Inspection load at 0% and CPU at 100%
Hi, I have an ASA firewall 5585X with IPS SSP60 module, the issue here is that in the IPS module with IME, IDM and CLI, the staticts show that the inspection load is ever at 0% and the CPU(the 24 cores) are at 100% of use, i Think that is not so real, because I can see alerts and I able to access to the module.
so here are some evidence:
Inspection load:
show statistics virtual-sensor
Virtual Sensor Statistics
   Statistics for Virtual Sensor vs0
      Name of current Signature-Defintion instance = sig0
      Name of current Event-Action-Rules instance = rules0
      List of interfaces monitored by this virtual sensor =
      General Statistics for this Virtual Sensor
         Number of seconds since a reset of the statistics = 128767
         MemoryAlloPercent = 3
         MemoryUsedPercent = 3
         MemoryMaxCapacity = 45000000
         MemoryMaxHighUsed = 1054898
         MemoryCurrentAllo = 1566870
         MemoryCurrentUsed = 1506030
        Inspection Load Percentage = 0
         Total packets processed since reset = 38248606
         Total IP packets processed since reset = 38248606
CPU usage:
CPU Statistics
   Note: CPU Usage statistics are not a good indication of the sensor processing load. The Inspection Load Percentage in the output of 'show inspection-load' should be used instead.
   Usage over last 5 seconds = 100
   Usage over last minute = 100
   Usage over last 5 minutes = 100
attached are the tech support file
someone know this problem?
Julio Carvajal Tue, 10/23/2012 - 16:08
  • Purple, 4500 points or more
Hello Mahuen,
This is the expected behavior.
Let me explain myself.
The explanation being that that the CPU polls the NIC more frequently, hence
decreasing the polling interval and reducing latency. The additional CPU
load that is reported while polling is actually available to process packets, and
reduces as inspection load goes up, it does not negatively affect the
overall throughput of the IPS.
This anomaly is discussed under the defect CSCtl74475
Hope this helps,
Julio
Julio Carvajal Wed, 10/24/2012 - 10:18
Hello Mahuen,
Well, there is no much traffic generating inspection across the box. That's all
Julio Carvajal Wed, 10/24/2012 - 12:41
Hello Mahuen,
Well that is what the ouptut means!
Have you check the service policy to check how many packets are being send to the module?
Related Content
