Warning message
911 dialing
Answered Question
Oct 31st, 2012
Hey guys,
Quick (and stupid) question regarding dialing 911
If we have the following config :
dial-peer voice 58 pots
trunkgroup ALL_T1E1
corlist outgoing call-emergency
description **CCA*North American-10-Digit*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 3
destination-pattern 9911
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 60 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 911
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-rule 1112
rule 1 /^9/ //
Does it means that if I dial 911 only (not 9911) it will call outside?
This is something kind of hard to test, and as I am unsure, I prefer to check this out before telling the client what to write in their emergency plan.
Thanks guys!
P.S. a chatroom would be nice for those questions
Correct Answer by Paul Dicine about 4 years 9 months ago
You can also do a translation rule test without having to actually dial 911. Go to Monitor ->Telephony -> Translation Profiles and you can see the results to make sure it's working O.K.
Correct Answer by danplacek about 4 years 9 months ago
Yes, that is a CCA generated config.
911 OR 9911 will work.
EDIT: I should mention -- it is always best practice to do an ACTUAL 911 test call. These can generally be scheduled by calling the non-emergency line first if you are concerned about being fined for non-emergency calls. (Though I've found they are generally very understanding about it as long as you state right away that it is a test call and you do not have an emergency)
Please rate helpful posts.
Overall Rating: 5 (2 ratings)
mdube@progel.ca Mon, 11/05/2012 - 08:40
Anyone?
It is my understanding that 911 would "go out" and dial 911 directly, but of course, dialing 911 is kinda wrong just to test it out...
Correct Answer
danplacek Mon, 11/05/2012 - 09:13
  • Silver, 250 points or more
Correct Answer
Paul Dicine Mon, 11/05/2012 - 10:52
Related Content
