Jabber 9 UCM 6 and phone control..
jmachiggins
Hello, I'm setting up Presence and Jabber for a client with UCM 6.1.  Everthing seems to be working fine except the ability to control desktop phones from Jabber.  Although all the settings appear to be ok whenever a user tries to change from softphone to hardphone in Jabber it fails.  I have a TAC case open and we are at the..let's pull the same logs again stage..which means they are stumped usually.  So my question is..Has anyone out there ever got this to work with CallManager 6?  I am begining to suspect that this feature just doesn't work with this version of CallManager.  Any help would be much appreciated.
Thanks!
Justin
Jaime Valencia
Supported Servers for On-Premises Deployments
  • Cisco Unified Communications Manager versions 7.1.4 to 9.0
    Note
    Cisco Jabber for Windows supports Cisco Unified Communications Manager 7.1.3 if you install the following COP file to enable CSF devices: ciscocm.installcsfdevicetype.cop.sgn.Download ciscocm.installcsfdevicetype.cop.sgn from the Cisco Jabber for Windows administration package on Cisco.com.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
