What's the difference between IP IVR and UCCX 9
curtishu19
We are planning to deploy UCCX 9 in our environment, just wondering if we do order the UCCX 9 premium version, do we still need to implement IP IVR?
If so, is that require additional licenses?
2 Accepted Solutions
Jonathan Schulenberg
IP IVR does not include the RmCm subsystem and therefor has no ACD functionality (i.e. no Skills/CSQs/Agents). It's used primarily with CCE although CVP is the more common IVR choice for that solution. It can also be used for building IVR-only self service applications.
Please remember to rate helpful responses and identify helpful or correct answers.
CCX Premium does, yes. They are the same software, the license keys just activate different subsystems.
Additional information on the features per license level is available in the CCX SRND.
curtishu19
So uccx include all ip IVR features, we don't need ip IVR if we have uccx premium?
curtishu19
Thanks for the information.
