How can I create a holiday schedule on CCX
Justin Westover
How can I create a holiday schedule in my CCX script so calls go to voicemail on holidays instead of going into the queue?
24 Replies 24
Andrew Skelly
Level 7
Level 7
Create an XML document (like the one attached) that has your company holidays in it.  You'll need to update it each year as the company recognized day changes each year.
You will need to collect the specific day in the script, and then reference the current day against the XML document.  I've include a basic script that only shows how the date collection would look in a scirpt.  There is probably a cleaner way to do this, but this should get you started.
Please rate helpful posts by clicking the thumbs up!
What is the ownername and ownerteam in the xml script for? I see that is also referenced in the .aef script.
Those are just the names of the fields in the XML document.  You can call them whatever you want.  I quick copied another XML I had to put the dates in there.  The script needs to know which fields in the XML it is looking at for data, so you need to specify in the script.
You can change the names to "Recognized Date" and "Company Holiday" or anything else you would like.  Just make sure whatever you call them in the XML you also reference in the script.
I'm actually really curious as to why the XML based solution for Holidays took off like it did.  Don't get me wrong, it's certainly a good option, and I have used it many times in the past myself.  I'm just curious.
Anyway, here's an alternate solution to the XML one Andrew posted, and the many others that exist on the forum.  We will explore using a Date array in lue of an XML document, and you simply call it via Subflow looking for the return value of "is_holiday."  It's pretty light weight.
Some benefits include:
  • Shareable between all scripts as a subflow (just like XML docs are)
  • Validates Date input at time of entry (XML docs can contain typos or improper formatting of dates)
Filename: holidays.aef
Variables
Date holiday = null
Date[] holidays = new Date[] {D[11/22/2012], D[11/23/2012], D[12/25/2012]}
Iterator holidays_iterator = com.cisco.util.EmptyIterator.iterator
boolean is_holiday = false
Date today = D[now]
Script
Start
Set holidays_iterator = holidays.iterator
Label Read Next Holiday
If (holidays_iterator.hasNext())
  True
    Set holiday = (Date) holidays_iterator.next()
    If (holiday.month == today.month && holiday.date == today.date && holiday.year == today.year)
      True
        Set is_holiday = true
        Goto End of Script
      False
        Goto Read Next Holiday
    False
      Goto End of Script
Label End of Script
End
So, that's the subflow, and this next script is your Main AA script.  I will omit everything except for the pieces necesary to use the holiday subflow.  It only uses a single variable, and two script steps.
Filename: main_aa.aef
Variables
Script
Start
...answer, greet, etc...
is_holiday = Call Subflow(SCRIPT[holidays.aef], is_holiday)
If (is_holiday)
  True
    /* Today is a holiday */
    ...holiday treatment...
  False
    /* Today is not a holiday */
...the remainder of the AA...
End
You could take this a step further and include timezone support by taking in an input parameter of type Timezone and name timezone, and then generate your today variable at runtime like so:
Set today = D[D[now], timezone]
You could also leverage the input parameter of the holidays Date array, which would override the default array.  Or even specify a new Date array called holidays_include to allow the inclusion of some additional holidays. You would just repeat the actions in the script for both variables.
Challenge: How could you implement a holidays_exclude feature?
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
Thanks Anthony.  I'm now on 8.5 and your suggestion works. A previous suggestion from you using xml worked for me on 7 so instead of searching for 8.5 holiday scripts I searched for your name on the forum!
Oh dear!  I better not start posting in the IP Telephony forum, it might delute your searches for UCCX solutions!
Thanks for the feedback, it's appreciated.
Anthony Holloway
Hi Anthony
I used your method and its working
going to implement this for a client next week
shameer
I tried to understand what you're saying but didn't manage it. The presentation you're doing with the date variables. My java/programming/whatever way of thinking is not developed :/ . I'm just a humble network engineer
Hello Anthony,
Can you take a look at my scripts and let me know what I may be missing as it seem like my is_holiday variable keeps changing to true regardless of what is in the Date Array.
Richard
Rich, I know you didn't ask me..but I would work with String with this..check out the Image..and test with the attached script..Let me know how it looks to you..
Hello Sam,
Thanks for your input, that worked like a charm yes
Thanks for you help
Rich
Hello Sam,
I used your input above but can't seem to get it to work.  Here is my post.
https://supportforums.cisco.com/discussion/12317046/holiday-script-uccx-date-array-creation
Any input would be greatly appreciated.
Thank you,
Jeffery
Sam Womack!  Good work as usual!  Works like a charm.
Hi Sam,
Would it be possible to pass the dates in the string array as a parameter to the scipt, to make it easier for end users to change the dates?
Cheers and thanks,
Sam.
