10-31-2012 04:43 AM - edited 03-14-2019 10:45 AM
Hi All,
AM using Queue to Agent, the rpoblem si when i login and Agent Available, the call lands. The calls is queued if the agent is not available. When i make the agent not ready, the call is supposed to be queued. But i the call fails to queue. How does the queue to agent work?
10-31-2012 06:53 AM
Are you using a CVP / IP IVR for the call queuing. Or you can also queue the call from the Gateway.
Can you explain your present setup?
Dass
11-01-2012 01:44 AM
Hi Prakash,
The call flow in our setup is as below:
VG-->CUSP-->CVP-->ICM-->CVP--->CUSP-->CM-->IP Phone
The logic for the script is as follows,the customer calls the call center and the user is prompted to enter the agent ID,if the agent is ready the call should be transferred to the agent and if the agent is not ready or logged out the call should be in queue.
We are able to achieve positive results using the queue to agent node in the ready and logged out state ,but are unable to queue the call in the not ready state.
Everytime i change the agent state from ready to not ready the call drops and it is not on queue.
After this if the agent state is changed to ready it doesnt seem to work.
I need to logout and login back for the call to land on the CAD.
11-02-2012 01:07 AM
Can you post the properties of Queue to SkillGroup Node. In parallel can you also check the Consider IF parameter in the Node?
Dass
