP(1305) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k CAPI(1317) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) CWAN SRP RF Client(6507) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CWAN SRP RF Client(6507) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) SLB RF Client(5088) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SLB RF Client(5088) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Switch SPAN client(504) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) REP SP client(1355) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) REP Protocol(212) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) MWAM RF Client(5104) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MWAM RF Client(5104) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) SAMI RF Client(5105) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SAMI RF Client(5105) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) MQC QoS(5103) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) MQC QoS(5103) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) IP Tunnel RF(5152) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IP Tunnel RF(5152) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Config Verify RF client(5095) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Config Verify RF client(5095) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) LAN-Switch IP Host Table(5510) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) LAN-Switch IP Host Table(5510) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) IKE RF Client(5136) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IKE RF Client(5136) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) IPSEC RF Client(5137) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IPSEC RF Client(5137) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) CRYPTO RSA(5131) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) CRYPTO RSA(5131) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) DHCPv6 Relay(5149) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DHCPv6 Relay(5149) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) ISSU process(3099) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) ISSU Test Client(9006) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) ISSU Test Client(9006) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Network RF 2 Client(5094) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Network RF 2 Client(5094) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) Cat6k PF_ML_RP(6321) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k PF_ML_RP(6321) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) LAN-Switch Private Vlan(511) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) PM SP client(1321) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) VLAN Mapping(1322) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k Clear counter(1315) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Cat6k Clear counter(6316) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Cat6k Clear counter(6316) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) DATA DESCRIPTOR RF CLIENT(5142) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) DATA DESCRIPTOR RF CLIENT(5142) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) C6K/7600 penultimate client(1356) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) IOS Config ARCHIVE(4020) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) IOS Config ARCHIVE(9021) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ARCHIVE(9021) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) IOS Config ROLLBACK(4021) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) IOS Config ROLLBACK(9022) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) IOS Config ROLLBACK(9022) op=204 rc=0
00:00:33 RF_PROG_ACTIVE(204) RF_LAST_CLIENT(65000) op=0 rc=11
00:00:43 client added: Cat6k Multicast Shortcuts(1309) seq=263
00:00:43 RF_STATUS_SEND_RF_STATE(408) Cat6k Multicast Shortcuts(1309) op=13 rc=0
00:00:43 client added: Switch Backup Interface client(507) seq=285
00:00:43 RF_STATUS_SEND_RF_STATE(408) Switch Backup Interface client(507) op=13 rc=0
00:00:43 client added: CWAN static MAC RF Client(1552) seq=344
00:00:43 RF_STATUS_SEND_RF_STATE(408) CWAN static MAC RF Client(1552) op=13 rc=0
00:00:43 client added: 802.1x authenticator(210) seq=145
00:00:43 RF_STATUS_SEND_RF_STATE(408) 802.1x authenticator(210) op=13 rc=0
00:00:43 client added: CWAN LTL SP RF Client(1508) seq=254
00:00:43 RF_STATUS_SEND_RF_STATE(408) CWAN LTL SP RF Client(1508) op=13 rc=0
00:00:43 client added: Cat6k MLS Multicast(1312) seq=269
00:00:43 RF_STATUS_SEND_RF_STATE(408) Cat6k MLS Multicast(1312) op=13 rc=0
00:00:44 client added: 7600 CMFIB-SP(1353) seq=346
00:00:44 RF_STATUS_SEND_RF_STATE(408) 7600 CMFIB-SP(1353) op=13 rc=0
00:00:44 client added: Spanning-Tree Protocol(503) seq=262
00:00:44 RF_STATUS_SEND_RF_STATE(408) Spanning-Tree Protocol(503) op=13 rc=0
00:00:44 client added: tcam mgr rf client(1324) seq=160
00:00:44 RF_STATUS_SEND_RF_STATE(408) tcam mgr rf client(1324) op=13 rc=0
00:00:44 client added: GVRP RF(97) seq=295
00:00:44 RF_STATUS_SEND_RF_STATE(408) GVRP RF(97) op=13 rc=0
00:00:44 client added: BD MAC SECURITY RF CLIENT(206) seq=177
00:00:44 RF_STATUS_SEND_RF_STATE(408) BD MAC SECURITY RF CLIENT(206) op=13 rc=0
00:00:44 client added: RF_TS_CLIENT(4000) seq=325
00:00:44 RF_STATUS_SEND_RF_STATE(408) RF_TS_CLIENT(4000) op=13 rc=0
00:00:44 client added: TPM RF client(402) seq=143
00:00:44 client added: LACP(226) seq=179
00:00:44 RF_STATUS_SEND_RF_STATE(408) LACP(226) op=13 rc=0
00:00:44 client added: Port Security Client(508) seq=305
00:00:44 RF_STATUS_SEND_RF_STATE(408) Port Security Client(508) op=13 rc=0
00:00:44 client added: Cat6k Local Target Logic(1308) seq=149
00:00:44 RF_STATUS_SEND_RF_STATE(408) Cat6k Local Target Logic(1308) op=13 rc=0
00:00:44 client added: MDR SM(138) seq=148
00:00:44 RF_STATUS_SEND_RF_STATE(408) MDR SM(138) op=13 rc=0
00:00:44 client added: IPROUTING NSF RF client(5021) seq=185
00:00:44 RF_STATUS_SEND_RF_STATE(408) IPROUTING NSF RF client(5021) op=13 rc=0
00:00:44 client added: Frame Relay(5024) seq=164
00:00:44 RF_STATUS_SEND_RF_STATE(408) Frame Relay(5024) op=13 rc=0
00:00:44 client added: HDLC(5050) seq=165
00:00:44 RF_STATUS_SEND_RF_STATE(408) HDLC(5050) op=13 rc=0
00:00:44 client added: FH_RF_Event_Detector_stub(5051) seq=248
00:00:44 RF_STATUS_SEND_RF_STATE(408) FH_RF_Event_Detector_stub(5051) op=13 rc=0
00:00:44 client added: ATM(5053) seq=202
00:00:44 RF_STATUS_SEND_RF_STATE(408) ATM(5053) op=13 rc=0
00:00:44 client added: SNMP HA RF Client(5055) seq=238
00:00:44 RF_STATUS_SEND_RF_STATE(408) SNMP HA RF Client(5055) op=13 rc=0
00:00:44 client added: Virtual Template RF Client(5069) seq=161
00:00:44 RF_STATUS_SEND_RF_STATE(408) Virtual Template RF Client(5069) op=13 rc=0
00:00:44 client added: AAA(5070) seq=206
00:00:44 RF_STATUS_SEND_RF_STATE(408) AAA(5070) op=13 rc=0
00:00:44 client added: LSD HA Proc(5073) seq=166
00:00:44 RF_STATUS_SEND_RF_STATE(408) LSD HA Proc(5073) op=13 rc=0
00:00:44 client added: LDP HA(5074) seq=239
00:00:44 RF_STATUS_SEND_RF_STATE(408) LDP HA(5074) op=13 rc=0
00:00:44 client added: MPLS VPN HA Client(5075) seq=198
00:00:44 RF_STATUS_SEND_RF_STATE(408) MPLS VPN HA Client(5075) op=13 rc=0
00:00:44 client added: Tableid HA(5076) seq=116
00:00:44 RF_STATUS_SEND_RF_STATE(408) Tableid HA(5076) op=13 rc=0
00:00:44 client added: IPRM(5077) seq=240
00:00:44 RF_STATUS_SEND_RF_STATE(408) IPRM(5077) op=13 rc=0
00:00:44 client added: TSPTUN HA(5079) seq=98
00:00:44 RF_STATUS_SEND_RF_STATE(408) TSPTUN HA(5079) op=13 rc=0
00:00:44 client added: CCM RF(5083) seq=209
00:00:44 RF_STATUS_SEND_RF_STATE(408) CCM RF(5083) op=13 rc=0
00:00:44 client added: AC RF Client(5084) seq=274
00:00:44 RF_STATUS_SEND_RF_STATE(408) AC RF Client(5084) op=13 rc=0
00:00:44 client added: AToM manager(5085) seq=276
00:00:44 RF_STATUS_SEND_RF_STATE(408) AToM manager(5085) op=13 rc=0
00:00:44 client added: SSM(5086) seq=277
00:00:44 RF_STATUS_SEND_RF_STATE(408) SSM(5086) op=13 rc=0
00:00:44 client added: HSRP(5089) seq=102
00:00:44 RF_STATUS_SEND_RF_STATE(408) HSRP(5089) op=13 rc=0
00:00:44 client added: L3 Mobility Manager(5090) seq=87
00:00:44 RF_STATUS_SEND_RF_STATE(408) L3 Mobility Manager(5090) op=13 rc=0
00:00:44 client added: RSVP HA Services(5091) seq=222
00:00:44 RF_STATUS_SEND_RF_STATE(408) RSVP HA Services(5091) op=13 rc=0
00:00:44 client added: DHCP Snooping(5106) seq=288
00:00:44 RF_STATUS_SEND_RF_STATE(408) DHCP Snooping(5106) op=13 rc=0
00:00:44 client added: MFI STATIC HA Proc(5114) seq=167
00:00:44 RF_STATUS_SEND_RF_STATE(408) MFI STATIC HA Proc(5114) op=13 rc=0
00:00:44 client added: GLBP(5115) seq=103
00:00:44 RF_STATUS_SEND_RF_STATE(408) GLBP(5115) op=13 rc=0
00:00:44 client added: CEM(5117) seq=204
00:00:44 RF_STATUS_SEND_RF_STATE(408) CEM(5117) op=13 rc=0
00:00:44 client added: IMA(5118) seq=205
00:00:44 RF_STATUS_SEND_RF_STATE(408) IMA(5118) op=13 rc=0
00:00:44 client added: XC L2TP HA manager(5120) seq=208
00:00:44 RF_STATUS_SEND_RF_STATE(408) XC L2TP HA manager(5120) op=13 rc=0
00:00:44 client added: ACR(5123) seq=203
00:00:44 RF_STATUS_SEND_RF_STATE(408) ACR(5123) op=13 rc=0
00:00:44 client added: VFI Mgr(5146) seq=275
00:00:44 RF_STATUS_SEND_RF_STATE(408) VFI Mgr(5146) op=13 rc=0
00:00:44 client added: BFD RF Client(5147) seq=126
00:00:44 RF_STATUS_SEND_RF_STATE(408) BFD RF Client(5147) op=13 rc=0
00:00:44 client added: BFD platform RF Client for 7600(5153) seq=127
00:00:44 RF_STATUS_SEND_RF_STATE(408) BFD platform RF Client for 7600(5153) op=13 rc=0
00:00:44 client added: ETHERNET OAM RF(5201) seq=173
00:00:44 RF_STATUS_SEND_RF_STATE(408) ETHERNET OAM RF(5201) op=13 rc=0
00:00:44 client added: ETHERNET LMI RF(5203) seq=176
00:00:44 RF_STATUS_SEND_RF_STATE(408) ETHERNET LMI RF(5203) op=13 rc=0
00:00:44 client added: ETHER INFRA RF(5205) seq=171
00:00:44 RF_STATUS_SEND_RF_STATE(408) ETHER INFRA RF(5205) op=13 rc=0
00:00:44 client added: BD MAC SECURITY RF CLIENT(5207) seq=177
00:00:44 RF_STATUS_SEND_RF_STATE(408) BD MAC SECURITY RF CLIENT(5207) op=13 rc=0
00:00:44 client added: ECFM RF(5208) seq=175
00:00:44 RF_STATUS_SEND_RF_STATE(408) ECFM RF(5208) op=13 rc=0
00:00:44 client added: 802.1x authenticator(5211) seq=145
00:00:44 RF_STATUS_SEND_RF_STATE(408) 802.1x authenticator(5211) op=13 rc=0
00:00:44 client added: VRRP(5226) seq=104
00:00:44 RF_STATUS_SEND_RF_STATE(408) VRRP(5226) op=13 rc=0
00:00:44 client added: EEM Server RF CLIENT(5251) seq=234
00:00:44 RF_STATUS_SEND_RF_STATE(408) EEM Server RF CLIENT(5251) op=13 rc=0
00:00:44 client added: EEM POLICY-DIR RF CLIENT(5253) seq=236
00:00:44 RF_STATUS_SEND_RF_STATE(408) EEM POLICY-DIR RF CLIENT(5253) op=13 rc=0
00:00:44 client added: MRIB RP RF Client(5302) seq=129
00:00:44 RF_STATUS_SEND_RF_STATE(408) MRIB RP RF Client(5302) op=13 rc=0
00:00:44 client added: IP multicast RF Client(5305) seq=100
00:00:44 RF_STATUS_SEND_RF_STATE(408) IP multicast RF Client(5305) op=13 rc=0
00:00:44 client added: Multicast ISSU Consolidation RF(5306) seq=99
00:00:44 RF_STATUS_SEND_RF_STATE(408) Multicast ISSU Consolidation RF(5306) op=13 rc=0
00:00:44 client added: TPM RF client(5403) seq=143
00:00:44 RF_STATUS_SEND_RF_STATE(408) TPM RF client(5403) op=13 rc=0
00:00:44 client added: Cat6k QoS Manager(6307) seq=89
00:00:44 RF_STATUS_SEND_RF_STATE(408) Cat6k QoS Manager(6307) op=13 rc=0
00:00:44 client added: Cat6k Feature Manager(6311) seq=96
00:00:44 RF_STATUS_SEND_RF_STATE(408) Cat6k Feature Manager(6311) op=13 rc=0
00:00:44 client added: Cat6k Layer3 Manager(6312) seq=265
00:00:44 RF_STATUS_SEND_RF_STATE(408) Cat6k Layer3 Manager(6312) op=13 rc=0
00:00:44 client added: Cat6k VPN RF Client(6326) seq=111
00:00:44 RF_STATUS_SEND_RF_STATE(408) Cat6k VPN RF Client(6326) op=13 rc=0
00:00:44 client added: Cat6k HA Vpnsm(6327) seq=342
00:00:44 RF_STATUS_SEND_RF_STATE(408) Cat6k HA Vpnsm(6327) op=13 rc=0
00:00:44 client added: CV6 RF Client(6328) seq=113
00:00:44 RF_STATUS_SEND_RF_STATE(408) CV6 RF Client(6328) op=13 rc=0
00:00:44 client added: 7600 CMFIB-RP(6355) seq=347
00:00:44 RF_STATUS_SEND_RF_STATE(408) 7600 CMFIB-RP(6355) op=13 rc=0
00:00:44 client added: Call-Home RF(6511) seq=293
00:00:44 RF_STATUS_SEND_RF_STATE(408) Call-Home RF(6511) op=13 rc=0
00:00:44 client added: CWAN ATOM HA RF Client(6552) seq=343
00:00:44 RF_STATUS_SEND_RF_STATE(408) CWAN ATOM HA RF Client(6552) op=13 rc=0
00:00:44 client added: Network Clock(9007) seq=345
00:00:44 RF_STATUS_SEND_RF_STATE(408) Network Clock(9007) op=13 rc=0
00:00:47 Configuration parsing complete
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Platform First Client(1319) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Redundancy Mode RF(5030) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IfIndex(5140) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Persistent Variable(3300) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Force RPR(3200) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CHKPT RF(25) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CHKPT RF(5026) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) PF_UCODE(1330) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MCM(3100) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Event Manager(77) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Event Manager(5078) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Fabric Manager(1302) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k OIR(1303) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) L3 Mobility Manager(5090) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k QoS Manager(6307) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k CWAN HA(6502) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CWAN VLAN RF Client(6504) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Feature Manager(6311) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) TSPTUN HA(5079) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Multicast ISSU Consolidation RF(5306) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IP multicast RF Client(5305) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Network RF Client(5023) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) HSRP(5089) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) GLBP(5115) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) VRRP(5226) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k SPA TSM(6506) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k VPN RF Client(6326) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CV6 RF Client(6328) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) TABLEID FOF SP(1511) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) TABLEID FOF RP(6513) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Tableid HA(5076) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch VTP VLAN(501) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) XDR RRP RF Client(5072) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CEF RRP RF Client(5025) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) BFD RF Client(5147) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) BFD platform RF Client for 7600(5153) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MRIB RP RF Client(5302) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MFIB RRP RF Client(5307) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k CWAN Interface Events(6505) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CWAN LTL Mgr HA RF Client(6508) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) TPM RF client(5403) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) 802.1x authenticator(210) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) 802.1x authenticator(5211) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Config Sync RF client(5006) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MDR SM(138) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Local Target Logic(1308) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch Port Manager(502) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Platform(1313) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Platform(6314) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Power(1318) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) tcam mgr rf client(1324) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Virtual Template RF Client(5069) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Frame Relay(5024) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) HDLC(5050) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LSD HA Proc(5073) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MFI STATIC HA Proc(5114) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ETHER INFRA RF(5205) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ETHERNET OAM RF(5201) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ECFM RF(5208) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ETHERNET LMI RF(5203) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) BD MAC SECURITY RF CLIENT(206) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) BD MAC SECURITY RF CLIENT(5207) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LACP(226) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IPROUTING NSF RF client(5021) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DHCPC(5101) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DHCPD(5102) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Startup Config Sync(1301) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Startup Config Sync(6302) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k IDPROM(1307) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MPLS VPN HA Client(5075) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SNMP RF Client(5035) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CWAN APS HA RF Client(6503) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ATM(5053) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ACR(5123) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CEM(5117) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IMA(5118) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) AAA(5070) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) XC L2TP HA manager(5120) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CCM RF(5083) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) History RF Client(5036) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) RSVP HA Services(5091) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) EEM Server RF CLIENT(5251) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) EEM POLICY-DIR RF CLIENT(5253) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SNMP HA RF Client(5055) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LDP HA(5074) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IPRM(5077) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ARP(5058) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) FH_RF_Event_Detector_stub(5051) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CWAN LTL SP RF Client(1508) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k PAgP/LACP(1305) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Spanning-Tree Protocol(503) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Multicast Shortcuts(1309) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Layer3 Manager(6312) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k CAPI(1317) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CWAN SRP RF Client(6507) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k MLS Multicast(1312) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) AC RF Client(5084) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) VFI Mgr(5146) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) AToM manager(5085) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SSM(5086) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SLB RF Client(5088) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Switch SPAN client(504) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Switch Backup Interface client(507) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) REP SP client(1355) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) REP Protocol(212) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DHCP Snooping(5106) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MWAM RF Client(5104) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SAMI RF Client(5105) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MQC QoS(5103) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Call-Home RF(6511) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) GVRP RF(97) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IP Tunnel RF(5152) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Config Verify RF client(5095) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Port Security Client(508) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch IP Host Table(5510) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IKE RF Client(5136) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IPSEC RF Client(5137) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CRYPTO RSA(5131) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DHCPv6 Relay(5149) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ISSU process(3099) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) RF_TS_CLIENT(4000) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ISSU Test Client(9006) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Network RF 2 Client(5094) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k PF_ML_RP(6321) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch PAgP/LACP(510) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch Private Vlan(511) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) PM SP client(1321) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) VLAN Mapping(1322) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Clear counter(1315) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k Clear counter(6316) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DATA DESCRIPTOR RF CLIENT(5142) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Cat6k HA Vpnsm(6327) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CWAN ATOM HA RF Client(6552) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CWAN static MAC RF Client(1552) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Network Clock(9007) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) 7600 CMFIB-SP(1353) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) 7600 CMFIB-RP(6355) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) C6K/7600 penultimate client(1356) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config ARCHIVE(4020) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config ARCHIVE(9021) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config ROLLBACK(4021) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config ROLLBACK(9022) op=7 rc=0
00:00:48 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) RF_LAST_CLIENT(65000) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Platform First Client(1319) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Redundancy Mode RF(5030) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IfIndex(5140) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Persistent Variable(3300) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Force RPR(3200) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CHKPT RF(25) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CHKPT RF(5026) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) PF_UCODE(1330) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MCM(3100) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Event Manager(77) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Event Manager(5078) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Fabric Manager(1302) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k OIR(1303) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) L3 Mobility Manager(5090) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k QoS Manager(6307) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k CWAN HA(6502) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CWAN VLAN RF Client(6504) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Feature Manager(6311) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) TSPTUN HA(5079) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Multicast ISSU Consolidation RF(5306) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IP multicast RF Client(5305) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Network RF Client(5023) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) HSRP(5089) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) GLBP(5115) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) VRRP(5226) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k SPA TSM(6506) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k VPN RF Client(6326) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CV6 RF Client(6328) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) TABLEID FOF SP(1511) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) TABLEID FOF RP(6513) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Tableid HA(5076) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LAN-Switch VTP VLAN(501) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) XDR RRP RF Client(5072) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CEF RRP RF Client(5025) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) BFD RF Client(5147) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) BFD platform RF Client for 7600(5153) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MRIB RP RF Client(5302) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MFIB RRP RF Client(5307) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k CWAN Interface Events(6505) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CWAN LTL Mgr HA RF Client(6508) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) TPM RF client(5403) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) 802.1x authenticator(210) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) 802.1x authenticator(5211) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Config Sync RF client(5006) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MDR SM(138) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Local Target Logic(1308) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LAN-Switch Port Manager(502) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Platform(1313) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Platform(6314) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Power(1318) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) tcam mgr rf client(1324) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Virtual Template RF Client(5069) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Frame Relay(5024) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) HDLC(5050) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LSD HA Proc(5073) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MFI STATIC HA Proc(5114) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ETHER INFRA RF(5205) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ETHERNET OAM RF(5201) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ECFM RF(5208) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ETHERNET LMI RF(5203) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) BD MAC SECURITY RF CLIENT(206) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) BD MAC SECURITY RF CLIENT(5207) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LACP(226) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IPROUTING NSF RF client(5021) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) DHCPC(5101) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) DHCPD(5102) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Startup Config Sync(1301) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Startup Config Sync(6302) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k IDPROM(1307) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MPLS VPN HA Client(5075) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) SNMP RF Client(5035) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CWAN APS HA RF Client(6503) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ATM(5053) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ACR(5123) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CEM(5117) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IMA(5118) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) AAA(5070) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) XC L2TP HA manager(5120) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CCM RF(5083) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) History RF Client(5036) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) RSVP HA Services(5091) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) EEM Server RF CLIENT(5251) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) EEM POLICY-DIR RF CLIENT(5253) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) SNMP HA RF Client(5055) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LDP HA(5074) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IPRM(5077) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ARP(5058) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) FH_RF_Event_Detector_stub(5051) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CWAN LTL SP RF Client(1508) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k PAgP/LACP(1305) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Spanning-Tree Protocol(503) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Multicast Shortcuts(1309) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Layer3 Manager(6312) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k CAPI(1317) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CWAN SRP RF Client(6507) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k MLS Multicast(1312) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) AC RF Client(5084) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) VFI Mgr(5146) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) AToM manager(5085) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) SSM(5086) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) SLB RF Client(5088) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Switch SPAN client(504) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Switch Backup Interface client(507) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) REP SP client(1355) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) REP Protocol(212) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) DHCP Snooping(5106) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MWAM RF Client(5104) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) SAMI RF Client(5105) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MQC QoS(5103) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Call-Home RF(6511) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) GVRP RF(97) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IP Tunnel RF(5152) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Config Verify RF client(5095) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Port Security Client(508) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LAN-Switch IP Host Table(5510) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IKE RF Client(5136) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IPSEC RF Client(5137) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CRYPTO RSA(5131) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) DHCPv6 Relay(5149) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ISSU process(3099) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) RF_TS_CLIENT(4000) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ISSU Test Client(9006) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Network RF 2 Client(5094) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k PF_ML_RP(6321) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LAN-Switch PAgP/LACP(510) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LAN-Switch Private Vlan(511) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) PM SP client(1321) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) VLAN Mapping(1322) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Clear counter(1315) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k Clear counter(6316) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) DATA DESCRIPTOR RF CLIENT(5142) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Cat6k HA Vpnsm(6327) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CWAN ATOM HA RF Client(6552) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CWAN static MAC RF Client(1552) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Network Clock(9007) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) 7600 CMFIB-SP(1353) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) 7600 CMFIB-RP(6355) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) C6K/7600 penultimate client(1356) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IOS Config ARCHIVE(4020) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IOS Config ARCHIVE(9021) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IOS Config ROLLBACK(4021) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IOS Config ROLLBACK(9022) op=7 rc=0
00:00:48 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) RF_LAST_CLIENT(65000) op=7 rc=0
00:00:50 System initialization complete
------------------ show controllers t1 ------------------
------------------ show controllers e1 ------------------
------------------ show ipc status ------------------
                            IPC System Status
Time last IPC stat cleared all zones : 00:00:00
This processor is an IPC slave server in zone 0 (default).
Do not drop output of IPC frames for test purposes.
6000 IPC Message Headers Cached.
                                                    Rx Side     Tx Side
Total Frames                                           565807      577387
Total from Local Ports                                 364870      282305
Total Protocol Control Frames                             416         180
Total Frames Dropped                                        0           0
                             Service Usage
Total via Unreliable Connection-Less Service            38088       37999
Total via Unreliable Sequenced Connection-Less Svc          0           0
Total via Reliable Connection-Oriented Service         332718      244299
Total Messages via Fragmentation                          784           9
Total Fragments                                          6302          37
Total Internal IPC Messages                               351           0
Total Messages Flushed                                      0           1
                      IPC Protocol Version 0
Total Acknowledgements                                 244307      295054
Total Negative Acknowledgements                             0           0
                             Device Drivers
Total via Local Driver                                      0           0
Total via Platform Driver                              565806      577387
Total Frames Dropped by Platform Drivers                    0           0
Total Frames Sent when media is quiesced                                0
                     Reliable Tx Statistics
Re-Transmission                                                         7
Re-Tx Timeout                                                           0
          Rx Errors                              Tx Errors
Unsupp IPC Proto Version          0  Tx Session Error                  0
Corrupt Frame                     0  Tx Seat Error                     0
Duplicate Frame                   0  Tx No Send Vector                 0
Unrel Out-of-Seq Frame            0  Tx Driver Failed                  0
Rx IPC Transform Errors           0  Tx IPC Transform Errors           0
Unable to Deliver Msg             0  Tx Test Drop                      0
Rx Msg Callback Hog               0  Ack Alloc Failed                  0
Rel Out-of-Seq Frame              0
Dest Port does Not Exist          0
Rx IPC Msg Alloc Failed           0
Rx IPC Frag Dropped               0
Rx Bootstrap Delivered            2
Rx Bootstrap Dropped              0
          Buffer Errors                          Misc Errors
IPC Msg Alloc                     0  IPC Open Port                     1
Emer IPC Msg Alloc                0  No HWQ                            0
IPC Frame PakType Alloc           0  Hardware Error                    0
IPC Frame MemD Alloc              0  Invalid Messages                  0
                                      IPC Backup Open Port              0
                                      IPC Fragment Errors               0
                                      Message Timer Errors              0
                                      Messages no xmt pending flag      0
          Tx Driver Errors
No Transport                      0
MTU Failure                       0
Dest does not Exist               0
          IPC Message Bundling Statistics
Seat-level    Tx Bundling (bdl/sub/nonbdl/urgent/err)  0/0/282333/0/0
Seat-level    Rx Bundling (bdl/sub/nonbdl/err)         0/0/565806/0
Session-level Tx Bundling (bdl/sub/nonbdl/urgent/err)  0/0/282298/144368/0
Session-level Rx Bundling (bdl/sub/nonbdl/err)         0/0/290702/0
------------------ show ipc queue ------------------
There are 0 IPC messages waiting for acknowledgement in the transmit queue.
There are 0 IPC messages waiting for a response.
There are 0 IPC messages waiting for additional fragments.
There are 0 IPC messages currently on the IPC inboundQ.
There are 0 IPC messages currently on the RX controller inboundQ.
There are 0 IPC messages currently on the TX controller inboundQ.
There are 0 IPC messages currently on the zone inboundQ.
Messages currently in use                     :         20
Message cache size                            :       6000
Maximum message cache usage                   :       6000
0  times message cache crossed      12000 [max]
Emergency messages currently in use           :          0
There are 19 messages currently reserved for reply msg.
Cache low watermark           [default/new]: [100/100]
         No of low watermark reached           :         0
         Total get cache after low watermark   :         0
         No of times zero cache reached        :         0
         No of times one cache added           :         0
         No of times cache chunk added         :         0
         Max no of get cache between wake2grow :         0
------------------ show ipc rpc ------------------
                    IPC RPC Status
                                  Rx Side      Tx Side
Total RPC requests                     69738        74584
Total RPC replies                      74584        69738
                    IPC RPC Statistics
Maximum RPC timeout(seconds)                          600
Number of RPC timeouts crossed default max[  600]       0
                    IPC RPC Errors
No Pending RPC Request for Received RPC Reply           0
RPC Request which have timeout out                      0
RPC Reply not sent due to NULL reply message            0
RPC Reply not sent due to NULL request message          0
RPC Reply not sent for NON RPC request message        398
RPC Reply with NULL reply and request message           0
Time last IPC RPC stat cleared                  00:00:00
------------------ show ipc port ------------------
                             IPC ACTIVE PORT TABLE
There are 39 ports defined.
Port ID        Type       Name                    (current/peak/total)
2150000.1     unicast    Card5/1:Zone
2150000.2     unicast    Card5/1:Echo
  port_index = 0  seat_id = 0x10000   last sent = 0     last heard = 7622
     rcv pending/peak/total       = 0/1/7622
     stateful_mode = 0     peer_port = 0,    peer_seat = 0
     seq-window size              = 128   number of messages in window = 0
     maximum out-of-seq received  = 0     maximum pending in window    = 0
     number of messages dropped   = 0     number of window resets      = 0
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/7622/0
2150000.3     multicast  Card5/1:Control
2150000.4     unicast    Rf_Proxy:Client:5
  port_index = 0  seat_id = 0x10000   last sent = 0     last heard = 540
     rcv pending/peak/total       = 0/2/540
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/540/0
2150000.5     unicast    ERP Agent Port #21
  port_index = 0  seat_id = 0x10000   last sent = 0     last heard = 1
     rcv pending/peak/total       = 0/1/1
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/1/0
2150000.6     unicast    OBFL Master Port
2150000.7     unicast    Card5/1:Request
  port_index = 1  seat_id = 0x10000   last sent = 0     last heard = 20
     rcv pending/peak/total       = 0/4/20
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/20/0
  port_index = 2  seat_id = 0x10000   last sent = 0     last heard = 32652
     rcv pending/peak/total       = 0/313/32624
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/32624/0
  port_index = 3  seat_id = 0x10000   last sent = 0     last heard = 0
     rcv pending/peak/total       = 0/1/38086
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/38086/0
  port_index = 4  seat_id = 0x2150000 last sent = 0     last heard = 0
     rcv pending/peak/total       = 0/0/0
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/0/0
  port_index = 5  seat_id = 0x2150000 last sent = 0     last heard = 0
  port_index = 6  seat_id = 0x2150000 last sent = 0     last heard = 0
  port_index = 7  seat_id = 0x2150000 last sent = 0     last heard = 0
2150000.8     unicast    Card21:Request
2150000.9     unicast    Card5/1:Event
2150000.A     unicast    Card5/1:Exception
2150000.B     multicast  Card5/1:McastRequest
   10000.3     multicast  IPC Master:Control
2150000.C     unicast    CHKPT:ACTIVE RP
2150000.D     unicast    RED MODE: Active Port
2150000.E     unicast    Config Sync ISSU nego active
2150000.F     unicast    TID HA: Active RP
2150000.10    unicast    issu:rfs:34930688
  port_index = 0  seat_id = 0x10000   last sent = 0     last heard = 242
     rcv pending/peak/total       = 0/2/242
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/242/0
2150000.11    unicast    RFS Pri RP Partfs Server Port
2150000.12    unicast    Pri RP console: RTTY port
2150000.13    unicast    RTTYEnh Master Port
  port_index = 0  seat_id = 0x10000   last sent = 0     last heard = 33
     rcv pending/peak/total       = 0/2/33
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/33/0
2150000.14    unicast    Master RFS Server Port
2150000.15    unicast    issu:rfs:Master RFS Server Port
2150000.16    unicast    ifindex_sync_active_port
2150000.17    unicast    IPC-Apps:Active
2150000.18    unicast    ISSU TEST::same port 1 0
2150000.19    unicast    ISSU TEST::shared msg port 1 0
2150000.1A    unicast    ISSU TEST::same port 1 1
2150000.1B    unicast    ISSU TEST::shared msg port 1 1
2150000.1C    unicast    ISSU TEST::shared nego port 1 0
2150000.1D    unicast    ProcMIB Statistics Server Port
  port_index = 0  seat_id = 0x10000   last sent = 0     last heard = 43549
     rcv pending/peak/total       = 0/2/43549
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/43549/0
2150000.1E    unicast    FIB Master: DFS.process_level.msgs
  port_index = 0  seat_id = 0x10000   last sent = 0     last heard = 7026
     rcv pending/peak/total       = 0/1/7026
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/7026/0
2150000.1F    unicast    FIB Master: DFS.interrupt.msgs
  port_index = 0  seat_id = 0x10000   last sent = 0     last heard = 20728
     rcv pending/peak/total       = 0/1/86264
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/86264/0
2150000.20    unicast    RP: MRIB.control.RIL
2150000.21    unicast    Draco:Laminar:Ref
2150000.22    unicast    CWAN IPC Master:Init
2150000.23    unicast    RP: MFIB.RIL
2150000.24    unicast    Remote TTY Server Port
2150000.25    unicast    Resource Manager Master
  port_index = 0  seat_id = 0x10000   last sent = 0     last heard = 1123
     rcv pending/peak/total       = 0/5/1110
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/1110/0
2150000.26    unicast    IPC Master: Slot 3/0 ICP
RPC packets: current/peak/total
                                                            1/5/74584
                            IPC STANDBY PORT TABLE
There are 0 ports defined.
                                                            1/5/74584
------------------ show ipc port open ------------------
                        IPC ACTIVE OPEN PORT TABLE
There are 16 ports defined.
   10000.4     unicast    ERP Agent Port #5
     port_index = 0  last sent = 4    last heard = 0
     session creator pc = 8D287FC
     xmt pending/peak/total       = 0/3/4
     session bundle status is OFF     seat bundle flag is NOT OK
     stateful_mode = 0, remote_seat = 10000
     Session/Seat level flow control state = 0x0/0x0
     Receiver seq-window size     = 128
   10000.8     unicast    Card5/0:Event
     port_index = 0  last sent = 2    last heard = 0
     xmt pending/peak/total       = 0/1/2
   10000.9     unicast    Card5/0:Exception
     port_index = 0  last sent = 0    last heard = 0
     xmt pending/peak/total       = 0/0/0
   10000.6     unicast    Card5/0:Request
     port_index = 3  last sent = 3398 last heard = 0
     xmt pending/peak/total       = 0/10/68934
     port_index = 4  last sent = 1830 last heard = 0
     xmt pending/peak/total       = 0/7/1830
     port_index = 5  last sent = 22   last heard = 0
     xmt pending/peak/total       = 0/4/22
     port_index = 6  last sent = 0    last heard = 0
     xmt pending/peak/total       = 0/1/37999
   10000.A     unicast    Unknown
     session creator pc = 0
     stateful_mode = 0, remote_seat = 0
     port_index = 1  last sent = 0    last heard = 0
   10000.5     unicast    Rf_Proxy:Server:5
     port_index = 0  last sent = 97   last heard = 0
     xmt pending/peak/total       = 0/1/97
   10000.2     unicast    Unknown
     port_index = 0  last sent = 7624 last heard = 0
     session creator pc = 8D286CC
     xmt pending/peak/total       = 0/3/7624
   10000.C     unicast    RTTYEnh Client Port 00010000
     port_index = 0  last sent = 18   last heard = 0
     xmt pending/peak/total       = 0/5/18
   10000.E     unicast    issu:rfs:Primary RFS Server Port
     port_index = 0  last sent = 124  last heard = 0
     xmt pending/peak/total       = 0/5/124
   10000.D     unicast    Primary RFS Server Port
     port_index = 0  last sent = 524  last heard = 0
     xmt pending/peak/total       = 0/4/526
   10000.17    unicast    Unknown
   10000.19    unicast    Slot 5: FAST.control.RIL
     port_index = 0  last sent = 32402last heard = 0
     xmt pending/peak/total       = 0/9/32402
   10000.18    unicast    Slot 5: DFS.control.IL
     port_index = 0  last sent = 14275last heard = 0
     xmt pending/peak/total       = 0/5/14275
   10000.1B    unicast    Unknown
     port_index = 4  last sent = 0    last heard = 0
     stateful_mode = 0, remote_seat = 2150000
     port_index = 5  last sent = 0    last heard = 0
     port_index = 7  last sent = 0    last heard = 0
   10000.15    unicast    L3MM port 5
                                                            0/2/69738
                       IPC STANDBY OPEN PORT TABLE
                                                            0/2/69738
------------------ show scp status ------------------
Rx 71187,  Tx 71187,  scp_my_addr 0x14
Id Sap      Channel name    current/peak/retry/dropped/total  time(queue/process/ack)
0  18   SCP Unsolicited:18      0/    0/    0/      0/    0      0/   0/   0
1  80   SCP Unsolicited:80      0/    0/    0/      0/    0      0/   0/   0
2  23   SCP async: LCP#5        0/    1/    2/      1/    2      0/2000/   0
3  0    SCP Unsolicited:0       0/    1/    0/      0/    2      0/   0/   0
4  25   SCP async: Draco-LC     0/    1/    0/      0/ 1216      4/ 760/ 760
------------------ show scp counters ------------------
received packets            = 71187
transmitted packets         = 71187
retransmitted packets       = 2
fast retransmitted packets  = 0
loop back packets           = 0
transmit failures           = 0
recv pkts not for me        = 0
recv pkts to dead process   = 2
recv pkts not enqueuable    = 0
response has wrong opcode   = 0
response has wrong seqnum   = 0
response is not an ack      = 0
response is too big         = 0
received expedited packets  = 0
transmitted expedited pkts  = 0
------------------ show scp accounting ------------------
     Total 11   19   29   100  123  138  1FF
Tot: 160F  4C0  A3F5 36A6 0    1    36A6 D
     1612  4C0  A3F5 36A6 1    2    36A6 E
03:  4C3   4C0  0    0    0    1    0    2
     4C6   4C0  0    0    1    2    0    3
05:  114C  0    A3F5 36A6 0    0    36A6 B
------------------ show ibc ------------------
Interface information:
        Interface IBC0/0(idb 0x183CD514)
        5 minute rx rate 52098000 bits/sec, 85888 packets/sec
        5 minute tx rate 126231000 bits/sec, 171809 packets/sec
        4471644835 packets input, 347898071160 bytes
        4471537060 broadcasts received
        4470390017 packets output, 347507459495 bytes
        12786 broadcasts sent
        0 Bridge Packet loopback drops
        3410958444 Packets CEF Switched, 0 Packets Fast Switched
        0 Packets SLB Switched, 3845323 Packets CWAN Switched
        Label switched pkts dropped: 0    Pkts dropped during dma: 4423
        Invalid pkts dropped: 0    Pkts dropped(not cwan consumed): 0
        IPSEC pkts: 0
        Xconnect pkts processed: 0, dropped: 0
        Xconnect pkt reflection drops: 0
        Total paks copied for process level 0
        Total short paks sent in route cache 64348
        Total throttle drops 4420    Input queue drops 3
        total spd packets classified (698190 low, 34253 medium, 19974 high)
        total spd packets dropped (4423 low, 0 medium, 0 high)
        spd prio pkts allowed in due to selective throttling (0 med, 0 high)
        IBC resets   = 1; last at 10:00:57.839 UTC Sat Sep 29 2012
Driver Level Counters: (Cumulative, Zeroed only at Reset)
          Frames          Bytes
  Rx(0)   50973           6766619
  Rx(1)   186111180       452037576
  Tx(0)   183543210       807879819
Input Drop Frame Count
     Rx0 = 0                Rx1 = 4185866
Per Queue Receive Errors:
     FRME   OFLW   BUFE   NOENP  DISCRD DISABLE BADCOUNT
Rx0 0      0      0      0      0        0    0
Rx1 0      0      0      957    0        0    0
  Tx Errors/State:
   One Collision Error   = 0            More Collisions       = 0
   No Encap Error        = 0            Deferred Error        = 0
   Loss Carrier Error    = 0            Late Collision Error  = 0
   Excessive Collisions  = 0            Buffer Error          = 0
   Tx Freeze Count       = 0            Tx Intrpt Serv timeout= 1
   Tx Flow State         = FLOW_ON
   Tx Flow Off Count     = 0            Tx Flow On Count      = 0
  Counters collected at Idb:
   Is input throttled    = 0            Throttle Count        = 0
   Rx Resource Errors    = 0            Input Drops           = 4185866
   Input Errors           = 1753512
   Output Drops          = 0            Giants/Runts          = 0/0
   Dma Mem Error         = 0            Input Overrun         = 0
Hash match table for multicast (in use 0, maximum 64 entries):
------------------ show icc status ------------------
Total Tx msgs pending :          0
Total Rx msgs pending :          0
Class Name             Msgs Pending  Max Pending       Total
    0 ICC(HQ)                     0            0          14
                                  0            1           1
    2 RPC                         0            6       67617
                                  0            6        4874
    3 MSC                         0            0           0
                                  0            1           2
    4 MCAST-SP(FC)                0            0        1538
                                  0            0           0
    6 L2-DRV(FC)                  0            0           8
                                  0            0           0
    8 L2-AGING(FC)                0            0         159
                                  0            0           0
   11 L3-MGMT(FC)                 0            7          38
                                  0            0           0
   13 EARL-ACL-TCAM(FC            0            2           6
                                  0            0           0
   14 QM(FC)                      0            5          60
                                  0            0           0
   15 ICC-SHIM                    0            0           0
                                  0            1           2
   23 IP-FIB                      0            1           1
                                  0            0           0
   29 EARL-INFO                   0            0           1
                                  0            0           0
   30 ESW-VLAN-STAT               0            0           0
                                  0            1        7610
   31 HEARTBEAT                   0            2       38001
                                  0            1       38086
   36 LOGGER(FC)                  0            4          20
                                  0            4          20
   40 REMOTE-CONSOLE              0            7        1135
                                  0          313       20120
   46 PF-CS(HQ)                   0            4           8
                                  0            0           0
   49 L2_APPL_REQUESTS            0            0         107
                                  0            0           0
   50 MPLS_REQUESTS               0            0           3
                                  0            0           0
   56 RATE_LIMIT_REQUE            0            2           7
                                  0            0           0
   57 CFIB_ERM_REQUEST            0            1           1
                                  0            0           0
   58 OIR                         0            0           0
                                  0            2          16
   61 SNMP_ICC_REQUEST            0            0          20
                                  0            0           0
   72 MLS_CEF_REQUESTS            0            3           3
                                  0            0           0
   79 L3-MGR-FM                   0            1           3
                                  0            0           0
   84 EARL-QOS-TCAM(FC            0            1           1
                                  0            0           0
   88 PF_REDUN                    0            0          12
                                  0            0           0
------------------ show icc counters ------------------
total tx ICC(HQ) packets to slot 5 CPU0/ = 14
  detail by request id:  (=)
   2 =1            9 =1            13=2            24=1
   31=9
total rx ICC(HQ) packets from slot 5 CPU0/ = 9
   2 =0            9 =0            13=0            24=0
   31=9
total tx RPC     packets to slot 5 CPU0/ = 67585
   0 =3            4 =4            5 =6            11=5
   12=5            15=53           16=9            28=9
   29=74           30=796          31=66621
total rx RPC     packets from slot 5 CPU0/ = 67582
   0 =0            4 =4            5 =6            11=5
total tx MCAST-SP(FC) packets to slot 5 CPU0/ = 1538
   4 =53           8 =53           10=53           15=53
   16=53           17=53           26=53           28=53
   30=53           31=1061
total rx MCAST-SP(FC) packets from slot 5 CPU0/ = 1485
   4 =0            8 =53           10=53           15=53
   30=53           31=1061
total tx L2-DRV(FC) packets to slot 5 CPU0/ = 8
   9 =4            18=4
total rx L2-DRV(FC) packets from slot 5 CPU0/ = 8
   9 =4            18=4
total tx L2-AGING(FC) packets to slot 5 CPU0/ = 159
   31=159
total rx L2-AGING(FC) packets from slot 5 CPU0/ = 159
   31=159
total tx L3-MGMT(FC) packets to slot 5 CPU0/ = 14
   13=3            17=5            26=6
total rx L3-MGMT(FC) packets from slot 5 CPU0/ = 14
   13=3            17=5            26=6
total tx EARL-ACL-TCAM(FC) packets to slot 5 CPU0/ = 4
   0 =4
total rx EARL-ACL-TCAM(FC) packets from slot 5 CPU0/ = 62
   0 =62
total tx QM(FC) packets to slot 5 CPU0/ = 53
   1 =53
total rx QM(FC) packets from slot 5 CPU0/ = 53
   1 =53
total tx EARL-INFO     packets to slot 5 CPU0/ = 1
   3 =1
total rx EARL-INFO     packets from slot 5 CPU0/ = 1
   3 =1
total tx HEARTBEAT     packets to slot 5 CPU0/ = 37999
   1 =37999
total rx HEARTBEAT     packets from slot 5 CPU0/ = 0
   1 =0
total tx LOGGER(FC) packets to slot 5 CPU0/ = 15
   6 =11           8 =4
total rx LOGGER(FC) packets from slot 5 CPU0/ = 15
   6 =11           8 =4
total tx L2_APPL_REQUESTS     packets to slot 5 CPU0/ = 107
   31=107
total rx L2_APPL_REQUESTS     packets from slot 5 CPU0/ = 106
   31=106
total tx MPLS_REQUESTS     packets to slot 5 CPU0/ = 3
   8 =1            13=1            14=1
total rx MPLS_REQUESTS     packets from slot 5 CPU0/ = 3
   8 =1            13=1            14=1
total tx RATE_LIMIT_REQUESTS     packets to slot 5 CPU0/ = 1
   31=1
total rx RATE_LIMIT_REQUESTS     packets from slot 5 CPU0/ = 1
   31=1
total tx SNMP_ICC_REQUESTS     packets to slot 5 CPU0/ = 20
   1 =19           3 =1
total rx SNMP_ICC_REQUESTS     packets from slot 5 CPU0/ = 20
   1 =19           3 =1
total tx L3-MGR-FM     packets to slot 5 CPU0/ = 0
   2 =0
total rx L3-MGR-FM     packets from slot 5 CPU0/ = 3
   2 =3
total tx EARL-QOS-TCAM(FC) packets to slot 5 CPU0/ = 0
   0 =0
total rx EARL-QOS-TCAM(FC) packets from slot 5 CPU0/ = 1
   0 =1
total tx PF_REDUN     packets to slot 5 CPU0/ = 12
   1 =12
total rx PF_REDUN     packets from slot 5 CPU0/ = 0
   1 =0
total tx CONST_MFIB_PFINFO_REQUESTS     packets to slot 5 CPU0/ = 0
   1 =0
total rx CONST_MFIB_PFINFO_REQUESTS     packets from slot 5 CPU0/ = 4
   1 =4
------------------ show icc flowcontrol ------------------
Class Name              FC state                     FC Counts (on/off)
                                            [ Local ]   [ Remote ]  [ IPC ]
    5 L3-MGR(FC)        [ OFF ]                 0/0         0/0         0/0
   13 EARL-ACL-TCAM(FC  [ OFF ]                 0/0         0/0         0/0
   14 QM(FC)            [ OFF ]                 0/0         0/0         0/0
   37 EARL_NDE(FC)      [ OFF ]                 0/0         0/0         0/0
   71 ACE_REQUESTS      [ OFF ]                 0/0         0/0         0/0
   77 ICC_FC_TEST_REQU  [ OFF ]                 0/0         0/0         0/0
   78 L3-MGR-QM(FC)     [ OFF ]                 0/0         0/0         0/0
   79 L3-MGR-FM         [ OFF ]                 0/0         0/0         0/0
   80 L3-MGR-INTF(FC)   [ OFF ]                 0/0         0/0         0/0
   82 L3-MGR-DSS(FC)    [ OFF ]                 0/0         0/0         0/0
   84 EARL-QOS-TCAM(FC  [ OFF ]                 0/0         0/0         0/0
  125 CONST_MFIB_PFINF  [ OFF ]                 0/0         0/0         0/0
------------------ show hw-module all fpd ------------------
% No cards with FPD support can be found in the system.
------------------ show hw-module all sensors ------------------
------------------ show hw-module subslot all oir ------------------
------------------ show ip nbar version ------------------
NBAR software version:  4
1   base                 Mv: 2
2   ftp                  Mv: 2
3   http                 Mv: 7
4   static               Mv: 6
5   tftp                 Mv: 1
6   exchange             Mv: 1
7   vdolive              Mv: 1
8   sqlnet               Mv: 1
9   rcmd                 Mv: 1
10  netshow              Mv: 1
11  sunrpc               Mv: 2
12  streamwork           Mv: 1
13  citrix               Mv: 5
14  fasttrack            Mv: 2
15  gnutella             Mv: 1
16  kazaa2               Mv: 6
17  custom-protocols     Mv: 1
18  rtsp                 Mv: 3
19  rtp                  Mv: 3
20  mgcp                 Mv: 1
21  skinny               Mv: 1
22  h323                 Mv: 1
23  sip                  Mv: 1
24  rtcp                 Mv: 1
25  edonkey              Mv: 2
26  winmx                Mv: 1
{} Mv: , {Nv: ; }
            {Iv:    - }
------------------ show crypto key mypubkey rsa ------------------
------------------ show inventory ------------------
NAME: "CISCO7606-S", DESCR: "Cisco Systems Cisco 7600 6-slot Chassis System"
PID: CISCO7606-S       , VID: V01, SN: FOX1249G0P1
NAME: "CLK-7600 1", DESCR: "OSR-7600 Clock FRU 1"
PID: CLK-7600          , VID:    , SN: NWG124701GP
NAME: "CLK-7600 2", DESCR: "OSR-7600 Clock FRU 2"
NAME: "module 5", DESCR: "RSP720-3C-GE 2 ports Route Switch Processor 720 Rev. 5.9"
PID: RSP720-3C-GE      , VID: V09, SN: JAE14070RU2
NAME: "msfc sub-module of 5", DESCR: "7600-MSFC4 C7600 MSFC4 Daughterboard Rev. 1.5"
PID: 7600-MSFC4        , VID: 000, SN: JAE14070R0N
NAME: "switching engine sub-module of 5", DESCR: "7600-PFC3C Policy Feature Card 3 Rev. 1.2"
PID: 7600-PFC3C        , VID: 000, SN: JAE1408021J
NAME: "Transceiver Gi5/1", DESCR: "Transceiver 1000BaseLH Gi5/1"
PID: N/A               , VID:    , SN: FNS0836R0N5
NAME: "Transceiver Gi5/2", DESCR: "Transceiver 1000BaseLH Gi5/2"
PID: N/A               , VID:    , SN: FNS0839K0RA
NAME: "FAN-MOD-6SHS 1", DESCR: "High Speed Fan Module for CISCO7606-S 1"
PID: FAN-MOD-6SHS      , VID: V01, SN: DCH12242403
NAME: "PS 1 PWR-2700-AC", DESCR: "(power supply type 0.0.1.4) 1"
PID: PWR-2700-AC       , VID: V02, SN: APS134300C1
NAME: "PS 2 PWR-2700-AC", DESCR: "(power supply type 0.0.1.4) 2"
PID: PWR-2700-AC       , VID: V02, SN: APS1335006V
------------------ show region ------------------
Region Manager:
      Start         End     Size(b)  Class  Media  Name
0x04000000  0x77FFFFFF  1946157056  Local  R/W    main
0x04000000  0x07FFFFFF    67108864  Local  R/W    main:rommon
0x08000000  0x0FFFFFFF   134217728  IText  R/O    main:text
0x10000000  0x115449B7    22301112  IData  R/W    main:data
0x115449B8  0x1322CA93    30310620  IBss   R/W    main:bss
0x1322CA94  0x77FFFFFF  1692218732  Local  R/W    main:heap
0x78000000  0x7FFFFFFF   134217728  Iomem  R/W    iomem
Free Region Manager:
------------------ Mempool statistics ------------------
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   1322CA94   1692218732   522442036   1169776696   1167289628   1168873196
      I/O   78000000   134217728    50320188    83897540    83838016    83831612
-------------- Top 100 allocator pc summary -----------
Allocator PC Summary for: Processor
    PC          Total   Count  Name
0x0877BA30     573424      38  Virtual Exec
0x08D313FC     119028      13  IPC Port
0x086DBED0      84980       1  AAA DB Elt Chunk
0x09AD6FA8      82636      17  TCL Chunks
0x0B892EDC      65588       1  MFI: InfoRply
0x0BD10994      65588       1  BITLIST CHUNK
0x08EB7F74      65588       1  MRIB route entry
0x08F2D9C8      65588       1  MRIB route entry
0x08D664E0      62584      74  IPC Tx Bit table
0x08D53BF4      45100       5  IPC Session Desc
0x08A39A70      32440      10  EEM Auto Registration Proc
0x08A1D3BC      29820      10  EEM Auto Registration Proc
0x08098758      20052       1  ARP Entry
0x08DE8B78      20052       1  IP ARP Adjacency Subblock
0x09AD7174      20052       1  TCL Chunks
0x08A38B4C      13320      10  policy_info
0x08D7C89C      10320       5  IPC Mcast Group
0x09A41C3C      10312       1  Virtual Exec
0x09C55660      10052       1  Watched Boolea
0x08091118      10052       1  ARP IDB Subblock
0x0B09BB88       9844       1  PM port_data
0x09BADFA0       8296       2  Resource User IDs
0x0A675998       5504      36  IPC Split Init
0x0BD28D60       5456       2  IP routing table
0x0BCCC224       4728       1  LI IDB IPC Chunk
0x086DBE34       4148       1  AAA Unique Id Hash Table
0x0A696DD8       3364       2  message nego r
0x091E371C       3160       2  TCP CB
0x08093BD4       3052       1  static ARP subblock
0x0ADFA1D4       2744       7  draco-oir:slot 5
0x08D73788       2736      36  IPC RMI Thresh table entries
0x09BA30A8       2152       2  Resource User IDs
0x0B07E954       2100       1  PF ISSU PRST media read proc
0x08CC6C14       2076       1  IPC Split Init
0x08D90118       1820       5  IPC Mcast Tx Group Session Structure
0x08091EF8       1744       1  interface ARP subblock
0x08D71C88       1580      13  IPC RU Context
0x08741490       1436       1  Connection
0x0BD345CC       1408       6  Virtual Exec
0x0875C9F8       1324      17  NameDB String
0x0B892E64       1188       1  MFI: InfoReq
0x08D716BC       1092      13  IPC RU Context Entity
0x083612CC       1040       2  BGP Open
0x08D71634        976      11  IPC Seat RU
0x08A38C64        952      10  policy_info_ent
0x0913D960        908       1  RIB: Control Block
0x09BAE2B8        844      11  IPC Split Init
0x094963F4        780       1  OSPF sw subblock
0x09C9C1D4        736       4  VPN ecomm list
0x0B179C5C        724       3  QM-SB
0x0874FEF4        704       5  TTY timer block
0x084B5E20        608       2  CEF: FIBSWSB control
0x094B2A54        608       1  Virtual Exec
0x08D73744        572       6  IPC RMI Thresh table
0x08D35C74        480       6  IPC Name
0x0A6759D4        456       6  IPC ISSU Receive Process
0x08479980        412       3  CDP sw subblock
0x09498E74        400       1  Virtual Exec
0x08D53EB8        380       5  IPC Subscriber Callback Element
0x085A3A6C        364       2  IPv4 FIB subblock
0x09C9DCDC        340       1  VPN record
0x0875D0BC        332       1  DRMI Master Reg. Slave Process
0x0A8CEE68        324       2  State Machine debug data
0x0876EA50        324       1  Virtual Exec
0x0B312020        272       2  dai_hwsb_t
0x08942744        264       2  DSS-SB
0x0A84A598        252       1  PF ISSU PRST media read proc
0x08479A54        252       3  CDP hw subblock
0x0B3A4250        236       1  RTTY Client Registration
0x08D8931C        228       3  IPC Mcast Member
0x0A5E9AD8        224       1  IPC ISSU Session
0x08837214        220       2  IPC Split Init
0x0A8CEE18        188       2  State Machine debug meta data
0x09C9DC4C        180       1  VRF sub record
0x0ADCA620        164       1  c6k ivrfs
0x0941AD18        164       1  SWIDB_SB: NETBIOS Info
0x0A8CE2B4        160       2  State Machine Instance
0x08D88EA8        156       1  IPC Mcast Group Member Session
0x09BB5D44        148       1  DRMI Master Reg. Slave Process
0x0808EA38        140       1  ARP APP Data Client
0x0A480FF8        136       1  DRMI Master Reg. Slave Process
0x0A48147C        136       1  DRMI Master Reg. Slave Process
0x0962CE28        124       1  QOS policymap name
0x0878FA10        112       1  Parser Mode
0x08F2D984        108       1  MRIB IPv6 Init Process
0x08EB7F30        108       1  MRIB IPv4 Init Process
0x087104A0        104       1  AAA MI SG NAME
0x0A5E9AF4         76       1  IPC ISSU Block the traffic
0x0B400684         76       1  PF ISSU PRST media read proc
0x09C9F93C         76       1  c6k ivrfs
0x0913D9C4         76       1  IP: RIB Name
0x0BD0D354         76       1  c6k ivrfs
0x0BD0D36C         76       1  c6k ivrfs
0x0BD0D398         76       1  c6k ivrfs
0x0A2E5D8C         76       1  c6k ivrfs
0x08CBA9FC         76       1  c6k ivrfs
0x08CBB4B8         76       1  c6k ivrfs
0x0877937C         76       1  Parser Linkage
0x0878FA78         76       1  Parser Mode Q1
0x0878FA9C         76       1  Parser Mode Q2
0x0BA9871C         76       1  MPLS VPN MIB sw subblock
Allocator PC Summary for: I/O
    PC          Total   Count  Name
------------------ remote command switch show nvlog ------------------
NVRAM log:
01. 07/28/2012 12:15:02: oir_reload_chassis:Reload Chassis requested
02. 07/28/2012 12:16:32: pf_redun_negotiate:Initialized as ACTIVE processor
03. 08/13/2012 12:11:06: oir_reload_chassis:Reload Chassis requested
04. 08/13/2012 12:12:37: pf_redun_negotiate:Initialized as ACTIVE processor
05. 08/17/2012 07:11:22: oir_reload_chassis:Reload Chassis requested
06. 08/17/2012 07:12:53: pf_redun_negotiate:Initialized as ACTIVE processor
07. 08/17/2012 07:16:11: oir_reload_chassis:Reload Chassis requested
08. 08/17/2012 07:17:41: pf_redun_negotiate:Initialized as ACTIVE processor
09. 08/21/2012 15:28:38: oir_reload_chassis:Reload Chassis requested
10. 08/21/2012 15:30:10: pf_redun_negotiate:Initialized as ACTIVE processor
11. 08/23/2012 08:14:13: oir_reload_chassis:Reload Chassis requested
12. 08/23/2012 08:15:44: pf_redun_negotiate:Initialized as ACTIVE processor
13. 08/23/2012 11:31:47: oir_reload_chassis:Reload Chassis requested
14. 08/23/2012 11:33:18: pf_redun_negotiate:Initialized as ACTIVE processor
15. 08/25/2012 03:47:44: oir_reload_chassis:Reload Chassis requested
16. 08/25/2012 03:49:15: pf_redun_negotiate:Initialized as ACTIVE processor
17. 08/25/2012 04:49:51: oir_reload_chassis:Reload Chassis requested
18. 08/25/2012 04:51:18: pf_redun_negotiate:Initialized as ACTIVE processor
19. 08/25/2012 10:02:34: oir_reload_chassis:Reload Chassis requested
20. 08/25/2012 10:04:00: pf_redun_negotiate:Initialized as ACTIVE processor
21. 08/26/2012 02:53:23: oir_reload_chassis:Reload Chassis requested
22. 08/26/2012 02:54:55: pf_redun_negotiate:Initialized as ACTIVE processor
23. 09/28/2012 20:38:05: oir_reload_chassis:Reload Chassis requested
24. 09/28/2012 20:40:14: pf_redun_negotiate:Initialized as ACTIVE processor
25. 09/28/2012 20:52:37: oir_reload_chassis:Reload Chassis requested
26. 09/28/2012 20:56:12: pf_redun_negotiate:Initialized as ACTIVE processor
27. 09/28/2012 22:09:51: oir_reload_chassis:Reload Chassis requested
28. 09/28/2012 22:11:17: pf_redun_negotiate:Initialized as ACTIVE processor
29. 09/29/2012 09:58:27: oir_reload_chassis:Reload Chassis requested
30. 09/29/2012 09:59:58: pf_redun_negotiate:Initialized as ACTIVE processor
------------------ remote command switch show platform nvhmr previous all ------------------
No reference time info
--- show ibc ---
        5 minute rx rate 52072000 bits/sec, 85844 packets/sec
        5 minute tx rate 126175000 bits/sec, 171722 packets/sec
        4471824027 packets input, 347911664783 bytes
        4471716250 broadcasts received
        4470569225 packets output, 347521079624 bytes
        3411137586 Packets CEF Switched, 0 Packets Fast Switched
        IPSEC pkts: 0
        total spd packets classified (698239 low, 34253 medium, 19975 high)
          Frames          Bytes
  Rx(0)   50973           6766619
  Rx(1)   186290388       474240607
  Tx(0)   183722434       827234336
Rx0 0      0      0      0      0        0    0
Rx1 0      0      0      957    0        0    0
  Tx Errors/State:
--- remote command switch show ibc ---
        Interface IBC0/0(idb 0x12A0BE9C)
        5 minute rx rate 0 bits/sec, 0 packets/sec
        5 minute tx rate 10000 bits/sec, 16 packets/sec
        83810 packets input, 5905868 bytes
        34080 broadcasts received
        630405 packets output, 43273548 bytes
        117830 broadcasts sent
        0 Packets CEF Switched, 0 Packets Fast Switched
        0 Packets SLB Switched, 0 Packets CWAN Switched
        Label switched pkts dropped: 0    Pkts dropped during dma: 0
        IPSEC pkts: 0
        Total short paks sent in route cache 0
        Total throttle drops 0    Input queue drops 0
        total spd packets classified (0 low, 0 medium, 9 high)
        total spd packets dropped (0 low, 0 medium, 0 high)
        IBC resets   = 1; last at 10:00:57.820 UTC Sat Sep 29 2012
          Frames          Bytes
  Rx(0)   34031           4099634
  Rx(1)   49808           5832456
  Tx(0)   630720          61091404
     Rx0 = 0                Rx1 = 0
Rx0 0      0      0      0      0        0    0
Rx1 0      0      0      0      0        0    0
  Tx Errors/State:
   Rx Resource Errors    = 0            Input Drops           = 0
   Input Errors           = 0
--- show fabric errors ---
Module errors:
slot    channel        crc      hbeat       sync   DDR sync
    5          0          0          0          0          0
Fabric errors:
slot    channel       sync     buffer    timeout
    5          0          0          0          0
--- show fabric channel-counters ---
slot channel   rxErrors   txErrors    txDrops  lbusDrops
    5       0          0          0          0          0
--- show eobc ---
  Statistics for eobc from SP/RP to linecards
        Hardware is RSP720 EOBC
        Interface EOBC0/0(idb 0x17CCC6D0)
        108696 packets input, 27128580 bytes
        4 broadcasts received
        126940 packets output, 45937033 bytes
        4301 broadcasts sent
Dev_Instance=0x183C6B98 406612888
Receive/Transmit Buffer Descriptors
        RingSz  Shadow   StartBD  LastBD   Head  Tail Pend
  Rx0    512   183C7534  79C43CC0 79C44CB8   152   0    0
  Tx0    512   0         79C44D00 79C45CF8   476   476  0
  Rx Drop On Busy Disabled
Hash match table for multicast (in use 1, maximum 64 entries):
    Entry 0 MAC Addr = 0100.8300.0000
ETSEC counters in Hardware
64b         = 685        64b-127b    = 227        128b-255b   = 51
256b-511b   = 609        512b-1023b  = 566        1024b-1518b = 937
1519b-1522b = 0          RxBytes     = 0          RxPkt       = 49
RxFCSErr    = 0          RxMCast     = 27         RxBCast     = 4
RxCntrlFr   = 0          RxPauseFR   = 0          RxUnkop     = 0
RxAlignErr  = 0          RxLenErr    = 0          RxCodeErr   = 0
RxSenseErr  = 0          RxUnder     = 0          RxOver      = 0
RxFrag      = 10         RxJab       = 0          RxDrop      = 0
RxFilerRej  = 0          Txbytes     = 0          TxPkt       = 988
TxMCast     = 203        TxBCast     = 0          TxPause     = 0
TxDef       = 205        TxCol       = 29         TxMCol      = 3
TxLateCol   = 0          TxExCol     = 0          TxTotCol    = 38
TxDrop      = 0          TxJab       = 0          TxFCS       = 0
TxOver      = 0          TxUnder     = 0          TxFrg       = 0
  Statistics for eobc fifo between RP and SP
        Hardware is RSP720 FIFO EOBC
        Interface EOBC0/2(idb 0x17C37190)
        528379 packets input, 217642492 bytes
        522054 packets output, 80299976 bytes
        0 broadcasts sent
Dev_Instance=0x18AC804C 413958220
  Rx0    256   18AC89E8  7AA85D40 7AA86538   251   0    0
  Tx0    256   0         7AA86580 7AA86D78   70    70   0
64b         = 911        64b-127b    = 77         128b-255b   = 323
256b-511b   = 145        512b-1023b  = 900        1024b-1518b = 525
1519b-1522b = 0          RxBytes     = 0          RxPkt       = 1019
RxFCSErr    = 0          RxMCast     = 0          RxBCast     = 0
RxFrag      = 0          RxJab       = 0          RxDrop      = 0
RxFilerRej  = 0          Txbytes     = 0          TxPkt       = 838
TxMCast     = 0          TxBCast     = 0          TxPause     = 0
TxDef       = 0          TxCol       = 0          TxMCol      = 0
TxLateCol   = 0          TxExCol     = 0          TxTotCol    = 0
--- remote command switch show eobc ---
        Interface EOBC0/0(idb 0x119A9C18)
        178322 packets input, 14379237 bytes
        4305 broadcasts received
        174034 packets output, 30797540 bytes
        28 broadcasts sent
Dev_Instance=0x12305D74 305159540
  Rx0    512   12306710  3D9ECE40 3D9EDE38   146   0    0
  Tx0    512   0         3D9EDE80 3D9EEE78   466   466  0
Hash match table for multicast (in use 5, maximum 64 entries):
    Entry 0 MAC Addr = 0100.8200.0000
    Entry 1 MAC Addr = 0100.8100.0000
    Entry 2 MAC Addr = 0100.8600.0000
    Entry 3 MAC Addr = 0100.8b00.0000
    Entry 4 MAC Addr = 0100.8500.0000
64b         = 686        64b-127b    = 226        128b-255b   = 51
256b-511b   = 609        512b-1023b  = 566        1024b-1518b = 936
1519b-1522b = 0          RxBytes     = 0          RxPkt       = 82
RxFCSErr    = 0          RxMCast     = 203        RxBCast     = 6
RxFrag      = 34         RxJab       = 0          RxDrop      = 0
RxFilerRej  = 0          Txbytes     = 0          TxPkt       = 978
TxMCast     = 27         TxBCast     = 0          TxPause     = 0
TxDef       = 25         TxCol       = 2          TxMCol      = 1
TxLateCol   = 0          TxExCol     = 0          TxTotCol    = 6
        Interface EOBC0/2(idb 0x11C0B184)
        543300 packets input, 82449311 bytes
        1 broadcasts received
        549625 packets output, 248488229 bytes
        0 broadcasts sent
Dev_Instance=0x12A07104 312504580
  Rx0    256   12A07AA0  3E82EEC0 3E82F6B8   68    0    0
  Tx0    256   0         3E82F700 3E82FEF8   249   249  0
64b         = 914        64b-127b    = 82         128b-255b   = 325
256b-511b   = 147        512b-1023b  = 901        1024b-1518b = 260
1519b-1522b = 0          RxBytes     = 0          RxPkt       = 580
RxSenseErr  = 0          RxUnder     = 21240      RxOver      = 0
RxFilerRej  = 0          Txbytes     = 0          TxPkt       = 761
Slot 5
--- remote command switch show plat hard asicreg PINNACLE slot 5 port 1 error-counters print-non-zero ---
--- remote command switch show plat hard asicreg PINNACLE slot 5 port 2 error-counters print-non-zero ---
--- remote command switch show plat hard asicreg PINNACLE slot 5 port 3 error-counters print-non-zero ---
--- remote command switch show plat hard asicreg PINNACLE slot 5 port 4 error-counters print-non-zero ---
--- show tech platform earl ---
--- show mls statistics ---
Statistics for Earl in Module 5
L2 Forwarding Engine
  Total packets Switched                : 19023027249
L3 Forwarding Engine
  Total packets Processed               : 19022993212 @ 343905 pps
  Total packets L3 Switched             : 10040602606 @ 177693 pps
  Total Packets Bridged                 : 4473070904
  Total Packets FIB Switched            : 10040602606
  Total Packets ACL Routed              : 0
  Total Packets Netflow Switched        : 0
  Total Mcast Packets Switched/Routed   : 101545
  Total ip packets with TOS changed     : 2
  Total ip packets with COS changed     : 2
  Total non ip packets COS changed      : 0
  Total packets dropped by ACL          : 154738
  Total packets dropped by Policing     : 0
  Total packets exceeding CIR           : 0
  Total packets exceeding PIR           : 0
Errors
  MAC/IP length inconsistencies         : 0
  Short IP packets received             : 0
  IP header checksum errors             : 0
  No-route packet drops                 : 213434601
  TTL failures                          : 160
  MTU failures                          : 4389
Total packets L3 Processed by all Modules: 19022993212 @ 343905 pps
--- remote command switch show platform hardware earl status ---
Superman 0 interrupt counts : Total 3224800
              se_one: 0
              se_hwm: 0
               se_dn: 3192033
            ntfy_one: 0
            ntfy_hwm: 0
           ntfy_ovfl: 0
      ft_b0_corr_ecc: 0
    ft_b0_uncorr_ecc: 0
      ft_b1_corr_ecc: 0
    ft_b1_uncorr_ecc: 0
  ft_b0_multi_pg_hit: 0
  ft_b1_multi_pg_hit: 0
       l2_flush_done: 0
           loop_ntfy: 0
      ntfy_fifo_full: 0
        l2_line_full: 0
              mc_cap: 32775
     b0_invld_pg_acc: 0
     b1_invld_pg_acc: 0
       pkt_crc32_err: 0
         cpu_par_err: 0
         cpu_timeout: 0
        rbus_timeout: 0
        dbus_timeout: 0
       ip_chksum_err: 0
          l3_fcs_err: 0
        dbus_seq_err: 0
        dbus_hdr_err: 0
   l2l3_seq_mismatch: 0
     l3_rcv_ovfl_err: 0
        l2_merge_err: 0
Tycho Interrupts: Total - 187826
CPU interrupt        block : Total interrupts - 0
Netflow interrupt    block : Total interrupts - 0
   IFIFO_OVF_INT         : 0
   SINGLE_BIT_ECC_INT    : 0
   MULTI_BIT_ECC_INT     : 0
   ECC_DATA_CAPT_INT     : 0
   TCAM_THRLD_EXCD_INT   : 0
   ICAM_THRLD_EXCD_INT   : 0
   TABLE_FULL_INT        : 0
   ENTRY_ALIAS_INT       : 0
FIB interrupt        block : Total interrupts - 0
   FC_FOVR_INT           : 0
   FC_FUDR_INT           : 0
   BP_FOVR_INT           : 0
   BP_FUDR_INT           : 0
   RS_FOVR_INT           : 0
   RS_FUDR_INT           : 0
   AJ_FOVR_INT           : 0
   AJ_FUDR_INT           : 0
   FB_COR_ECC_INT        : 0
   FB_UNCOR_ECC_INT      : 0
Search interrupt     block : Total interrupts - 187796
Adj. Statistics tabl block : Total interrupts - 0
Adj. table interface block : Total interrupts - 0
   AT_SEQ_ERR_INT        : 0
   AT_FOVR_INT           : 0
   AT_FUDR_INT           : 0
   AT_IB_ADJ_INT         : 0
   AT_BZONE_INT          : 0
   AT_CORR_ECC_ERR_INT   : 0
   AT_UNCORR_ECC_ERR_INT : 0
   AT_ECC_ERR_DATA_CAPT  : 0
Packet Parser block  block : Total interrupts - 0
   IP_LEN_INT            : 0
   IP_SHRT_INT           : 0
   IP_CS_INT             : 0
   QDBUS_CRC_INT         : 0
   QDBUS_LEN_INT         : 0
   IB_LEN_INT            : 0
   IB_SEC_INT            : 0
Decision Engine bloc block : Total interrupts - 0
   NS_ECC_SBE_INT        : 0
   NS_ECC_MBE_INT        : 0
   NS_ECC_DCE_INT        : 0
   ACL_SEQ_ERR_INT       : 0
   STAT_FOVF_INT         : 0
   RSLT_FOVF_INT         : 0
   GEM_MEM_LEAK_INT      : 0
Rewrite block interr block : Total interrupts - 0
   RW_VO_INT             : 0
   RW_VU_INT             : 0
   RW_RO_INT             : 0
   RW_RU_INT             : 0
Statistics block int block : Total interrupts - 30
   GLOBAL_OVFL           : 0
   BGP_OVFL              : 30
   VLAN_OVFL_0           : 0
   VLAN_OVFL_1           : 0
   VLAN_OVFL_2           : 0
   VLAN_OVFL_3           : 0
   VLAN_OVFL_4           : 0
   VLAN_OVFL_5           : 0
   INIT_DONE             : 0
Level 4 Map interfac block : Total interrupts - 0
   L4MAP_OVFL            : 0
Key Queue Block inte block : Total interrupts - 0
   KQ_OVFL               : 0
Interrupt statistics for Kuma 0
Kuma cpu parity error                                        : 0
Kuma K interface: data intf crc error                        : 0
Kuma K'interface: data intf crc error                        : 0
Kuma K interface: result intf hdr fcs err                    : 0
Kuma K interface: result intf data fcs err                   : 0
Kuma K'interface: result intf hdr fcs err                    : 0
Kuma K'interface: result intf data fcs err                   : 0
Kuma K interface: intf freeze err                            : 0
Kuma K'interface: intf freeze err                            : 0
Kuma stats overflow_0 err                                    : 0
Kuma stats overflow_1 err                                    : 0
Kuma stats saturate_0 err                                    : 0
Kuma stats saturate_1 err                                    : 0
Kuma K'interface err                                         : 0
Kuma K interface err                                         : 0
Kuma E interface: frame crc error on received dbus frame     : 0
Kuma E interface: header crc error on received dbus frame    : 0
Kuma E interface: length error on received dbus frame        : 0
Kuma E interface: received rbus frame seqeunce mismatch err  : 0
Kuma E interface: seqtbl overflow err                        : 0
Kuma E interface: seqtbl underrun err                        : 0
Kuma E interface: seqtbl is not empty when dbus or rbus out  : 0
Kuma E interface: rbrx fcs1/header checksum err              : 0
Kuma E interface: rbrx fcs2/data checksum err                : 0
Kuma E interface: dbus seq num out of order err              : 0
Kuma E interface: rbus seq num out of order                  : 0
Kuma E interface: dbus fci counter reached                   : 0
Kuma E interface: dbus idle timeout                          : 0
Kuma E interface: rbus idle timeout                          : 0
Kuma E interface: rbus async fifo flow controlled            : 0
Kuma E interface: dbus async fifo flow controlled            : 0
Kuma E interface: dbus transmit for K' fifo full             : 0
Kuma E interface: dbus transmit for K fifo full              : 0
Kuma E interface: rbus transmit fifo full                    : 0
Kuma E interface: rbus transmit fcs1 err                     : 0
Kuma E interface: rbus transmit fcs2 err                     : 0
No of times all interrupts got throttled                     : 0
No of times all interrupts got unthrottled                   : 0
Kuma 1 Soft Reset Reg
SOFT_RESET_REG:              FFFF
Kuma 1 EIF Ebus Cfg Reg
EIF_EBUS_CFG:              E8C6Forwarding statistics for kuma 0
KIF DBUS PKTS:                  0x00000000
KIF RBUS PKTS:                  0x00000000
KIF DBUS PKT CRC ERRORS:        0x00000000
KIF RBUS PKT HDR FCS ERRORS:    0x00000000
KIF RBUS PKT DATA ERRORS:       0x00000000
PIF RBUS PKTS:                  0x15AF413D
PIF DBUS PKT CRC ERRORS:        0x00000000
PIF RBUS PKT HDR FCS ERRORS:    0x00000000
PIF RBUS PKT DATA ERRORS:       0x00000000
EIF DBUS COMPACT PKTS:          0x15AF413B
EIF DBUS LEGACY PKTS:           0x00000000
EIF DBUS TRUNCATED PKTS:        0x00001C09
EIF DBUS EXTENDED PKTS:         0x00000000
EIF RBUS NORMAL PKTS:           0x15AF413B
EIF RBUS EXTENDED PKTS:         0x00000000
EIF DBUS PKT HDR CRC ERRORS:    0x00000000
EIF DBUS PKT DATA CRC ERRORS:   0x00000000
EIF RBUS PKT HDR FCS ERRORS:    0x00000000
EIF RBUS PKT DATA ERRORS:       0x00000000
--- remote command switch show platform hardware earl statistics ---
Superman 0 Forwarding statistics:
Forwarded Frames                   = 0x000000046DDD4DF4 (19023089140)
Frames fwd'ed to Tycho             = 0x000000046DDCC900 (19023055104)
L3 results rcvd                    = 0x000000046DDCC8FF (19023055103)
Src Mac entries created in Bank 0  = 0x00000001FA770847 (8497072199)
Src Mac entries created in Bank 1  = 0x00000002736645AE (10526016942)
Dst Mac entries created in Bank 0  = 0x000000000019D3F7 (1692663)
Dst Mac entries created in Bank 1  = 0x000000046DC379FE (19021396478)
L2 banks congest status            = 0x0000000000000000 (0)
frames redirected due to Src Mac   = 0x0000000000000003 (3)
frames redirected due to Dst Mac   = 0x00000000000084F0 (34032)
Src Mac misses                     = 0x00000003635A3D02 (14551760130)
Dst Mac misses                     = 0x0000000360F15B9F (14511332255)
line full encountered during New l = 0x0000000000000000 (0)
frames matching fid_hit reg        = 0x0000000000085756 (546646)
frames rcvd with protocol code 0   = 0x000000046DD29B4E (19022388046)
frames rcvd with protocol code 1   = 0x0000000000000000 (0)
frames rcvd with protocol code 2   = 0x0000000000000000 (0)
frames rcvd with protocol code 3   = 0x000000000000016C (364)
frames rcvd with protocol code 4   = 0x0000000000000000 (0)
frames rcvd with protocol code 5   = 0x0000000000000000 (0)
frames rcvd with protocol code 6   = 0x0000000000007551 (30033)
frames rcvd with protocol code 7   = 0x0000000000000000 (0)
frames rcvd with protocol code 8   = 0x0000000000000000 (0)
frames rcvd with protocol code 9   = 0x0000000000000000 (0)
frames rcvd with protocol code 10  = 0x0000000000000000 (0)
frames rcvd with protocol code 11  = 0x0000000000000000 (0)
frames rcvd with protocol code 12  = 0x0000000000000000 (0)
frames rcvd with protocol code 13  = 0x0000000000000000 (0)
frames rcvd with protocol code 14  = 0x0000000000000000 (0)
frames rcvd with protocol code 15  = 0x00000000000A3BEB (670699)
bytes rcvd with protocol code 0    = 0x0000018DF77CC81E (1709254166558)
bytes rcvd with protocol code 1    = 0x0000000000000000 (0)
bytes rcvd with protocol code 2    = 0x0000000000000000 (0)
bytes rcvd with protocol code 3    = 0x000000000000732C (29484)
bytes rcvd with protocol code 4    = 0x0000000000000000 (0)
bytes rcvd with protocol code 5    = 0x0000000000000000 (0)
bytes rcvd with protocol code 6    = 0x0000000000319E6B (3251819)
bytes rcvd with protocol code 7    = 0x0000000000000000 (0)
bytes rcvd with protocol code 8    = 0x0000000000000000 (0)
bytes rcvd with protocol code 9    = 0x0000000000000000 (0)
bytes rcvd with protocol code 10   = 0x0000000000000000 (0)
bytes rcvd with protocol code 11   = 0x0000000000000000 (0)
bytes rcvd with protocol code 12   = 0x0000000000000000 (0)
bytes rcvd with protocol code 13   = 0x0000000000000000 (0)
bytes rcvd with protocol code 14   = 0x0000000000000000 (0)
bytes rcvd with protocol code 15   = 0x0000000002CAA4DE (46834910)
frames rate limited                = 0x0000000000000000 (0)
correctable errors in bank 0       = 0x0000000000000000 (0)
uncorrectable errors in bank 0     = 0x0000000000000000 (0)
correctable errors in bank 1       = 0x0000000000000000 (0)
uncorrectable errors in bank 1     = 0x0000000000000000 (0)
DBus Header Checksum errors        = 0x0000000000000000 (0)
address of the line full           = 0x00000000
address of the last error in Bank0 = 0x0000BD6F
address of the last error in Bank1 = 0x0000FFFF
--- remote command switch show mls cef hardware ---
  CEF TCAM v2:
        65536 rows/device, 4 device(s)
        32 entries/mask-block
        8192 total blocks (32b wide)
        1212416 s/w table memory
  Options:
        sanity check: on
        sanity interval: 301 seconds
        consistency check: on
        consistency interval: 11 seconds
        redistribution: off
            redistribution interval: 120 seconds
            redistribution threshold: 10
        compression: on
            compression interval: 31 seconds
        tcam/ssram shadowing: on
  Operation Statistics:
        Entries inserted:               0000000000341693
        Entries deleted:                0000000000010497
        Entries compressed:             0000000000001668
        Blocks inserted:                0000000000069830
        Blocks deleted:                 0000000000063677
        Blocks compressed:              0000000000000121
        Blocks shuffled:                0000000000059315
        Blocks deleted for exception:   0000000000004220
        Direct h/w modifications:       0000000000000000
  Background Task Statistics:
        Consistency Check count:        0000000000006898
        Consistency Errors:             0000000000000000
        SSRAM Consistency Errors:       0000000000000000
        Sanity Check count:             0000000000000253
        Sanity Check Errors:            0000000000000000
        Compression count:              0000000000000351
        Exception Handling status    : on
        L3 Hardware switching status : on
        Fatal Error Handling Status  : Reset
        Fatal Errors:                   0000000000000000
        Fatal Error Recovery Count:     0000000000000000
  SSRAM ECC error summary:
        Uncorrectable ecc entries    : 0
        Correctable ecc entries      : 0
        Packets dropped              : 0
        Packets software switched    : 0
FIB SSRAM Entry status
Key: UC - Uncorrectable error, C - Correctable error
        SSRAM banks  :  Bank0    Bank1
No ECC errors reported in FIB SSRAM.
--- remote command switch show platform hardware superman interrupts ---
Superman 0 interrupt counts : Total 3224822
              se_one: 0
              se_hwm: 0
               se_dn: 3192055
            ntfy_one: 0
            ntfy_hwm: 0
           ntfy_ovfl: 0
      ft_b0_corr_ecc: 0
    ft_b0_uncorr_ecc: 0
      ft_b1_corr_ecc: 0
    ft_b1_uncorr_ecc: 0
       l2_flush_done: 0
           loop_ntfy: 0
      ntfy_fifo_full: 0
        l2_line_full: 0
              mc_cap: 32775
     b0_invld_pg_acc: 0
     b1_invld_pg_acc: 0
       pkt_crc32_err: 0
         cpu_par_err: 0
         cpu_timeout: 0
        rbus_timeout: 0
        dbus_timeout: 0
       ip_chksum_err: 0
          l3_fcs_err: 0
        dbus_seq_err: 0
        dbus_hdr_err: 0
     l3_rcv_ovfl_err: 0
        l2_merge_err: 0
--- remote command switch show platform hardware superman forwarding-table-ecc ---
No forwarding table ecc errors found
--- remote command switch show platform hardware superman config ---
Superman hash configuration
Hash 0: x^12+x^8+x^6+x^5+1
Hash 1: x^12+x^9+x^8+x^6+x^5+x^4+1
Superman 1 Control Reg
SYS_CONFIG:               2
NEW_MIX_HASH_EN:          Enable
PACKET_FORMAT:            Compact
GE_SUPP_EN:               Disable
IPV6_RUNT_ETHERNET_CHK_DIS: 0
IPV6_IGN_L4_HDR_CHK_DIS:    0
IPV6_LANE_HDR_VLD_CHK_DIS:  0
VLAN_IP_HASH_EN:            Enable
ROHINI_WRKARND_EN:          Disable
ARGOS_MN_EGRS_WRKARND_EN:   Disable
ARGOS_MN_IGRS_WRKARND_EN:   Disable
ETHERCHNL_SLOT_NUM:         0xD
NEG_MN_FLOOD_DIS:           0
POS_MN_FLOOD_DIS:           0
CAP2_GEN_ORPOE_DIS:       Disable
BRDG_ON_FF_DIS:           Disable
DBUS_CRC:                 Enable
L3_FCS1_EN:               Enable
L3_FCS2_EN:               Enable
TIMEOUT_DIAG:             Disable
TIMEOUT_CNT:              0
RBUS_TIMEOUT:             Enable
DBUS_TIMEOUT:             Enable
RBUS:                     Enable
DBUS:                     Enable
CPU_PAR_CHK:              Disable
CPU_PAR_POL:              Enable
LOOP_NTFY_DIAG:           Disable
LOOP_NTFY_EN:             Disable
RED_FLUSH_EN:             Disable
L2_ONLY:                  Disable
IGMP_SNOOP_ON_MCAST_ONLY: Enable
IPV6_IGMP_SNOOP_DIS:      Disable
INGRESS_GEN_MN_DIS:       Enable
RB_SC_DIS:                Disable
RES_CAP_SEL:              CAP1 and CAP2
EGRESS_CAP_SEL:           Enable
DONT_USE_IP_FOR_RBH:      Disable
BNDL_SEL:                 IP
BNDL_HASH:                Source XOR Destination
RBH_HASH_SEL:             x^17 + x^4 + 1
USE_HDR_RBH:              Enable
IGNR_VLAN:                Disable
HASH_CNFG:                0
HASH_INPUT_SEL:           Lyra mode
BCST_MISS:                Disable
COND_LRN:                 Enable
FT_ECC_CHK_DIS:           Disable
FT_ECC_CORR_DIS:          Disable
BPDU_CHK:                 Enable
NTFY_FF_CTL:              Modify
NTFY_IL:                  Disable
NTFY_NL:                  Disable
CLEAR_IGS:                Disable
CACHE_ENH_EN:             Disable
ALWAYS_L3_VLAN_LKUP:      Enable
CCC_FIX_NON_L3_FRM_EN:    Disable
CCC_FIX_EGR_EN:           Disable
CCC_FIX:                  Enable
--- remote command switch show platform hardware tycho interrupts ---
Tycho Interrupts: Total - 187830
   IFIFO_OVF_INT         : 0
   TABLE_FULL_INT        : 0
   ENTRY_ALIAS_INT       : 0
   FC_FOVR_INT           : 0
   FC_FUDR_INT           : 0
   BP_FOVR_INT           : 0
   BP_FUDR_INT           : 0
   RS_FOVR_INT           : 0
   RS_FUDR_INT           : 0
   AJ_FOVR_INT           : 0
   AJ_FUDR_INT           : 0
   FB_COR_ECC_INT        : 0
Search interrupt     block : Total interrupts - 187800
   AT_SEQ_ERR_INT        : 0
   AT_FOVR_INT           : 0
   AT_FUDR_INT           : 0
   AT_IB_ADJ_INT         : 0
   AT_BZONE_INT          : 0
   IP_LEN_INT            : 0
   IP_SHRT_INT           : 0
   IP_CS_INT             : 0
   QDBUS_CRC_INT         : 0
   QDBUS_LEN_INT         : 0
   IB_LEN_INT            : 0
   IB_SEC_INT            : 0
   NS_ECC_SBE_INT        : 0
   NS_ECC_MBE_INT        : 0
   NS_ECC_DCE_INT        : 0
   ACL_SEQ_ERR_INT       : 0
   STAT_FOVF_INT         : 0
   RSLT_FOVF_INT         : 0
   RW_VO_INT             : 0
   RW_VU_INT             : 0
   RW_RO_INT             : 0
   RW_RU_INT             : 0
   GLOBAL_OVFL           : 0
   BGP_OVFL              : 30
   VLAN_OVFL_0           : 0
   VLAN_OVFL_1           : 0
   VLAN_OVFL_2           : 0
   VLAN_OVFL_3           : 0
   VLAN_OVFL_4           : 0
   VLAN_OVFL_5           : 0
   INIT_DONE             : 0
   L4MAP_OVFL            : 0
   KQ_OVFL               : 0
--- remote command switch show platform software earl reset config ---
EBUS Out of seq.        : Enabled
Earl freeze check.      : Enabled
EARL Patch invocation limit per every 30 secs  : 10
Upon reaching EARL patch invocation limit : Crash
--- remote command switch show platform software earl reset history ---
Num. of times patch applied   : 0
Num. of times patch requested : 0
AclDeny detection: (Total=0 Failed=0)
Slot 5
--- remote command switch show platform hardware asic-versions slot 5 ---
            ASIC Name      Version
slot : 5
         ST_TYCHO (68)     (3.2)
      ST_SUPERMAN (67)     (2.2)
             KUMA (70)     (3.0)
              SSA (43)     (9.0)
              SSO (44)     (2.0)
         HYPERION (42)     (6.0)
         PINNACLE (26)     (4.0)
--- remote command module 5 show platform hardware earl status ---
              se_one: 0
              se_hwm: 0
               se_dn: 3192055
            ntfy_one: 0
            ntfy_hwm: 0
           ntfy_ovfl: 0
      ft_b0_corr_ecc: 0
    ft_b0_uncorr_ecc: 0
      ft_b1_corr_ecc: 0
    ft_b1_uncorr_ecc: 0
       l2_flush_done: 0
           loop_ntfy: 0
      ntfy_fifo_full: 0
        l2_line_full: 0
              mc_cap: 32775
     b0_invld_pg_acc: 0
     b1_invld_pg_acc: 0
       pkt_crc32_err: 0
         cpu_par_err: 0
         cpu_timeout: 0
        rbus_timeout: 0
        dbus_timeout: 0
       ip_chksum_err: 0
          l3_fcs_err: 0
        dbus_seq_err: 0
        dbus_hdr_err: 0
     l3_rcv_ovfl_err: 0
        l2_merge_err: 0
   IFIFO_OVF_INT         : 0
   TABLE_FULL_INT        : 0
   ENTRY_ALIAS_INT       : 0
   FC_FOVR_INT           : 0
   FC_FUDR_INT           : 0
   BP_FOVR_INT           : 0
   BP_FUDR_INT           : 0
   RS_FOVR_INT           : 0
   RS_FUDR_INT           : 0
   AJ_FOVR_INT           : 0
   AJ_FUDR_INT           : 0
   FB_COR_ECC_INT        : 0
   AT_SEQ_ERR_INT        : 0
   AT_FOVR_INT           : 0
   AT_FUDR_INT           : 0
   AT_IB_ADJ_INT         : 0
   AT_BZONE_INT          : 0
   IP_LEN_INT            : 0
   IP_SHRT_INT           : 0
   IP_CS_INT             : 0
   QDBUS_CRC_INT         : 0
   QDBUS_LEN_INT         : 0
   IB_LEN_INT            : 0
   IB_SEC_INT            : 0
   NS_ECC_SBE_INT        : 0
   NS_ECC_MBE_INT        : 0
   NS_ECC_DCE_INT        : 0
   ACL_SEQ_ERR_INT       : 0
   STAT_FOVF_INT         : 0
   RSLT_FOVF_INT         : 0
   RW_VO_INT             : 0
   RW_VU_INT             : 0
   RW_RO_INT             : 0
   RW_RU_INT             : 0
   GLOBAL_OVFL           : 0
   BGP_OVFL              : 30
   VLAN_OVFL_0           : 0
   VLAN_OVFL_1           : 0
   VLAN_OVFL_2           : 0
   VLAN_OVFL_3           : 0
   VLAN_OVFL_4           : 0
   VLAN_OVFL_5           : 0
   INIT_DONE             : 0
   L4MAP_OVFL            : 0
   KQ_OVFL               : 0
PIF RBUS PKTS:                  0x0009CBFB
EIF DBUS COMPACT PKTS:          0x0009CBFC
EIF DBUS TRUNCATED PKTS:        0x0000000D
EIF RBUS NORMAL PKTS:           0x0009CBFE
--- remote command module 5 show platform hardware earl statistics ---
Forwarded Frames                   = 0x000000046DE71C31 (19023731761)
Frames fwd'ed to Tycho             = 0x000000046DE6973B (19023697723)
L3 results rcvd                    = 0x000000046DE6973B (19023697723)
Src Mac entries created in Bank 0  = 0x00000001FA799073 (8497238131)
Src Mac entries created in Bank 1  = 0x00000002736D8BBE (10526493630)
Dst Mac entries created in Bank 0  = 0x000000000019D408 (1692680)
Dst Mac entries created in Bank 1  = 0x000000046DCD4829 (19022039081)
frames redirected due to Dst Mac   = 0x00000000000084F1 (34033)
Src Mac misses                     = 0x000000036361AB8B (14552247179)
Dst Mac misses                     = 0x0000000360F8CA29 (14511819305)
frames matching fid_hit reg        = 0x0000000000085763 (546659)
frames rcvd with protocol code 0   = 0x000000046DDC6974 (19023030644)
frames rcvd with protocol code 6   = 0x0000000000007557 (30039)
frames rcvd with protocol code 15  = 0x00000000000A3BFA (670714)
bytes rcvd with protocol code 0    = 0x0000018DFAE33B5A (1709311212378)
bytes rcvd with protocol code 6    = 0x000000000031A063 (3252323)
bytes rcvd with protocol code 15   = 0x0000000002CAA8D2 (46835922)
--- remote command module 5 show platform hardware superman interrupts ---
Superman 0 interrupt counts : Total 3224874
              se_one: 0
              se_hwm: 0
               se_dn: 3192107
            ntfy_one: 0
            ntfy_hwm: 0
           ntfy_ovfl: 0
      ft_b0_corr_ecc: 0
    ft_b0_uncorr_ecc: 0
      ft_b1_corr_ecc: 0
    ft_b1_uncorr_ecc: 0
       l2_flush_done: 0
           loop_ntfy: 0
      ntfy_fifo_full: 0
        l2_line_full: 0
              mc_cap: 32775
     b0_invld_pg_acc: 0
     b1_invld_pg_acc: 0
       pkt_crc32_err: 0
         cpu_par_err: 0
         cpu_timeout: 0
        rbus_timeout: 0
        dbus_timeout: 0
       ip_chksum_err: 0
          l3_fcs_err: 0
        dbus_seq_err: 0
        dbus_hdr_err: 0
     l3_rcv_ovfl_err: 0
        l2_merge_err: 0
--- remote command module 5 show platform hardware superman forwarding-table-ecc ---
--- remote command module 5 show platform hardware superman config ---
SYS_CONFIG:               2
GE_SUPP_EN:               Disable
NEG_MN_FLOOD_DIS:           0
POS_MN_FLOOD_DIS:           0
DBUS_CRC:                 Enable
L3_FCS1_EN:               Enable
L3_FCS2_EN:               Enable
TIMEOUT_CNT:              0
RBUS:                     Enable
DBUS:                     Enable
CPU_PAR_POL:              Enable
L2_ONLY:                  Disable
RB_SC_DIS:                Disable
BNDL_SEL:                 IP
USE_HDR_RBH:              Enable
IGNR_VLAN:                Disable
HASH_CNFG:                0
BCST_MISS:                Disable
COND_LRN:                 Enable
BPDU_CHK:                 Enable
NTFY_FF_CTL:              Modify
NTFY_IL:                  Disable
NTFY_NL:                  Disable
CLEAR_IGS:                Disable
CCC_FIX:                  Enable
SYS_CONFIG:               2
GE_SUPP_EN:               Disable
NEG_MN_FLOOD_DIS:           0
POS_MN_FLOOD_DIS:           0
DBUS_CRC:                 Enable
L3_FCS1_EN:               Enable
L3_FCS2_EN:               Enable
TIMEOUT_CNT:              0
RBUS:                     Enable
DBUS:                     Enable
CPU_PAR_POL:              Enable
L2_ONLY:                  Disable
RB_SC_DIS:                Disable
BNDL_SEL:                 IP
USE_HDR_RBH:              Enable
IGNR_VLAN:                Disable
HASH_CNFG:                0
BCST_MISS:                Disable
COND_LRN:                 Enable
BPDU_CHK:                 Enable
NTFY_FF_CTL:              Modify
NTFY_IL:                  Disable
NTFY_NL:                  Disable
CLEAR_IGS:                Disable
CCC_FIX:                  Enable
--- remote command module 5 show platform software earl reset config ---
--- remote command module 5 show platform software earl reset history ---
--- show error-detection crc status ---
------------------ show buffers ------------------
Buffer elements:
     850 in free list (500 max allowed)
     4276969 hits, 0 misses, 619 created
Public buffer pools:
Small buffers, 104 bytes (total 1024, permanent 1024):
     1017 in free list (128 min, 2048 max allowed)
     1523393 hits, 0 misses, 0 trims, 0 created
     0 failures (0 no memory)
Medium buffers, 256 bytes (total 3000, permanent 3000):
     3000 in free list (64 min, 3000 max allowed)
     74456 hits, 0 misses, 0 trims, 0 created
Middle buffers, 600 bytes (total 512, permanent 512, peak 584 @ 19:08:45):
     508 in free list (64 min, 1024 max allowed)
     82034 hits, 24 misses, 72 trims, 72 created
Big buffers, 1536 bytes (total 1000, permanent 1000):
     1000 in free list (64 min, 1000 max allowed)
     199887 hits, 0 misses, 0 trims, 0 created
VeryBig buffers, 4520 bytes (total 10, permanent 10):
     10 in free list (0 min, 300 max allowed)
     628 hits, 0 misses, 0 trims, 0 created
Large buffers, 9240 bytes (total 8, permanent 8):
     8 in free list (0 min, 10 max allowed)
     30 hits, 0 misses, 0 trims, 0 created
Huge buffers, 18024 bytes (total 2, permanent 2):
     2 in free list (0 min, 4 max allowed)
     15 hits, 0 misses, 0 trims, 0 created
Interface buffer pools:
CF Small buffers, 104 bytes (total 100, permanent 100):
     100 in free list (100 min, 200 max allowed)
CF Middle buffers, 600 bytes (total 100, permanent 100):
Syslog ED Pool buffers, 600 bytes (total 288, permanent 288):
     256 in free list (288 min, 288 max allowed)
     177 hits, 0 misses
LI Middle buffers, 600 bytes (total 512, permanent 256, peak 512 @ 21:09:25):
     256 in free list (256 min, 768 max allowed)
     171 hits, 85 fallbacks, 0 trims, 256 created
     256 max cache size, 256 in cache
     0 hits in cache, 0 misses in cache
DMA-2 buffers, 1536 bytes (total 1024, permanent 1024):
     512 in free list (0 min, 1024 max allowed)
     512 hits, 0 misses
     512 max cache size, 512 in cache
CF Big buffers, 1536 bytes (total 25, permanent 25):
     25 in free list (25 min, 50 max allowed)
LI Big buffers, 1536 bytes (total 512, permanent 256, peak 512 @ 21:09:25):
EOBC0/0 buffers, 2198 bytes (total 6144, permanent 6144):
     3072 in free list (0 min, 6144 max allowed)
     3072 hits, 0 fallbacks
     3072 max cache size, 2559 in cache
     109208 hits in cache, 0 misses in cache
EOBC0/2 buffers, 2198 bytes (total 6144, permanent 6144):
     3072 max cache size, 2816 in cache
     528908 hits in cache, 0 misses in cache
IPC buffers, 4096 bytes (total 2016, permanent 2016):
     1994 in free list (448 min, 4480 max allowed)
     157875 hits, 0 fallbacks, 0 trims, 0 created
CF VeryBig buffers, 4520 bytes (total 2, permanent 2):
     2 in free list (2 min, 4 max allowed)
LI Very Big buffers, 4520 bytes (total 257, permanent 128, peak 257 @ 21:10:22):
     129 in free list (128 min, 384 max allowed)
     85 hits, 43 fallbacks, 14 trims, 143 created
     128 max cache size, 128 in cache
CF Large buffers, 5024 bytes (total 1, permanent 1):
     1 in free list (1 min, 2 max allowed)
Private Huge IPC buffers, 18024 bytes (total 2, permanent 2):
     2 in free list (1 min, 4 max allowed)
Private Huge buffers, 65280 bytes (total 2, permanent 2):
     107 hits, 0 misses, 0 trims, 0 created
Header pools:
Particle Clones:
     1024 clones, 5 hits, 0 misses
Public particle pools:
Normal buffers, 1532 bytes (total 1024, permanent 1024):
     1024 in free list (512 min, 2048 max allowed)
     8703 hits, 0 misses, 0 trims, 0 created
F/S buffers, 1590 bytes (total 512, permanent 512):
     0 in free list (0 min, 512 max allowed)
     512 hits, 0 misses
     3 hits in cache, 0 misses in cache
Private particle pools:
IBC0/0 buffers, 648 bytes (total 512, permanent 512):
     512 hits, 8703 fallbacks
     512 max cache size, 256 in cache
     186740492 hits in cache, 0 misses in cache
------------------ show buffers usage ------------------
Statistics for the Small pool
Input IDB    :      Gi5/2 count:        1
Caller pc    : 0x B42FFD8 count:        2
Resource User:   IP Input count:        2
Caller pc    : 0x B3F1948 count:        3
Resource User:     *Dead* count:        3
Caller pc    : 0x B1DFA38 count:        3
Resource User:       Init count:        3
Number of Buffers used by packets generated by system: 1022
Number of Buffers used by incoming packets:               2
Statistics for the Medium pool
Number of Buffers used by packets generated by system: 3000
Number of Buffers used by incoming packets:               0
Statistics for the Middle pool
Output IDB   :      Gi5/2 count:        9
Caller pc    : 0x 91DFCDC count:       10
Resource User: Virtual Ex count:       10
Number of Buffers used by packets generated by system:  512
Statistics for the Big pool
Number of Buffers used by packets generated by system: 1000
Statistics for the VeryBig pool
Statistics for the Large pool
Number of Buffers used by packets generated by system:    8
Statistics for the Huge pool
Number of Buffers used by packets generated by system:    2
Statistics for the CF Small pool
Statistics for the CF Middle pool
Statistics for the Syslog ED Pool pool
Caller pc    : 0x 8A961E8 count:       32
Resource User: EEM ED Sys count:       32
Number of Buffers used by packets generated by system:  288
Statistics for the LI Middle pool
Statistics for the DMA-2 pool
Number of Buffers used by packets generated by system: 1024
Statistics for the CF Big pool
Number of Buffers used by packets generated by system:   25
Statistics for the LI Big pool
Statistics for the EOBC0/0 pool
Caller pc    : 0x AAB898C count:      513
Resource User: IPC Memory count:      506
Resource User: SCP async: count:        7
Input IDB    :      EO0/0 count:        1
Number of Buffers used by packets generated by system: 6144
Statistics for the EOBC0/2 pool
Caller pc    : 0x AAB898C count:      256
Resource User: IPC Memory count:      245
Resource User: Port manag count:       10
Statistics for the IPC pool
Caller pc    : 0x 8D6050C count:       22
Resource User:     *Dead* count:        1
Resource User: IPC Seat R count:       14
Resource User: Card 0x15  count:        1
Resource User: Card 0x15  count:        2
Resource User:  XDR mcast count:        2
Resource User:       Init count:        1
Number of Buffers used by packets generated by system: 2016
Statistics for the CF VeryBig pool
Statistics for the LI Very Big pool
Number of Buffers used by packets generated by system:  257
Statistics for the CF Large pool
Statistics for the Private Huge IPC pool
Statistics for the Private Huge pool
Statistics for the FS Header pool
Caller pc    : 0x B3BAE80 count:        2
Resource User:       Init count:       13
Caller pc    : 0x B87475C count:        1
Caller pc    : 0x 8B79C40 count:        1
Caller pc    : 0x A3D00D0 count:        8
Caller pc    : 0x A26760C count:        1
Caller pc    : 0x 85AE3F8 count:        1
Resource User: IP ARP Adj count:        1
Number of Buffers used by packets generated by system:   31
Statistics for the l2frag pak pool pool
Number of Buffers used by packets generated by system:    0
Statistics for the SW Crypto Header pool
Caller pc    : 0x 9DDB1AC count:        1
------------------ show controllers cwan ------------------
------------------ show diagbus ------------------
------------------ show logging ------------------
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 177 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 177 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 171 message lines logged
Log Buffer (8192 bytes):
4:46:31.186: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet3/0/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 14:46:38.282: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet3/0/1 from LOADING to FULL, Loading Done
*Sep 29 14:56:52.814: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet3/0/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 14:57:02.234: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet3/0/1 from LOADING to FULL, Loading Done
*Sep 29 15:34:31.346: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(180.149.7.153)
*Sep 29 15:37:35.862: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet3/0/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 15:37:41.198: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet3/0/1 from LOADING to FULL, Loading Done
*Sep 29 15:50:12.182: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(180.149.7.153)
*Sep 29 16:11:31.718: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet3/0/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 16:11:37.574: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet3/0/1 from LOADING to FULL, Loading Done
*Sep 29 16:24:14.434: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(117.18.231.23)
*Sep 29 17:09:21.522: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(117.18.231.26)
*Sep 29 18:17:42.865: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(117.18.231.26)
*Sep 29 18:29:16.721: %SYS-5-CONFIG_I: Configured from console by rtl on vty0 (117.18.231.26)
*Sep 29 18:29:41.329: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 2(117.18.231.13)
*Sep 29 18:32:51.561: %SYS-5-CONFIG_I: Configured from console by rtl on vty0 (117.18.231.26)
*Sep 29 18:33:52.253: %SYS-5-CONFIG_I: Configured from console by rtl on vty0 (117.18.231.26)
*Sep 29 18:44:55.645: %SYS-5-CONFIG_I: Configured from console by rtl on vty0 (117.18.231.26)
*Sep 29 18:51:33.697: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet3/0/1 from FULL to DOWN, Neighbor Down: Interface down or detached
*Sep 29 18:51:33.697: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet3/0/1 from FULL to DOWN, Neighbor Down: Interface down or detached
*Sep 29 18:52:43.697: %BGP-5-ADJCHANGE: neighbor 192.168.18.1 Down BGP Notification sent
*Sep 29 18:52:43.697: %BGP-3-NOTIFICATION: sent to neighbor 192.168.18.1 4/0 (hold time expired) 0 bytes
*Sep 29 18:52:58.537: %BGP_SESSION-5-ADJCHANGE: neighbor 192.168.18.1 IPv4 Unicast topology base removed from session  BGP Notification sent
*Sep 29 18:55:47.865: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(117.18.231.26)
*Sep 29 18:56:30.773: %SYS-5-CONFIG_I: Configured from console by rtl on vty2 (117.18.231.26)
*Sep 29 18:59:51.181: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 2(180.149.7.153)
*Sep 29 19:15:36.477: %SYS-5-CONFIG_I: Configured from console by rtl on vty2 (117.18.231.26)
*Sep 29 19:18:28.337: %SYS-5-CONFIG_I: Configured from console by rtl on vty2 (117.18.231.26)
*Sep 29 19:28:52.937: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 3(117.18.231.26)
*Sep 29 19:35:30.877: %SYS-5-CONFIG_I: Configured from console by rtl on vty0 (117.18.231.26)
*Sep 29 19:36:13.377: %SYS-5-CONFIG_I: Configured from console by rtl on vty0 (117.18.231.26)
*Sep 29 19:36:15.581: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 4(180.149.7.153)
*Sep 29 19:46:14.357: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(117.18.231.26)
*Sep 29 19:50:47.061: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet5/1 from LOADING to FULL, Loading Done
*Sep 29 19:50:48.917: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet5/1 from LOADING to FULL, Loading Done
*Sep 29 19:51:37.925: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet5/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 19:51:37.925: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet5/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 19:51:44.941: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet5/1 from LOADING to FULL, Loading Done
*Sep 29 19:51:44.941: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet5/1 from LOADING to FULL, Loading Done
*Sep 29 19:51:54.357: %BGP-5-ADJCHANGE: neighbor 192.168.18.1 Up
*Sep 29 19:52:49.705: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet5/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 19:52:50.141: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet5/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 19:53:24.729: %BGP-5-ADJCHANGE: neighbor 192.168.18.1 Down BGP Notification sent
*Sep 29 19:53:24.729: %BGP-3-NOTIFICATION: sent to neighbor 192.168.18.1 4/0 (hold time expired) 0 bytes
*Sep 29 19:53:39.693: %BGP_SESSION-5-ADJCHANGE: neighbor 192.168.18.1 IPv4 Unicast topology base removed from session  BGP Notification sent
*Sep 29 19:54:11.517: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet5/1 from LOADING to FULL, Loading Done
*Sep 29 19:54:15.801: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet5/1 from LOADING to FULL, Loading Done
*Sep 29 19:55:04.925: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet5/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 19:55:04.925: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet5/1 from FULL to DOWN, Neighbor Down: Dead timer expired
*Sep 29 19:56:59.149: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.1 on GigabitEthernet5/1 from LOADING to FULL, Loading Done
*Sep 29 19:56:59.149: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.18.2 on GigabitEthernet5/1 from LOADING to FULL, Loading Done
*Sep 29 19:57:06.549: %BGP-5-ADJCHANGE: neighbor 192.168.18.1 Up
*Sep 29 19:59:03.525: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(180.149.7.153)
SLOT 3: *Sep 29 20:08:48.085: %ETH_SPA_GILA_FUGU-3-SPI4_RDOOF_ERR: Fugu : TXHSPI Rdata Out of Frame error
SLOT 3: *Sep 29 20:08:48.089: %CARDMGR-2-SYNC_CHECK_FAIL: The SPA in subslot 3/0 egress SPI4 interface sync with the host failed.
SLOT 3: *Sep 29 20:08:48.101: %ETH_SPA_MAC-3-SPI4_ERROR: Marvel MAC : SPI4 Error occured in the MAC
*Sep 29 20:08:48.513: %SPA_OIR-6-OFFLINECARD: SPA (SPA-5X1GE-V2) offline in subslot 3/0
SLOT 3: *Sep 29 20:08:48.509: %SPA_OIR-6-REMCARD: Card removed from Subslot 0, interfaces disabled
*Sep 29 20:09:00.349: %SYS-5-CONFIG_I: Configured from console by rtl on vty1 (117.18.231.26)
*Sep 29 20:09:59.593: %OIR-6-REMCARD: Card removed from slot 3, interfaces disabled
*Sep 29 20:09:59.599: %OIR-SP-6-REMCARD: Card removed from slot 3, interfaces disabled
*Sep 29 20:11:00.553: %SYS-5-CONFIG_I: Configured from console by rtl on vty1 (117.18.231.26)
*Sep 29 20:11:56.897: %SYS-5-CONFIG_I: Configured from console by rtl on vty1 (117.18.231.26)
*Sep 29 20:13:17.513: %SYS-5-CONFIG_I: Configured from console by rtl on vty1 (117.18.231.26)
*Sep 29 20:16:00.797: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 2(117.18.231.26)
*Sep 29 20:22:25.917: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 2(117.18.231.26)
*Sep 29 20:49:26.873: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 2(180.149.7.153)
*Sep 29 21:00:42.857: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(180.149.7.153)
*Sep 30 03:32:39.735: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(117.18.231.9)
*Sep 30 04:07:23.811: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(117.58.247.137)
*Sep 30 04:33:08.155: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(180.149.7.153)
*Sep 30 06:02:23.519: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 2(117.18.231.28)
*Sep 30 06:13:35.786: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(203.76.109.154)
*Sep 30 06:14:10.722: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 2(103.23.171.5)
*Sep 30 06:39:56.186: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(203.76.109.154)
*Sep 30 06:45:13.806: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(203.76.109.154)
*Sep 30 07:10:36.746: %SYS-6-EXIT_CONFIG: User rtl has exited tty session 1(203.76.109.154)
------------------ show module ------------------
Mod Ports Card Type                              Model              Serial No.
  5    2  Route Switch Processor 720 (Active)    RSP720-3C-GE       JAE14070RU2
Mod MAC addresses                       Hw    Fw           Sw           Status
  5  001c.584f.2abc to 001c.584f.2abf   5.9   12.2(33r)SRD 12.2(33)SRE6 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  5  Policy Feature Card 3       7600-PFC3C         JAE1408021J  1.2    Ok
  5  C7600 MSFC4 Daughterboard   7600-MSFC4         JAE14070R0N  1.5    Ok
Mod  Online Diag Status
  5  Pass
------------------ show mls asic ------------------
Earl in Module 5
Tycho      - ver : 2,  Cisco-id :  2A4,  Vendor-id : 215
Superman   - ver : 2,  Cisco-id :  2A4,  Vendor-id : 215
------------------ show mls cef summary ------------------
Total routes:                     196319
    IPv4 unicast routes:          194265
    IPv4 Multicast routes:        4
    MPLS routes:                  2048
    IPv6 unicast routes:          2
    IPv6 multicast routes:        3
    EoM routes:                   0
------------------ show power ------------------
system power redundancy mode = redundant
system power total =     2669.10 Watts (63.55 Amps @ 42V)
system power used =       800.94 Watts (19.07 Amps @ 42V)
system power available = 1868.16 Watts (44.48 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    PWR-2700-AC        2669.10 63.55  OK     OK     on
2    PWR-2700-AC        2669.10 63.55  OK     OK     on
                        Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    FAN-MOD-6SHS        180.18  4.29  OK
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
5    RSP720-3C-GE        310.38  7.39   310.38  7.39  on    on
6    (Redundant Sup)       -     -      310.38  7.39  -     -
------------------ show environment ------------------
environmental alarms:
  no alarms
backplane:
  operating clock count: 2
fan-tray 1:
  fan-tray 1 type: FAN-MOD-6SHS
  fan-tray 1 mode: Auto
  fan-tray 1 fan-fail: OK
clock 1:
  clock 1 OK: OK, clock 1 clock-inuse: in-use
clock 2:
  clock 2 OK: OK, clock 2 clock-inuse: not-in-use
power-supply 1:
  power-supply 1 fan-fail: OK
  power-supply 1 power-input: AC 220V
  power-supply 1 power-output-mode: high
  power-supply 1 incompatible with fan: OK
  power-supply 1 power-output-fail: OK
power-supply 2:
  power-supply 2 fan-fail: OK
  power-supply 2 power-input: AC 220V
  power-supply 2 power-output-mode: high
  power-supply 2 incompatible with fan: OK
  power-supply 2 power-output-fail: OK
module 5:
  module 5 power-output-fail: OK
  module 5 outlet temperature: 27C
  module 5 inlet temperature: 23C
  module 5 device-1 temperature: 31C
  module 5 device-2 temperature: 32C
  module 5 asic-1 (SSO-1) temp: 23C
  module 5 asic-2 (SSO-2) temp: 23C
  module 5 asic-3 (SSO-3) temp: 23C
  module 5 asic-4 (SSO-4) temp: 23C
  module 5 asic-5 (SSA-1) temp: 23C
  module 5 asic-6 (HYPERION-1) temp: 24C
  module 5 RP outlet temperature: 27C
  module 5 RP inlet temperature: 25C
  module 5 EARL outlet temperature: 29C
  module 5 EARL inlet temperature: 24C
chassis connector rating: 1680.00 Watts (40.00 Amps @ 42V)
module 5
  module 5 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 5 power consumption: 310.38 Watts ( 7.39 Amps @ 42V)
chassis per slot cooling capacity: 91 cfm
ambient temperature: < 55C
  module 5 cooling requirement: 35 cfm
------------------ show catalyst6000 all ------------------
  chassis MAC addresses: 64 addresses from 0021.a00b.1f80 to 0021.a00b.1fbf
  traffic meter =   0%   Last cleared at 10:00:23 UTC Sat Sep 29 2012
           peak =   1%        reached at 10:00:23 UTC Sat Sep 29 2012
  switching-clock: clock switchover and system reset is allowed
------------------ show diagnostic result module all detail ------------------
Current bootup diagnostic level: minimal
Module 5: Route Switch Processor 720 (Active)  SerialNo : JAE14070RU2
  Overall Diagnostic Result for Module 5 : PASS
  Diagnostic level at card bootup: minimal
  Test results: (. = Pass, F = Fail, U = Untested)
  ___________________________________________________________________________
    1) TestScratchRegister -------------> .
          Error code ------------------> 0 (DIAG_SUCCESS)
          Total run count -------------> 2344
          Last test execution time ----> Sep 30 2012 07:10:45
          First test failure time -----> n/a
          Last test failure time ------> n/a
          Last test pass time ---------> Sep 30 2012 07:10:45
          Total failure count ---------> 0
          Consecutive failure count ---> 0
    2) TestSPRPInbandPing --------------> .
          Total run count -------------> 4688
          Last test execution time ----> Sep 30 2012 07:10:47
          Last test pass time ---------> Sep 30 2012 07:10:47
          CPU util(5sec) SP -----------> 11%
          CPU util(5sec) RP -----------> 54%
          Traffic ---------------------> 0%
          netint_thr_active -----------> 0
          Inband Tx_Rate --------------> 1661
          Inband Rx_Rate --------------> 193
          Per-device Failure Count ----> n/a
    3) TestTransceiverIntegrity:
      Port  1  2
          Total run count -------------> 0
          Last test execution time ----> n/a
          Last test pass time ---------> n/a
    4) TestActiveToStandbyLoopback:
      Port  1  2
            U  U
    5) TestLoopback:
      Port  1  2
          Total run count -------------> 1
          Last test execution time ----> Sep 29 2012 10:00:53
          Last test pass time ---------> Sep 29 2012 10:00:53
    6) TestNewIndexLearn ---------------> .
    7) TestDontConditionalLearn --------> .
    8) TestBadBpduTrap -----------------> .
    9) TestMatchCapture ----------------> .
          Last test execution time ----> Sep 29 2012 10:00:54
          Last test pass time ---------> Sep 29 2012 10:00:54
   10) TestProtocolMatchChannel --------> .
   11) TestFibDevices ------------------> .
          Last test execution time ----> Sep 29 2012 10:00:55
          Last test pass time ---------> Sep 29 2012 10:00:55
   12) TestIPv4FibShortcut -------------> .
   13) TestL3Capture2 ------------------> .
   14) TestIPv6FibShortcut -------------> .
   15) TestMPLSFibShortcut -------------> .
          Last test execution time ----> Sep 29 2012 10:00:56
          Last test pass time ---------> Sep 29 2012 10:00:56
   16) TestNATFibShortcut --------------> .
   17) TestAclPermit -------------------> .
   18) TestQoSTcam ---------------------> .
   19) TestL3VlanMet -------------------> .
   20) TestIngressSpan -----------------> .
   21) TestEgressSpan ------------------> .
   22) TestNetflowInlineRewrite:
      Port  1  2
            U  U
   23) TestFabricSnakeForward ----------> .
   24) TestFabricSnakeBackward ---------> .
          Last test execution time ----> Sep 29 2012 10:00:57
          Last test pass time ---------> Sep 29 2012 10:00:57
   25) TestTrafficStress ---------------> U
   26) TestFibTcamSSRAM ----------------> U
   27) TestAsicMemory ------------------> U
   28) TestAclQosTcam ------------------> U
   29) TestNetflowTcam -----------------> U
   30) ScheduleSwitchover --------------> U
   31) FirmwareDiagStatus --------------> .
   32) TestFabricFlowControlStatus -----> U
          Current run count -------------------------->: 0
          First test execution time ------------------>:
          Last test execution time ------------------->:
          Total FPOE Rate0 Count --------------------->: 0
          Total FPOE Reduced Rate Count -------------->: 0
   33) TestErrorCounterMonitor ---------> .
          Error Records ---------------> n/a
------------------ show diagnostic events ------------------
Diagnostic events (storage for 500 events, 4 events recorded)
Event Type (ET): I - Info, W - Warning, E - Error
Time Stamp         ET [Card] Event Message
09/29 10:00:57.547 I  [5] Diagnostics Passed
09/29 10:01:46.103 E  [3] BusConnectivityTest Failed
09/29 10:01:46.127 E  [3] Minor Error Detected
09/29 10:01:50.487 I  [3] Diagnostics Passed
------------------ show interfaces switchport brief ------------------
------------------ show interfaces trunk ------------------
------------------ show vlan ------------------
VLAN Name                             Status    Ports
1    default                          active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
------------------ show mac-address-table ------------------
Legend: * - primary entry
        age - seconds since last seen
        n/a - not available
  vlan   mac address     type    learn     age              ports
*    1  0100.0ccc.ccce    static  No           -   Switch
*  ---  0000.0000.aaaa    static  No           -   Switch
*  ---  0021.a00b.1f80    static  No           -   Router
------------------ show spanning-tree active ------------------
No spanning tree instance exists.
------------------ show spanning-tree summary ------------------
Switch is in pvst mode
Root bridge for: none
EtherChannel misconfig guard is enabled
Extended system ID           is enabled
Portfast Default             is disabled
PortFast BPDU Guard Default  is disabled
Portfast BPDU Filter Default is disabled
Loopguard Default            is disabled
UplinkFast                   is disabled
BackboneFast                 is disabled
Pathcost method used         is short
Name                   Blocking Listening Learning Forwarding STP Active
Total                        0         0        0          0          0
------------------ show heartbeat ------------------
Out of buffers          = 0
EOBC tx failures        = 0
Negative clock updates  = 0
Fatal errors            = 0
Last heartbeat sched    = 872
Last heartbeat sent     = 872
Peer 5/0 [online]:
Heartbeats received     = 38091
Config msgs received    = 0
Clock cfg msgs received = 0
Unknown msgs received   = 0
Not heard warnings      = 0
Current rx warnings     = 0 (max 5)
Peer 5/1 [online]:
Heartbeats received     = 0
Scheduler history [show techsupport huge_stack 50%/48% (00:00:00.916 53%/48%)] [show techsupport huge_stack 00:00:00.020] [SSS Feature Timer 00:00:00.020] [show techsupport huge_stack 00:00:00.020]
--- remote command switch show process memory ---
Processor Pool Total:  612166308 Used:  249681824 Free:  362484484
      I/O Pool Total:   67108864 Used:   43819104 Free:   23289760
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0  186015264     351372  168224364       6698      34840 *Init*
   0   0      14040    7708612      14040          0          0 *Sched*
   0   0  111306764  105074580   20117948        774       1285 *Dead*
   0   0          0          0     393528          0          0 *MallocLite*
   1   0     131176          0     138404          0          0 Chunk Manager
   2   0        236        236       4228          0          0 Load Meter
   3   0          0          0      13092          0          0 CFC stats broker
   4   0          0          0       7228          0          0 Retransmission o
   5   0      15124          0       7228          1          1 IPC ISSU Dispatc
   6   0          0          0       7228          0          0 PF Redun ICC Req
   7   0       3344        236      10336          0          0 Check heaps
   8   0          0          0       7228       5560          0 Pool Manager
   9   0          0          0       7228          0          0 DiscardQ Backgro
  10   0        236        236       7228          0          0 Timers
  11   0          0          0       4228          0          0 WATCH_AFS
  12   0        236        236       7228          0          0 Serial Backgroun
  13   0          0          0       7228          0          0 AAA_SERVER_DEADT
  14   0          0          0      13228          0          0 Policy Manager
  15   0          0          0      25228          0          0 Crash writer
  16   0        304          0       7532          0          0 Exception contro
  17   0          0          0       7228          0          0 RO Notify Timers
  18   0          0          0       4228          0          0 RMI RM Notify Wa
  19   0         80        568       7228          0          0 IPC Event Notifi
  20   0      15208          0       7228          1          1 IPC Mcast Pendin
  21   0          0          0       7228          0          0 IPC Dynamic Cach
  22   0          0          0       7228        348        348 IPC Service NonC
  23   0          0          0       7228          0          0 IPC Zone Manager
  24   0          0          0       7228      27555      27555 IPC Periodic Tim
  25   0       2432       5112       7228          8          8 IPC Deferred Por
  26   0          0          0       7228          0          0 IPC Process leve
  27   0      13964       9820      12392        260        258 IPC Seat Manager
  28   0          0          0       7228          0          0 IPC Check Queue
  29   0     545424       1900     366844        355        338 IPC Seat RX Cont
  30   0          0          0       7228          0          0 IPC Seat TX Cont
  31   0      19132        472      16536      11275      11275 IPC Keep Alive M
  32   0          0          0       7228          0          0 IPC Loadometer
  33   0        236        236       7228          0          0 PrstVbl
  34   1        540          0      13732         18         16 Virtual Exec
  35   0          0          0       7228          2          3 ARP Input
  36   0          0          0       7228          0          0 ARP Background
  37   0        236        236       7228          0          0 DDR Timers
  38   0          0          0       7228          0          0 SERIAL A'detect
  39   0        236        236       7228          0          0 GraphIt
  40   0       4484       4484       7228         57         57 fabm_ch_sync:4
  41   0          0          0       7228          0          0 Reset Process
  42   0        472        604       7228          0          0 RPC pf_media_lay
  43   0      45460       6176      36148         21         21 client_entity_se
  44   0        236        236      13228          0          0 Dialer event
  45   0          0          0       7228          0          0 Critical Bkgnd
  46   0     116880          0      98196          0          0 Net Background
  47   0       1676       1360      13544          0          0 IDB Work
  48   0        236        236      13228         65         65 Logger
  49   0        236        236       7228          0          0 TTY Background
  50   0       4728        804      11956         89        103 SCP Multicast
  51   0       5740          0      12832          0          0 CEF LC Stats
  52   0     106524       1012      29640    1628551    1698538 SCP Download Lis
  53   0          0          0       7228          0          0 LCP Bootupg proc
  54   0      11940        944      18224         45         45 RPC Sync
  55   0          0        132       7228          0          0 RPC rpc-master
  56   0        472        236       7464          0          0 DFC Command Task
  57   0          0          0       7228          9          9 Net Input
  58   0       1180       1180       7228         10         10 Module oper stat
  59   0          0          0      13228          0          0 SNMP Traps
  60   0       4720       4720       7228         40         40 Snmp ICC Process
  61   0      88952      63964      32288        501        501 rf proxy sp agen
  62   0          0          0       7228          0          0 IPC ISSU Version
  63   0          0          0       7228          0          0 IPC ISSU Version
  65   0          0          0       7228          0          0 IPC ISSU Version
  66   0          0          0       7228          0          0 IPC ISSU Version
  67   0          0          0       7228          0          0 IPC ISSU Version
  68   0          0          0       7228          0          0 IPC ISSU Version
  69   0          0          0       7228          0          0 IPC ISSU Version
  70   0          0          0       7228          0          0 IPC ISSU Version
  71   0          0          0       7228          0          0 IPC ISSU Version
  72   0          0          0       7228          0          0 IPC ISSU Version
  73   0          0          0       7228          0          0 IPC ISSU Version
  74   0          0          0       7228          0          0 IPC ISSU Version
  75   0          0          0       7228          0          0 IPC ISSU Version
  76   0          0          0       7228          0          0 IPC ISSU Version
  77   0          0          0       7228          0          0 IPC ISSU Version
  78   0          0          0       7228          0          0 RTTYS Process
  79   0          0          0       7228          0          0 IPC ISSU Version
  80   0          0          0       7228          0          0 IPC ISSU Version
  81   0          0          0       7228          0          0 IPC ISSU Version
  82   0       4728          0      11956          0          0 IPC ISSU Version
  83   0          0          0       7228          0          0 IPC ISSU Version
  84   0          0          0       7228          0          0 IPC ISSU Version
  85   0          0          0       7228          0          0 IPC ISSU Version
  86   0          0          0       7228          0          0 IPC ISSU Version
  87   0          0          0       7228          0          0 IPC ISSU Version
  88   0          0          0       7228          0          0 IPC ISSU Version
  89   0          0          0       7228          0          0 IPC ISSU Version
  90   0          0          0       7228          0          0 IPC ISSU Version
  91   0          0          0       7228          0          0 IPC ISSU Version
  92   0          0          0       7228          0          0 IPC ISSU Version
  93   0          0          0       7228          0          0 IPC ISSU Version
  94   0          0          0       7228          0          0 IPC ISSU Version
  95   0          0          0       7228          0          0 IPC ISSU Version
  96   0          0          0       7228          0          0 IPC ISSU Version
  97   0          0          0       7228          0          0 IPC ISSU Version
  98   0          0          0       7228          0          0 IPC ISSU Version
  99   0          0          0       7228          0          0 IPC ISSU Version
100   0          0          0       7228          0          0 ISSU PROCESS IPC
101   0       8608       8608       7228          0          0 PF Sync process
102   0      65824        236      72816          0          0 ACE_REQUESTS han
103   0          0          0       7228          0          0 ACE Process Msg
104   0          0          0       7228          0          0 ACE SP Tunnel Ta
105   0          0          0       7228          0          0 MDR SM Platform
106   0          0          0       7228          0          0 ICC Nego
107   0          0          0       7228          0          0 PF DB SCP ICC pr
108   0          0          0      10228          0          0 PF SCP process
109   0          0          0       7228          0          0 PrstVbl IPC Msg
110   0          0          0       7228          0          0 EOBC ETSEC FREEZ
111   0       5076       5784       7228         70         70 Logger SP Proces
112   0      38444      19048      26624          0          0 Env action
113   0        472        604       7228          0          0 RPC rf_set_debug
114   0     110900      45312       7228        192        192 RF Status
115   0          0          0       4228          0          0 Inode Table Dest
116   0          0          0       7228          0          0 cpf_msg_holdq_pr
117   0          0          0       7228          0          0 cpf_msg_rcvq_pro
118   0          0          0       7228          0          0 CAPI HA IPC flow
119   0       3264       2632       7860         20         20 Const ICC reques
120   0          0          0       7228          0          0 Const ICC event
121   0          0          0       7228          0          0 Const ICC except
122   0          0          0       7228          0          0 ICC Local Reques
123   0          0        944       7228          0          0 ICC Async mcast
124   0          0      20180       7228          0          0 ICC Async true m
125   0          0         80       7228          0          0 ICC Mcast IPC Ev
126   0          0          0       7228          0          0 ICC_REQ Debug Pr
127   0          0          0       7228          0          0 ICC FC Process
128   0          0          0       7228          0          0 ICC FC Test Send
129   0          0          0       7228          0          0 ICC FC Test Low
130   0          0          0      13092          0          0 CFC LC Test Stat
131   0          0          0       7228          0          0 IVFS SP ICC Proc
132   0       9188       8800      10092          2          2 spa diag process
133   0    2405400    2564668      35612      18353      27470 OIR Process
134   0        116          0       7344      76180      76180 Heartbeat Proces
135   0       9032       1652      13492       5114       5116 Fabric Manager
136   0   62768556   62552672     241112     814354     814354 slcp process
137   0          0          0       7228          0          0 CHKPT Test clien
138   0          0          0       7228          0          0 MDR SM Proxy Mas
139   0      28904          0      15484          2          2 CEF: IPv4 proces
140   0          0          0       7228          0          0 itasca_sp
141   0     117584      36592      73764        471        471 rf task
142   0          0          0       7228          0          0 RF High Priority
143   0        236        236       7228          0          0 Compute load avg
144   0          0          0       7228          0          0 Per-minute Jobs
145   0       9556        236      19548          1          1 Per-Second Jobs
146   0      72228       5904      54628         14         14 RPC cygnus-oir
147   0     248508       2676     142724         19         18 PF_Init Process
148   0          0          0       7228          0          0 Fabman Timeout P
149   0          0          0       7228          2          0 Heartbeat
150   0        236        236       7228          0          0 SP BACKGROUND
151   0          0          0       7228          0          0 RF Messaging Pro
152   0       1536       1376       7388         32         32 IPC RTTYC Messag
153   0       1416       1416       7228         30         30 PF_Split Sync Pr
154   0       2788       2336       7812         12         12 RPC pf-split-sp
155   0        820        952       7812          0          0 RPC idprom-SP
156   0          0          0       7228          0          0 RTTYC Flush
157   0    5593884          0      13228        393        393 RFS server proce
158   0          0          0       7228          0          0 BACK CHECK
159   0       1356       3016       7228          6          6 AggMgr Process
160   0          0          0       7228          0          0 cpf_process_tpQ
161   0        224          0       7492          0          0 EARL Intr Thrtl
162   0          0          0       7228          0          0 Transport Port A
163   0          0          0       7228          0          0 EARL FIB Manager
164   0        224          0       7452          0          0 SPAN EARL Task
165   0        236        236       7228          0          0 Protocol Filteri
166   0    2422416     350996      14716       1472       1471 Remote Console P
167   0          0          0       7228          0          0 ADJ MGR
168   0       2860          0      10088          0          0 ADJ_MGR
169   0      82276      78584      12180         66         66 L2 Control Task
170   0     107744       1804      97532         46         46 L2 Throttle Task
171   0    4312808    4312356       7680        318        318 L2 Aging Task
172   0    2136604    2132556      11276      15222      15222 Vlan Statistics
173   0  890050804  890050804       7228          0          0 L2 PI_E consiste
174   0       1744          0      11972          0          0 EARL7 monitor ta
175   0     272228     272228       7228          0          0 TYFIB Table Mana
176   0    1426376    1421648      11956          0          0 NF Exception Tas
177   0    1351940    1351292      10228       8479       8479 L3 Control Task
178   0    6259248          0    6237564          0          0 Netflow NDE Task
179   0        152          0       7380          0          0 Netflow Aging Ta
180   0          0          0       7228          0          0 Task for pre-pro
181   0      10516       5368      12376         83         83 Netflow Mgmt_Sta
182   0          0          0       7228          0          0 Netflow Sampling
183   0        224          0       7452          0          0 Online Linecard
184   0          0          0       7228          0          0 CFIB-BGP Task
185   0        236        236       7228          0          0 CFIB LC High Pri
186   0   10101188   10101024   10107944          4          4 CFIB LC Main Tas
187   0          0          0       7228          0          0 CFIB LC Timer Ta
188   0          0          0       7228          0          0 CFIB LC STATS Ta
189   0        448        236       7440          0          0 Gemini SP proces
190   0        236          0       4464          0          0 Async write proc
191   0        236          0       4464          0          0 Async write proc
192   0        236          0       4464          0          0 Async write proc
193   0        236          0       4464          0          0 Async write proc
194   0          0          0       4228          0          0 DFS flush period
195   0        236          0       4464          0          0 Async write proc
196   0        236          0       4464          0          0 Async write proc
197   0        236          0       4464          0          0 Async write proc
198   0        236          0       4464          0          0 Async write proc
199   0          0          0       4228          0          0 DFS flush period
200   0        236        236       7228          0          0 AAA Dictionary R
201   0        236        236       7228          0          0 AAA Server
202   0          0          0       7228          0          0 AAA ACCT Proc
203   0      49384          0      56612          0          0 ACCT Periodic Pr
204   0          0          0       7228          0          0 AAA System Acct
205   0         84        196       7312          0          0 PIM Snooping Pro
206   0          0          0       4228          0          0 BGP INT
207   0       3268        708       9788          1          1 mls-hal Process
208   0      10380        236      17372          0          0 mls-msc-ha proce
209   0      78476       3412      81240         11         12 mls-msc Process
210   0         84          0       7312          0          0 mls-msc-cc Proce
211   0        472        236       7464          0          0 Spanning Tree
212   0        236        236       7228          0          0 Ethchnl
213   0        932        236      13924          0          0 DTP Protocol
214   0      25660      25660      25228        265        267 QoS SP Process
215   0   23056860     395652   22679208        136        135 TCAM Manager pro
216   0       1204        944       7228      12285      12285 Mcast Hw Agent6
217   0        236        236       7228          0          0 capture process
218   0   32308692   32242880      73040          0          0 L2 MAC oob sync
219   0        236        236       7228          2          2 Const Rate Limit
220   0          0          0       7228          0          0 SP DHCP Snooping
221   0      75640          0      82868          0          0 Private hosts sp
222   0          0          0       7228          0          0 L3 Manager SP Co
223   0          0          0      13228          0          0 L3 Manager SP
224   0        236        236      10228          0          0 GVRP Process
225   0        236        236       7228          0          0 MAC-Security-Agi
226   0          0          0      13228          0          0 STATIC MAC HANDL
227   0          0          0       7228          0          0 CWAN static MAC
228   0          0          0      13228          0          0 CWAN PORT CHANNE
229   0        236        236       7228          0          0 REP Topology cha
230   0       1084          0      14312          0          0 IP ARP Adjacency
231   0      49384          0      56612          0          0 IP ARP Retry Age
232   0          0          0      13228          0          0 IP Input
233   0          0          0       7228          0          0 ICMP event handl
234   0        236        236       7228          0          0 IPAM/ODAP Events
235   0      49384          0      62612          0          0 IPAM Manager
236   0        236        236      13228          0          0 IPAM Events
237   0        236        236       7228          0          0 PPP SIP
238   0        236        236       7228          0          0 PPP Bind
239   0        236        236      13228          0          0 PPP IP Route
240   0       2192          0       9420          0          0 Switch Backup In
241   0        780        472       7536          2          2 UDLD
242   0        224          0       7452          0          0 Port-Security
243   0          0          0       7228          8          8 802.1x switch
244   0        276          0      13504          0          0 CEF switching ba
245   0       4964        236      11956          0          0 OCE punted Pkts
246   0          0          0      13228          0          0 SSS Manager
247   0          0          0      13228          0          0 SSS Policy Manag
248   0          0          0       7228          0          0 SSS Feature Mana
249   0          0          0       7228          0          0 SSS Feature Time
250   0          0          0       7228          0          0 SG DPM
251   0          0          0       7228          0          0 Timer handler fo
252   0          0          0       7228          0          0 Prepaid response
253   0          0          0       7228          0          0 Timed Policy act
254   0          0          0       7228          0          0 AAA response han
255   0          0          0       7228          0          0 AAA EPD HANDLER
256   0          0          0       7228          0          0 PM EPD API
257   0          0          0       7228          0          0 EAP Framework
258   0          0          0       7228          0          0 EAP Test
259   0      10372        236      23364          0          0 SSM connection m
260   0     686316     686316       7228          0          0 QoS stats proces
261   0          0          0      13228          0          0 TCP Timer
262   0          0          0      13228          0          0 TCP Protocols
263   0          0          0       7228          0          0 Socket Timers
264   0        940          0      11168          0          0 HTTP CORE
265   0        472        236       4464          0          0 PfR BR Learn
266   0          0          0       7228          0          0 CFMPAL OIR POWER
267   0        472        236       7464          0          0 CFMPAL Process
268   0        224          0       7452          0          0 XDR background p
269   0      13172       2792      17916       7028       7027 XDR mcast
270   0    1504088    1499716      16052      15434      15434 mls-gc Process
271   0          0          0       7228          0          0 mls-pimsn Proces
272   0       1924       1760       7484          5          5 MLTL Agent
273   0       7544      14952      13592          8          8 mfib-const-lc Pr
274   0        224          0       7452          0          0 mls-igmp Process
275   0        224          0       7452          0          0 mls-cgmp Process
276   0        224          0       7452          0          0 mls-mld Process
277   0        224          0       7452          0          0 mld-mrouter Proc
278   0          0          0       7228          0          0 FRR Background P
279   0        224        152      13452          0          0 CEF background p
280   0        224          0      13452          0          0 fib_fib_bfd_sb e
281   0    6734648    6734648       7228      74730      74728 XDR LC PRIO Back
282   0          0          0       7228          0          0 XDR LC PRIO Crit
283   0   96408632    1386128   85084404      11553      11552 XDR LC Backgroun
284   0        224          0      13452          0          0 MFIB Master back
285   0          0          0       7228          0          0 STP HA IPC flow
286   0        472        236       7464          0          0 CEF LC IPC Backg
287   0        236        236       7228          0          0 LC ETHER EFP Com
288   0        236        236       7228          0          0 BD MACSEC HA
289   0        236        236       7228          0          0 REP LSL Proc
290   0      10288        236      17280          0          0 REP BPA/EPA Proc
291   0      19492        236      26484          0          0 SCTP Main Proces
292   0          0          0       7228          0          0 IP Traceroute
293   0          0          0       7228          0          0 Probe Input
294   0          0          0       7228          0          0 RARP Input
295   0          0          0       7228          0          0 X.25 Encaps Mana
296   0        224          0       7452          0          0 Hardware API bac
297   0          0          0      13228          0          0 Path set broker
298   0        224          0       7452          0          0 XDR FOF process
299   0        236        236       7228          0          0 LOCAL AAA
300   0        236        236       7228          0          0 ENABLE AAA
301   0        236        236       7228          0          0 LINE AAA
302   0        236        236       7228          0          0 AAA Cached Serve
303   0          0          0       7228          0          0 EM Background Pr
304   0          0          0       7228          0          0 IDMGR CORE
305   0          0          0       7228          0          0 Pre-download RP
306   0          0          0       7228          0          0 Pre-dnld LC to A
307   0          0          0       7228          0          0 Pre-download pee
308   0      66624        236       8028          0          0 TPLUS
309   0        236        236      10228          0          0 GVRP SWITCH Proc
310   0        236      51616       7228          0          0 AAA SEND STOP EV
311   0          0          0       7228          0          0 HW Capacity ICC
312   0          0          0       7228          0          0 PM Vlan Timer Pr
313   0          0          0       7228          0          0 pm icc process
314   0      58960      41852      11708        141        142 pm scp process
315   0       1552       1552       7228         35         35 PM CP Process
316   0    2541104      11668    2534860         70         70 RPC pm-cp
317   0       5704      12448       7228          0          0 PM Callback
318   0     333724     260836      85912         32         32 VLAN Manager
319   0        236        236       7228          0          0 Port manager per
320   0          0          0       7228          0          0 Max CPU utilizat
321   0       1416       1548       7228         10         10 RPC ecfmpal_rpc_
322   0        236        368       7228          0          0 RPC icrm_rp2sp
323   0          0          0       7228          0          0 Inline Power Por
324   0        236        368       7228          0          0 RPC storm_contro
325   0          0          0       7228          0          0 StandbyDiagDaemo
326   0          0          0       7228          0          0 DiagInbandRatePr
327   0     486116          0     471592          0          0 SEA main process
328   0      14308      14440       7228        106        106 RPC pf_issu_rp2s
329   0       2360       2492       7228         18         18 RPC pf_prst_vbl_
330   0        236        368       7228          0          0 RPC pf_redun_rp2
331   0        224          0       7520          0          0 SEA write CF pro
332   0          0          0       7228          0          0 TM Stat Adj Task
333   0      28304      28076      10456       7102       7102 L2 Application T
334   0          0          0      13228          0          0 VPN_MAPPER
335   0        236        368       7228          0          0 RPC dhcp_snoopin
336   0        236        368       7228          0          0 RPC pvt_hosts_sw
337   0          0          0       7228          0          0 Const FIB excep
338   0        236        368       7228          0          0 RPC pclc_g2_fw_s
339   0        236        368       7228          0          0 RPC pclc_g2_ids_
340   0        224          0       7452          2          2 SEA write messag
341   0   12283144   12199784      25000      43551      43551 C6K PROCMIB SP P
342   0          0          0       7228          0          0 CMFI CC Backgrou
343   0        236        368       7228          0          0 RPC cfib_rp2sp
344   0        236        236       7228          0          0 Rommon upgrade p
345   0          0          0       7228          0          0 CONST SMC
346   0        236        368      61228          0          0 RPC epld_isp_rpc
347   0        236        368       7228          0          0 RPC itasca_sp
348   0        236        368       7228          0          0 RPC cdump_rp_req
349   0        236        368       7228          0          0 RPC logging_even
350   0          0          0       7228          0          0 NV Health Monito
351   0        236        368       7228          0          0 RPC sw_backup_in
352   0       2360       2492       7228         18         18 RPC mlacp_mp2sp
353   0    9259100    9259232      10228      68723      68723 RPC sw_vlan_sp
354   0      22380      22512       7228        160        160 RPC stp_switch_a
355   0     212504     212636       7228       1592       1592 RPC pagp_switch_
356   0        236        368       7228          0          0 RPC lacp_switch_
357   0        236        368       7228          0          0 RPC pt_switch_mp
358   0        236        368       7228          0          0 RPC qnq_switch_m
359   0        944       1076      10228          6          6 RPC span_switch_
360   0      15828      15960       7228        116        116 RPC mapping_sp
361   0        236        368       7228          0          0 RPC intacc_rp
362   0      57032      57164       7228        426        426 RPC udld_sp
363   0        236        236       7228          0          0 SP Error Detecti
364   0        236        368       7228          0          0 RPC error_detect
365   0     824716     824848      13228       6004       6004 RPC c6k_power_sp
366   0    2041524    2041524       7228      22542      24973 Env Poll
367   0    5589356    5589488       7228      40396      40396 RPC c6k_sp_envir
368   0        236        368       7228          0          0 RPC chapi_sp
369   0     445900     423320      27024       3142       3142 RPC pm_switch_rp
370   0        236        368       7228          0          0 RPC const_nv_cfg
371   0        236        368       7228          0          0 RPC l2_bridge
372   0     328876     329008       7228       6762       6762 RPC online_diag_
373   0        236        368       7228          0          0 RPC online_diag_
374   0      33032      43956       7560         12         12 RPC online_wan_d
375   0       4356       4488       7228         28         28 RPC pikachu_sp
376   0    1604672    1604804       7228      10598      10598 RPC rf_cli_rp2sp
377   0      59292      59424       7228        444        444 RPC issu_cli_rp2
378   0       2668       2800       7228         16         16 RPC c6k_stack_mi
379   0        236        368       7228          0          0 RPC psecure_sp
380   0       3068       3200       7228         30         30 RPC gbic_seprom_
381   0        236        368       7228          0          0 RPC const_ehsa_r
382   0        236        368       7228          0          0 RPC const_platfo
383   0        236        368       7228          0          0 RPC pm_mat_mp2sp
384   0        236        368       7228          0          0 RPC switch_engin
385   0        236        368       7228          0          0 RPC ether_oam_rp
386   0        236        368       7228          0          0 RPC dot1ad_mp2sp
387   0        236        368       7228          0          0 RPC acr_rp2sp
388   0        472        604       7228          3          3 RPC rep_rp2sp_ap
389   0        236        368       7228          0          0 RPC dot1x_sp
390   0        708        840       7228          4          4 RPC lcc_rp
391   0     210828     210960       7228       1568       1568 RPC fabman_rp
392   0      14376      14508       7228        106        106 RPC sea_rp_cli_r
393   0        236        368       7228          0          0 RPC const_ifs_rp
394   0        236        368       7228          0          0 RPC gvrp_rp2sp
395   0       1988        472       7456          6          6 L2 Manager Task
396   0        212          0       7440          0          0 L2 Manager Earl6
397   0      33012      33328       7612         56         57 LTL MGR
398   0        460          0       7688          0          0 LTL MGR cc
399   0        236        236       7228          0          0 SPAN switch
400   0       3068      13248       7464         36         42 SPAN Switch SP
401   0       4952          0      12180          0          0 SPAN Switch SP B
402   0       2380        236       7380          6          6 LC Registry Expo
403   0        236        236       7228          0          0 LC IPC ICC Init
404   0    2801792          0    2809020          0          0 Const2 IPv6 Proc
405   0          0          0       7228          0          0 v6fib stat colle
406   0      10052          0      17280          0          0 CMFI
407   0          0       4960       7228          0          0 CMFI Scanner
408   0        708        708       7228          6          6 CMFI Misc
409   0          0          0       7228          0          0 CMFI Background
410   0          0          0       7228          0          0 CMFI iEdge Proce
411   0        236        236       7228          0          0 EI SP
412   0        236        236       7228          0          0 REP SP Proc
413   0       3568       3500       7316          0          0 ADJ background
414   0        224          0       7452          2          3 SEA receive proc
415   0       7284       7284      13228         30         30 Syslog
416   0          0          0       7228          0          0 NDE - IPV4
417   0          0          0       7228          0          0 NDE - MPLS
418   0          0          0       7228          0          0 NDE - L2
419   0          0          0       7228          0          0 NDE - IPV6
420   0          0          0       7228          0          0 SpanTree Helper
421   0          0          0       7092          0          0 MFI LFD Stats Pr
422   0          0          0      13092          0          0 MFI LFD Timer Pr
423   0      93576        304     100284          0          0 MFI LFD Main Pro
424   0      19092      33704      13316          0          0 Collection proce
426   0   64652816   64621540      42144     645982     645982 DiagCard5/-1
427   0   33186536   33186536       7092     393434     393434 SCP async: LCP#5
428   0          0          0       7092          0          0 IPC ISSU Version
429   0          0          0       7152          0          0 system Image Rec
431   0          0          0       7116          0          0 fabm_ch_sync:2
                                324163108 Total
--- remote command switch show process cpu ---
CPU utilization for five seconds: 10%/0%; one minute: 10%; five minutes: 10%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1           0           4          0  0.00%  0.00%  0.00%   0 Chunk Manager
   2          48       15244          3  0.00%  0.00%  0.00%   0 Load Meter
   3           8        7123          1  0.00%  0.00%  0.00%   0 CFC stats broker
   4           0         223          0  0.00%  0.00%  0.00%   0 Retransmission o
   5           0           3          0  0.00%  0.00%  0.00%   0 IPC ISSU Dispatc
   6           4          13        307  0.00%  0.00%  0.00%   0 PF Redun ICC Req
   7      298148       17983      16579  0.00%  0.32%  0.35%   0 Check heaps
   8           0           1          0  0.00%  0.00%  0.00%   0 Pool Manager
   9           0           1          0  0.00%  0.00%  0.00%   0 DiscardQ Backgro
  10           0           2          0  0.00%  0.00%  0.00%   0 Timers
  11           0         200          0  0.00%  0.00%  0.00%   0 WATCH_AFS
  12           0           2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  13           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  14           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  15           0           1          0  0.00%  0.00%  0.00%   0 Crash writer
  16           0           1          0  0.00%  0.00%  0.00%   0 Exception contro
  17           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  18           0           1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  19           4       15249          0  0.00%  0.00%  0.00%   0 IPC Event Notifi
  20          28       74394          0  0.00%  0.00%  0.00%   0 IPC Mcast Pendin
  21           0        1271          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  22          12       15247          0  0.00%  0.00%  0.00%   0 IPC Service NonC
  23           0           1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  24          16       74394          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  25           4       74402          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  26           0           1          0  0.00%  0.00%  0.00%   0 IPC Process leve
  27          48       11397          4  0.00%  0.00%  0.00%   0 IPC Seat Manager
  28           0        1387          0  0.00%  0.00%  0.00%   0 IPC Check Queue
  29          16         173         92  0.00%  0.00%  0.00%   0 IPC Seat RX Cont
  30           0           2          0  0.00%  0.00%  0.00%   0 IPC Seat TX Cont
  31          32        7666          4  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  32          88       15248          5  0.00%  0.00%  0.00%   0 IPC Loadometer
  33         852           4     213000  0.00%  0.00%  0.00%   0 PrstVbl
  34           4           6        666  0.00%  0.00%  0.00%   1 Virtual Exec
  35           0           2          0  0.00%  0.00%  0.00%   0 ARP Input
  36          20       79468          0  0.00%  0.00%  0.00%   0 ARP Background
  37           0           2          0  0.00%  0.00%  0.00%   0 DDR Timers
  38           0           1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  39          16       76212          0  0.00%  0.00%  0.00%   0 GraphIt
  40           4          23        173  0.00%  0.00%  0.00%   0 fabm_ch_sync:4
  41           0           1          0  0.00%  0.00%  0.00%   0 Reset Process
  42           0           3          0  0.00%  0.00%  0.00%   0 RPC pf_media_lay
  43           0          13          0  0.00%  0.00%  0.00%   0 client_entity_se
  44           0           2          0  0.00%  0.00%  0.00%   0 Dialer event
  45           0           1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  46           4       15318          0  0.00%  0.00%  0.00%   0 Net Background
  47           0           5          0  0.00%  0.00%  0.00%   0 IDB Work
  48           0          28          0  0.00%  0.00%  0.00%   0 Logger
  49          88       75977          1  0.00%  0.00%  0.00%   0 TTY Background
  50           0          71          0  0.00%  0.00%  0.00%   0 SCP Multicast
  51          44       84389          0  0.00%  0.00%  0.00%   0 CEF LC Stats
  52        3832      408172          9  0.00%  0.01%  0.00%   0 SCP Download Lis
  53           0           1          0  0.00%  0.00%  0.00%   0 LCP Bootupg proc
  54           0         113          0  0.00%  0.00%  0.00%   0 RPC Sync
  55           0           1          0  0.00%  0.00%  0.00%   0 RPC rpc-master
  56           0           2          0  0.00%  0.00%  0.00%   0 DFC Command Task
  57           0          10          0  0.00%  0.00%  0.00%   0 Net Input
  58           4          11        363  0.00%  0.00%  0.00%   0 Module oper stat
  59           0           1          0  0.00%  0.00%  0.00%   0 SNMP Traps
  60           0          41          0  0.00%  0.00%  0.00%   0 Snmp ICC Process
  61          28         553         50  0.00%  0.00%  0.00%   0 rf proxy sp agen
  62           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  63           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  65           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  66           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  67           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  68           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  69           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  70           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  71           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  72           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  73           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  74           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  75           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  76           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  77           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  78           0           1          0  0.00%  0.00%  0.00%   0 RTTYS Process
  79           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  80           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  81           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  82           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  83           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  84           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  85           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  86           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  87           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  88           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  89           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  90           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  91           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  92           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  93           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  94           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  95           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  96           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  97           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  98           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  99           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
100           0           1          0  0.00%  0.00%  0.00%   0 ISSU PROCESS IPC
101           4           5        800  0.00%  0.00%  0.00%   0 PF Sync process
102           0           2          0  0.00%  0.00%  0.00%   0 ACE_REQUESTS han
103           0           1          0  0.00%  0.00%  0.00%   0 ACE Process Msg
104           0          12          0  0.00%  0.00%  0.00%   0 ACE SP Tunnel Ta
105           0           1          0  0.00%  0.00%  0.00%   0 MDR SM Platform
106           0           1          0  0.00%  0.00%  0.00%   0 ICC Nego
107           0           1          0  0.00%  0.00%  0.00%   0 PF DB SCP ICC pr
108           0           1          0  0.00%  0.00%  0.00%   0 PF SCP process
109           0           1          0  0.00%  0.00%  0.00%   0 PrstVbl IPC Msg
110          64       76011          0  0.00%  0.00%  0.00%   0 EOBC ETSEC FREEZ
111           0          49          0  0.00%  0.00%  0.00%   0 Logger SP Proces
112           8         177         45  0.00%  0.00%  0.00%   0 Env action
113           0           5          0  0.00%  0.00%  0.00%   0 RPC rf_set_debug
114           0         194          0  0.00%  0.00%  0.00%   0 RF Status
115           0           1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
116           0           2          0  0.00%  0.00%  0.00%   0 cpf_msg_holdq_pr
117           0           1          0  0.00%  0.00%  0.00%   0 cpf_msg_rcvq_pro
118           0           2          0  0.00%  0.00%  0.00%   0 CAPI HA IPC flow
119           0          25          0  0.00%  0.00%  0.00%   0 Const ICC reques
120           0           1          0  0.00%  0.00%  0.00%   0 Const ICC event
121           0           1          0  0.00%  0.00%  0.00%   0 Const ICC except
122           0           1          0  0.00%  0.00%  0.00%   0 ICC Local Reques
123           0           8          0  0.00%  0.00%  0.00%   0 ICC Async mcast
124           0          46          0  0.00%  0.00%  0.00%   0 ICC Async true m
125           0           3          0  0.00%  0.00%  0.00%   0 ICC Mcast IPC Ev
126           0           1          0  0.00%  0.00%  0.00%   0 ICC_REQ Debug Pr
127           0           1          0  0.00%  0.00%  0.00%   0 ICC FC Process
128           0           1          0  0.00%  0.00%  0.00%   0 ICC FC Test Send
129           0           1          0  0.00%  0.00%  0.00%   0 ICC FC Test Low
130           0           1          0  0.00%  0.00%  0.00%   0 CFC LC Test Stat
131           0           1          0  0.00%  0.00%  0.00%   0 IVFS SP ICC Proc
132           0           4          0  0.00%  0.00%  0.00%   0 spa diag process
133        1092       47292         23  0.00%  0.00%  0.00%   0 OIR Process
134         184       76073          2  0.00%  0.00%  0.45%   0 Heartbeat Proces
135           8        5104          1  0.00%  0.00%  0.00%   0 Fabric Manager
136      949724     9332830        101  7.19%  7.23%  7.22%   0 slcp process
137           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
138           0           1          0  0.00%  0.00%  0.00%   0 MDR SM Proxy Mas
139         316      110582          2  0.00%  0.00%  0.00%   0 CEF: IPv4 proces
140           0           1          0  0.00%  0.00%  0.00%   0 itasca_sp
141          24         256         93  0.00%  0.00%  0.00%   0 rf task
142           0           1          0  0.00%  0.00%  0.00%   0 RF High Priority
143          16       15250          1  0.00%  0.00%  0.00%   0 Compute load avg
144       10172        1291       7879  0.00%  0.00%  0.00%   0 Per-minute Jobs
145          48       76268          0  0.00%  0.00%  0.00%   0 Per-Second Jobs
146         424          17      24941  0.00%  0.00%  0.00%   0 RPC cygnus-oir
147        1484       76043         19  0.00%  0.00%  0.00%   0 PF_Init Process
148           0           4          0  0.00%  0.00%  0.00%   0 Fabman Timeout P
149         196      496195          0  0.00%  0.00%  0.00%   0 Heartbeat
150          24       50755          0  0.00%  0.00%  0.00%   0 SP BACKGROUND
151           0           1          0  0.00%  0.00%  0.00%   0 RF Messaging Pro
152           4          19        210  0.00%  0.00%  0.00%   0 IPC RTTYC Messag
153           0          24          0  0.00%  0.00%  0.00%   0 PF_Split Sync Pr
154           0          14          0  0.00%  0.00%  0.00%   0 RPC pf-split-sp
155           0           5          0  0.00%  0.00%  0.00%   0 RPC idprom-SP
156           0           9          0  0.00%  0.00%  0.00%   0 RTTYC Flush
157          96         404        237  0.00%  0.02%  0.00%   0 RFS server proce
158           0          17          0  0.00%  0.00%  0.00%   0 BACK CHECK
159           0           8          0  0.00%  0.00%  0.00%   0 AggMgr Process
160           0           1          0  0.00%  0.00%  0.00%   0 cpf_process_tpQ
161         180     1207151          0  0.00%  0.00%  0.00%   0 EARL Intr Thrtl
162           0           1          0  0.00%  0.00%  0.00%   0 Transport Port A
163           0           3          0  0.00%  0.00%  0.00%   0 EARL FIB Manager
164           0           1          0  0.00%  0.00%  0.00%   0 SPAN EARL Task
165           0           2          0  0.00%  0.00%  0.00%   0 Protocol Filteri
166         156        1215        128  0.07%  0.01%  0.00%   0 Remote Console P
167           0           1          0  0.00%  0.00%  0.00%   0 ADJ MGR
168           0           2          0  0.00%  0.00%  0.00%   0 ADJ_MGR
169          16         108        148  0.00%  0.00%  0.00%   0 L2 Control Task
170           4          77         51  0.00%  0.00%  0.00%   0 L2 Throttle Task
171          44       30822          1  0.00%  0.00%  0.00%   0 L2 Aging Task
172     1022588       31167      32809  1.35%  1.38%  1.36%   0 Vlan Statistics
173       70648     3378979         20  0.15%  0.19%  0.18%   0 L2 PI_E consiste
174          16       40648          0  0.00%  0.00%  0.00%   0 EARL7 monitor ta
175      327812        9601      34143  0.00%  0.41%  0.43%   0 TYFIB Table Mana
176       52016      272925        190  0.00%  0.00%  0.00%   0 NF Exception Tas
177         764       65765         11  0.00%  0.00%  0.00%   0 L3 Control Task
178          12           1      12000  0.00%  0.00%  0.00%   0 Netflow NDE Task
179          72       37117          1  0.00%  0.00%  0.00%   0 Netflow Aging Ta
180           0          41          0  0.00%  0.00%  0.00%   0 Task for pre-pro
181          44        7681          5  0.00%  0.00%  0.00%   0 Netflow Mgmt_Sta
182           0           1          0  0.00%  0.00%  0.00%   0 Netflow Sampling
183           0           1          0  0.00%  0.00%  0.00%   0 Online Linecard
184           0        1271          0  0.00%  0.00%  0.00%   0 CFIB-BGP Task
185           0           2          0  0.00%  0.00%  0.00%   0 CFIB LC High Pri
186       28532        4088       6979  0.00%  0.00%  0.00%   0 CFIB LC Main Tas
187          32        7621          4  0.00%  0.00%  0.00%   0 CFIB LC Timer Ta
188           4        7621          0  0.00%  0.00%  0.00%   0 CFIB LC STATS Ta
189           0           3          0  0.00%  0.00%  0.00%   0 Gemini SP proces
190           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
191           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
192           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
193           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
194           0        1271          0  0.00%  0.00%  0.00%   0 DFS flush period
195           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
196           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
197           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
198           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
199           0        1271          0  0.00%  0.00%  0.00%   0 DFS flush period
200           0           2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
201           0           2          0  0.00%  0.00%  0.00%   0 AAA Server
202           0           1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
203           0           1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
204           0           1          0  0.00%  0.00%  0.00%   0 AAA System Acct
205           0           2          0  0.00%  0.00%  0.00%   0 PIM Snooping Pro
206          20          31        645  0.00%  0.00%  0.00%   0 BGP INT
207          48       47894          1  0.00%  0.00%  0.00%   0 mls-hal Process
208           0           2          0  0.00%  0.00%  0.00%   0 mls-msc-ha proce
209           4          25        160  0.00%  0.00%  0.00%   0 mls-msc Process
210           0           1          0  0.00%  0.00%  0.00%   0 mls-msc-cc Proce
211           0           2          0  0.00%  0.00%  0.00%   0 Spanning Tree
212           0        7623          0  0.00%  0.00%  0.00%   0 Ethchnl
213           0           2          0  0.00%  0.00%  0.00%   0 DTP Protocol
214           8         139         57  0.00%  0.00%  0.00%   0 QoS SP Process
215         708        2668        265  0.00%  0.00%  0.00%   0 TCAM Manager pro
216         144      757514          0  0.00%  0.00%  0.00%   0 Mcast Hw Agent6
217           0           2          0  0.00%  0.00%  0.00%   0 capture process
218           0        2394          0  0.00%  0.00%  0.00%   0 L2 MAC oob sync
219           4          11        363  0.00%  0.00%  0.00%   0 Const Rate Limit
220           0           1          0  0.00%  0.00%  0.00%   0 SP DHCP Snooping
221           0           1          0  0.00%  0.00%  0.00%   0 Private hosts sp
222          12        4250          2  0.00%  0.00%  0.00%   0 L3 Manager SP Co
223          92        4228         21  0.00%  0.00%  0.00%   0 L3 Manager SP
224           0           2          0  0.00%  0.00%  0.00%   0 GVRP Process
225           0       18605          0  0.00%  0.00%  0.00%   0 MAC-Security-Agi
226           0           1          0  0.00%  0.00%  0.00%   0 STATIC MAC HANDL
227           0           1          0  0.00%  0.00%  0.00%   0 CWAN static MAC
228           0           1          0  0.00%  0.00%  0.00%   0 CWAN PORT CHANNE
229           0           2          0  0.00%  0.00%  0.00%   0 REP Topology cha
230           0           1          0  0.00%  0.00%  0.00%   0 IP ARP Adjacency
231         160     2330277          0  0.00%  0.01%  0.00%   0 IP ARP Retry Age
232           4        1271          3  0.00%  0.00%  0.00%   0 IP Input
233           0           1          0  0.00%  0.00%  0.00%   0 ICMP event handl
234           0           2          0  0.00%  0.00%  0.00%   0 IPAM/ODAP Events
235         176     2330462          0  0.07%  0.02%  0.00%   0 IPAM Manager
236           0           2          0  0.00%  0.00%  0.00%   0 IPAM Events
237           0           2          0  0.00%  0.00%  0.00%   0 PPP SIP
238           0           2          0  0.00%  0.00%  0.00%   0 PPP Bind
239           0           2          0  0.00%  0.00%  0.00%   0 PPP IP Route
240           0           1          0  0.00%  0.00%  0.00%   0 Switch Backup In
241           0       76215          0  0.00%  0.00%  0.00%   0 UDLD
242           4        1271          3  0.00%  0.00%  0.00%   0 Port-Security
243           0           5          0  0.00%  0.00%  0.00%   0 802.1x switch
244           0           2          0  0.00%  0.00%  0.00%   0 CEF switching ba
245           0           2          0  0.00%  0.00%  0.00%   0 OCE punted Pkts
246           0           1          0  0.00%  0.00%  0.00%   0 SSS Manager
247           0           1          0  0.00%  0.00%  0.00%   0 SSS Policy Manag
248           0           1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
249          36      297674          0  0.00%  0.00%  0.00%   0 SSS Feature Time
250           0           1          0  0.00%  0.00%  0.00%   0 SG DPM
251           0           1          0  0.00%  0.00%  0.00%   0 Timer handler fo
252           0           1          0  0.00%  0.00%  0.00%   0 Prepaid response
253           0           1          0  0.00%  0.00%  0.00%   0 Timed Policy act
254           0           1          0  0.00%  0.00%  0.00%   0 AAA response han
255           0           1          0  0.00%  0.00%  0.00%   0 AAA EPD HANDLER
256           0           1          0  0.00%  0.00%  0.00%   0 PM EPD API
257           0           1          0  0.00%  0.00%  0.00%   0 EAP Framework
258           0           1          0  0.00%  0.00%  0.00%   0 EAP Test
259           4       15246          0  0.00%  0.00%  0.00%   0 SSM connection m
260           8        7617          1  0.00%  0.00%  0.00%   0 QoS stats proces
261           0           1          0  0.00%  0.00%  0.00%   0 TCP Timer
262           0           1          0  0.00%  0.00%  0.00%   0 TCP Protocols
263           0           1          0  0.00%  0.00%  0.00%   0 Socket Timers
264           0         255          0  0.00%  0.00%  0.00%   0 HTTP CORE
265          80       76478          1  0.00%  0.00%  0.00%   0 PfR BR Learn
266           0           1          0  0.00%  0.00%  0.00%   0 CFMPAL OIR POWER
267          12       27436          0  0.00%  0.00%  0.00%   0 CFMPAL Process
268           0           1          0  0.00%  0.00%  0.00%   0 XDR background p
269           4        7093          0  0.00%  0.00%  0.00%   0 XDR mcast
270         180       22409          8  0.00%  0.00%  0.00%   0 mls-gc Process
271           0           1          0  0.00%  0.00%  0.00%   0 mls-pimsn Proces
272         488       76135          6  0.00%  0.00%  0.00%   0 MLTL Agent
273           0          35          0  0.00%  0.00%  0.00%   0 mfib-const-lc Pr
274           0        4066          0  0.00%  0.00%  0.00%   0 mls-igmp Process
275           0           1          0  0.00%  0.00%  0.00%   0 mls-cgmp Process
276           4        7623          0  0.00%  0.00%  0.00%   0 mls-mld Process
277           0           1          0  0.00%  0.00%  0.00%   0 mld-mrouter Proc
278           0           1          0  0.00%  0.00%  0.00%   0 FRR Background P
279           4        1276          3  0.00%  0.00%  0.00%   0 CEF background p
280           0           3          0  0.00%  0.00%  0.00%   0 fib_fib_bfd_sb e
281         272       74802          3  0.00%  0.00%  0.00%   0 XDR LC PRIO Back
282          56       14278          3  0.00% 38.05% 39.55%   0 XDR LC PRIO Crit
283       17832        8123       2195  0.00%  0.00%  0.00%   0 XDR LC Backgroun
284           0           3          0  0.00%  0.00%  0.00%   0 MFIB Master back
285           0           2          0  0.00%  0.00%  0.00%   0 STP HA IPC flow
286           0           2          0  0.00%  0.00%  0.00%   0 CEF LC IPC Backg
287          16        7622          2  0.00%  0.00%  0.00%   0 LC ETHER EFP Com
288           0           2          0  0.00%  0.00%  0.00%   0 BD MACSEC HA
289           0           2          0  0.00%  0.00%  0.00%   0 REP LSL Proc
290           0           2          0  0.00%  0.00%  0.00%   0 REP BPA/EPA Proc
291           0           2          0  0.00%  0.00%  0.00%   0 SCTP Main Proces
292           0           1          0  0.00%  0.00%  0.00%   0 IP Traceroute
293           0           1          0  0.00%  0.00%  0.00%   0 Probe Input
294           0           1          0  0.00%  0.00%  0.00%   0 RARP Input
295           0           1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
296        1412       17320         81  0.00%  0.00%  0.00%   0 Hardware API bac
297           0           1          0  0.00%  0.00%  0.00%   0 Path set broker
298           0           2          0  0.00%  0.00%  0.00%   0 XDR FOF process
299           0           2          0  0.00%  0.00%  0.00%   0 LOCAL AAA
300           0           2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
301           0           2          0  0.00%  0.00%  0.00%   0 LINE AAA
302           0           2          0  0.00%  0.00%  0.00%   0 AAA Cached Serve
303           0           1          0  0.00%  0.00%  0.00%   0 EM Background Pr
304           0           1          0  0.00%  0.00%  0.00%   0 IDMGR CORE
305           0           1          0  0.00%  0.00%  0.00%   0 Pre-download RP
306           0           1          0  0.00%  0.00%  0.00%   0 Pre-dnld LC to A
307           0           1          0  0.00%  0.00%  0.00%   0 Pre-download pee
308           0           2          0  0.00%  0.00%  0.00%   0 TPLUS
309           0           2          0  0.00%  0.00%  0.00%   0 GVRP SWITCH Proc
310           4         136         29  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
311           0           1          0  0.00%  0.00%  0.00%   0 HW Capacity ICC
312           0           2          0  0.00%  0.00%  0.00%   0 PM Vlan Timer Pr
313           0           1          0  0.00%  0.00%  0.00%   0 pm icc process
314           0          21          0  0.00%  0.00%  0.00%   0 pm scp process
315           0          15          0  0.00%  0.00%  0.00%   0 PM CP Process
316          12          40        300  0.00%  0.00%  0.00%   0 RPC pm-cp
317           8       18674          0  0.00%  0.00%  0.00%   0 PM Callback
318         488          20      24400  0.00%  0.00%  0.00%   0 VLAN Manager
319           8        7622          1  0.00%  0.00%  0.00%   0 Port manager per
320           8       15241          0  0.00%  0.00%  0.00%   0 Max CPU utilizat
321           0          12          0  0.00%  0.00%  0.00%   0 RPC ecfmpal_rpc_
322           0           2          0  0.00%  0.00%  0.00%   0 RPC icrm_rp2sp
323           4       15241          0  0.00%  0.00%  0.00%   0 Inline Power Por
324           0           2          0  0.00%  0.00%  0.00%   0 RPC storm_contro
325           0           1          0  0.00%  0.00%  0.00%   0 StandbyDiagDaemo
326           8       25400          0  0.00%  0.00%  0.00%   0 DiagInbandRatePr
327           4         100         40  0.00%  0.00%  0.00%   0 SEA main process
328           8         108         74  0.00%  0.00%  0.00%   0 RPC pf_issu_rp2s
329           0          20          0  0.00%  0.00%  0.00%   0 RPC pf_prst_vbl_
330           0           2          0  0.00%  0.00%  0.00%   0 RPC pf_redun_rp2
331           8       15586          0  0.00%  0.00%  0.00%   0 SEA write CF pro
332          36        7621          4  0.00%  0.00%  0.00%   0 TM Stat Adj Task
333         176         135       1303  0.00%  0.00%  0.00%   0 L2 Application T
334           0           1          0  0.00%  0.00%  0.00%   0 VPN_MAPPER
335           0           2          0  0.00%  0.00%  0.00%   0 RPC dhcp_snoopin
336           0           2          0  0.00%  0.00%  0.00%   0 RPC pvt_hosts_sw
337           0           2          0  0.00%  0.00%  0.00%   0 Const FIB excep
338           0           2          0  0.00%  0.00%  0.00%   0 RPC pclc_g2_fw_s
339           0           2          0  0.00%  0.00%  0.00%   0 RPC pclc_g2_ids_
340           0           3          0  0.00%  0.00%  0.00%   0 SEA write messag
341        4164       44729         93  0.00%  0.00%  0.00%   0 C6K PROCMIB SP P
342           0           1          0  0.00%  0.00%  0.00%   0 CMFI CC Backgrou
343           0           2          0  0.00%  0.00%  0.00%   0 RPC cfib_rp2sp
344           0           2          0  0.00%  0.00%  0.00%   0 Rommon upgrade p
345           0           1          0  0.00%  0.00%  0.00%   0 CONST SMC
346           0           2          0  0.00%  0.00%  0.00%   0 RPC epld_isp_rpc
347           0           2          0  0.00%  0.00%  0.00%   0 RPC itasca_sp
348           0           2          0  0.00%  0.00%  0.00%   0 RPC cdump_rp_req
349           0           3          0  0.00%  0.00%  0.00%   0 RPC logging_even
350          32       76161          0  0.00%  0.00%  0.00%   0 NV Health Monito
351           0           2          0  0.00%  0.00%  0.00%   0 RPC sw_backup_in
352           4          20        200  0.00%  0.00%  0.00%   0 RPC mlacp_mp2sp
353        3816       68420         55  0.00%  0.00%  0.00%   0 RPC sw_vlan_sp
354          16         162         98  0.00%  0.00%  0.00%   0 RPC stp_switch_a
355          92        1588         57  0.00%  0.00%  0.00%   0 RPC pagp_switch_
356           0           2          0  0.00%  0.00%  0.00%   0 RPC lacp_switch_
357           0           2          0  0.00%  0.00%  0.00%   0 RPC pt_switch_mp
358           0           2          0  0.00%  0.00%  0.00%   0 RPC qnq_switch_m
359           0           8          0  0.00%  0.00%  0.00%   0 RPC span_switch_
360           8         118         67  0.00%  0.00%  0.00%   0 RPC mapping_sp
361           0           2          0  0.00%  0.00%  0.00%   0 RPC intacc_rp
362          28         425         65  0.00%  0.00%  0.00%   0 RPC udld_sp
363           8        7623          1  0.00%  0.00%  0.00%   0 SP Error Detecti
364           0           2          0  0.00%  0.00%  0.00%   0 RPC error_detect
365         324        5966         54  0.23%  0.02%  0.00%   0 RPC c6k_power_sp
366        3476       62347         55  0.07%  0.04%  0.05%   0 Env Poll
367        1712       40116         42  0.00%  0.00%  0.00%   0 RPC c6k_sp_envir
368           0           2          0  0.00%  0.00%  0.00%   0 RPC chapi_sp
369         148        3134         47  0.00%  0.00%  0.00%   0 RPC pm_switch_rp
370           0           2          0  0.00%  0.00%  0.00%   0 RPC const_nv_cfg
371           0           2          0  0.00%  0.00%  0.00%   0 RPC l2_bridge
372         176        2434         72  0.07%  0.00%  0.00%   0 RPC online_diag_
373           0           2          0  0.00%  0.00%  0.00%   0 RPC online_diag_
374           0          12          0  0.00%  0.00%  0.00%   0 RPC online_wan_d
375           0          30          0  0.00%  0.00%  0.00%   0 RPC pikachu_sp
376         520       10533         49  0.00%  0.17%  0.04%   0 RPC rf_cli_rp2sp
377          24         444         54  0.00%  0.00%  0.00%   0 RPC issu_cli_rp2
378           0          18          0  0.00%  0.00%  0.00%   0 RPC c6k_stack_mi
379           0           2          0  0.00%  0.00%  0.00%   0 RPC psecure_sp
380           4          20        200  0.00%  0.00%  0.00%   0 RPC gbic_seprom_
381           0           2          0  0.00%  0.00%  0.00%   0 RPC const_ehsa_r
382           0           2          0  0.00%  0.00%  0.00%   0 RPC const_platfo
383           0           2          0  0.00%  0.00%  0.00%   0 RPC pm_mat_mp2sp
384           0           2          0  0.00%  0.00%  0.00%   0 RPC switch_engin
385           0           2          0  0.00%  0.00%  0.00%   0 RPC ether_oam_rp
386           0           2          0  0.00%  0.00%  0.00%   0 RPC dot1ad_mp2sp
387           0           2          0  0.00%  0.00%  0.00%   0 RPC acr_rp2sp
388           0           4          0  0.00%  0.00%  0.00%   0 RPC rep_rp2sp_ap
389           0           2          0  0.00%  0.00%  0.00%   0 RPC dot1x_sp
390           0           6          0  0.00%  0.00%  0.00%   0 RPC lcc_rp
391          96        1564         61  0.00%  0.00%  0.00%   0 RPC fabman_rp
392           0         108          0  0.00%  0.00%  0.00%   0 RPC sea_rp_cli_r
393           0           2          0  0.00%  0.00%  0.00%   0 RPC const_ifs_rp
394           0           2          0  0.00%  0.00%  0.00%   0 RPC gvrp_rp2sp
395           4           4       1000  0.00%  0.00%  0.00%   0 L2 Manager Task
396           0           1          0  0.00%  0.00%  0.00%   0 L2 Manager Earl6
397          56         730         76  0.00%  0.00%  0.00%   0 LTL MGR
398           0           1          0  0.00%  0.00%  0.00%   0 LTL MGR cc
399           0           3          0  0.00%  0.00%  0.00%   0 SPAN switch
400           0          15          0  0.00%  0.00%  0.00%   0 SPAN Switch SP
401           4        7620          0  0.00%  0.00%  0.00%   0 SPAN Switch SP B
402           0          10          0  0.00%  0.00%  0.00%   0 LC Registry Expo
403           0           2          0  0.00%  0.00%  0.00%   0 LC IPC ICC Init
404           8          38        210  0.00%  0.00%  0.00%   0 Const2 IPv6 Proc
405           0           1          0  0.00%  0.00%  0.00%   0 v6fib stat colle
406           0          18          0  0.00%  0.00%  0.00%   0 CMFI
407           0          27          0  0.00%  0.00%  0.00%   0 CMFI Scanner
408           0           8          0  0.00%  0.00%  0.00%   0 CMFI Misc
409          20        7938          2  0.00%  0.00%  0.00%   0 CMFI Background
410           0           1          0  0.00%  0.00%  0.00%   0 CMFI iEdge Proce
411           0           2          0  0.00%  0.00%  0.00%   0 EI SP
412           0           2          0  0.00%  0.00%  0.00%   0 REP SP Proc
413           0           7          0  0.00%  0.00%  0.00%   0 ADJ background
414           0           2          0  0.00%  0.00%  0.00%   0 SEA receive proc
415           0          16          0  0.00%  0.00%  0.00%   0 Syslog
416           0        2495          0  0.00%  0.00%  0.00%   0 NDE - IPV4
417           0           1          0  0.00%  0.00%  0.00%   0 NDE - MPLS
418           0           1          0  0.00%  0.00%  0.00%   0 NDE - L2
419           0         124          0  0.00%  0.00%  0.00%   0 NDE - IPV6
420           0           1          0  0.00%  0.00%  0.00%   0 SpanTree Helper
421           4        7620          0  0.00%  0.00%  0.00%   0 MFI LFD Stats Pr
422           4       14380          0  0.00%  0.00%  0.00%   0 MFI LFD Timer Pr
423           4           3       1333  0.00%  0.00%  0.00%   0 MFI LFD Main Pro
424           4          47         85  0.00%  0.00%  0.00%   0 Collection proce
426         984      256290          3  0.00%  0.02%  0.00%   0 DiagCard5/-1
427          52      262099          0  0.00%  0.00%  0.00%   0 SCP async: LCP#5
428           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
429           4        1271          3  0.00%  0.00%  0.00%   0 system Image Rec
431           0           2          0  0.00%  0.00%  0.00%   0 fabm_ch_sync:2
--- remote command switch show ipc status ---
                            IPC System Status
Time last IPC stat cleared all zones : 00:00:00
This processor is the IPC master server in zone 0 (default).
Do not drop output of IPC frames for test purposes.
6000 IPC Message Headers Cached.
                                                    Rx Side     Tx Side
Total Frames                                           481095      482971
Total from Local Ports                                 237025      304573
Total Protocol Control Frames                             185         364
Total Frames Dropped                                        7           0
                             Service Usage
Total via Unreliable Connection-Less Service            38008       38093
Total via Unreliable Sequenced Connection-Less Svc          0           0
Total via Reliable Connection-Oriented Service         199232      266479
Total Messages via Fragmentation                            9         791
Total Fragments                                            37        6328
Total Internal IPC Messages                               352           0
Total Messages Flushed                                      0           0
                      IPC Protocol Version 0
Total Acknowledgements                                 272015      172861
Total Negative Acknowledgements                             0           0
                             Device Drivers
Total via Local Driver                                  16396       16396
Total via Platform Driver                              464697      466575
Total Frames Dropped by Platform Drivers                    0           0
Total Frames Sent when media is quiesced                                0
                     Reliable Tx Statistics
Re-Transmission                                                         1
Re-Tx Timeout                                                           0
          Rx Errors                              Tx Errors
Unsupp IPC Proto Version          0  Tx Session Error                  0
Corrupt Frame                     0  Tx Seat Error                     0
Duplicate Frame                   7  Tx No Send Vector                 0
Unrel Out-of-Seq Frame            0  Tx Driver Failed                  0
Rx IPC Transform Errors           0  Tx IPC Transform Errors           0
Unable to Deliver Msg             0  Tx Test Drop                      0
Rx Msg Callback Hog               0  Ack Alloc Failed                  0
Rel Out-of-Seq Frame              0
Dest Port does Not Exist          0
Rx IPC Msg Alloc Failed           0
Rx IPC Frag Dropped               0
Rx Bootstrap Delivered            2
Rx Bootstrap Dropped              0
          Buffer Errors                          Misc Errors
IPC Msg Alloc                     0  IPC Open Port                    51
Emer IPC Msg Alloc                0  No HWQ                            0
IPC Frame PakType Alloc           0  Hardware Error                    0
IPC Frame MemD Alloc              0  Invalid Messages                  0
                                      IPC Backup Open Port              0
                                      IPC Fragment Errors               0
                                      Message Timer Errors              0
                                      Messages no xmt pending flag      0
          Tx Driver Errors
No Transport                      0
MTU Failure                       0
Dest does not Exist               0
          IPC Message Bundling Statistics
Seat-level    Tx Bundling (bdl/sub/nonbdl/urgent/err)  0/0/310110/0/0
Seat-level    Rx Bundling (bdl/sub/nonbdl/err)         0/0/481093/0
Session-level Tx Bundling (bdl/sub/nonbdl/urgent/err)  0/0/304572/139887/0
Session-level Rx Bundling (bdl/sub/nonbdl/err)         0/0/176436/0
--- remote command switch show ipc queue ---
There are 4 IPC messages waiting for acknowledgement in the transmit queue.
There are 0 IPC messages waiting for a response.
There are 0 IPC messages waiting for additional fragments.
There are 0 IPC messages currently on the IPC inboundQ.
There are 0 IPC messages currently on the RX controller inboundQ.
There are 0 IPC messages currently on the TX controller inboundQ.
There are 0 IPC messages currently on the zone inboundQ.
Messages currently in use                     :         31
Message cache size                            :       6000
Maximum message cache usage                   :       6000
0  times message cache crossed      12000 [max]
Emergency messages currently in use           :          0
There are 25 messages currently reserved for reply msg.
Cache low watermark           [default/new]: [100/100]
         No of low watermark reached           :         0
         Total get cache after low watermark   :         0
         No of times zero cache reached        :         0
         No of times one cache added           :         0
         No of times cache chunk added         :         0
         Max no of get cache between wake2grow :         0
IPC Retransmission Table:
Source                         Destination                    Size  Tries  Seq  Msg
   10000.0     IPC Master       2150000.25    Resource Man... 37    0      1182 0x10E8F058
   10000.0     IPC Master       2150000.25    Resource Man... 25    0      1183 0x10E8D014
   10000.0     IPC Master       2150000.25    Resource Man... 37    0      1184 0x10E90B14
   10000.0     IPC Master       2150000.7     Card5/1:Reques  16    0      32968 0x10E8DC10
--- remote command switch show heartbeat ---
Out of buffers          = 0
Fatal errors            = 0
Last heartbeat sched    = 632
Last heartbeat sent     = 1324
Peer 5/0 [online]:
Peer 5/1 [online]:
Heartbeats received     = 38006
Config msgs received    = 1
Clock cfg msgs received = 1
Scheduler history [Virtual Exec 10%/0% (00:00:04.004 12%/0%)] [Virtual Exec 00:00:00.152] [Remote Console Process 00:00:00.156] [UDLD 00:00:00.156]
RTLSGR1#
Pulikkal Sekhar... Sun, 09/30/2012 - 03:42
  • Cisco Employee,
I can see input drops on Gig 5/1.
Please get me the following outputs. Take 3 sets of outputs with ~ 1 minute interval between the captures
1. Show ip traffic
2. show int gi 5/1 stat
3. show int gi 5/1 switching
4. Show int gi 5/2 stat
5. show int gi 5/2 switching
sabuz_banik Sun, 09/30/2012 - 04:08
RTLSGR1#sh ip traffic
IP statistics:
  Rcvd:  1201087872 total, 646509 local destination
         0 format errors, 0 checksum errors, 6546 bad hop count
         0 unknown protocol, 0 not a gateway
         0 security failures, 0 bad options, 8 with options
  Opts:  0 end, 0 nop, 0 basic security, 0 loose source route
         0 timestamp, 0 extended security, 0 record route
         0 stream ID, 0 strict source route, 8 alert, 0 cipso, 0 ump
         0 other
  Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble
         0 fragmented, 0 couldn't fragment
  Bcast: 1296 received, 0 sent
  Mcast: 19513 received, 9486 sent
  Sent:  762481 generated, 3989749131 forwarded
  Drop:  12 encapsulation failed, 0 unresolved, 0 no adjacency
         1295 no route, 0 unicast RPF, 0 forced drop, 0 unsupported-addr
         0 options denied, 0 source IP address zero
ICMP statistics:
  Rcvd: 6 format errors, 0 checksum errors, 0 redirects, 286 unreachable
        397547 echo, 165 echo reply, 0 mask requests, 0 mask replies, 0 quench
        0 parameter, 0 timestamp, 0 info request, 2 other
        0 irdp solicitations, 0 irdp advertisements
  Sent: 0 redirects, 98909 unreachable, 175 echo, 397547 echo reply
        0 mask requests, 0 mask replies, 0 quench, 0 timestamp
        0 info reply, 481 time exceeded, 0 parameter problem
BGP statistics:
  Rcvd: 135688 total, 7 opens, 2 notifications, 132580 updates
        3099 keepalives, 0 route-refresh, 0 unrecognized
  Sent: 4284 total, 7 opens, 3 notifications, 0 updates
        4274 keepalives, 0 route-refresh
EIGRP-IPv4 statistics:
  Rcvd: 0 total
  Sent: 0 total
TCP statistics:
  Rcvd: 93741 total, 18 checksum errors, 23 no port
  Sent: 121184 total
PIMv2 statistics: Sent/Received
  Total: 0/0, 0 checksum errors, 0 format errors
  Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0,  Hellos: 0/0
  Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0
  Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0
  Queue drops: 0
  State-Refresh: 0/0
IGMP statistics: Sent/Received
  Total: 0/0, Format errors: 0/0, Checksum errors: 0/0
  Host Queries: 0/0, Host Reports: 0/0, Host Leaves: 0/0
  DVMRP: 0/0, PIM: 0/0
  Queue drops: 0
UDP statistics:
  Rcvd: 135147 total, 0 checksum errors, 295 no port
  Sent: 134835 total, 0 forwarded broadcasts
OSPF statistics:
  Last clearing of OSPF traffic counters never
  Rcvd: 19596 total, 0 checksum errors
        18877 hello, 44 database desc, 8 link state req
        361 link state updates, 197 link state acks
  Sent: 9661 total
        9241 hello, 39 database desc, 11 link state req
        172 link state updates, 202 link state acks
Probe statistics:
  Rcvd: 0 address requests, 0 address replies
        0 proxy name requests, 0 where-is requests, 0 other
  Sent: 0 address requests, 0 address replies (0 proxy)
        0 proxy name replies, 0 where-is replies
ARP statistics:
  Rcvd: 168 requests, 16 replies, 0 reverse, 0 other
  Sent: 9070 requests, 25 replies (0 proxy), 0 reverse
  Drop due to input queue full: 0
RTLSGR1#
RTLSGR1#sh int gi5/1 stat
GigabitEthernet5/1
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
               Processor     106745    9048634      51710   16055410
             Route cache 4730160497 361950786744        270      22832
       Distributed cache 3603516173 470043068068 10055243954 914016291307
                   Total 8333783415 832002903446 10055295934 914032369549
RTLSGR1#
RTLSGR1#show int gi 5/1 switching
GigabitEthernet5/1 Internet With NetroNext
          Throttle count          3
                   Drops         RP       4426         SP          0
             SPD Flushes       Fast          0        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs      26866      Drops          0
    Protocol  IP
                 Process      57139    4966228      46179   17182152
            Cache misses          0          -          -          -
                    Fast 4739191132 362656259906        270      22832
               Auton/SSE 3612493106 471074695184 10071708798 915679168901
    Protocol  DEC MOP
                 Process         32       2464        127      14351
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Spanning Tree
                 Process      38436    1998672          0          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process       7084     425872       5547     532512
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process       1237     566546          0          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    NOTE: all counts are cumulative and reset only after a reload.
RTLSGR1#sh int gi5/2 stat
GigabitEthernet5/2
               Processor     653281   67059528     669349   73389781
             Route cache     775338  280445136 5805678066 444689501595
       Distributed cache 5851631726 473093070689  619334594 50306453853
                   Total 5853060345 473440575353 6425682009 495069345229
RTLSGR1#
RTLSGR1#show int gi 5/2 switching
GigabitEthernet5/2
          Throttle count          0
                   Drops         RP          0         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs      10240      Drops          0
    Protocol  IP
                 Process     653681   64478658     669593   94836007
                    Fast     775436  280451853 5810691636 445082995797
               Auton/SSE 5856326840 473484061519  619782207 50344143470
    Protocol  DEC MOP
                 Process          0          0        147      16611
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process          8        480          8        768
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
RTLSGR1#
After 5 Min               After 5 Min                         After 5 Min                                        After 5 Min
IP statistics:
  Rcvd:  1325523576 total, 651172 local destination
         0 other
  Bcast: 1304 received, 0 sent
  Mcast: 19671 received, 9559 sent
  Sent:  767796 generated, 4168295526 forwarded
ICMP statistics:
        401563 echo, 165 echo reply, 0 mask requests, 0 mask replies, 0 quench
  Sent: 0 redirects, 99699 unreachable, 175 echo, 401563 echo reply
BGP statistics:
  Rcvd: 136112 total, 7 opens, 2 notifications, 132979 updates
        3124 keepalives, 0 route-refresh, 0 unrecognized
  Sent: 4320 total, 7 opens, 3 notifications, 0 updates
        4310 keepalives, 0 route-refresh
  Rcvd: 0 total
  Sent: 0 total
TCP statistics:
  Rcvd: 94218 total, 18 checksum errors, 23 no port
  Sent: 121612 total
  Queue drops: 0
  State-Refresh: 0/0
  Queue drops: 0
UDP statistics:
  Rcvd: 135159 total, 0 checksum errors, 295 no port
  Sent: 134847 total, 0 forwarded broadcasts
OSPF statistics:
  Rcvd: 19754 total, 0 checksum errors
        19032 hello, 44 database desc, 8 link state req
        363 link state updates, 198 link state acks
  Sent: 9735 total
        9313 hello, 39 database desc, 11 link state req
        172 link state updates, 204 link state acks
Probe statistics:
ARP statistics:
  Rcvd: 169 requests, 16 replies, 0 reverse, 0 other
  Sent: 9132 requests, 25 replies (0 proxy), 0 reverse
RTLSGR1#
GigabitEthernet5/1
               Processor     108078    9151786      52629   16159723
             Route cache 4785047155 366243453033        270      22832
       Distributed cache 3668518490 477550142800 10168662168 925524284345
                   Total 8453673723 843802747619 10168715067 925540466900
RTLSGR1#
          Throttle count          3
                   Drops         RP       4426         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs      27120      Drops          0
    Protocol  IP
                 Process      58127    5042647      47087   17318573
                    Fast 4794386221 366974472835        270      22832
               Auton/SSE 3680358933 478916563850 10189693235 927664285151
    Protocol  DEC MOP
                 Process         32       2464        128      14464
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
                 Process      38822    2018744          0          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process       7085     425932       5586     536256
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process       1250     572500          0          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
RTLSGR1#
GigabitEthernet5/2
               Processor     658087   67465441     674124   73794790
             Route cache     777936  280610295 5857530651 448745142886
       Distributed cache 5902969561 477363657083  624035056 50703987462
                   Total 5904405584 477711732819 6482239831 499522925138
RTLSGR1#
GigabitEthernet5/2
          Throttle count          0
                   Drops         RP          0         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs      10287      Drops          0
    Protocol  IP
                 Process     658702   64879453     674568   95424560
                    Fast     778053  280617813 5862646520 449144181072
               Auton/SSE 5907375471 477729069916  624497683 50743545627
    Protocol  DEC MOP
                 Process          0          0        148      16724
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process          8        480          8        768
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
RTLSGR1#
Pulikkal Sekhar... Sun, 09/30/2012 - 06:45
  • Cisco Employee,
We see lot of packets gettign fast switched. Also the traffic in and out to the CPU is very high
------------------ show ibc ------------------
Interface information:
        Interface IBC0/0(idb 0x183CD514)
        5 minute rx rate 52098000 bits/sec, 85888 packets/sec
        5 minute tx rate 126231000 bits/sec, 171809 packets/sec
To find which packets are hitting the CPU, either we need to sniff the CPU or capture netdr output
Sniffing the CPU is mentioend in below link
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a00804916e0.shtml
To collect the netdr output. Please do the following
1. Run the following command from enable mode
  Debug netdr
2. wait for 2 minutes and execute the following command
Undebug all
3. Collect the following output and attach here
show netdr captured packets
note: The command starts with the word debug.  But this doesn't add any load to CPU and it safe to run even when CPU is running at 99%
sabuz_banik Sun, 09/30/2012 - 21:47
Hi Rajs,
How to avoid fast switching as already CEF is on. Yes i am sharing you the capture file of netdr.
Pulikkal Sekhar... Sun, 09/30/2012 - 22:08
  • Cisco Employee,
yes. CEF is on. We need to analyze the packets hitting the CPU, to analyze this
sabuz_banik Sun, 09/30/2012 - 22:09
----- dump of outgoing inband packet -------
interface Gi5/2, routine naboo_fastsend, timestamp 04:40:22.261
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x4E(78)
  bpdu 0, index_dir 0, flood 0, dont_lrn 0, dest_indx 0x7F0A(32522)
  00020000 03F82800 03800000 4E000000 00110000 20B00000 50330000 7F0A2000
destmac 00.0E.D6.1D.B8.CE, srcmac 00.21.A0.0B.1F.80, protocol 0800
layer 3 data: 4500003C 00004000 39111E60 670E5033 465625BA C9882A76
              00280000 80128543 615D9EA0 23064664 54B3FBD1 4C4FF2AC
              07C4547A D9D5ED6E 000003F8 00000101 00000380 7AC6
------- dump of incoming inband packet -------
interface Gi5/1, routine process_rx_packet_inline, timestamp 04:40:22.261
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x4E(78)
  60000400 03FB0000 01000000 4E000000 0011B8AA 8732670E 50330000 7F0A2000
destmac 00.21.A0.0B.1F.80, srcmac 64.16.8D.15.40.45, protocol 0800
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 60, identifier 0
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 184.170.135.50
    udp src 7038, dst 8570 len 40 checksum 0x0
------- dump of outgoing inband packet -------
  00020000 03F82800 03800000 4E000000 00110000 80300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39114A93 670E5033 B8AA8732 1B7E217A
              00280000 801227DD 615D9EA0 03EE668C 6DA20847 92DFB214
              14E96702 484F72A9 000003F8 00000101 00000380 7AC5
  70000400 03FB0000 01000000 4E000000 0011BC8A 60E6670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 188.138.96.230
    udp src 20428, dst 11358 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 20E00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39116CFF 670E5033 BC8A60E6 4FCC2C5E
              00280000 801235CA 615D9EA0 209C45FE 7548C6EB 28124C6F
              63D04056 B49E9F62 000003F8 00000101 00000380 7AC8
  78000400 03FB0000 01000000 4E000000 00114447 29FA670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.41.250
    udp src 16688, dst 7362 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 20F00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39111C2F 670E5033 444729FA 41301CC2
              00280000 8012721F 615D9EA0 188E7DEC 77C883F0 92C5AE62
              0A913E6B D8E04E12 000003F8 00000101 00000380 7AC5
  90000400 03FB0000 01000000 4E000000 0011D12C 7F24670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.44.127.36
    udp src 5890, dst 7450 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 30200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39113A1F 670E5033 D12C7F24 17021D1A
              00280000 80121352 615D6F70 144D712F AB3AAC5B 9B3BE337
              01E5ABDE 9F553773 000003F8 00000101 00000380 7AC6
  98000400 03FB0000 01000000 4E000000 00114447 39F6670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.57.246
    udp src 44344, dst 10646 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 30F00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39110C33 670E5033 444739F6 AD382996
              00280000 80125C00 615D6F70 768913EB 79BF8AB3 42D7D081
              744C3876 8E06CCEE 000003F8 00000101 00000380 7AC8
  C0000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 70.87.221.51
    udp src 58458, dst 24496 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 90300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 E45A5FB0
              00280000 80128478 615D6F70 6A200F42 78009CC6 A6FB1750
              2696F8BE E3D43DA2 000003F8 00000101 00000380 7AC8
  28000400 03FB0000 01000000 4E000000 00115519 B829670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 85.25.184.41
    udp src 11216, dst 9522 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 B0200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39117D2D 670E5033 5519B829 2BD02532
              00280000 80128B49 615D6F70 36F05392 13E0D132 B87D2F01
              136F1AA5 D13A4B4C 000003F8 00000101 00000380 7AC5
  40000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.74.97.226
    udp src 16142, dst 8206 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 3F0E200E
              00280000 80124DAE 615D6F70 05746016 F6DBC213 3BA0A96A
              1353F6DB C1865899 000003F8 00000101 00000380 7AC7
  D0000400 03FB0000 01000000 4E000000 00113E4B FE2B670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 62.75.254.43
    udp src 38414, dst 9146 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B 960E23BA
              00280000 80123A03 816188A0 176C720E 5C1A9CD8 02BB0C61
              625042CA DC4BA7E2 000003F8 00000101 00000380 7AC7
  D8000400 03FB0000 01000000 4E000000 00115519 4945670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 85.25.73.69
    udp src 29514, dst 10494 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 00400000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911EC11 670E5033 55194945 734A28FE
              00280000 80127646 3DE30510 72F21790 D4E08704 C038C8FA
              D041D4F0 B20EC076 000003F8 00000101 00000380 7AC8
  E8000400 03FB0000 01000000 4E000000 0011482C 4C3D670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 72.44.76.61
    udp src 20176, dst 10002 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 00300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911F606 670E5033 482C4C3D 4ED02712
              00280000 80123A14 3DE30510 0FFA6A98 606ABC3E DF0A940A
              121E40D7 B9315742 000003F8 00000101 00000380 7AC7
  10000400 03FB0000 01000000 4E000000 00114447 2E98670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.46.152
    udp src 65124, dst 8294 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 20900000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39111791 670E5033 44472E98 FE642066
              00280000 8012D38E 3DE30510 330C566E F8F0C9EB CEEBC2F4
              DD1E7503 F88BF312 000003F8 00000101 00000380 7AC6
  38000400 03FB0000 01000000 4E000000 0011ADF6 27C4670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 173.246.39.196
    udp src 12684, dst 3358 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 20C00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911B4B5 670E5033 ADF627C4 318C0D1E
              00280000 8012A4C0 816188A0 7BD71EB5 5C3B98F8 8732082E
              BE1472B3 2176F5E2 000003F8 00000101 00000380 7AC5
  50000400 03FB0000 01000000 4E000000 00116CA6 D01D670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.208.29
    udp src 37036, dst 6530 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 90100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39114DAC 670E5033 6CA6D01D 90AC1982
              00280000 80121CA0 3DE30510 1048752A F21B7372 B93FD0E4
              271032E0 B3A15D3E 000003F8 00000101 00000380 7AC8
  60000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
    udp src 29596, dst 50792 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 739CC668
              00280000 80120781 816188A0 53533631 7856AB60 00FAC200
              07D678EB 6B6000FA 000003F8 00000101 00000380 7AC5
  68000400 03FB0000 01000000 4E000000 00113261 4E69670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 50.97.78.105
    udp src 63858, dst 6750 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 00600000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 F9721A5E
              00280000 80126F6A 3DE30510 223F475D 52F9E5C8 0212D2DF
              7616FC18 7C7253AE 000003F8 00000101 00000380 7AC5
  70000400 03FB0000 01000000 4E000000 00114E81 B22E670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 78.129.178.46
    udp src 10198, dst 6222 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391189C0 670E5033 4E81B22E 27D6184E
              00280000 8012097C 3DE30510 2E714B13 78CAB3EE E42ED26F
              151678AA D739A7B2 000003F8 00000101 00000380 7AC8
  88000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.228.3.77
    udp src 65328, dst 56864 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D FF30DE20
              00280000 80121E38 816188A0 06DC63BE 8EDF168B 9861F1DA
              098A576C 9607D16C 000003F8 00000101 00000380 7AC7
  90000400 03FB0000 01000000 4E000000 001143D4 5019670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.212.80.25
    udp src 51148, dst 9210 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 10100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911F682 670E5033 43D45019 C7CC23FA
              00280000 80123F50 3DE30510 182B7D49 F82BF625 3F7A522D
              265B70CA D1E16C22 000003F8 00000101 00000380 7AC8
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0xDA(218)
  A0000400 03FB0000 01000000 DA000000 0011AE88 2869670E 50330000 7F0A2000
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 200, identifier 0
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 174.136.40.105
    udp src 43236, dst 28134 len 180 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0xDA(218)
  00020000 03F82800 03800000 DA000000 00110000 20600000 50330000 7F0A2000
layer 3 data: 450000C8 00004000 3911B2F2 670E5033 AE882869 A8E46DE6
              00B40000 800870CC 816188A0 06756317 D555D5D5 55D5D5D5
              D5D5D5D5 D5D5D5D5 000003F8 00000101 00000380 7AC6
  A8000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
    udp src 25564, dst 29446 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 63DC7306
              00280000 8012E324 3DE30510 63A706C5 05F8C6F2 A9A717BB
              918C0FEE 07CB08DE 000003F8 00000101 00000380 7AC9
  B0000400 03FB0000 01000000 4E000000 0011D5E5 539B670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 213.229.83.155
    udp src 43474, dst 11250 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 10900000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391160EF 670E5033 D5E5539B A9D22BF2
              00280000 801242E1 816188A0 559D30FF 5C14E589 D8D9080D
              54344A41 E160F95D 000003F8 00000101 00000380 7AC7
  B8000400 03FB0000 01000000 4E000000 001145A2 5F12670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 69.162.95.18
    udp src 13458, dst 18434 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911E5BB 670E5033 45A25F12 34924802
              00280000 801239E2 3DE30510 1579701B 35D3C4CD 136EFC20
              91C43DF2 C81BF9B3 000003F8 00000101 00000380 7AC7
  C8000400 03FB0000 01000000 4E000000 00115519 B0F7670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 85.25.176.247
    udp src 6528, dst 7218 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 B0F00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911845F 670E5033 5519B0F7 19801C32
              00280000 801265E1 816188A0 2B884EEA 705F7BC8 7FD817EA
              301014BB 78D653AA 000003F8 00000101 00000380 7AC8
interface Gi5/2, routine naboo_fastsend, timestamp 04:40:22.269
layer 3 data: 4500003C 00004000 3911F60A 670E5033 43D45091 A30C92AE
              00280000 80120247 615D9EF0 66EF038D 781680A0 00FAC200
              07D67873 40A000FA 000003F8 00000101 00000380 7AC8
interface Gi5/1, routine process_rx_packet_inline, timestamp 04:40:22.269
  A8000400 03FB0000 01000000 4E000000 0011321E 2329670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 50.30.35.41
    udp src 35372, dst 6170 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 20200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39113529 670E5033 321E2329 8A2C181A
              00280000 80122047 615D9EF0 27154277 21931137 FC63EB7D
              D6C833DD 2F544393 000003F8 00000101 00000380 7AC6
  B0000400 03FB0000 01000000 4E000000 00114298 A8E4670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.168.228
    udp src 63438, dst 8406 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 A0E00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119EF3 670E5033 4298A8E4 F7CE20D6
              00280000 80124699 615D9EF0 2B774E15 D629A2E6 AAE0A810
              DC9651FB 4284771E 000003F8 00000101 00000380 7AC5
  C0000400 03FB0000 01000000 4E000000 0011482C 436B670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 72.44.67.107
    udp src 46554, dst 8878 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911FED8 670E5033 482C436B B5DA22AE
              00280000 801259C2 615D9EF0 22FC479E 42E36513 AD4A98BA
              121A407B F4D8FCA2 000003F8 00000101 00000380 7AC7
  E0000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
    udp src 64848, dst 45846 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D FD50B316
              00280000 801293C3 615D9EF0 26C043A2 E070573C 845BCB30
              DB54A85A 7CEC6B93 000003F8 00000101 00000380 7AC6
  E8000400 03FB0000 01000000 4E000000 0011D12C 7F24670E 50330000 7F0A2000
    udp src 59948, dst 9182 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A1F 670E5033 D12C7F24 EA2C23DE
              00280000 801297A2 615D9EF0 46D923BB 30402051 1F88CFB8
              11D2F832 93D0B512 000003F8 00000101 00000380 7AC7
  F0000400 03FB0000 01000000 4E000000 00116CA6 C7EA670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.199.234
    udp src 50978, dst 6390 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 80E00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391155DF 670E5033 6CA6C7EA C72218F6
              00280000 80120D5F 615D9EF0 7EFF1B9D 4C058B58 B0B8355C
              11FFBF1E 4B96E053 000003F8 00000101 00000380 7AC6
  F8000400 03FB0000 01000000 4E000000 0011D12C 7F24670E 50330000 7F0A2000
    udp src 28786, dst 10214 len 40 checksum 0x0
RTLSGR1#
Pulikkal Sekhar... Sun, 09/30/2012 - 23:01
  • Cisco Employee,
The netdr can capture 4096 packets. your capture has only 63 packets. analysis of 4096 packets can give more detailed analysis
I have looked at the 63 packets uploaded. and most of traffic is coming from 103.14.80.51.
1. Can you check this is expected traffic.
it was sending udp traffic of 60 bytes to destinations
70.87.221.51 3,  209.44.127.36 3,  67.228.3.77 2,  213.229.83.155 1,  174.136.40.105 1 ,  67.212.80.25    69.162.95.18      78.129.178.46    50.30.35.41        108.166.199.234.
Chcek if we have routes to the following
1. Send me the followign outputs too
show ip route 70.87.221.51 3
show ip route 209.44.127.36
show mls rate
show mls rate usage
sabuz_banik Mon, 10/01/2012 - 00:06
I am giving you 4096 packet with content of your asked show command.
103.14.80.51 is the expected server where pubpic ip should hit. Rest real ip are customer (Carrier of voice traffic) who and all are passing there voice traffic through 103.14.80.51. 103.14.80.51 then send the requested traffic to other private block ip's.Customer is an IGW.
interface Gi5/2, routine naboo_fastsend, timestamp 06:30:06.856
layer 3 data: 4500003C 00004000 39111791 670E5033 44472E98 EE5C1A6E
              00280000 80125B82 64813790 45FE209C 781A6F89 E95A5B72
              891A5229 6B794A9B 000003F8 00000101 00000380 7AC6
interface Gi5/1, routine process_rx_packet_inline, timestamp 06:30:06.856
    udp src 22698, dst 58740 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 58AAE574
              00280000 80123DA5 64813790 6A0B0F69 4597C5F0 8DAAB115
              E64929D0 4629641D 000003F8 00000101 00000380 7AC8
  68000400 03FB0000 01000000 4E000000 0011D040 E513670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 208.64.229.19
    udp src 34638, dst 6526 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 A0100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911D51B 670E5033 D040E513 874E197E
              00280000 80126C76 64813790 7D471825 47C489EE 7262BE3D
              C116BDBB FF216DF2 000003F8 00000101 00000380 7AC7
  80000400 03FB0000 01000000 4E000000 0011CFB6 884A670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 207.182.136.74
    udp src 53670, dst 6154 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 80400000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911326F 670E5033 CFB6884A D1A6180A
              00280000 8012E0E8 64813790 37C052A2 7212D984 0FBA469D
              65D1421A FC2E2AB2 000003F8 00000101 00000380 7AC5
  88000400 03FB0000 01000000 4E000000 00114447 2E98670E 50330000 7F0A2000
    udp src 16546, dst 8274 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111791 670E5033 44472E98 40A22052
              00280000 80122603 64813790 0BBF6EDD 0D626A0F F7A24839
              FE1A054D A513B19A 000003F8 00000101 00000380 7AC7
  90000400 03FB0000 01000000 4E000000 001145A2 481A670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 69.162.72.26
    udp src 21916, dst 6338 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 00100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911FCB3 670E5033 45A2481A 559C18C2
              00280000 80122FC7 64813790 7B8F1EED 91B487C0 B85F2F15
              591A267C 471A6363 000003F8 00000101 00000380 7AC7
  98000400 03FB0000 01000000 4E000000 0011C694 7EAA670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.148.126.170
    udp src 65216, dst 6282 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 30A00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39114531 670E5033 C6947EAA FEC0188A
              00280000 801200BF 64813790 34665104 78FB40A0 00FAC200
              07D6782E 80A000FA 000003F8 00000101 00000380 7AC8
  C8000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
    udp src 55506, dst 17258 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D D8D2436A
              00280000 80129CB2 4106CCE0 028867EA 708B6B20 A6BB7E3C
              BC9AF894 F2879D0E 000003F8 00000101 00000380 7AC7
  D0000400 03FB0000 01000000 4E000000 001143D4 5A3D670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.212.90.61
    udp src 15402, dst 7746 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 10300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911EC5E 670E5033 43D45A3D 3C2A1E42
              00280000 80121670 4106CCE0 12A777C5 8DBAC755 D0834B96
              969F26D8 45B22CAB 000003F8 00000101 00000380 7AC6
  E0000400 03FB0000 01000000 4E000000 0011C694 646A670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.148.100.106
    udp src 12754, dst 6830 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 20600000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39115F71 670E5033 C694646A 31D21AAE
              00280000 80123173 4106CCE0 686A0D08 B07B1F54 6BBB1481
              FEC730AD 630E3563 000003F8 00000101 00000380 7AC5
  E8000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.34.176.54
    udp src 23474, dst 21026 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 B0300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 5BB25222
              00280000 80122610 4106CCE0 06E9638B 5000BCA4 A713C240
              C8120242 43A3C2C2 000003F8 00000101 00000380 7AC8
  F0000400 03FB0000 01000000 4E000000 0011CDCC 4772670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 205.204.71.114
    udp src 60230, dst 6854 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 00700000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39117531 670E5033 CDCC4772 EB461AC6
              00280000 80123466 4106CCE0 34145176 657ECD52 70DF7175
              FC4F2792 CD959F99 000003F8 00000101 00000380 7AC6
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x8A(138)
  F8000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 120, identifier 0
    udp src 7216, dst 56030 len 100 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x8A(138)
  00020000 03F82800 03800000 8A000000 00110000 20600000 50330000 7F0A2000
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 1C30DADE
              00640000 80082D27 4106CD80 1BDC7EBE 545654D1 D15454D5
              D6D65650 D4D0D756 000003F8 00000101 00000380 7AC5
  08000400 03FB0000 01000000 4E000000 001145A2 481A670E 50330000 7F0A2000
    udp src 53094, dst 6470 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911FCB3 670E5033 45A2481A CF661946
              00280000 801227DA 4106CD30 50C435A6 58F06958 093BF1E4
              F552306A D9885533 000003F8 00000101 00000380 7AC5
  10000400 03FB0000 01000000 4E000000 0011AE8E 2764670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 174.142.39.100
    udp src 30820, dst 7258 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B47D 670E5033 AE8E2764 78641C5A
              00280000 8012312D 4106CCE0 60BC05DE 787E9725 88FA5590
              9194E420 6A0421EE 000003F8 00000101 00000380 7AC9
  20000400 03FB0000 01000000 4E000000 00116CA6 DAD2670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.218.210
    udp src 47142, dst 6882 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 90D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391142F7 670E5033 6CA6DAD2 B8261AE2
              00280000 80122C00 4106CCE0 402F254D 3063FFFD 94D8154F
              05527CD7 7E8CF53A 000003F8 00000101 00000380 7AC8
  28000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
    udp src 19790, dst 33598 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 4D4E833E
              00280000 8012B93F 4106CCE0 19FD7C9F F8FB9317 7E12D807
              5252406D D30A8733 000003F8 00000101 00000380 7AC7
  38000400 03FB0000 01000000 4E000000 0011266C 5C4B670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 38.108.92.75
    udp src 35416, dst 8272 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 10400000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391107B9 670E5033 266C5C4B 8A582050
              00280000 801203F9 4106CD30 3CD659B4 0D624C39 CA59730C
              D4F168DB 4C70179A 000003F8 00000101 00000380 7AC6
    udp src 61266, dst 9542 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 EF522546
              00280000 80120CC3 84855070 08A66DC4 2005DFD4 79428C05
              8E9472CD EF8CA893 000003F8 00000101 00000380 7AC9
  48000400 03FB0000 01000000 4E000000 0011C694 72B2670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.148.114.178
    udp src 17996, dst 7082 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 30B00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39115129 670E5033 C69472B2 464C1BAA
              00280000 8012AE82 4106CCE0 6DE9088B 79A3CC77 0A88D120
              8896F286 B5E3103B 000003F8 00000101 00000380 7AC7
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x52(82)
  50000400 03FB0000 01000000 52000000 00116CA6 DAE8670E 50330000 7F0A2000
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 64, identifier 0
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.218.232
    udp src 59374, dst 9286 len 44 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x52(82)
  00020000 03F82800 03800000 52000000 00110000 90E00000 50330000 7F0A2000
layer 3 data: 45000040 00004000 391142DD 670E5033 6CA6DAE8 E7EE2446
              002C0000 80040083 84855160 27A342C1 F04E6A0B 0AA4A889
              02000000 B2807519 000003F8 00000101 00000380 7AC9
  60000400 03FB0000 01000000 4E000000 0011ADF4 A4D2670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 173.244.164.210
    udp src 36176, dst 7562 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 A0D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391137A9 670E5033 ADF4A4D2 8D501D8A
              00280000 80125C5A 84855070 2A9C4FFE E2A98702 2A277012
              060863E9 478BF0AD 000003F8 00000101 00000380 7AC9
  78000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
    udp src 29738, dst 13594 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 742A351A
              00280000 8012563D 84855070 49E32C81 69DC9946 51AEF2AE
              CEF3613B C5F29CA5 000003F8 00000101 00000380 7AC7
  80000400 03FB0000 01000000 4E000000 0011482C 4D9B670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 72.44.77.155
    udp src 43654, dst 10782 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 00900000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911F4A8 670E5033 482C4D9B AA862A1E
              00280000 801223F7 84855070 0D18687A 7241F4C9 873A5E7B
              A1927801 CE1D0EDA 000003F8 00000101 00000380 7AC6
  88000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
    udp src 32652, dst 44338 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 7F8CAD32
              00640000 8008869B 84855110 0F3F6A5D 55555555 55555555
              55545455 55D5D5D5 000003F8 00000101 00000380 7AC7
  98000400 03FB0000 01000000 4E000000 0011AE88 2869670E 50330000 7F0A2000
    udp src 35906, dst 63366 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B37E 670E5033 AE882869 8C42F786
              00280000 80121BBE 84855070 27C642A4 753888C4 EA48D049
              44C64262 F8D5FA5A 000003F8 00000101 00000380 7AC8
  A8000400 03FB0000 01000000 4E000000 0011D1BE 1DD2670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.190.29.210
    udp src 16394, dst 11990 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 10D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119ADF 670E5033 D1BE1DD2 400A2ED6
              00280000 8012A40D 84855070 67CB02A9 72454EDC 17094C50
              D6D2DC30 12BD9C68 000003F8 00000101 00000380 7AC7
  B0000400 03FB0000 01000000 4E000000 0011642A 4B83670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 100.42.75.131
    udp src 51642, dst 6398 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 00800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911DAC2 670E5033 642A4B83 C9BA18FE
              00280000 80122582 84855070 37CA52A8 D16280B3 A77F4116
              9292769B 0E01196B 000003F8 00000101 00000380 7AC7
  B8000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
    udp src 11400, dst 56796 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 2C88DDDC
              00640000 800801D1 84855110 56AF33CD 55555555 55555555
              55555555 55555555 000003F8 00000101 00000380 7AC7
  C8000400 03FB0000 01000000 4E000000 00113E4B FE2B670E 50330000 7F0A2000
    udp src 48974, dst 10810 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B BF4E2A3A
              00280000 80120A48 84855070 505A3538 1FD3C5BB B5C30FB4
              C4C2F6EB C668FB5F 000003F8 00000101 00000380 7AC8
  D0000400 03FB0000 01000000 4E000000 0011AE7B 5702670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 174.123.87.2
    udp src 61260, dst 9030 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 10000000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391184F2 670E5033 AE7B5702 EF4C2346
              00280000 80122EBA 84855070 7B8A1EE8 7506FB4B E4B8D00B
              ECD278EB 1A164D9B 000003F8 00000101 00000380 7AC8
  E0000400 03FB0000 01000000 4E000000 00113261 278B670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 50.97.39.139
    udp src 53440, dst 11762 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 20800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39113084 670E5033 3261278B D0C02DF2
              00280000 801228CA 84855070 5C9739F5 09E086F2 AE530C3B
              C7D37EF3 C6365DE8 000003F8 00000101 00000380 7AC6
  E8000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
    udp src 31530, dst 31404 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 7B2A7AAC
              00280000 8012BA15 84855070 5B1A3E78 146FD012 B1AE143F
              BE745482 EA4E3C98 000003F8 00000101 00000380 7AC5
  08000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
    udp src 51984, dst 32226 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 CB107DE2
              00280000 80120829 648166C0 1B7F7E1D 54BAFE90 FC465049
              796E54D6 BDCB3FB8 000003F8 00000101 00000380 7AC6
  10000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
    udp src 63256, dst 50670 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 F718C5EE
              00640000 800873EA 64816710 06C963AB D5D55455 D5D5D4D4
              D55555D5 D5D45456 000003F8 00000101 00000380 7AC6
  20000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
    udp src 6884, dst 40138 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 1AE49CCA
              00280000 8012BE58 648166C0 25A040C2 F8E8E7FC 321A421D
              B2585943 B4879F43 000003F8 00000101 00000380 7AC6
  30000400 03FB0000 01000000 4E000000 0011D1BE 265A670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.190.38.90
    udp src 32100, dst 36414 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 20500000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119257 670E5033 D1BE265A 7D648E3E
              00280000 8012A4FA 648166C0 64700112 493A8679 98EB52CA
              451F26C2 C709EB62 000003F8 00000101 00000380 7AC8
  40000400 03FB0000 01000000 4E000000 0011D12C 7F24670E 50330000 7F0A2000
    udp src 61092, dst 6802 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A1F 670E5033 D12C7F24 EEA41A92
              00280000 80127C22 648166C0 5DB338D1 6030FA2C D49A0E95
              5F16F8BF 41D4F68F 000003F8 00000101 00000380 7AC8
  50000400 03FB0000 01000000 4E000000 00113E4B FE2B670E 50330000 7F0A2000
    udp src 46388, dst 9978 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B B53426FA
              00280000 8012206B 648166C0 7FC81AAA 78AF55D2 8F1A8AD4
              F0DB3052 E00C9ABA 000003F8 00000101 00000380 7AC6
  58000400 03FB0000 01000000 4E000000 0011D1A0 219D670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.160.33.157
    udp src 22476, dst 15474 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119732 670E5033 D1A0219D 57CC3C72
              00280000 80128EAE 64816670 1C5B7939 B97446B3 84B20D53
              830EFD07 4700A9AA 000003F8 00000101 00000380 7AC5
  68000400 03FB0000 01000000 4E000000 0011D1BE 265A670E 50330000 7F0A2000
    udp src 9582, dst 38014 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119257 670E5033 D1BE265A 256E947E
              00280000 801212E2 648166C0 31EC548E 16C0CD0A 56CC3041
              6E359AC1 8D0B7797 000003F8 00000101 00000380 7AC8
  70000400 03FB0000 01000000 4E000000 00113261 74E3670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 50.97.116.227
    udp src 5668, dst 9582 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 30E00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911E32B 670E5033 326174E3 1624256E
              00280000 801211EC 648166C0 56FD339F 60B3E230 6733492A
              B1DF59F8 DC1A0E13 000003F8 00000101 00000380 7AC7
  78000400 03FB0000 01000000 4E000000 00114E81 8E07670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 78.129.142.7
    udp src 19360, dst 6290 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 80000000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911ADE7 670E5033 4E818E07 4BA01892
              00280000 8012B779 648166C0 51AC34CE 78A77280 4263D013
              57907960 FFFEC6EF 000003F8 00000101 00000380 7AC9
  80000400 03FB0000 01000000 4E000000 00114447 39F6670E 50330000 7F0A2000
    udp src 55190, dst 11274 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39110C33 670E5033 444739F6 D7962C0A
              00280000 8012045F 648166C0 764F132D 71E0927C F15B175F
              A474147F F2D914C3 000003F8 00000101 00000380 7AC5
  88000400 03FB0000 01000000 4E000000 0011CDCC 504F670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 205.204.80.79
    udp src 36316, dst 7302 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116C54 670E5033 CDCC504F 8DDC1C86
              00280000 80128A97 648166C0 34AE51CC 64A3CD0C 6762529B
              4E117093 9546047B 000003F8 00000101 00000380 7AC7
  90000400 03FB0000 01000000 4E000000 0011321E 2329670E 50330000 7F0A2000
    udp src 26260, dst 6362 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113529 670E5033 321E2329 669418DA
              00280000 80122755 648166C0 679302F1 CAEF8BC6 9C99EEA4
              A63D4AAD 0B0B09A7 000003F8 00000101 00000380 7AC8
  98000400 03FB0000 01000000 4E000000 0011ADC0 2123670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 173.192.33.35
    udp src 49328, dst 10546 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911BB8C 670E5033 ADC02123 C0B02932
              00280000 801207B1 648166C0 5FEB3A89 38F2714F 033E4D6D
              59DF7D54 456324CE 000003F8 00000101 00000380 7AC8
  A8000400 03FB0000 01000000 4E000000 00116CA6 C7EA670E 50330000 7F0A2000
    udp src 40708, dst 9018 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391155DF 670E5033 6CA6C7EA 9F04233A
              00280000 80127101 648166C0 4D69280B E0736013 91C3D02A
              8B5A7203 4C365F13 000003F8 00000101 00000380 7AC8
  B0000400 03FB0000 01000000 4E000000 0011D1A0 183F670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.160.24.63
    udp src 62546, dst 21662 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911A090 670E5033 D1A0183F F452549E
              00280000 801240FF 648166C0 3268570A F240D2F5 3E42D31E
              14D2B0CE 4F3E74C2 000003F8 00000101 00000380 7AC8
  B8000400 03FB0000 01000000 4E000000 00114005 20D7670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.5.32.215
    udp src 18608, dst 15618 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 20D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39112994 670E5033 400520D7 48B03D02
              00280000 801269A9 648166C0 2D3C485E 024818AC 605241CD
              19977927 5DEECDD2 000003F8 00000101 00000380 7AC7
  C0000400 03FB0000 01000000 4E000000 00116CA6 DBE4670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.219.228
    udp src 26930, dst 7218 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 90E00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391141E5 670E5033 6CA6DBE4 69321C32
              00280000 8012B4E4 648166C0 73FD169F C0E78622 78FA4F82
              CDD4F820 F1D4D972 000003F8 00000101 00000380 7AC7
  D0000400 03FB0000 01000000 4E000000 001143D4 5019670E 50330000 7F0A2000
    udp src 49926, dst 9186 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911F682 670E5033 43D45019 C30623E2
              00280000 80121715 648166C0 2ECC4BAE 67A65A8A 5E3DF3BF
              C16A677A DB666670 000003F8 00000101 00000380 7AC7
  E8000400 03FB0000 01000000 4E000000 001143D5 4E64670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.213.78.100
    udp src 50640, dst 6570 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911F836 670E5033 43D54E64 C5D019AA
              00280000 8012044B 648166C0 147B7119 79E46002 7BF350EC
              14907232 E600CABB 000003F8 00000101 00000380 7AC7
  F0000400 03FB0000 01000000 4E000000 00113E4B FE2B670E 50330000 7F0A2000
    udp src 41316, dst 10850 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B A1642A62
              00280000 80120347 1AE911E0 297F4C1D 78AEC0A0 00FAC200
              07D67878 00A000FA 000003F8 00000101 00000380 7AC5
  F8000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
    udp src 13070, dst 9554 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 330E2552
              00280000 80120AD6 648166C0 776D120F 12740C3B 8E4E736A
              DB3F1AFF 8CF4905D 000003F8 00000101 00000380 7AC5
  10000400 03FB0000 01000000 4E000000 0011CDCC 518F670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 205.204.81.143
    udp src 32968, dst 11110 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 10800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39116B14 670E5033 CDCC518F 80C82B66
              00280000 801217FB 1AE911E0 02EF678D 7CDE67A6 DD5B0E98
              BCD85858 75F30353 000003F8 00000101 00000380 7AC8
  20000400 03FB0000 01000000 4E000000 0011482C 4D9B670E 50330000 7F0A2000
    udp src 33966, dst 9194 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911F4A8 670E5033 482C4D9B 84AE23EA
              00280000 8012E96E 648166C0 568A33E8 F80FF208 2E3A0D89
              E39238BE DC8C3E6A 000003F8 00000101 00000380 7AC9
  38000400 03FB0000 01000000 8A000000 0011C7BD 5491670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 199.189.84.145
    udp src 6448, dst 10442 len 100 checksum 0x0
  00020000 03F82800 03800000 8A000000 00110000 10900000 50330000 7F0A2000
layer 3 data: 45000078 00004000 39116DE5 670E5033 C7BD5491 193028CA
              00640000 80008182 64816710 26224340 706D6970 767076F4
              EF7678ED EFF6ECEC 000003F8 00000101 00000380 7AC7
  40000400 03FB0000 01000000 4E000000 00114447 2E98670E 50330000 7F0A2000
    udp src 21568, dst 8862 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111791 670E5033 44472E98 5440229E
              00280000 80120F4A 1AE911E0 463E235C 7087E4AD B9E20600
              FC91F85B 3E836922 000003F8 00000101 00000380 7AC6
  58000400 03FB0000 01000000 4E000000 0011AE24 7CD3670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 174.36.124.211
    udp src 6446, dst 6222 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 30D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39115F78 670E5033 AE247CD3 192E184E
              00280000 80121C41 1AE911E0 5AE23F80 4CFB7F3A 714B14D7
              2A5C72DB 60D629F3 000003F8 00000101 00000380 7AC7
  60000400 03FB0000 01000000 4E000000 00116CA6 C7EA670E 50330000 7F0A2000
    udp src 37920, dst 8434 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391155DF 670E5033 6CA6C7EA 942020F2
              00280000 8012B64C 648166C0 27064264 49D297F1 3833EC56
              AA9F0DAF D8367CA3 000003F8 00000101 00000380 7AC6
  70000400 03FB0000 01000000 4E000000 0011BC8A 1056670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 188.138.16.86
    udp src 60198, dst 9862 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 10500000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911BD8F 670E5033 BC8A1056 EB262686
              00280000 80128420 648166C0 258040E2 186055C7 1A999371
              B2BD48E9 13947099 000003F8 00000101 00000380 7AC7
  78000400 03FB0000 01000000 4E000000 0011D1BE 265A670E 50330000 7F0A2000
    udp src 50094, dst 21710 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119257 670E5033 D1BE265A C3AE54CE
              00280000 8012E0C3 1AE911E0 1F1F7A7D 78029DF0 6A9B09EB
              091A68A8 74DC20B2 000003F8 00000101 00000380 7AC6
  88000400 03FB0000 01000000 4E000000 00113E4B FE2B670E 50330000 7F0A2000
    udp src 54066, dst 9338 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B D332247A
              00280000 80122F98 648166C0 26DA43B8 64B33ABD D71A5568
              C3D43091 5312D6B2 000003F8 00000101 00000380 7AC6
  90000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
    udp src 15596, dst 28046 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 3CEC6D8E
              00280000 801292DA 1AE911E0 0AE16F83 73F38E0C 775D337E
              ADEB5FD8 0E41805E 000003F8 00000101 00000380 7AC7
  98000400 03FB0000 01000000 4E000000 00114298 BC42670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.188.66
    udp src 22410, dst 6046 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 B0400000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39118B95 670E5033 4298BC42 578A179E
              00280000 801240FA 1AE911E0 368553E7 F67D83E2 84C56E05
              1DA834D5 C3A64246 000003F8 00000101 00000380 7AC8
  A0000400 03FB0000 01000000 4E000000 001145A2 481A670E 50330000 7F0A2000
    udp src 56702, dst 6522 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911FCB3 670E5033 45A2481A DD7E197A
              00280000 8012253E 648166C0 66D603B4 23C986A8 0FC7CEB2
              6A8A26B2 85E4023F 000003F8 00000101 00000380 7AC7
  F8000400 03FB0000 01000000 4E000000 0011ADF6 27C4670E 50330000 7F0A2000
    udp src 33140, dst 3430 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B4B5 670E5033 ADF627C4 81740D66
              00280000 80122C28 1AE911E0 09476C25 7C80991C 145A52FE
              B4D852D5 1B37CF38 000003F8 00000101 00000380 7AC8
  08000400 03FB0000 01000000 4E000000 001145A2 5F12670E 50330000 7F0A2000
    udp src 63712, dst 6166 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911E5BB 670E5033 45A25F12 F8E01816
              00280000 80120DE7 648166C0 640B0169 DEB64321 84C32BE7
              CF754496 03B91CA1 000003F8 00000101 00000380 7AC8
  10000400 03FB0000 01000000 4E000000 00115C30 7F8B670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 92.48.127.139
    udp src 60552, dst 11258 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 30800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911AEB4 670E5033 5C307F8B EC882BFA
              00280000 80122D31 1AE911E0 0B176E75 B0E6F665 819B0F49
              E0967802 732C4893 000003F8 00000101 00000380 7AC6
    udp src 55090, dst 52282 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 D732CC3A
              00280000 80120F7C 1AE911E0 7F6B1A09 14F3448D D2DFDEAD
              921CD43B 007EB952 000003F8 00000101 00000380 7AC7
  48000400 03FB0000 01000000 4E000000 00115519 4945670E 50330000 7F0A2000
    udp src 33376, dst 7418 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911EC11 670E5033 55194945 82601CFA
              00280000 801215AD 648166C0 10BB75D9 B62324E4 823DEF09
              64863672 3E404EC8 000003F8 00000101 00000380 7AC9
  50000400 03FB0000 01000000 4E000000 00114005 3984670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.5.57.132
    udp src 20790, dst 28678 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391110E7 670E5033 40053984 51367006
              00280000 8012CCCC 1AE911E0 266B4309 78F7A1F0 47A3D002
              379E1523 5C8AC0A2 000003F8 00000101 00000380 7AC9
  58000400 03FB0000 01000000 4E000000 0011B2FF 2C83670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 178.255.44.131
    udp src 58644, dst 6030 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911AAED 670E5033 B2FF2C83 E514178E
              00280000 80122529 648166C0 27A442C6 74C27ABA 6F86D321
              9D4878B7 664316A6 000003F8 00000101 00000380 7AC6
  70000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
    udp src 43200, dst 37826 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 A8C093C2
              00280000 80128236 648166C0 13D876BA 69E0CBCF 786F1247
              B97B2F52 4CF3FC90 000003F8 00000101 00000380 7AC8
  78000400 03FB0000 01000000 4E000000 00114005 312C670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.5.49.44
    udp src 11582, dst 24520 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911193F 670E5033 4005312C 2D3E5FC8
              00280000 80120F54 1AE911E0 32E05782 F327D6C9 1F83154F
              2BCAF50B 0A248910 000003F8 00000101 00000380 7AC8
  88000400 03FB0000 01000000 DA000000 0011AE88 2869670E 50330000 7F0A2000
    udp src 22178, dst 36914 len 180 checksum 0x0
layer 3 data: 450000C8 00004000 3911B2F2 670E5033 AE882869 56A29032
              00B40000 8008111B 648166C0 3FA55AC7 D5D5D554 D5D5D5D4
              D55454D5 D5D4D555 000003F8 00000101 00000380 7AC8
  A0000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
    udp src 9540, dst 18962 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 25444A12
              00280000 80120DE1 1AE911E0 6C440926 4573D057 9C68715C
              723B2F22 50132677 000003F8 00000101 00000380 7AC5
  A8000400 03FB0000 01000000 52000000 00114837 85F0670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 72.55.133.240
    udp src 65340, dst 7602 len 44 checksum 0x0
  00020000 03F82800 03800000 52000000 00110000 80F00000 50330000 7F0A2000
layer 3 data: 45000040 00004000 3911BC44 670E5033 483785F0 FF3C1DB2
              002C0000 8004203E 648167B0 6569000B 505B5770 38E5409E
              51AA6E87 00CB2EA2 000003F8 00000101 00000380 7AC7
  B8000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
    udp src 50646, dst 14610 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 C5D63912
              00280000 801234F7 648166C0 4AE22F80 583AB32E 953A5B78
              3014D412 736CAAB2 000003F8 00000101 00000380 7AC7
  D0000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
    udp src 6552, dst 37986 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 19989462
              00280000 80126D20 648166C0 4AAD2FCF 14467335 C7AA5154
              C21472AB B1DE530E 000003F8 00000101 00000380 7AC9
  D8000400 03FB0000 01000000 4E000000 00115BDD 9885670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 91.221.152.133
    udp src 48434, dst 10074 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 90800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911960D 670E5033 5BDD9885 BD32275A
              00280000 801205AE 1AE911E0 0CFA6998 785240A0 00FAC200
              07D67812 80A000FA 000003F8 00000101 00000380 7AC8
    udp src 16838, dst 44246 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 41C6ACD6
              00280000 801208A1 648166C0 67A202C0 753B5C06 04EA594E
              2252606F 4E8B3572 000003F8 00000101 00000380 7AC7
    udp src 52654, dst 25490 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 CDAE6392
              00280000 80121495 1AE911E0 5F533A31 42F2D3C4 53334FA9
              835F78BA 76291962 000003F8 00000101 00000380 7AC6
  F0000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
    udp src 50788, dst 35674 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 C6648B5A
              00280000 8012025C 648166C0 62E70785 78A800A0 00FAC200
              07D67852 C0A000FA 000003F8 00000101 00000380 7AC7
  F8000400 03FB0000 01000000 4E000000 0011B8AA 8732670E 50330000 7F0A2000
    udp src 54196, dst 10942 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114A93 670E5033 B8AA8732 D3B42ABE
              00280000 801224DE 1AE911E0 564F332D 75AFF280 20E25728
              0EDBF828 1C4E6C22 000003F8 00000101 00000380 7AC6
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x6A(106)
  28000400 03FB0000 01000000 6A000000 001155C3 5BD2670E 50330000 7F0A2000
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 88, identifier 0
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 85.195.91.210
    udp src 47298, dst 11154 len 68 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x6A(106)
  00020000 03F82800 03800000 6A000000 00110000 10D00000 50330000 7F0A2000
layer 3 data: 45000058 00004000 3911D8BE 670E5033 55C35BD2 B8C22B92
              00440000 80046E00 64816620 4F1D2A7F 08649065 D4C49B63
              A2BC49CA 2C501E88 000003F8 00000101 00000380 7AC6
  30000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
    udp src 60162, dst 9562 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 EB02255A
              00280000 80120894 64813790 189A7DF8 050C4D97 A8B31127
              341E2D22 4E4BDFA3 000003F8 00000101 00000380 7AC9
  40000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
    udp src 18824, dst 27314 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 49886AB2
              00280000 80120830 64813790 589A3DF8 97428B14 813591E1
              0F68973A CC74BB75 000003F8 00000101 00000380 7AC8
  58000400 03FB0000 01000000 4E000000 0011C64A 670A670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.74.103.10
    udp src 37220, dst 6582 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 20000000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39115D1B 670E5033 C64A670A 916419B6
              00280000 801219BA 64813790 17447226 6CD2BECE 9D5F581C
              E6F02EBF 7FB9F88A 000003F8 00000101 00000380 7AC7
  68000400 03FB0000 01000000 4E000000 00114447 32F1670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.50.241
    udp src 16926, dst 11006 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111338 670E5033 444732F1 421E2AFE
              00280000 8012360C 64813790 6219077B 525DE473 D9FE1258
              39921459 79790550 000003F8 00000101 00000380 7AC8
  70000400 03FB0000 01000000 4E000000 001143D4 5019670E 50330000 7F0A2000
    udp src 46346, dst 9170 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911F682 670E5033 43D45019 B50A23D2
              00280000 8012178F 64813790 2E254B47 521072CD 77C28B8A
              811E60E7 58FEA573 000003F8 00000101 00000380 7AC6
  78000400 03FB0000 01000000 4E000000 0011D12C 7A03670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.44.122.3
    udp src 48284, dst 6450 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 30000000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39113F40 670E5033 D12C7A03 BC9C1932
              00280000 80128D55 64813790 127A7718 75FA3843 538E11C4
              E54064A0 3D9284C3 000003F8 00000101 00000380 7AC6
  80000400 03FB0000 01000000 DA000000 0011AE88 2869670E 50330000 7F0A2000
    udp src 8978, dst 54146 len 180 checksum 0x0
layer 3 data: 450000C8 00004000 3911B2F2 670E5033 AE882869 2312D382
              00B40000 80084854 64813790 5E423B20 D5D5D5D5 D5D5D5D5
              D5D5D5D5 D7D5D4D5 000003F8 00000101 00000380 7AC8
  88000400 03FB0000 01000000 4E000000 00116DEC 5620670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 109.236.86.32
    udp src 18966, dst 7610 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 10200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911C663 670E5033 6DEC5620 4A161DBA
              00280000 8012318E 64813790 34775115 BD7E74D9 2F9485DF
              298A3D22 9D25EE95 000003F8 00000101 00000380 7AC6
  90000400 03FB0000 01000000 4E000000 00114447 2AE8670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.42.232
    udp src 13072, dst 8174 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111B41 670E5033 44472AE8 33101FEE
              00280000 801235F8 64813790 7F691A0B 00E7A821 B8221B18
              E79EF298 0F3E8D38 000003F8 00000101 00000380 7AC6
    udp src 38022, dst 13898 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 9486364A
              00280000 80120ACE 64813790 6EA60BC4 6B734CB2 F8E93281
              F8886173 0CE59739 000003F8 00000101 00000380 7AC8
  A8000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
    udp src 41020, dst 9526 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 A03C2536
              00280000 80120E0C 64813790 6DD908BB 782B7288 3A0A54A7
              919A04E1 7BD85B32 000003F8 00000101 00000380 7AC6
  B0000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
    udp src 9420, dst 38592 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 24CC96C0
              00280000 801218B6 64813790 2B694E0B 780DD8A1 51420D52
              DE1B7068 3798EF5E 000003F8 00000101 00000380 7AC5
  10000400 03FB0000 01000000 4E000000 00114298 BB62670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.187.98
    udp src 60342, dst 11298 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 B0600000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39118C75 670E5033 4298BB62 EBB62C22
              00280000 80122B68 4106CD30 031C667E 0D3B5234 798BD1BE
              14BF1851 11A7C00E 000003F8 00000101 00000380 7AC5
  18000400 03FB0000 01000000 4E000000 0011AE88 2869670E 50330000 7F0A2000
    udp src 45338, dst 25968 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B37E 670E5033 AE882869 B11A6570
              00280000 8012B310 4106CD30 469523F7 30CFB7C4 C73A9215
              6E569A7C 0973AD66 000003F8 00000101 00000380 7AC6
  20000400 03FB0000 01000000 4E000000 00114298 BBD2670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.187.210
    udp src 51580, dst 6458 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 B0D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39118C05 670E5033 4298BBD2 C97C193A
              00280000 80128D6A 4106CD30 28E14D83 1422AE7D D1AB5B89
              1E52F8F8 FED4DC4B 000003F8 00000101 00000380 7AC7
  28000400 03FB0000 01000000 52000000 00114A3F DBA2670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 74.63.219.162
    udp src 8166, dst 6758 len 44 checksum 0x0
  00020000 03F82800 03800000 52000000 00110000 90A00000 50330000 7F0A2000
layer 3 data: 45000040 00004000 3911648A 670E5033 4A3FDBA2 1FE61A66
              002C0000 80044CCF 4106CE20 16F57397 008C5533 2B006BB1
              031D50F0 B0CF8241 000003F8 00000101 00000380 7AC8
  30000400 03FB0000 01000000 4E000000 0011C694 7EAA670E 50330000 7F0A2000
    udp src 10296, dst 6034 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114531 670E5033 C6947EAA 28381792
              00280000 80126ED4 4106CD30 575B3239 F68BE69B A37AB1C4
              4B7335A7 F49EC36A 000003F8 00000101 00000380 7AC5
  38000400 03FB0000 01000000 4E000000 00114298 BB62670E 50330000 7F0A2000
    udp src 29124, dst 11646 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C75 670E5033 4298BB62 71C42D7E
              00280000 801209A8 4106CD30 32A057C2 7A08F633 8E8281E7
              F09078E3 A2623BD3 000003F8 00000101 00000380 7AC8
  50000400 03FB0000 01000000 4E000000 0011D5E5 4ED2670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 213.229.78.210
    udp src 12098, dst 7186 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 00D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391165B8 670E5033 D5E54ED2 2F421C12
              00280000 80122F5F 4106CD30 554B3029 DFD94C6B 87E77195
              C90FC365 0CA072E1 000003F8 00000101 00000380 7AC8
  60000400 03FB0000 01000000 4E000000 00114298 BD82670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.189.130
    udp src 21324, dst 9166 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 B0800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39118A55 670E5033 4298BD82 534C23CE
              00280000 80127C99 4106CD30 5F423A20 72EAD015 6B1353DE
              431EF828 CCBA4C5A 000003F8 00000101 00000380 7AC5
  70000400 03FB0000 01000000 4E000000 0011BC8A 0B8F670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 188.138.11.143
    udp src 64062, dst 10850 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911C256 670E5033 BC8A0B8F FA3E2A62
              00280000 80128454 4106CD30 6D360854 30637D01 D11A926C
              4C927257 E0C0A25A 000003F8 00000101 00000380 7AC8
  80000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
    udp src 10794, dst 52050 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 2A2ACB52
              00280000 8012075F 84855070 3E145B76 4583526A 3408B258
              37952AF7 92A49827 000003F8 00000101 00000380 7AC7
    udp src 32914, dst 50154 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 8092C3EA
              00280000 80123978 4106CD30 6B810EE3 6D4B9F0F D35EF015
              75712BF3 5F06E08B 000003F8 00000101 00000380 7AC6
    udp src 7238, dst 49578 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 1C46C1AA
              00280000 80123149 84855070 76651307 78CA546A FD520F39
              DA927923 2F0CBB02 000003F8 00000101 00000380 7AC6
  98000400 03FB0000 01000000 4E000000 00114298 B722670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.183.34
    udp src 23546, dst 7462 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391190B5 670E5033 4298B722 5BFA1D26
              00280000 801234AF 84855070 20C545A7 6374D01E 6D6C30E1
              C08F62DE D011F3FF 000003F8 00000101 00000380 7AC8
  A0000400 03FB0000 01000000 4E000000 0011C694 646A670E 50330000 7F0A2000
    udp src 17460, dst 7342 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39115F71 670E5033 C694646A 44341CAE
              00280000 80128AB3 4106CD30 619D04FF 10E7DCCF 4568DB82
              A11E68F2 E3D035AA 000003F8 00000101 00000380 7AC8
  A8000400 03FB0000 01000000 4E000000 0011642A 4B85670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 100.42.75.133
    udp src 56380, dst 6154 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911DAC0 670E5033 642A4B85 DC3C180A
              00280000 80128148 4106CD30 319C54FE 53B44D12 DE2B95E8
              32DC403C 9E3418B9 000003F8 00000101 00000380 7AC6
  B8000400 03FB0000 01000000 4E000000 0011D1BE 265A670E 50330000 7F0A2000
    udp src 39326, dst 30246 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119257 670E5033 D1BE265A 999E7626
              00280000 8012F6D1 848550C0 073A6258 603283FF 073B0A6D
              5CD47C46 F2838542 000003F8 00000101 00000380 7AC5
  C0000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
    udp src 63136, dst 8110 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 F6A01FAE
              00280000 80123D69 4106CD30 1528704A 0533FE96 A0AB10EC
              CB580CBB 6F925362 000003F8 00000101 00000380 7AC7
    udp src 11986, dst 37944 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 2ED29438
              00280000 80120ECE 848550C0 30135571 D85B4A35 2C83C83E
              8CD87857 6761964A 000003F8 00000101 00000380 7AC7
  D8000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
    udp src 38762, dst 24112 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 976A5E30
              00280000 8012827F 4106CD30 679D02FF 084A4746 A671557E
              41372F26 4923EC6B 000003F8 00000101 00000380 7AC8
  E0000400 03FB0000 01000000 4E000000 001143D4 5019670E 50330000 7F0A2000
    udp src 26146, dst 9282 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911F682 670E5033 43D45019 66222442
              00280000 80121329 848550C0 07AC62CE 75750CF3 88A8C420
              8498740B CB5D26D9 000003F8 00000101 00000380 7AC6
  E8000400 03FB0000 01000000 4E000000 00116CA6 C3CC670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.195.204
    udp src 10428, dst 6318 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 80C00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391159FD 670E5033 6CA6C3CC 28BC18AE
              00280000 8012394B 4106CD30 6D2B0849 235B5E20 B5320E6C
              45CE05DB E162C7A9 000003F8 00000101 00000380 7AC7
  F0000400 03FB0000 01000000 4E000000 0011D12C 7A03670E 50330000 7F0A2000
    udp src 45634, dst 6790 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113F40 670E5033 D12C7A03 B2421A86
              00280000 8012810D 84855070 108575E7 F813D22D 173251BF
              D29E308F 55CAA8CA 000003F8 00000101 00000380 7AC6
  F8000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
    udp src 59226, dst 30898 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 E75A78B2
              00280000 8012264F 4106CD30 70511533 0EA90B10 B7DE2C87
              32E98A58 892F9E56 000003F8 00000101 00000380 7AC6
  18000400 03FB0000 01000000 52000000 0011CA5F 780D670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 202.95.120.13
    udp src 6578, dst 17964 len 44 checksum 0x0
  00020000 03F82800 03800000 52000000 00110000 30000000 50330000 7F0A2000
layer 3 data: 45000040 00004000 391147FF 670E5033 CA5F780D 19B2462C
              002C0000 8004498D 4106CDD0 6A960FF4 5CE66CB6 C00826E6
              2F796AB5 86CC85F0 000003F8 00000101 00000380 7AC6
  30000400 03FB0000 01000000 4E000000 00114298 A214670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.162.20
    udp src 44094, dst 6606 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911A5C3 670E5033 4298A214 AC3E19CE
              00280000 80120DD4 848550C0 25B040D2 655346FD C12B15D2
              679ED8F2 9E6F354B 000003F8 00000101 00000380 7AC6
  40000400 03FB0000 01000000 DA000000 0011AE88 2869670E 50330000 7F0A2000
    udp src 46254, dst 50782 len 180 checksum 0x0
layer 3 data: 450000C8 00004000 3911B2F2 670E5033 AE882869 B4AEC65E
              00B40000 80086284 848550C0 3CC859AA 54545754 5754D5D5
              D5D7D655 54555454 000003F8 00000101 00000380 7AC9
  50000400 03FB0000 01000000 4E000000 0011CDCC 43C9670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 205.204.67.201
    udp src 40818, dst 10790 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 00C00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391178DA 670E5033 CDCC43C9 9F722A26
              00280000 80123624 848550C0 5639335B 7505BCAF 3FBB1E35
              F052F838 24341842 000003F8 00000101 00000380 7AC6
  58000400 03FB0000 01000000 4E000000 00114298 BBD2670E 50330000 7F0A2000
    udp src 60926, dst 9226 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C05 670E5033 4298BBD2 EDFE240A
              00280000 8012026C 848550C0 541F317D 79CB7744 AF39D04E
              E2DE66C6 DBE20CA3 000003F8 00000101 00000380 7AC7
  60000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
    udp src 13564, dst 8686 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 34FC21EE
              00280000 8012C30A 848550C0 19E87C8A 74BAC786 729A9248
              8C58600B 7F25A182 000003F8 00000101 00000380 7AC6
  68000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
    udp src 35632, dst 55884 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 8B30DA4C
              00280000 80125A5F 848550C0 22EB4789 63EB09A2 8F68F002
              BDF3C311 8844113C 000003F8 00000101 00000380 7AC6
  88000400 03FB0000 01000000 4E000000 00113261 4E69670E 50330000 7F0A2000
    udp src 21836, dst 6922 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 554C1B0A
              00280000 8012D0E0 84855070 724C172E 75E2FB81 EE0A513F
              3452140A F57F45AA 000003F8 00000101 00000380 7AC7
  A0000400 03FB0000 01000000 4E000000 0011C64A 61E2670E 50330000 7F0A2000
    udp src 55240, dst 9506 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 D7C82522
              00280000 80121024 84855070 4E9D2BFF 706BAE3D 953EC50E
              6F1EF8F2 E50076D8 000003F8 00000101 00000380 7AC8
  08000400 03FB0000 01000000 4E000000 00114298 BBD2670E 50330000 7F0A2000
    udp src 48896, dst 7894 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C05 670E5033 4298BBD2 BF001ED6
              00280000 80126BA1 848550C0 2F974AF5 F88E9308 CE32127E
              CC107842 F80F999B 000003F8 00000101 00000380 7AC8
    udp src 65030, dst 11710 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C75 670E5033 4298BB62 FE062DBE
              00280000 8012024E 848550C0 013C645E F2E3415B 21420E93
              4313F88F A958AC52 000003F8 00000101 00000380 7AC5
  28000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
    udp src 59046, dst 55950 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 E6A6DA8E
              00640000 8008F7BB 64816710 5F333A51 55D45555 D555D4D4
              54D45555 5454D556 000003F8 00000101 00000380 7AC7
  38000400 03FB0000 01000000 4E000000 00114298 AC3A670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.172.58
    udp src 59750, dst 6078 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 A0300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119B9D 670E5033 4298AC3A E96617BE
              00280000 80123623 648166C0 630F066D F0029996 8A821334
              CC5375A8 73EACA13 000003F8 00000101 00000380 7AC8
  48000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
    udp src 20258, dst 38744 len 40 checksum 0x0
dbus info: src_vlan 0x3F8(1016), src_indx 0x380(896), len 0x4E(78)
  bpdu 0, index_dir 0, flood 0, dont_lrn 0, dest_indx 0x7F0A(32522)
destmac 00.0E.D6.1D.B8.CE, srcmac 00.21.A0.0B.1F.80, protocol 0800
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 4F229758
              00280000 8012023E 648166C0 7EC51BA7 4D308CE2 F86DD23F
              2F384DEA 4D4D3331 000003F8 00000101 00000380 7AC8
------- dump of incoming inband packet -------
dbus info: src_vlan 0x3FB(1019), src_indx 0x100(256), len 0x4E(78)
  50000400 03FB0000 01000000 4E000000 0011D12C 7F24670E 50330000 7F0A2000
destmac 00.21.A0.0B.1F.80, srcmac 64.16.8D.15.40.45, protocol 0800
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 60, identifier 0
    udp src 43168, dst 11110 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A1F 670E5033 D12C7F24 A8A02B66
              00280000 8012C8B3 648166C0 18AC7DCE B07A8627 514B102E
              271EE073 0849B45B 000003F8 00000101 00000380 7AC7
  58000400 03FB0000 01000000 4E000000 00114447 29FA670E 50330000 7F0A2000
    udp src 13620, dst 9226 len 40 checksum 0x0
------- dump of outgoing inband packet -------
layer 3 data: 4500003C 00004000 39111C2F 670E5033 444729FA 3534240A
              00280000 80126521 648166C0 348E51EC F5E8D69C 4792EECD
              38D8F853 E2BF189A 000003F8 00000101 00000380 7AC7
  60000400 03FB0000 01000000 4E000000 00113261 4E69670E 50330000 7F0A2000
    udp src 57620, dst 11730 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 E1142DD2
              00280000 80122237 648166C0 7018157A F85BEC12 02B25EE2
              8A5802E0 32DF1E5A 000003F8 00000101 00000380 7AC6
  70000400 03FB0000 01000000 4E000000 001143D4 5A3D670E 50330000 7F0A2000
    udp src 8262, dst 7666 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911EC5E 670E5033 43D45A3D 20461DF2
              00280000 80123AB0 648166C0 39F05C92 72F3B48C F383CED3
              AB9E587E 33E99F62 000003F8 00000101 00000380 7AC8
  78000400 03FB0000 01000000 6A000000 0011BC8A 30BD670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 188.138.48.189
    udp src 54550, dst 6970 len 68 checksum 0x0
  00020000 03F82800 03800000 6A000000 00110000 30B00000 50330000 7F0A2000
layer 3 data: 45000058 00004000 39119D0C 670E5033 BC8A30BD D5161B3A
              00440000 80044335 64816620 1B6D7E0F 448AC93A F5583984
              C1A86420 74024332 000003F8 00000101 00000380 7AC7
  B0000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
    udp src 65052, dst 14450 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 FE1C3872
              00280000 801237BD 648166C0 7E181B7A FC1A8ED8 47B9CD4A
              5318647B 3CB97D82 000003F8 00000101 00000380 7AC5
    udp src 63358, dst 28938 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 F77E710A
              00640000 80084A18 64816710 04406122 D5D555D4 D5D4D7D5
              D4D45451 51575555 000003F8 00000101 00000380 7AC6
    udp src 54110, dst 51136 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 D35EC7C0
              00280000 8012110C 648166C0 2B094E6B 089769D2 180BD4DB
              785E601B 8C728036 000003F8 00000101 00000380 7AC8
  C8000400 03FB0000 01000000 4E000000 001145A2 481A670E 50330000 7F0A2000
    udp src 21320, dst 6674 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911FCB3 670E5033 45A2481A 53481A12
              00280000 80121D91 648166C0 5B053E67 44B0E91C BF129604
              549040CB D3D19178 000003F8 00000101 00000380 7AC8
  D8000400 03FB0000 01000000 4E000000 00113261 4E69670E 50330000 7F0A2000
    udp src 18064, dst 11250 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 46902BF2
              00280000 80123506 648166C0 418424E6 5BF34A2D 815234CF
              8B180EF3 CAA9C7B2 000003F8 00000101 00000380 7AC9
  E8000400 03FB0000 01000000 4E000000 00114005 312C670E 50330000 7F0A2000
    udp src 63666, dst 17448 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 30200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911193F 670E5033 4005312C F8B24428
              00280000 80127C27 648166C0 78681D0A 787EBD5E E248C984
              895EF8E8 F70D9B9B 000003F8 00000101 00000380 7AC5
  F0000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 70.87.221.51
    udp src 8868, dst 59380 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 90300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 22A4E7F4
              00280000 80126580 1AE911E0 0D8568E7 14FB040C 44E2132C
              0252F963 9139D19B 000003F8 00000101 00000380 7AC5
  F8000400 03FB0000 01000000 4E000000 00114447 29FA670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.41.250
    udp src 30928, dst 11182 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 20F00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39111C2F 670E5033 444729FA 78D02BAE
              00280000 80121332 648166C0 4DA828CA 762284CB CCA28294
              B7583866 C52A77FA 000003F8 00000101 00000380 7AC6
  08000400 03FB0000 01000000 52000000 0011CA5F 780D670E 50330000 7F0A2000
    udp src 40276, dst 19434 len 44 checksum 0x0
layer 3 data: 45000040 00004000 391147FF 670E5033 CA5F780D 9D544BEA
              002C0000 8004019A 1AE91230 07DE62BC 9422A024 1C2C7E6A
              81A88A02 BAE6B727 000003F8 00000101 00000380 7AC7
  28000400 03FB0000 01000000 4E000000 00116CA6 C14B670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.193.75
    udp src 18646, dst 8466 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39115C7E 670E5033 6CA6C14B 48D62112
              00280000 80120045 1AE911E0 7BD91EBB 60FA682C A18B5409
              C7907512 AA0FAF72 000003F8 00000101 00000380 7AC9
  48000400 03FB0000 01000000 4E000000 00116CA6 D01D670E 50330000 7F0A2000
    udp src 50774, dst 8830 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39114DAC 670E5033 6CA6D01D C656227E
              00280000 80129546 648166C0 046E610C 2396C674 D0D3EFDC
              509169BE 46229763 000003F8 00000101 00000380 7AC9
  58000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
    udp src 64118, dst 60150 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 FA76EAF6
              00280000 80122A25 1AE911E0 3F215A43 7246F205 296A5D6A
              EE9A405D BA2A1202 000003F8 00000101 00000380 7AC7
  70000400 03FB0000 01000000 4E000000 00114298 A8BA670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 66.152.168.186
    udp src 53478, dst 11026 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 A0B00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119F1D 670E5033 4298A8BA D0E62B12
              00280000 80124B5B 64813790 65A000C2 58A9F886 9231EE6C
              C2977018 E5DF148A 000003F8 00000101 00000380 7AC9
  78000400 03FB0000 01000000 4E000000 0011D12C 7F2F670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 209.44.127.47
    udp src 12962, dst 6078 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A14 670E5033 D12C7F2F 32A217BE
              00280000 8012498A 64813790 18177D75 13AEC491 B4C1B010
              953B2C9D 8412C587 000003F8 00000101 00000380 7AC6
  90000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
    udp src 45652, dst 10258 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 B2542812
              00280000 80122829 64813790 0128644A 727BF0FE 5899CF4B
              64D214D3 B788DA58 000003F8 00000101 00000380 7AC7
  98000400 03FB0000 01000000 4E000000 0011AE7B 5702670E 50330000 7F0A2000
    udp src 63768, dst 8722 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391184F2 670E5033 AE7B5702 F9182212
              00280000 80123A30 64813790 14A271C0 6DAB4248 756BEA2E
              EE57A723 42468D38 000003F8 00000101 00000380 7AC7
  B8000400 03FB0000 01000000 8A000000 0011D1BE 265A670E 50330000 7F0A2000
    udp src 34266, dst 12278 len 100 checksum 0x0
  00020000 03F82800 03800000 8A000000 00110000 20500000 50330000 7F0A2000
layer 3 data: 45000078 00004000 3911921B 670E5033 D1BE265A 85DA2FF6
              00640000 800854A5 648137E0 5249372B B1BFB8BF B18D9561
              01343637 3703134F 000003F8 00000101 00000380 7AC7
  C0000400 03FB0000 01000000 4E000000 0011D1A0 219D670E 50330000 7F0A2000
    udp src 35918, dst 14350 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 20900000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119732 670E5033 D1A0219D 8C4E380E
              00280000 8012F4E8 64813790 31375455 615F5866 67D312C0
              E9CB11D8 1832B053 000003F8 00000101 00000380 7AC8
  E0000400 03FB0000 01000000 DA000000 0011AE88 2869670E 50330000 7F0A2000
    udp src 38388, dst 39762 len 180 checksum 0x0
layer 3 data: 450000C8 00004000 3911B2F2 670E5033 AE882869 95F49B52
              00B40000 80081271 64813790 3FFB5A99 F1E4E4F0 C0C6DF5F
              43465B58 5F52D7C9 000003F8 00000101 00000380 7AC7
  E8000400 03FB0000 01000000 52000000 00114022 B036670E 50330000 7F0A2000
    udp src 35530, dst 16458 len 44 checksum 0x0
  00020000 03F82800 03800000 52000000 00110000 B0300000 50330000 7F0A2000
layer 3 data: 45000040 00004000 39119A13 670E5033 4022B036 8ACA404A
              002C0000 80042A05 648137E0 6548002A B05F530B 496BCF4E
              700FAE26 4A428599 000003F8 00000101 00000380 7AC6
  F0000400 03FB0000 01000000 4E000000 00114447 29FA670E 50330000 7F0A2000
    udp src 26134, dst 10850 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111C2F 670E5033 444729FA 66162A62
              00280000 80122491 64813790 77661204 765AF24F BE225E8A
              A2C03E73 45A519CB 000003F8 00000101 00000380 7AC7
  08000400 03FB0000 01000000 4E000000 0011602B 5342670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 96.43.83.66
    udp src 50184, dst 6042 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911D702 670E5033 602B5342 C408179A
              00280000 80124520 64813790 7FB41AD6 29D38C37 B0573294
              89E3B360 8C27E3B1 000003F8 00000101 00000380 7AC6
  20000400 03FB0000 01000000 4E000000 0011AE88 2869670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 174.136.40.105
    udp src 12308, dst 24904 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B37E 670E5033 AE882869 30146148
              00280000 80121325 64813790 654A0028 E423D479 D7725018
              251EB5C7 7538C7E8 000003F8 00000101 00000380 7AC5
  30000400 03FB0000 01000000 4E000000 00114022 B036670E 50330000 7F0A2000
    udp src 21678, dst 17834 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 54AE45AA
              00280000 80129B15 64813790 3308566A 4272B9E6 D0B29788
              B152E0E0 7FE4ECBA 000003F8 00000101 00000380 7AC6
  40000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
    udp src 61868, dst 51956 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 F1ACCAF4
              00280000 80121D29 64813790 2FFE4A9C 78E7FCB4 039B07B4
              83525291 43F8AF6A 000003F8 00000101 00000380 7AC8
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 62.75.254.43
    udp src 54928, dst 9982 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 B0200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39114DF9 670E5033 3E4BFE2B D69026FE
              00280000 80122095 64813790 43FD269F 2EA36223 0F6E3300
              14D43094 A16BBBBB 000003F8 00000101 00000380 7AC8
  58000400 03FB0000 01000000 4E000000 0011D1BE 265A670E 50330000 7F0A2000
    udp src 44188, dst 32618 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119257 670E5033 D1BE265A AC9C7F6A
              00280000 8012FEBA 64813790 2C8E49EC 009B8840 FA925016
              9390F8BB 654CDCA2 000003F8 00000101 00000380 7AC7
  68000400 03FB0000 01000000 4E000000 00116CA6 C3CC670E 50330000 7F0A2000
    udp src 38842, dst 6326 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391159FD 670E5033 6CA6C3CC 97BA18B6
              00280000 80121CEE 64813790 0A616F03 0ADB0C6F 2833F002
              D2C1491A 8B481E50 000003F8 00000101 00000380 7AC5
  78000400 03FB0000 01000000 4E000000 00114298 BC42670E 50330000 7F0A2000
    udp src 45682, dst 8782 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118B95 670E5033 4298BC42 B272224E
              00280000 8012391C 64813790 2F364A54 72BDF328 C0088B04
              C94C14B0 F19BD066 000003F8 00000101 00000380 7AC6
  80000400 03FB0000 01000000 4E000000 0011D12C 7F2F670E 50330000 7F0A2000
    udp src 57310, dst 10338 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39113A14 670E5033 D12C7F2F DFDE2862
              00280000 8012A02E 64813790 3A955FF7 5AFBF92C 29334802
              19701C5F FAAECE22 000003F8 00000101 00000380 7AC8
  90000400 03FB0000 01000000 4E000000 0011C64A 62DA670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.74.98.218
    udp src 55394, dst 6274 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911614B 670E5033 C64A62DA D8621882
              00280000 8012289C 64813790 54A731C5 782757A0 B8D29481
              7F1078D3 B524AC02 000003F8 00000101 00000380 7AC8
    udp src 24990, dst 37306 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B37E 670E5033 AE882869 619E91BA
              00280000 80122770 64813790 59693C0B 787261A6 1CEB46BC
              F0D4513B 7DCCFF8B 000003F8 00000101 00000380 7AC6
  A8000400 03FB0000 01000000 4E000000 0011C64A 632A670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.74.99.42
    udp src 16086, dst 9962 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 20200000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391160FB 670E5033 C64A632A 3ED626EA
              00280000 80127914 64813790 7B801EE2 49BB51B0 1C682FA9
              D511615B D132CFAC 000003F8 00000101 00000380 7AC6
  C8000400 03FB0000 01000000 4E000000 001143D4 5019670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.212.80.25
    udp src 39056, dst 9634 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 10100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911F682 670E5033 43D45019 989025A2
              00280000 80120489 64813790 568E33EC 782B6B60 00FAC200
              07D678FE AB6000FA 000003F8 00000101 00000380 7AC8
  D0000400 03FB0000 01000000 4E000000 00114447 29FA670E 50330000 7F0A2000
    udp src 25696, dst 11582 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39111C2F 670E5033 444729FA 64602D3E
              00280000 8012031C 64813790 32E8578A 306A66C3 46534B01
              FE1E719A E76669D3 000003F8 00000101 00000380 7AC7
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 50.97.78.105
    udp src 34464, dst 9922 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 00600000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391109A6 670E5033 32614E69 86A026C2
              00280000 80124489 64813790 66560334 331009B4 2BC11008
              32BB555A 096A013C 000003F8 00000101 00000380 7AC5
  E0000400 03FB0000 01000000 4E000000 00116CA6 C0DC670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.192.220
    udp src 16590, dst 10698 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 80D00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39115CED 670E5033 6CA6C0DC 40CE29CA
              00280000 80124DC1 64813790 6BF30E91 D9BB47C9 B8620240
              F091407A AAC51108 000003F8 00000101 00000380 7AC9
  F0000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 67.228.3.77
    udp src 27426, dst 36642 len 40 checksum 0x0
interface Gi5/2, routine naboo_fastsend, timestamp 06:30:06.856
  00020000 03F82800 03800000 4E000000 00110000 00400000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 6B228F22
              00280000 80125556 64813790 31745416 783B99DA 2C08CC1D
              8BDA407B F80FFA3A 000003F8 00000101 00000380 7AC7
interface Gi5/1, routine process_rx_packet_inline, timestamp 06:30:06.856
  30000400 03FB0000 01000000 4E000000 0011CDCC 518F670E 50330000 7F0A2000
    udp src 51212, dst 11106 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116B14 670E5033 CDCC518F C80C2B62
              00280000 8012183A 4106CD30 2D014863 70A35FCE 4E58D167
              E6587847 FE9C641A 000003F8 00000101 00000380 7AC8
  40000400 03FB0000 01000000 4E000000 0011D040 E513670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 208.64.229.19
    udp src 54240, dst 8542 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 A0100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911D51B 670E5033 D040E513 D3E0215E
              00280000 80124CC3 4106CD30 18FA7D98 757F4481 C8E9D304
              F3547273 B7D972BA 000003F8 00000101 00000380 7AC7
  48000400 03FB0000 01000000 4E000000 00114298 BBD2670E 50330000 7F0A2000
    udp src 50826, dst 6430 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C05 670E5033 4298BBD2 C68A191E
              00280000 80129166 4106CD30 18B67DD4 8A904841 66D0AFB4
              02655BB0 C5E428C1 000003F8 00000101 00000380 7AC7
  50000400 03FB0000 01000000 4E000000 0011C64A 6192670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.74.97.146
    udp src 10186, dst 9110 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116293 670E5033 C64A6192 27CA2396
              00280000 801245E6 848550C0 5E093B6B 6873DA98 61DA49F3
              6B54301A 9B7DD722 000003F8 00000101 00000380 7AC7
  58000400 03FB0000 01000000 4E000000 00114447 39F6670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 68.71.57.246
    udp src 24152, dst 8786 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 30F00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39110C33 670E5033 444739F6 5E582252
              00280000 80126A04 848550C0 33075665 1A72D6D6 68BF120E
              E2F91AF8 D6520B9D 000003F8 00000101 00000380 7AC8
  60000400 03FB0000 01000000 4E000000 00114A37 710C670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 74.55.113.12
    udp src 63834, dst 10138 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911CF2C 670E5033 4A37710C F95A279A
              00280000 80129140 848550C0 168473E6 58EAB6A3 AE1A94DB
              4758F833 9B2BD402 000003F8 00000101 00000380 7AC8
  68000400 03FB0000 01000000 4E000000 0011BC8A 30BD670E 50330000 7F0A2000
    udp src 11882, dst 7130 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39119D28 670E5033 BC8A30BD 2E6A1BDA
              00280000 801277C4 848550C0 3E0A5B68 86A3CB51 BDAD8952
              45D3BEAB C9A0BA03 000003F8 00000101 00000380 7AC8
  70000400 03FB0000 01000000 8A000000 0011AE88 2869670E 50330000 7F0A2000
    udp src 29272, dst 41458 len 100 checksum 0x0
layer 3 data: 45000078 00004000 3911B342 670E5033 AE882869 7258A1F2
              00640000 80088BDD 84855110 1259773B D15554D5 54545757
              5757D554 55D4D6D6 000003F8 00000101 00000380 7AC7
  78000400 03FB0000 01000000 4E000000 00114447 2AE8670E 50330000 7F0A2000
    udp src 17960, dst 7714 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 20E00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39111B41 670E5033 44472AE8 46281E22
              00280000 80125361 848550C0 30FE559C 3327A4F3 87C6BB52
              05263E7B E5D5B111 000003F8 00000101 00000380 7AC9
  80000400 03FB0000 01000000 4E000000 00115519 B0F7670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 85.25.176.247
    udp src 48946, dst 10654 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 B0F00000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911845F 670E5033 5519B0F7 BF32299E
              00280000 80121B5D 848550C0 19A87CCA BE955083 9B11131F
              4498DE00 916DC4E7 000003F8 00000101 00000380 7AC8
  88000400 03FB0000 01000000 4E000000 0011BC8A 68D3670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 188.138.104.211
    udp src 53876, dst 6002 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116512 670E5033 BC8A68D3 D2741772
              00280000 801211EE 848550C0 2A5E4F3C 75C3D30C A6D9F226
              815C3567 BD0C414A 000003F8 00000101 00000380 7AC5
  90000400 03FB0000 01000000 4E000000 00114076 5517670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.118.85.23
    udp src 10962, dst 8614 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911F4E2 670E5033 40765517 2AD221A6
              00280000 80121CAC 848550C0 14627100 4DE3D59B 925954DA
              5AC0617B 8E057FE3 000003F8 00000101 00000380 7AC5
  98000400 03FB0000 01000000 4E000000 001145A2 481A670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 69.162.72.26
    udp src 53514, dst 7214 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 00100000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911FCB3 670E5033 45A2481A D10A1C2E
              00280000 8012035C 848550C0 3DFE589C 781340A0 00FAC200
              07D678AE 80A000FA 000003F8 00000101 00000380 7AC7
  A0000400 03FB0000 01000000 4E000000 00115519 4945670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 85.25.73.69
    udp src 51682, dst 6618 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911EC11 670E5033 55194945 C9E219DA
              00280000 801228BE 848550C0 36535331 74737673 E3D9D7CA
              B3125CB7 C403492B 000003F8 00000101 00000380 7AC6
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 198.74.97.226
    udp src 28308, dst 8658 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 6E9421D2
              00280000 8012C98B 848550C0 30415523 C6E3D5D6 D7E71262
              B7883752 95D7AB06 000003F8 00000101 00000380 7AC6
  C8000400 03FB0000 01000000 4E000000 00116CA6 C78A670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 108.166.199.138
    udp src 56182, dst 7174 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 80800000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 3911563F 670E5033 6CA6C78A DB761C06
              00280000 80120323 648166C0 4D462824 79C0C32A DE680B0D
              471B4221 02CF1338 000003F8 00000101 00000380 7AC7
  D0000400 03FB0000 01000000 4E000000 0011CC0D 9992670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 204.13.153.146
    udp src 10836, dst 6134 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 90900000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 391124D0 670E5033 CC0D9992 2A5417F6
              00280000 80125045 648166C0 669E03FC DCDB488B 4782D7B4
              874B78A7 6B344C52 000003F8 00000101 00000380 7AC7
  F0000400 03FB0000 01000000 4E000000 00114E81 B22E670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 78.129.178.46
    udp src 12658, dst 6270 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391189C0 670E5033 4E81B22E 3172187E
              00280000 80121D28 648166C0 2FA94ACB EA74CCFA 08FF5571
              73024AD6 CBCAD558 000003F8 00000101 00000380 7AC8
  08000400 03FB0000 01000000 4E000000 0011AE88 248B670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 174.136.36.139
    udp src 61866, dst 31030 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911B75C 670E5033 AE88248B F1AA7936
              00280000 80120A68 648166C0 1CD579B7 30D4CE58 582B112E
              569078CB 49FA432A 000003F8 00000101 00000380 7AC7
  10000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
    udp src 40082, dst 46176 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 9C92B460
              00280000 80120FCC 648166C0 25704012 BED0DEEC D384CA65
              54E43834 80F975BD 000003F8 00000101 00000380 7AC6
  18000400 03FB0000 01000000 4E000000 00114657 DD33670E 50330000 7F0A2000
    udp src 15756, dst 39492 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391166E5 670E5033 4657DD33 3D8C9A44
              00280000 80127C7D 648166C0 74EE118C 787ACA37 65825ABB
              6E9E5233 E343FA4E 000003F8 00000101 00000380 7AC7
  20000400 03FB0000 01000000 4E000000 00116CA6 C3CC670E 50330000 7F0A2000
    udp src 33246, dst 6234 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391159FD 670E5033 6CA6C3CC 81DE185A
              00280000 80123C68 648166C0 3C235941 72F4EA51 5AA8DB24
              9A126473 4FAC08DB 000003F8 00000101 00000380 7AC6
  28000400 03FB0000 01000000 4E000000 00115519 B829670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 85.25.184.41
    udp src 43978, dst 10562 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39117D2D 670E5033 5519B829 ABCA2942
              00280000 80120315 648166C0 24F64194 0E6F28A2 BBA19C6C
              503C4E10 FFEF01DC 000003F8 00000101 00000380 7AC9
  38000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
    udp src 19854, dst 60222 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 4D8EEB3E
              00280000 80121E4A 648166C0 39575C35 87CA893D 9E524E62
              7558AB72 8A75B415 000003F8 00000101 00000380 7AC9
  40000400 03FB0000 01000000 4E000000 0011400F 4767670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.15.71.103
    udp src 49740, dst 10110 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 391102FA 670E5033 400F4767 C24C277E
              00280000 8012286D 648166C0 28234D41 31A314EC D0E254A3
              38C04CFE EBE27669 000003F8 00000101 00000380 7AC7
  50000400 03FB0000 01000000 4E000000 001143E4 034D670E 50330000 7F0A2000
    udp src 7342, dst 64874 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911433F 670E5033 43E4034D 1CAEFD6A
              00280000 80124A4B 648166C0 78801DE2 F8EAE60B 84CFC3E2
              D952746B 793E3E9B 000003F8 00000101 00000380 7AC6
    udp src 64218, dst 8538 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C05 670E5033 4298BBD2 FADA215A
              00280000 80121DE0 648166C0 2E164B74 12ABFC77 F0D29BD1
              CC9A540B 6EFCE77B 000003F8 00000101 00000380 7AC8
    udp src 47544, dst 9322 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39116243 670E5033 C64A61E2 B9B8246A
              00280000 80123146 648166C0 55503032 70D2F53C F868D35C
              361E3662 CB126403 000003F8 00000101 00000380 7AC8
  70000400 03FB0000 01000000 4E000000 001145A2 5F12670E 50330000 7F0A2000
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 69.162.95.18
    udp src 11412, dst 6534 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 3911E5BB 670E5033 45A25F12 2C941986
              00280000 801201A3 648166C0 680D0D6F 78AA40A0 00FAC200
              07D6787A 80A000FA 000003F8 00000101 00000380 7AC7
  88000400 03FB0000 01000000 4E000000 00114298 BB62670E 50330000 7F0A2000
    udp src 63468, dst 8334 len 40 checksum 0x0
layer 3 data: 4500003C 00004000 39118C75 670E5033 4298BB62 F7EC208E
              00280000 80121FD9 648166C0 018C64EE D235BAE4 1F8B076B
              00D8F83A 8062BCC2 000003F8 00000101 00000380 7AC5
  df 1, mf 0, fo 0, ttl 58, src 103.14.80.51, dst 64.34.176.54
    udp src 46492, dst 16074 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 B0300000 50330000 7F0A2000
layer 3 data: 4500003C 00004000 39119A17 670E5033 4022B036 B59C3ECA
              00280000 8012C548 1AE911E0 46142376 2EAC91AD 0C5971EA
              641F2E9D D1A7B8AF 000003F8 00000101 00000380 7AC8
  98000400 03FB0000 01000000 4E000000 00114A3F DBA2670E 50330000 7F0A2000
    udp src 28918, dst 6306 len 40 checksum 0x0
  00020000 03F82800 03800000 4E000000 00110000 90A00000 50330000 7F0A2000
