11-07-2012 06:03 AM - edited 02-21-2020 04:46 AM
hello guys,
I'm having problems with the cisco ise in my company.
every day is got the following error:
Cause: No NTP Server reachable from SPCISE01
Details: All of the NTP Servers configured on this node are unreachable. If NTP authentication is configured ensure that key ID and value match that of the server. Execute 'show ntp' from CLI for troubleshooting.
admin# show ntp
Configured NTP Servers:
10.0.4.6
synchronised to NTP server (10.0.4.6) at stratum 7
time correct to within 556 ms
polling server every 256 s
remote refid st t when poll reach delay offset jitter
127.127.1.0 .LOCL. 10 l 49 64 377 0.000 0.000 0.001
*10.0.4.6 10.0.4.4 6 u 1 256 377 2.133 6.875 8.734
* Current time source, + Candidate
Warning: Output results may conflict during periods of changing synchronization.
how can I force the sync ntp in ise?
01-24-2013 07:08 AM
We are having the same problem, have you managed to find any solution for this issue?
07-29-2013 11:03 AM
I am also having this issue. Every 15 minutes I get alarms. Tried differnt NTp servers 0 AD, external, etc.. with no luck. I am hoping someone has made progress in resolving this issue.
09-26-2013 05:17 AM
We are having the same issue. What's worst: The error is reported as CRITICAL and the description says that "No NTP Server reachable" (or that "All of the NTP Servers configured on this node are unreachable") and this is clearly wrong.
Running "sho ntp" about one hour after the error message clearly shows that only one out of three configured redundant ntp sources had a temporary problem:
Configured NTP Servers: 10.0.1.119 pool.ntp.org de.pool.ntp.org synchronised to NTP server (91.64.203.19) at stratum 2 time correct to within 54 ms polling server every 1024 s remote refid st t when poll reach delay offset jitter ============================================================================== 127.127.1.0 .LOCL. 10 l 27 64 377 0.000 0.000 0.001 +10.0.1.119 217.79.179.106 3 u 224 1024 367 0.234 -27.926 6.174 +89.163.176.81 178.63.97.57 3 u 95 1024 377 10.224 -4.777 0.533 *91.64.203.19 .PPS. 1 u 348 1024 377 29.527 0.121 3.608 * Current time source, + Candidate Warning: Output results may conflict during periods of changing synchronization.
Given that non-reachability of single hosts is something the ntp protocol is specifically designed for, issuing a "critical" message in a far-from-critical situation (it's not even an "error", it should be at most a "warning" I guess) is very annoying.
09-26-2013 05:54 AM
I resolved this issue by setting up NTP on our core switch 6513 and pointing ISE towards that. We got the same errors you are seeing when using an AD server for NTP. Since moving I have not gotten any NTP errors.
