RV042G can't connect another PC
reiddarinc
I've setup the RV042G with one ISP connection for now.
I have my main PC running fine, but I have another PC hard lined to the router that had a connection after I power cycled the modem and router but now it no longer does.
I disabled the network on that PC, now I can't get it back at all.
I have a wireless e2000 in one of the ports that I disabled the DCHP on and it seems to be running nicely.
Before I disabled the PC in question, aka port 3, it was showing as connected in the "192...." but now only as enabled.
There must be some settings I'm overlooking.
Thank you
janickle
Based on the symptom you are describing it sounds like you may have a duplicate IP address on the network.  Is the RV042G doing DHCP for you or do you have static IP address on the PC’s?  Also I would double check that the e2000 does indeed have the DHCP turned off.
Thank you,
Jason Nickle
