Anyconnect install problem
                  We are seeing an install problem with the AnyConnect Secure Mobility Client under Windows 7. The installer stalls after a minute or so then reports:
There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected.
There has been no other install issue on these machines and we have reinstalled Windows 7 to insure that the Installer is robust.
Please advise.
D Miller
Marvin Rhoads Tue, 10/23/2012 - 17:59
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
How are you deploying? Pre-deployment using the installer in the ISO file (anyconnect-win-3.1.01065-pre-deploy-k9.iso) or via a pkg file (anyconnect-win-3.1.01065-k9.pkg) from the ASA?
I've used both successfully on Windows 7 clients.
Marvin Rhoads Tue, 10/23/2012 - 20:35
Which file are you using specifically? The current AnyConnect pre-deploy file for VPN clients is not an .exe - it is an .msi file:
     anyconnect-win-3.1.00495-pre-deploy-k9.msi
...which is extracted from the .iso (anyconnect-win-3.1.01065-pre-deploy-k9.iso) available for download from Cisco.com here.
Javier Portuguez Wed, 10/24/2012 - 14:05
  • Red, 2250 points or more
Hi Dennis,
Do you disable any FW / AV during this test?
Are you doing it as an Administrator?
How many computers experience the issue? Same configuration?
What if you try through the WebVPN portal?
Please try the silent installation:
"msiexec /i specific_AnyConnect.msi /norestart /quiet /lvx* install-log.txt"
Let us know.
Thanks.
Portu.
Please rate any helpful posts
meconomou Tue, 11/06/2012 - 09:33
I am also having this same issue since upgrading from XP to Win7 and the quiet install isn't working.
anyconnect-win-3.0.5080-web-deploy-k9.exe is the stand alone I download after the web-based install fails.
stephen.fernandez Mon, 11/19/2012 - 11:03
Experiencing the same issue here. Running Windows 7 x64 and am an administrator. I have checked the registry for the RunOnce key and confirmed it is there. I have also tried running the installer silently with the same result.
Trying to install 3.0.5080 msi.
jeankedotcom Wed, 04/10/2013 - 04:31
Same problem here on Windows 8 with anyconnect-win-3.1.02026-pre-deploy-k9.msi.
I ran "msiexec /i anyconnect-win-3.1.02026-pre-deploy-k9.msi /norestart /quiet /lvx* install-log.txt"
The results can be found here: http://devgem.be/install-log.txt
Any help is appreciated.
bravotom99 Mon, 11/19/2012 - 11:48
I ran into a similar issue installing anyconnect 2.5 a while back and installing it with a NOISNTALLACTIVEX=1 at a CMD line resolved it.  Perhaps this will work for 3.0 as well
msiexec /i anyconnect-win-x.x.x-pre-deploy-k9.msi NOINSTALLACTIVEX=1
genel3971 Mon, 04/22/2013 - 12:00
Has anyone resolved this issue.. seems i can install 2.5 versions but every newer vers 3.0 and up Fails at the same Point.
michaelvivek Thu, 05/23/2013 - 21:01
Hi All,
Even i get the same error messge. kindly suggest and help.
rajan-sbc Wed, 06/05/2013 - 05:33
Team - I have been having the same issue of not being able to install on Windows 7. It gives the same install error. Any final resolution? Thank you
aromn Wed, 11/06/2013 - 13:46
I am experiencing the same problem, and have tried the following options:
  1. Disabled all HIPS in my local machine and ran the installation with administrator privileges
  2. Tried to install anyconnect-win-3.0.5080-web-deploy-k9.exe from the ASA
  3. Tried to install anyconnect-win-3.0.08057-pre-deploy-k9.msi, because version 3.0.5080 is not available to download from Cisco anymore (version 3.0.08057 is the oldest one that can be downloaded from Cisco)
  4. Tried to install anyconnect-win-3.0.08057-pre-deploy-k9.msi with the NOINSTALLACTIVEX=1 option
  5. Tried to install anyconnect-win-3.0.08057-pre-deploy-k9.msi with the/norestart /quiet /lvx* install-log.txt options
But none of them worked
As a workaround, I manually downloaded anyconnect-win-3.1.04072-pre-deploy-k9.iso from Cisco and the install was successful. However, it seems that not all of the ASAs are configured to allow this version, just older versions
Has anybody found a solution yet?
