C3750X - Power supply OIDs problems
Markelson
We are trying to monitor two stacks of CISCO WS-c3750X running IOS 12.2.(58)SE.
We can get the state of the power supplies, but after a power cycle or reboot of the switches the identifier of ONE of the Power supplies ALWAYS change. The OIDs for the rest of the PS do not vary. The problem happens in the two stacks.
Any idea or work around?
Kind regards
Mark
8 Replies 8
deyadav
Hi Mark,
Few other users are also experiencing this problem and I am currently working on one of the TAC case around the same. I'll update you how it goes, however at this moment I'm trying to establish if this is expected or an unexpected behavior. If possible, try not to poll individual OID indexes for the power supply and instead use the OID only, example:
server% snmpwalk -v1 -c public 1.3.6.1.4.1.9.9.13.1.5.1.2
SNMPv2-SMI::enterprises.9.9.13.1.5.1.2.1034 = STRING: "Sw1, PS1 Normal, RPS NotExist"
SNMPv2-SMI::enterprises.9.9.13.1.5.1.2.1035 = STRING: "Sw1, PS2 Normal, RPS NotExist"
SNMPv2-SMI::enterprises.9.9.13.1.5.1.2.2034 = STRING: "Sw2, PS1 Normal, RPS NotExist"
I'll update once there is more insight on this.
Deepak
Hi any update on this issue?
Just updated software, problem not solved yet
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3750X-24       15.0(2)SE1            C3750E-UNIVERSALK9-M
     2 30    WS-C3750X-24       15.0(2)SE1            C3750E-UNIVERSALK9-M
snmpwalk -v 2c -c **********  X.X.X.X .1.3.6.1.4.1.9.9.13.1.5.1.2
iso.3.6.1.4.1.9.9.13.1.5.1.2.1034 = STRING: "Sw1, PS1 Normal, RPS NotExist"
iso.3.6.1.4.1.9.9.13.1.5.1.2.1036 = STRING: "Sw1, PS2 Faulty, RPS NotExist"
iso.3.6.1.4.1.9.9.13.1.5.1.2.2034 = STRING: "Sw2, PS1 Normal, RPS NotExist"
iso.3.6.1.4.1.9.9.13.1.5.1.2.2035 = STRING: "Sw2, PS2 Faulty, RPS NotExist"
#sh env al
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  C3KX-PWR-350WAC     LIT161700PF OK              Good     Good     350/0
1B  C3KX-PWR-350WAC     AZS161800V4 OK              Good     Good     350/0
2A  C3KX-PWR-350WAC     AZS161800QS OK              Good     Good     350/0
2B  C3KX-PWR-350WAC     AZS161800V9 OK              Good     Good     350/0
Deepak,
Do you have an update on this?
We have the same issue and the monitoring we use needs to poll individual OID values in order to get a numerical response, the
type output is no use to us for monitoring purposes.
Apologies for delay in responding. Here is the final update although may not solve purpose easily for most NMS systems, however the following is the status:
IOS is unable to maintain a persistent state for the following OID indexes:
entPhysicalIndex
This is used to provide index for power supplies as well which may change after reload. So, the requirement for NMS is to ensure discovering the correct index after reload and then use for monitoring power supplies.
Unfortunately, this change has to happen on NMS and IOS cannot accomodate this. AFAIK IOS-XR got some persistency through enhancement bug:CSCsl67774, however with IOS is seen as a limitation due to design.
Thanks & Regards,
Deepak
I'm trying to determine if the issue addressed in this post is a match with the following symptom:
As you can see from the output below - the switch 2 power supplies appear to be healthy:
SWITCH#show env power switch 1
1A  C3KX-PWR-350WAC     AZS161707F3  OK              Good     Good     350/0
1B  C3KX-PWR-715WAC     LIT16180RRU  OK              Good     Good     715/0
SWITCH#show env power switch 2
2A  C3KX-PWR-715WAC     LIT16180RRY  OK              Good     Good     715/0
2B  C3KX-PWR-350WAC     AZS161707FZ  OK              Good     Good     350/0
Yet, the snmpwalk output shows a Sw2 PS2 power supply fault:
              snmpwalk -v1 X.X.X.X  -c READONLY .1.3.6.1.4.1.9.9.13.1.5.1
SNMPv2-SMI::enterprises.9.9.13.1.5.1.2.1035 = STRING: "Sw1, PS1 Normal, RPS NotExist"
SNMPv2-SMI::enterprises.9.9.13.1.5.1.2.1036 = STRING: "Sw1, PS2 Normal, RPS NotExist"
SNMPv2-SMI::enterprises.9.9.13.1.5.1.2.2035 = STRING: "Sw2, PS2 Faulty, RPS NotExist"
Do my symptoms match with the issue addressed in this post ?
TIA,
Amir
I am not understanding how a NMS would detect a change, is that some functionality that can be built into the software? Was anyone able to come up with a solution or workaround to monitor power supply status after reboot?
Hi Deepak,
can you tell us what solution is suggested by TAC suppport?
Is this a know bug?
We see this on Prime infra 1.3 as well.
kind regards
Ad
This is a limitation imposed by IOS and no solution from IOS perspective to overcome this. Upon reload the indexes would not be persistent and rediscovery from NMS is required to find the right object/index and then monitor it, if this could be performed by NMS. I am not a NMS expert, so feel free to post your question on a new forum to seek help to make this possible from NMS applications.
