dmvpn eigrp neighour flapping
Nov 14th, 2012
my company config dmvpn and use eigrp as route , now the problem is the tunnel interface flapping  , and log:
*Nov 15 05:26:46.899: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 192.168.96.1 (Tunnel100) is down: Peer Termination received
*Nov 15 05:27:01.695: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 192.168.96.1 (Tunnel100) is up: new adjacency
*Nov 15 05:27:21.271: %ADJ-5-PARENT: Midchain parent maintenance for IP midchain out of Tunnel100, addr 192.168.96.1 - looped chain attempting to stack
how to deal with it ,top players ,thank you very much~~~~
config:
interface Tunnel100
description to_ShenYang
bandwidth 10000
ip address 192.168.96.137 255.255.255.0
no ip redirects
ip mtu 1400
ip hello-interval eigrp 100 15
ip hold-time eigrp 100 45
ip nhrp map 192.168.96.1 210.83.25.66
ip nhrp map multicast 210.83.25.66
ip nhrp network-id 1234
ip nhrp holdtime 60
ip nhrp nhs 192.168.96.1
ip nhrp shortcut
ip summary-address eigrp 100 10.19.100.0 255.255.255.0
ip summary-address eigrp 100 172.16.1.64 255.255.255.248
qos pre-classify
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel key 1234
tunnel protection ipsec profile myprofile
interface Tunnel101
description to_ShenYang_Backup
bandwidth 10000
ip address 192.168.97.137 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map multicast 59.44.43.217
ip nhrp map 192.168.97.129 59.44.43.217
ip nhrp network-id 5678
ip nhrp holdtime 60
ip nhrp nhs 192.168.97.129
ip nhrp shortcut
qos pre-classify
tunnel key 5678
tunnel protection ipsec profile myprofile1
router eigrp 100
network 10.19.100.0 0.0.0.255
network 172.16.1.64 0.0.0.7
network 192.168.96.0
network 192.168.97.0
interface Tunnel100
bandwidth 10000
no ip redirects
ip mtu 1400
ip nhrp holdtime 60
ip nhrp shortcut
qos pre-classify
tunnel key 1234
interface Tunnel101
bandwidth 10000
no ip redirects
ip mtu 1400
ip nhrp holdtime 60
ip nhrp shortcut
qos pre-classify
tunnel key 5678
ip route 0.0.0.0 0.0.0.0 112.230.206.77
router eigrp 100
Harish Balakrishnan Wed, 11/14/2012 - 23:40
  • Silver, 250 points or more
Hello
Can you post the complete configuration.. Also another question is whether this was working earlier or since when you started seeing this issue
regards
Harish
Chetankumar Phu... Thu, 11/15/2012 - 04:07
  • Cisco Employee,
Hi Zhuo Zhao,
This issue usually occurs if there is a routing loop for destination physical address, 210.83.25.66 in your case. Can you please check if there are any routing issues for this particular destination?
Chetan
Related Content
