hi,
so I have this setup going in gns3.
I have a spoke, at first it was connected to 2 hubs with a gre/ipsec tunnel per hub so 2 tunnels on the spoke running with eigrp. It would get a 0.0.0.0 defaut route from both hubs but with an offset list I would prioritize one hub over the other since I don't want the spoke to load balance traffic between hubs.
now I,m running the same setup but with odr.
my spokes gets a default route from both hubs... any way to give priority to one hub over the other with odr? I have seen setups but they're all setups with spoke to hub and not spoke to many hubs with 2 tunnels up (active/waiting) type.
so can I do what I want with odr.
if not then I think the other solution would be rip.
I'm working with gns3 on a dmvpn setup that could accept thousands of spokes so I rather not use eigrp because it will be cpu intensive. all I need to do is pass a 0.0.0.0 route to my spokes ... my first choice was odr but it seems limited... next option is rip.
thanks for any feedbacks.
