back to back vPCs with layer 3 port-channeling
Answered Question
Nov 15th, 2012
hello all. is it possible to run Layer 3 back to back VPCs btw 2 N 7009s (sup2 running f2 cards)? If so, do I put the same port-channel interface IP address on each VPC peer?
please see sample configuration below for one of the vpc domains. Thanks
vpc domain 2
  peer-keepalive destination 10.10.10.2 source 10.10.10.1 vrf peer-keepalive
peer-switch
interface port-channel1
  description vpc_peer-link
switch
  switchport mode trunk
  vpc peer-link
  spanning-tree port type network
shut
interface e3/47-48,e4/47-48
switch
channel-group 1 mode active
shut
interface port-channel50
  description L3_TO_DISTRIBUTION
  no switch
ip address 10.1.1.1/30   --- do I need this same IP to be configured on the other peer
  vpc 50
interface e3/1,e4/1
  no switch
no ip add
channel-group 50 mode active
Correct Answer by Chad Peterson about 4 years 5 months ago
L3 port channels are not supported on vPCs.  When connecting to a layer 3 host the best method is to use independent /30 links.  Trying to do L3 over a vPC isn't providing any additional redundancy and load balancing can already be achieved over layer three links via ECMP.
Take a look at this presentation PDI gave at a recent DC Byte-Z session.  We cover supported L3 topologies in vPC environments:
https://communities.cisco.com/docs/DOC-31528
Hope that helps
Chad
Overall Rating: 5 (1 ratings)
Correct Answer
Chad Peterson Fri, 11/16/2012 - 06:10
  • Cisco Employee,
Hope that helps
Chad
Related Content
Trending Topics: Other DC Subjects
