AIR-LAP1131AG-A-K9 V05 Not able to join WLC 4402
ahmedbishry
hope you are all doing well,
i need your advice that i have a AIR-LAP1131AG-A-K9 V05 Not able to join WLC 4402 with error,
I connect the console to the LAP1131 and i found the below error log,
thanks in advanced for your effort,
File "flash:/c1130-k9w8-mx.124-21a.JA/c1130-k9w8-mx.124-21a.JA" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1130 Software (C1130-K9W8-M), Version 12.4(21a)JA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 08-Jun-09 16:10 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 25 files, 8 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 6821888
flashfs[1]: Bytes available: 9177088
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Radio0  present A506 7100 E8000000 A0000000 80000000 3
Radio1  present A506 6700 E8000100 A0040000 80010000 2
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1131AG-A-K9   (PowerPCElvis) processor (revision B0) with 24566K/8192K bytes of memory.
Processor board ID FTX1421N00D
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 6.0.182.0
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 54:75:D0:16:44:FE
Part Number                          : 73-8962-14
PCA Assembly Number                  : 800-24818-13
PCA Revision Number                  : A0
PCB Serial Number                    : FOC141707J5
Top Assembly Part Number             : 800-29144-03
Top Assembly Serial Number           : FTX1421N00D
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1131AG-A-K9
% Please define a domain-name first.
Press RETURN to get started!
p: 10.100.1.250 peer_port: 5246
*Oct  2 15:20:48.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Oct  2 15:20:49.411: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.100.1.250 peer_port: 5246
*Oct  2 15:20:49.412: %CAPWAP-5-SENDJOIN: sending Join Request to 10.100.1.250
*Oct  2 15:20:49.413: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Oct  2 15:20:49.504: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Oct  2 15:20:49.504: %CAPWAP-3-ERRORLOG: Starting config timer
*Oct  2 15:20:49.512: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.100.1.250
*Oct  2 15:20:49.512: %DTLS-5-PEER_DISCONNECT: Peer 10.100.1.250 has closed connection.
*Oct  2 15:20:49.512: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.100.1.250:5246
*Oct  2 15:20:49.556: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Oct  2 15:20:49.566: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Oct  2 15:20:49.578: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct  2 15:20:49.578: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Oct  2 15:20:49.610: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct  2 15:20:49.638: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Oct  2 15:20:49.639: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Oct  2 15:20:49.671: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct  2 15:20:59.593: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Oct  2 15:20:59.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.100.1.250 peer_port: 5246
*Oct  2 15:20:59.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Oct  2 15:21:00.413: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.100.1.250 peer_port: 5246
*Oct  2 15:21:00.415: %CAPWAP-5-SENDJOIN: sending Join Request to 10.100.1.250
*Oct  2 15:21:00.415: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Oct  2 15:21:00.505: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Oct  2 15:21:00.505: %CAPWAP-3-ERRORLOG: Starting config timer
*Oct  2 15:21:00.516: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.100.1.250
*Oct  2 15:21:00.517: %DTLS-5-PEER_DISCONNECT: Peer 10.100.1.250 has closed connection.
*Oct  2 15:21:00.517: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.100.1.250:5246
*Oct  2 15:21:00.562: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Oct  2 15:21:00.573: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Oct  2 15:21:00.585: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct  2 15:21:00.585: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Oct  2 15:21:00.617: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct  2 15:21:00.645: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Oct  2 15:21:00.676: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct  2 15:21:10.600: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Oct  2 15:21:11.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.100.1.250 peer_port: 5246
*Oct  2 15:21:11.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Oct  2 15:21:12.404: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.100.1.250 peer_port: 5246
*Oct  2 15:21:12.406: %CAPWAP-5-SENDJOIN: sending Join Request to 10.100.1.250
*Oct  2 15:21:12.406: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Oct  2 15:21:12.497: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Oct  2 15:21:12.497: %CAPWAP-3-ERRORLOG: Starting config timer
*Oct  2 15:21:12.505: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.100.1.250
*Oct  2 15:21:12.505: %DTLS-5-PEER_DISCONNECT: Peer 10.100.1.250 has closed connection.
*Oct  2 15:21:12.506: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.100.1.250:5246
*Oct  2 15:21:13.174: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Oct  2 15:21:13.175: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Oct  2 15:21:13.184: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Oct  2 15:21:13.184: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Oct  2 15:21:13.196: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct  2 15:21:13.196: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Oct  2 15:21:13.198: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Oct  2 15:21:13.228: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct  2 15:21:13.229: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Oct  2 15:21:13.257: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Oct  2 15:21:13.258: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Oct  2 15:21:13.259: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Oct  2 15:21:13.289: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct  2 15:21:23.212: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Oct  2 15:21:23.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.100.1.250 peer_port: 5246
*Oct  2 15:21:23.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Oct  2 15:21:24.410: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.100.1.250 peer_port: 5246
*Oct  2 15:21:24.411: %CAPWAP-5-SENDJOIN: sending Join Request to 10.100.1.250
*Oct  2 15:21:24.411: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Oct  2 15:21:24.502: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Oct  2 15:21:24.502: %CAPWAP-3-ERRORLOG: Starting config timer
*Oct  2 15:21:24.512: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.100.1.250
*Oct  2 15:21:24.512: %DTLS-5-PEER_DISCONNECT: Peer 10.100.1.250 has closed connection.
*Oct  2 15:21:24.512: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.100.1.250:5246
*Oct  2 15:21:24.557: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Oct  2 15:21:24.567: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Oct  2 15:21:24.579: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct  2 15:21:24.579: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Oct  2 15:21:24.611: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct  2 15:21:24.639: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Oct  2 15:21:24.640: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Oct  2 15:21:24.671: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct  2 15:21:34.594: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Oct  2 15:21:35.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.100.1.250 peer_port: 5246
*Oct  2 15:21:35.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Oct  2 15:21:36.409: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.100.1.250 peer_port: 5246
*Oct  2 15:21:36.410: %CAPWAP-5-SENDJOIN: sending Join Request to 10.100.1.250
*Oct  2 15:21:36.410: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Oct  2 15:21:36.503: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Oct  2 15:21:36.504: %CAPWAP-3-ERRORLOG: Starting config timer
*Oct  2 15:21:36.514: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.100.1.250
*Oct  2 15:21:36.514: %DTLS-5-PEER_DISCONNECT: Peer 10.100.1.250 has closed connection.
*Oct  2 15:21:36.515: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.100.1.250:5246
*Oct  2 15:21:36.559: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Oct  2 15:21:36.569: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Oct  2 15:21:36.581: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
Login to the WLC, go to Wireless > Country.  Check the box for US.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
12 Replies 12
Yahya Jaber
Check the license.
are they on the same subnet?
force the AP to join ""
AP#capwap ap ip address
AP#capwap ap ip default-gateway
AP#capwap ap controller ip address
is it happening with all AP's?
Dear Yehya,
many thanks for your reply
I will do this and reply to you,
Dear Yahya,
  • the license is fine we can add more LAP
  • they are in different subnet
  • there are only two LAP working like that (both of theme has the same part number AIR-LAP1131AG-K9 V05) and the other AP (with part number AIR-LAP1131G-E-K9 V02) are working normally,
I will try the commands that you gave me then i will send you my feedback,
Ok so the working are -E and the -A are not able to join. Sounds like it would be a country code issue. Do you have US as an selected country code?
If your deployment is only in Europe you may just want to get your partner/reseller to get you -E instead.
Steve
HTH,
Steve
Hi Steve,
many thanks for the reply,
Is there any way to make it both -E and -A works on the WLC ?
Yes, add US as a country code.
Steve
HTH,
Steve
Hi Steve,
How can I do this?
please explain to me,
HTH,
Steve
HTH,
Steve
If that do not help, did u bought him as lap or did u convert him from standalone to lap. If yes check if I allow self signed certificates under the security tab.
Hi Steve,
many thanks for your reply i will try it and send you my feedback,
Hi Sebastain,
many thanks for your reply,
the device is originally coming as LAP with no changes made on it,
Many thanks all it's sovled now
it was as steve said it's Country issue,
