Unity Connection admin permissions / privileges
dwaters
On Cisco Unity Connection version 7.0.2.10000-38 an administrator has accidently removed privileges from there selves; this has resulted in loss of access to administer the system. When logging in the message “Not Authorized” is displayed and we don’t get any further.
Please note: I dont have another Web admin user to login as.
I can access the CLi however I’m unable to find a method to reset permissions.
'utils reset_ui_administrator_password' and 'utils reset_ui_administrator_username' I don’t think will be much help.
2 Accepted Solutions
Hello Daniel,
Are you not able to login to Admin page using the Administrator account ?
A. Create  another Admin account
1. Create a user with No mailbox
run cuc dbquery unitydirdb execute procedure csp_UserCreate(ptemplateObjectId=(select objectid from vw_Usertemplate where displayname='Administrator Template'),palias='<alias which you want>')
2. Assign "System  Administrator" Role to the user
run cuc dbquery unitydirdb execute procedure csp_PolicyCreate (pRoleObjectId=(SELECT objectid FROM vw_role WHERE rolename='System Administrator'), pUserObjectId=(SELECT objectid FROM vw_globaluser WHERE alias=''));
3. Reset the Password of the user
utils cuc reset password <alias you created above>
4. Try login and then reset the cucadministrator password from CUCA.
Credit is for A.M.Mahesh Babu !
David Peck
Here an example during lab recreation:
admin:run cuc dbquery unitydirdb execute procedure csp_UserCreate(ptemplateObjectId=(select objectid from vw_Usertemplate where displayname='Administrator Template'),palias='davidcliscript')
pmailboxid  pobjectid
null        1c05947c-2e14-4e52-82ae-308d12da39e3
admin:run cuc dbquery unitydirdb execute procedure csp_PolicyCreate (pRoleObjectId=(SELECT objectid FROM vw_role WHERE rolename='System Administrator'), pUserObjectId=(SELECT objectid FROM vw_globaluser WHERE alias='davidcliscript'))
pobjectid
476457e0-f834-4138-93ff-4458709cc1ef
admin:show account
Account = Administrator, Privilege = 4
Account = test, Privilege = 1
admin:utils cuc reset password davidcliscript
Enter password:
Re-enter password:
davidcliscript
10/23/2012 08:50:30.486 : Update SUCCEEDED
If by any reason you want to find out if some other non-subscriber accounts exist, you can run:
admin:run cuc dbquery unitydirdb select alias from vw_usernonsubscriber
alias
administrator
unityconnection
David Peck
6 Replies 6
Bradford Magnani
Hi Daniel,
I think you're actually looking for
utils reset_application_ui_administrator_name
utils reset_application_ui_administrator_password
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/7_1_3/cli_ref_713.html#wp113347
Brad
admin:utils reset_ui_administrator_password
New password:
Confirm new password:
-------------------- utils reset_ui_administrator_password --------------------
Reset user interface password
CUCAdministrator
Read Credential for CUCAdministrator failed.
10/23/2012 09:35:30.645 : Update FAILED: code = 1, AUTHORIZATION FAILURE
Bah!
admin:utils cuc reset password CUCAdministrator
Enter password:
Re-enter password:
CUCAdministrator
10/23/2012 09:40:54.789 : Update FAILED: code = 1, AUTHORIZATION FAILURE
2012-10-23 09:40:54,798 ERROR [Thread-149] cli.cmdUtilsCucResetPassword - Command failed: 1: stderr=''; stdout='CUCAdministrator
admin:
That command also fails.
Hello Daniel,
David Peck
pobjectid
admin:show account
Enter password:
Re-enter password:
davidcliscript
alias
administrator
unityconnection
David Peck
Does this work on CUCM too?
